[PATCH v2 05/12] kern_tc.c: Replace FREEBSD event mechanism by adding pointers to function
Sebastian Huber
Tue May 3 07:08:04 UTC 2022
On 29/04/2022 09:20, Gabriel Moyano wrote:
> cpukit/include/sys/timepps.h | 6 ++++++
> cpukit/score/src/kern_tc.c | 25 +++++++++++++++++++++++++
> 2 files changed, 31 insertions(+)
> diff --git a/cpukit/include/sys/timepps.h b/cpukit/include/sys/timepps.h
> index 5703381ffa..0d666a4f2e 100644
> --- a/cpukit/include/sys/timepps.h
> +++ b/cpukit/include/sys/timepps.h
> @@ -26,6 +26,7 @@
> #include <sys/time.h>
> #ifdef __rtems__
> #include <rtems/score/atomic.h>
> +#include <rtems/rtems/types.h>
> #endif /* __rtems__ */
> #define PPS_API_VERS_1 1
> @@ -164,6 +165,11 @@ struct pps_state {
> int ppscap;
> struct timecounter *ppstc;
> unsigned ppscount[3];
> +#ifdef __rtems__
> + rtems_id task_waiting;
You don't need task_waiting, this is an implementation detail of
potential wait/wakeup implementations.
> + int (*wait)(struct pps_state *pps, struct timespec timeout); /* Wait for an event. Called internally when time_pps_fetch() is used. It shall not be NULL*/
> + void (*wakeup)(struct pps_state *pps); /* Used to wakeup tasks waiting for an event. It shall not be NULL*/
Please fix the formatting and take care that you keep the line limit.
> +#endif /* __rtems__ */
> * The following fields are valid if the driver calls pps_init_abi().
> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
> index f7d0a0b4ba..76e3e056de 100644
> --- a/cpukit/score/src/kern_tc.c
> +++ b/cpukit/score/src/kern_tc.c
> @@ -1917,9 +1917,15 @@ abi_aware(struct pps_state *pps, int vers)
> static int
> pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
> +#ifndef __rtems__
> int err, timo;
> +#else /* __rtems__ */
> + int err;
> pps_seq_t aseq, cseq;
> +#ifndef __rtems__
> struct timeval tv;
> if (fapi->tsformat && fapi->tsformat != PPS_TSFMT_TSPEC)
> return (EINVAL);
> @@ -1932,6 +1938,7 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
> * sleep a long time.
> if (fapi->timeout.tv_sec || fapi->timeout.tv_nsec) {
> +#ifndef __rtems__
> if (fapi->timeout.tv_sec == -1)
> timo = 0x7fffffff;
> else {
> @@ -1939,10 +1946,12 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
> tv.tv_usec = fapi->timeout.tv_nsec / 1000;
> timo = tvtohz(&tv);
> aseq = atomic_load_int(&pps->ppsinfo.assert_sequence);
> cseq = atomic_load_int(&pps->ppsinfo.clear_sequence);
> while (aseq == atomic_load_int(&pps->ppsinfo.assert_sequence) &&
> cseq == atomic_load_int(&pps->ppsinfo.clear_sequence)) {
> +#ifndef __rtems__
> if (abi_aware(pps, 1) && pps->driver_mtx != NULL) {
> if (pps->flags & PPSFLAG_MTX_SPIN) {
> err = msleep_spin(pps, pps->driver_mtx,
> @@ -1954,6 +1963,12 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
> } else {
> err = tsleep(pps, PCATCH, "ppsfch", timo);
> + if (pps->wait != NULL)
> + err = (*pps->wait)(pps, fapi->timeout);
> + else
> + err = EAGAIN;
Replace the NULL check with an _Assert(). Check in pps_init() that the
handler are not NULL, otherwise generate a new fatal error. You need
tests for the fatal errors.
> if (err == EWOULDBLOCK) {
> if (fapi->timeout.tv_sec == -1) {
> continue;
> @@ -2061,6 +2076,11 @@ pps_ioctl(u_long cmd, caddr_t data, struct pps_state *pps)
> void
> pps_init(struct pps_state *pps)
> +#ifdef __rtems__
> + _Assert(pps->wakeup != NULL);
> + pps->task_waiting = RTEMS_INVALID_ID;
> pps->ppscap |= PPS_TSFMT_TSPEC | PPS_CANWAIT;
> if (pps->ppscap & PPS_CAPTUREASSERT)
> pps->ppscap |= PPS_OFFSETASSERT;
> @@ -2227,7 +2247,12 @@ pps_event(struct pps_state *pps, int event)
> #endif
> /* Wakeup anyone sleeping in pps_fetch(). */
> +#ifndef __rtems__
> wakeup(pps);
> + if (pps->wakeup != NULL)
> + (*pps->wakeup)(pps);
Add an _Assert() and just call pps->wakeup.
> /* FIXME: https://devel.rtems.org/ticket/2349 */
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
