[PATCH v3 04/11] kern_tc.c: Replace FREEBSD event mechanism by adding pointers to function
Gabriel Moyano
gabriel.moyano at dlr.de
Wed May 4 12:12:00 UTC 2022
cpukit/include/sys/timepps.h | 21 ++++++++++++++++++++
cpukit/score/src/kern_tc.c | 38 ++++++++++++++++++++++++++++++++++++
2 files changed, 59 insertions(+)
diff --git a/cpukit/include/sys/timepps.h b/cpukit/include/sys/timepps.h
index 5703381ffa..b734c6f841 100644
--- a/cpukit/include/sys/timepps.h
+++ b/cpukit/include/sys/timepps.h
@@ -164,6 +164,27 @@ struct pps_state {
int ppscap;
struct timecounter *ppstc;
unsigned ppscount[3];
+#ifdef __rtems__
+ * @brief Wait for an event.
+ * Called internally when time_pps_fetch() is used.
+ * It is initialized with an empty function by default.
+ * @param pps is the pointer to the object.
+ * @param timeout
+ * @return 0 if no error otherwise a negative value.
+ int (*wait)(struct pps_state *pps, struct timespec timeout);
+ * @brief Wakeup the tasks waiting for an event.
+ void (*wakeup)(struct pps_state *pps);
+#endif /* __rtems__ */
* The following fields are valid if the driver calls pps_init_abi().
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index f7d0a0b4ba..6ca408e4ab 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -1917,9 +1917,15 @@ abi_aware(struct pps_state *pps, int vers)
static int
pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
+#ifndef __rtems__
int err, timo;
+#else /* __rtems__ */
+ int err;
pps_seq_t aseq, cseq;
+#ifndef __rtems__
struct timeval tv;
if (fapi->tsformat && fapi->tsformat != PPS_TSFMT_TSPEC)
return (EINVAL);
@@ -1932,6 +1938,7 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
* sleep a long time.
if (fapi->timeout.tv_sec || fapi->timeout.tv_nsec) {
+#ifndef __rtems__
if (fapi->timeout.tv_sec == -1)
timo = 0x7fffffff;
else {
@@ -1939,10 +1946,12 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
tv.tv_usec = fapi->timeout.tv_nsec / 1000;
timo = tvtohz(&tv);
aseq = atomic_load_int(&pps->ppsinfo.assert_sequence);
cseq = atomic_load_int(&pps->ppsinfo.clear_sequence);
while (aseq == atomic_load_int(&pps->ppsinfo.assert_sequence) &&
cseq == atomic_load_int(&pps->ppsinfo.clear_sequence)) {
+#ifndef __rtems__
if (abi_aware(pps, 1) && pps->driver_mtx != NULL) {
if (pps->flags & PPSFLAG_MTX_SPIN) {
err = msleep_spin(pps, pps->driver_mtx,
@@ -1954,6 +1963,10 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps)
} else {
err = tsleep(pps, PCATCH, "ppsfch", timo);
+ _Assert(pps->wait != NULL);
+ err = (*pps->wait)(pps, fapi->timeout);
if (err == EWOULDBLOCK) {
if (fapi->timeout.tv_sec == -1) {
continue;
@@ -2058,9 +2071,29 @@ pps_ioctl(u_long cmd, caddr_t data, struct pps_state *pps)
+#ifdef __rtems__
+static int
+default_wait(struct pps_state *pps, struct timespec timeout)
+ (void) pps;
+ (void) timeout;
+ return 0;
+static void
+default_wakeup(struct pps_state *pps)
+ (void) pps;
void
pps_init(struct pps_state *pps)
+#ifdef __rtems__
+ pps->wait = default_wait;
+ pps->wakeup = default_wakeup;
pps->ppscap |= PPS_TSFMT_TSPEC | PPS_CANWAIT;
if (pps->ppscap & PPS_CAPTUREASSERT)
pps->ppscap |= PPS_OFFSETASSERT;
@@ -2227,7 +2260,12 @@ pps_event(struct pps_state *pps, int event)
#endif
/* Wakeup anyone sleeping in pps_fetch(). */
+#ifndef __rtems__
wakeup(pps);
+ _Assert(pps->wakeup != NULL);
+ (*pps->wakeup)(pps);
/* FIXME: https://devel.rtems.org/ticket/2349 */
2.25.1
