[PATCH] ISL, MPC, MPFR: fix configuration issues on ARM64/Darwin host
Joel Sherrill
joel at rtems.org
Fri May 13 14:25:33 UTC 2022
On Fri, May 13, 2022, 9:08 AM Karel Gardas <karel at functional.vision> wrote:
> Joel,
> I agree that having support upstreamed would be the best option. Due to
> upstream lag behind apple hardware development I'm afraid we would miss
> RTEMS 6 release if we would wait on upstream here, hence apple M1 users
> would not be able to use RTEMS 6.
Submitting them and then referencing the upstream email, git commit, or
attachment to their ticket. We don't wait for upstream releases.
> Hence offered short cut solution, just for RTEMS 6, is to add those 3
> patches and remove them once upstream apply fixes.
> I'm just following historic way of doing things in RSB. It still holds
> three patches at least here
> rtems at silence:~/git/rtems/rtems-source-builder-ref$ find . -name '*.diff'
> ./source-builder/patches/texane-stlink-3494c11-1.diff
> ./source-builder/patches/texane-stlink-3494c11-2.diff
> ./source-builder/patches/gcc-4.7.2-arm-eabi-multilib-20121014.diff
Notice 2012 in the name of the last one.
File a ticket on devel.rtems.org and attach the patches. Use the url to
there.
> The patches accompany patch submitted yesterday for elftoolchain fix
> (sync of libelf config header file with recent FreeBSD version) and make
> RSB working on M1. Tested here, although hardware is here last day then
> it'll be moved out of my reach. Also tested on x64 darwin and ubuntu 20.04.
I'm not questioning the quality of the work. Just the process. We lost
patches when we dumped them in our repos.
> Thanks,
> Karel
> On 5/13/22 15:57, Joel Sherrill wrote:
> > We do not put patches in RTEMS repos. File an rtems ticket, attach them,
> > and reference them from there.
> > If they are needed upstream, please submit them to the appropriate
> projects.
> > Otherwise, I can't test this so don't have much to say. Looks necessary
> > based on email discussions.
> > --joel
> > On Fri, May 13, 2022 at 8:48 AM Karel Gardas <karel at functional.vision>
> > wrote:
> > Sponsored-By: Precidata
> > rtems/config/tools/rtems-gcc-12-newlib-head.cfg | 7 +++++++
> > rtems/patches/fix-mac-arm64-isl-config.patch | 12 ++++++++++++
> > rtems/patches/fix-mac-arm64-mpc-config.patch | 13 +++++++++++++
> > rtems/patches/fix-mac-arm64-mpfr-config.patch | 12 ++++++++++++
> > 4 files changed, 44 insertions(+)
> > create mode 100644 rtems/patches/fix-mac-arm64-isl-config.patch
> > create mode 100644 rtems/patches/fix-mac-arm64-mpc-config.patch
> > create mode 100644 rtems/patches/fix-mac-arm64-mpfr-config.patch
> > diff --git a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > index 4ea99a0..95b38c6 100644
> > --- a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > @@ -13,6 +13,13 @@
> > %patch add newlib -p1
> https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly-v2.patch
> > %hash sha512
> 7ca237eabfd5b382713186e1fc290dfc999a353315795ecb8dd0d22fcd1ab7f5bf31f4329954adab91ad04c100dcac0e86d406fdbce8f82cf9dc23842c88caf6
> > +%patch add isl -p1 file://fix-mac-arm64-isl-config.patch
> > +%hash sha512 fix-mac-arm64-isl-config.patch
> c07fdb605a6520d194358504731e63b540211ef680383f1ca4ec65b4ac43ae27687534fd7d8196a4dbe83a0ecf2c42a4254c71e609ee484a7614573bc499a2e8
> > +%patch add mpfr -p1 file://fix-mac-arm64-mpfr-config.patch
> > +%hash sha512 fix-mac-arm64-mpfr-config.patch
> dc5069df870bd02b7e78ed22c6ad9e9a2bb9ca372ce1a6b7e8fa5b7635dcef35c29f251fe5195c9c2a43513116c12cab1b0e96171cf34bd7fb7d0334c2c740fb
> > +%patch add mpc -p1 file://fix-mac-arm64-mpc-config.patch
> > +%hash sha512 fix-mac-arm64-mpc-config.patch
> 2849b11e360ea98e0b4d708c67723ad2d6c7bac6d1e469673f408b0111cf0278429e8bc38fd2b7538dc2d5bb0cc430c646a0fa7f0b6b105a0482a5455fadc8b9
> > %define newlib_version 64b2081
> > %define newlib_external 1
> > %define newlib_expand_name
> > sourceware-mirror-newlib-cygwin-%{newlib_version}
> > diff --git a/rtems/patches/fix-mac-arm64-isl-config.patch
> > b/rtems/patches/fix-mac-arm64-isl-config.patch
> > new file mode 100644
> > index 0000000..6b8f07d
> > --- /dev/null
> > +++ b/rtems/patches/fix-mac-arm64-isl-config.patch
> > @@ -0,0 +1,12 @@
> > +--- isl/config.sub.orig 2022-05-11 07:19:04.000000000 +0200
> > ++++ isl/config.sub 2022-05-11 07:19:26.000000000 +0200
> > +@@ -516,6 +516,9 @@
> > + basic_machine=m68k-apollo
> > + os=-bsd
> > ++ arm64-*)
> > ++ basic_machine=aarch64-`echo "$basic_machine" | sed
> > 's/^[^-]*-//'`
> > + aros)
> > + basic_machine=i386-pc
> > + os=-aros
> > diff --git a/rtems/patches/fix-mac-arm64-mpc-config.patch
> > b/rtems/patches/fix-mac-arm64-mpc-config.patch
> > index 0000000..89ea483
> > --- /dev/null
> > +++ b/rtems/patches/fix-mac-arm64-mpc-config.patch
> > @@ -0,0 +1,13 @@
> > +--- mpc/build-aux/config.sub.orig 2022-05-11
> > 09:20:51.000000000 +0200
> > ++++ mpc/build-aux/config.sub 2022-05-11 09:23:47.000000000 +0200
> > +@@ -916,6 +916,10 @@
> > + cpu=sparc
> > + vendor=`echo "$basic_machine" | sed 's/-.*//'`
> > ++ arm64-*)
> > ++ cpu=aarch64
> > ++ vendor=`echo "$basic_machine" | sed 's/-.*//'`
> > + # shellcheck disable=SC2162
> > diff --git a/rtems/patches/fix-mac-arm64-mpfr-config.patch
> > b/rtems/patches/fix-mac-arm64-mpfr-config.patch
> > index 0000000..37cec7e
> > --- /dev/null
> > +++ b/rtems/patches/fix-mac-arm64-mpfr-config.patch
> > @@ -0,0 +1,12 @@
> > +--- mpfr/config.sub.orig 2022-05-11 07:13:02.000000000 +0200
> > ++++ mpfr/config.sub 2022-05-11 07:14:42.000000000 +0200
> > + os=-bsd
> > ++ arm64-*)
> > 's/^[^-]*-//'`
> > + aros)
> > + os=-aros
> > 2.25.1
> > devel mailing list
> > devel at rtems.org <mailto:devel at rtems.org>
> > <http://lists.rtems.org/mailman/listinfo/devel>
