[PATCH v3 00/11] ENABLE PPS API in RTEMS6
Gabriel Moyano gabriel.moyano at dlr.de
Wed May 4 12:11:56 UTC 2022
This is the 3rd version of the patches for enabling the PPS API in RTEMS6.
It contains the changes suggested by Sebastian from yesterday (03/05/2022).
Gabriel Moyano (11):
  kern_ntptime.c: Disable freebsd features
  kern_ntptime.c: Add lmax() qmin() definitions
  kern_tc.c: Add atomic dependencies required by the PPS API
  kern_tc.c: Replace FREEBSD event mechanism by adding pointers to
    function
  timecounter.h: Rename tc_getfrequency() to
    _Timecounter_Get_frequency()
  kern_tc.c: Add definitions required by PPS API
  kern_tc.c: Enable PPS API support
  kern_ntptime.c: Add define in order to remove warning
  timepps.h: PPS_SYNC defined by default
  timecounter.h: Add _Timecounter_Discipline()
  testsuites/sptests: Add sppps01 test
 cpukit/include/rtems/score/timecounter.h  |  25 ++++
 cpukit/include/sys/timepps.h              |  32 ++++
 cpukit/include/sys/timetc.h               |   3 +
 cpukit/score/src/kern_ntptime.c           |  19 +--
 cpukit/score/src/kern_tc.c                |  54 ++++++-
 spec/build/testsuites/sptests/grp.yml     |   2 +
 spec/build/testsuites/sptests/sppps01.yml |  19 +++
 testsuites/sptests/sppps01/init.c         | 173 ++++++++++++++++++++++
 8 files changed, 312 insertions(+), 15 deletions(-)
 create mode 100644 spec/build/testsuites/sptests/sppps01.yml
 create mode 100644 testsuites/sptests/sppps01/init.c
2.25.1
