[PATCH 2/7] bsps/stm32h7: add configuration and enable build of stm32h757i-eval BSP
Karel Gardas karel at functional.vision
Mon May 16 12:12:49 UTC 2022
This is minimalist configuration for the stm32h757i-eval BSP provided
here. The only general enhancement worth mention is boot core
configuration which is needed here as this is the first dual-core board
supported by stm32h7 BSP family and we need to choose boot core in order
to get C files compiling well.
Sponsored-By:	Precidata
 .../bsps/arm/stm32h7/bspstm32h757i-eval.yml   | 21 +++++++++++++++++
 spec/build/bsps/arm/stm32h7/grp.yml           |  2 ++
 spec/build/bsps/arm/stm32h7/optbootcore.yml   | 23 +++++++++++++++++++
 spec/build/bsps/arm/stm32h7/optlinkcmds.yml   |  1 +
 spec/build/bsps/arm/stm32h7/optpwrsupply.yml  |  1 +
 .../bsps/arm/stm32h7/optusart1gpioregs.yml    |  3 +++
 spec/build/bsps/arm/stm32h7/optvariant.yml    |  3 +++
 7 files changed, 54 insertions(+)
 create mode 100644 spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
 create mode 100644 spec/build/bsps/arm/stm32h7/optbootcore.yml
diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
new file mode 100644
index 0000000000..4ef5690a65
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+arch: arm
+bsp: stm32h757i-eval
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2022 Karel Gardas <karel at functional.vision>
+cppflags: []
+enabled-by: true
+family: stm32h7
+includes: []
+install: []
+links:
+- role: build-dependency
+  uid: grp
+source:
+- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-clk.c
+- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-osc.c
+- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-per.c
+- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/system_stm32h7xx.c
+type: build
diff --git a/spec/build/bsps/arm/stm32h7/grp.yml b/spec/build/bsps/arm/stm32h7/grp.yml
index 7cb8f698cc..401b8b415a 100644
--- a/spec/build/bsps/arm/stm32h7/grp.yml
+++ b/spec/build/bsps/arm/stm32h7/grp.yml
@@ -83,6 +83,8 @@ links:
   uid: optprintkinstance
   uid: optpwrsupply
+  uid: optbootcore
   uid: optusart1gpiopins
diff --git a/spec/build/bsps/arm/stm32h7/optbootcore.yml b/spec/build/bsps/arm/stm32h7/optbootcore.yml
index 0000000000..53ffb496cc
--- /dev/null
+++ b/spec/build/bsps/arm/stm32h7/optbootcore.yml
@@ -0,0 +1,23 @@
+actions:
+- get-string: null
+- script: |
+          cores = ["CORE_CM7", "CORE_CM4", "BOOT_CORE_DEFINE_NOT_NEEDED"]
+          if value not in cores:
+             conf.fatal("STM32H7 boot core '{}' is not one of {}".format(value, cores))
+          conf.define_cond(value, True)
+build-type: option
+default: BOOT_CORE_DEFINE_NOT_NEEDED
+default-by-variant:
+- value: CORE_CM7
+  variants:
+  - arm/stm32h757i-eval
+enabled-by: true
+format: '{}'
+links: []
+name: STM32H7_BOOT_CORE
+description: |
+  Select the boot core. Possible values are CORE_CM7 and CORE_CM4
+type: build
+copyrights:
diff --git a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
index 18a1983f63..a7281addd8 100644
--- a/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
+++ b/spec/build/bsps/arm/stm32h7/optlinkcmds.yml
@@ -7,6 +7,7 @@ default-by-variant:
 - value: linkcmds.flash
   variants:
   - arm/stm32h7b3i-dk
 enabled-by: true
 format: '{}'
 links: []
diff --git a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
index d7eeb63906..76888fc1ca 100644
--- a/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
+++ b/spec/build/bsps/arm/stm32h7/optpwrsupply.yml
 - value: PWR_DIRECT_SMPS_SUPPLY
   variants:
   - arm/stm32h7b3i-dk
 enabled-by: true
 format: '{}'
 links: []
diff --git a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
index 46d10616bb..e389efe6a9 100644
--- a/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
+++ b/spec/build/bsps/arm/stm32h7/optusart1gpioregs.yml
@@ -7,6 +7,9 @@ default-by-variant:
 - value: GPIOA
   variants:
   - arm/stm32h7b3i-dk
+- value: GPIOB
+  variants:
 enabled-by: true
 format: '{}'
 links: []
diff --git a/spec/build/bsps/arm/stm32h7/optvariant.yml b/spec/build/bsps/arm/stm32h7/optvariant.yml
index 5d77ece120..fd77d26f7f 100644
--- a/spec/build/bsps/arm/stm32h7/optvariant.yml
+++ b/spec/build/bsps/arm/stm32h7/optvariant.yml
@@ -17,6 +17,9 @@ default-by-variant:
 - value: STM32H7B3xxQ
   variants:
     - arm/stm32h7b3i-dk
+- value: STM32H757xx
+  variants:
 enabled-by: true
 format: '{}'
 links: []
2.25.1
