[PATCH] RSB: Remove option --with-java
Chris Johns
chrisj at rtems.org
Mon May 9 00:44:07 UTC 2022
OK.
Thanks
On 7/5/2022 1:20 am, Frank Kuehndel wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> The sb-set-builder options --with-java / --without-java do not work.
> GCC configure does not known language "java". See
> https://gcc.gnu.org/install/configure.html option --enable-languages.
> update #4647
> source-builder/config/checks.cfg | 9 ---------
> source-builder/config/gcc-common-1.cfg | 3 ---
> 2 files changed, 12 deletions(-)
> diff --git a/source-builder/config/checks.cfg b/source-builder/config/checks.cfg
> index 93d4c97..b374d2c 100644
> --- a/source-builder/config/checks.cfg
> +++ b/source-builder/config/checks.cfg
> @@ -19,8 +19,6 @@
> %{?without_ada:%define enable_ada 0}
> %{?with_fortran:%define enable_fortran 1}
> %{?without_fortran:%define enable_fortran 0}
> -%{?with_java:%define enable_java 1}
> -%{?without_java:%define enable_java 0}
> %{?with_objc:%define enable_objc 1}
> %{?without_objc:%define enable_objc 0}
> @@ -52,13 +50,6 @@
> %endif
> -# Default to Java off.
> -%ifn %{defined enable_java}
> - %define enable_java 0
> -%endif
> # Default to ObjC off.
> diff --git a/source-builder/config/gcc-common-1.cfg b/source-builder/config/gcc-common-1.cfg
> index 05e0e3c..9723946 100644
> --- a/source-builder/config/gcc-common-1.cfg
> +++ b/source-builder/config/gcc-common-1.cfg
> @@ -165,9 +165,6 @@ URL: http://gcc.gnu.org/
> %if %{enable_fortran}
> languages="$languages,fortran"
> %endif
> -%if %{enable_java}
> - languages="$languages,java"
> -%endif
> %if %{enable_objc}
> languages="$languages,objc"
> %endif
