[PATCH 8/8] tcpdump: Do not use signals and chroot
Sebastian Huber
Wed May 11 06:56:41 UTC 2022
Update #4650.
freebsd/contrib/tcpdump/tcpdump.c | 22 ++++++++++++++++++++--
1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/freebsd/contrib/tcpdump/tcpdump.c b/freebsd/contrib/tcpdump/tcpdump.c
index 73e2e844..5b658412 100644
--- a/freebsd/contrib/tcpdump/tcpdump.c
+++ b/freebsd/contrib/tcpdump/tcpdump.c
@@ -207,8 +207,10 @@ cap_channel_t *capdns;
static void error(FORMAT_STRING(const char *), ...) NORETURN PRINTFLIKE(1, 2);
static void warning(FORMAT_STRING(const char *), ...) PRINTFLIKE(1, 2);
static void exit_tcpdump(int) NORETURN;
+#ifndef __rtems__
static RETSIGTYPE cleanup(int);
static RETSIGTYPE child_cleanup(int);
+#endif /* __rtems__ */
static void print_version(void);
static void print_usage(void);
static void show_tstamp_types_and_exit(pcap_t *, const char *device) NORETURN;
@@ -220,6 +222,7 @@ static void show_devices_and_exit (void) NORETURN;
static void print_packet(u_char *, const struct pcap_pkthdr *, const u_char *);
static void dump_packet_and_trunc(u_char *, const struct pcap_pkthdr *, const u_char *);
static void dump_packet(u_char *, const struct pcap_pkthdr *, const u_char *);
+#ifndef __rtems__
static void droproot(const char *, const char *);
#ifdef SIGNAL_REQ_INFO
@@ -233,6 +236,7 @@ RETSIGTYPE requestinfo(int);
#elif defined(HAVE_ALARM)
static void verbose_stats_dump(int sig);
#endif
static void info(int);
static u_int packets_captured;
@@ -624,6 +628,7 @@ static const struct option longopts[] = {
{ NULL, 0, NULL, 0 }
+#ifndef __rtems__
#ifndef _WIN32
/* Drop root privileges and chroot if necessary */
static void
@@ -655,7 +660,6 @@ droproot(const char *username, const char *chroot_dir)
fprintf(stderr, "dropped privs to %s\n", username);
#else
-#ifndef __rtems__
if (initgroups(pw->pw_name, pw->pw_gid) != 0 ||
setgid(pw->pw_gid) != 0 || setuid(pw->pw_uid) != 0) {
fprintf(stderr, "%s: Couldn't change to '%.32s' uid=%lu gid=%lu: %s\n",
@@ -668,7 +672,6 @@ droproot(const char *username, const char *chroot_dir)
else {
-#endif /* __rtems__ */
#endif /* HAVE_LIBCAP_NG */
else {
@@ -690,6 +693,7 @@ droproot(const char *username, const char *chroot_dir)
#endif /* _WIN32 */
static int
getWflagChars(int x)
@@ -1294,15 +1298,19 @@ main(int argc, char **argv)
int dlt;
const char *dlt_name;
struct bpf_program fcode;
+#ifndef __rtems__
#ifndef _WIN32
RETSIGTYPE (*oldhandler)(int);
#endif
struct dump_info dumpinfo;
u_char *pcap_userdata;
char ebuf[PCAP_ERRBUF_SIZE];
char VFileLine[PATH_MAX + 1];
+#ifndef __rtems__
char *username = NULL;
char *chroot_dir = NULL;
char *ret = NULL;
char *end;
#ifdef HAVE_PCAP_FINDALLDEVS
@@ -1674,9 +1682,11 @@ main(int argc, char **argv)
zflag = optarg;
break;
+#ifndef __rtems__
case 'Z':
username = optarg;
break;
case '#':
ndo->ndo_packet_number = 1;
@@ -1973,6 +1983,7 @@ main(int argc, char **argv)
init_print(ndo, localnet, netmask, timezone_offset);
+#ifndef __rtems__
#ifndef _WIN32
(void)setsignal(SIGPIPE, cleanup);
(void)setsignal(SIGTERM, cleanup);
@@ -2040,6 +2051,7 @@ main(int argc, char **argv)
#endif /* _WIN32 */
if (pcap_setfilter(pd, &fcode) < 0)
error("%s", pcap_geterr(pd));
@@ -2147,6 +2159,7 @@ main(int argc, char **argv)
pcap_userdata = (u_char *)ndo;
+#ifndef __rtems__
* We can't get statistics when reading from a file rather
@@ -2171,6 +2184,7 @@ main(int argc, char **argv)
alarm(1);
#endif
if (RFileName == NULL) {
@@ -2344,6 +2358,7 @@ main(int argc, char **argv)
exit_tcpdump(status == -1 ? 1 : 0);
+#ifndef __rtems__
/* make a clean exit on interrupts */
static RETSIGTYPE
cleanup(int signo _U_)
@@ -2396,6 +2411,7 @@ child_cleanup(int signo _U_)
wait(NULL);
#endif /* HAVE_FORK && HAVE_VFORK */
static void
info(register int verbose)
@@ -2756,6 +2772,7 @@ print_packet(u_char *user, const struct pcap_pkthdr *h, const u_char *sp)
char Wpcap_version[]="3.1";
#endif
+#ifndef __rtems__
RETSIGTYPE requestinfo(int signo _U_)
@@ -2784,6 +2801,7 @@ static void verbose_stats_dump(int sig _U_)
alarm(1);
#endif
USES_APPLE_DEPRECATED_API
static void
2.35.3
