[PATCH] Synchronize all file descriptors in sync()
Sebastian Huber
Fri May 13 11:21:34 UTC 2022
Synchronize all file descriptors and not just the ones associated with a FILE
object.
Close #4656.
cpukit/libcsupport/src/sync.c | 84 +++++------------------------------
1 file changed, 12 insertions(+), 72 deletions(-)
diff --git a/cpukit/libcsupport/src/sync.c b/cpukit/libcsupport/src/sync.c
index dc50ae1121..116b22b617 100644
--- a/cpukit/libcsupport/src/sync.c
+++ b/cpukit/libcsupport/src/sync.c
@@ -1,15 +1,15 @@
/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
+ * @file
- * @brief Synchronize Data on Disk with Memory
- * @ingroup libcsupport
+ * @ingroup libcsupport
+ * @brief This source file contains the implementation of sync().
- * COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2022 embedded brains GmbH.
* modification, are permitted provided that the following conditions
@@ -37,76 +37,16 @@
#include "config.h"
#endif
-#include <sys/reent.h>
#include <unistd.h>
-#include <stdio.h>
-#include <rtems.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/percpu.h>
-/* In Newlib this function is declared in a private header file */
-int _fwalk_reent (struct _reent *, int (*)(struct _reent *, FILE *));
+#include <rtems/libio_.h>
-static int sync_wrapper(struct _reent *reent, FILE *f)
+void sync( void )
- int fn = fileno(f);
- (void) reent;
- * There is no way to report errors here. So this is a best-effort approach.
- (void) fsync(fn);
- (void) fdatasync(fn);
- return 0;
-/* iterate over all FILE *'s for this thread */
-static bool sync_per_thread(Thread_Control *t, void *arg)
- struct _reent *current_reent;
- struct _reent *this_reent;
- * The sync_wrapper() function will operate on the current thread's
- * reent structure so we will temporarily use that.
- this_reent = t->libc_reent;
- if ( this_reent ) {
- Thread_Control *executing = _Thread_Get_executing();
- current_reent = executing->libc_reent;
- executing->libc_reent = this_reent;
- _fwalk_reent (this_reent, sync_wrapper);
- executing->libc_reent = current_reent;
- return false;
- * This function operates by as follows:
- * for all threads
- * for all FILE *
- * fsync()
- * fdatasync()
-void sync(void)
- * Walk the one used initially by RTEMS.
- _fwalk_reent(_GLOBAL_REENT, sync_wrapper);
- * XXX Do we walk the one used globally by newlib?
- * XXX Do we need the RTEMS global one?
+ uint32_t fd;
- * Now walk all the per-thread reentrancy structures.
- rtems_task_iterate(sync_per_thread, NULL);
+ for ( fd = 0; fd < rtems_libio_number_iops; ++fd ) {
+ (void) fsync( (int) fd );
+ (void) fdatasync( (int) fd );
2.35.3
