AW: [PATCH v2 11/12] timepps.h: Move hardpps to the _ namespace
Wed May 4 06:22:03 UTC 2022
On 04/05/2022 08:09, Gabriel.Moyano at dlr.de wrote:
>> On 29/04/2022 09:20, Gabriel Moyano wrote:
>>>    cpukit/include/sys/timepps.h | 1 +
>>>    1 file changed, 1 insertion(+)
>>> diff --git a/cpukit/include/sys/timepps.h
>>> b/cpukit/include/sys/timepps.h index b13ac6bf26..25370f3f4b 100644
>>> --- a/cpukit/include/sys/timepps.h
>>> +++ b/cpukit/include/sys/timepps.h
>>> @@ -28,6 +28,7 @@
>>>    #include <rtems/score/atomic.h>
>>>    #include <rtems/rtems/types.h>
>>>    #define PPS_SYNC
>>> +#define hardpps _PPS_Discipline_cpu_clock
>>>    #endif /* __rtems__ */
>>>    #define PPS_API_VERS_1	1
>> This function needs Doxygen documentation somewhere. What is the "cpu_clock"? I would place it into the _Timecounter
>> namespace.
> I was wondering if it makes sense to place it into _Timecounter.
> There is a very good description where hardpps() is defined, would you like to copy it?
> Just for clarification, the name "cpu_clock" comes from that documentation.
This comment contains also some historic stuff which doesn't apply to
RTEMS. It would be good to give a short documentation what this function
does and how it is used in the RTEMS context. The brief description
should be probably be something like "Updates the timecounter frequency
adjustment used by _Timecounter_NTP_update_second().".
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
