[PATCH rtems-source-builder v1] source-builder: Handle utf8 in path
Kinsey Moore
kinsey.moore at oarcorp.com
Fri May 13 17:15:18 UTC 2022
It's possible for an environment to have unicode characters in its
paths. This was recently exposed by the latest newlib update and RSB
fails under Python 2.7 in this situation. This resolves the issue by
ensuring that the paths are encoded and decoded as necessary.
Related issue that caused the change in newlib:
https://github.com/golang/go/issues/27836
source-builder/sb/path.py | 14 +++++++-------
1 file changed, 7 insertions(+), 7 deletions(-)
diff --git a/source-builder/sb/path.py b/source-builder/sb/path.py
index b27cf14..d36e12a 100644
--- a/source-builder/sb/path.py
+++ b/source-builder/sb/path.py
@@ -58,7 +58,7 @@ def host(path):
def shell(path):
if isinstance(path, bytes):
- path = path.decode('ascii')
+ path = path.decode('utf8')
if path is not None:
if windows or windows_posix:
path = path.encode('ascii', 'ignore').decode('ascii')
@@ -189,11 +189,11 @@ def removeall(path):
# get to the max path length on Windows.
def _isdir(path):
- hpath = host(path)
+ hpath = host(path).encode('utf8')
return os.path.isdir(hpath) and not os.path.islink(hpath)
def _remove_node(path):
if not os.path.islink(hpath) and not os.access(hpath, os.W_OK):
os.chmod(hpath, stat.S_IWUSR)
if _isdir(path):
@@ -216,7 +216,7 @@ def removeall(path):
_remove_node(dir)
path = shell(path)
if os.path.exists(hpath):
_remove(path)
@@ -317,11 +317,11 @@ def get_size(path, depth = -1):
def _isdir(path):
def _node_size(path):
size = 0
if not os.path.islink(hpath):
size = os.path.getsize(hpath)
@@ -345,7 +345,7 @@ def get_size(path, depth = -1):
return size
path = shell(path)
size = 0
2.30.2
