riscv failures from bsp builder
Joel Sherrill
joel at rtems.org
Sun May 15 17:51:11 UTC 2022
This doesn't appear to fail on FreeBSD based on
https://lists.rtems.org/pipermail/build/2022-May/033521.html.
Not sure what that means.
--joel
On Sat, May 14, 2022 at 12:14 PM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> These four cases fail regularly on recent bsp builder runs. This is a
> fragment from the most recent (
> https://lists.rtems.org/pipermail/build/2022-May/033465.html) failure
> which ran on Ubuntu. My builds on my CentOS 7 host show no issues building
> with debug on for the first bsp.
> Ryan .. anything useful in a log on the VM?
> Anyone else have any ideas?
> 1 debug riscv/rv32i build:
> configure: /home/tester/rtems-cron-6/rtems/waf configure\
> --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
> /rtems-cron-6/rtems --rtems-config=config-riscv-rv32i-debug.ini
> error: ld/collect2:0 error: no error message found!
> 2 debug riscv/rv32iac build:
> /rtems-cron-6/rtems --rtems-config=config-riscv-rv32iac-debug.ini
> 3 debug riscv/rv32im build:
> /rtems-cron-6/rtems --rtems-config=config-riscv-rv32im-debug.ini
> 4 debug riscv/rv32imac build:
> /rtems-cron-6/rtems --rtems-config=config-riscv-rv32imac-debug.ini
> Thanks.
> --joel
