[PATCH 2/7] bsps/arm: disable cache operations on Cortex-M4
Karel Gardas karel at functional.vision
Mon May 16 14:02:14 UTC 2022
 bsps/arm/shared/cache/cache-v7m.c | 22 ++++++++++++++++++++++
 1 file changed, 22 insertions(+)
diff --git a/bsps/arm/shared/cache/cache-v7m.c b/bsps/arm/shared/cache/cache-v7m.c
index f5a9e208e5..100d38765f 100644
--- a/bsps/arm/shared/cache/cache-v7m.c
+++ b/bsps/arm/shared/cache/cache-v7m.c
@@ -9,21 +9,25 @@
 #include <chip.h>
+#if __CORTEX_M != 0x04U
 #define CPU_DATA_CACHE_ALIGNMENT 32
 #define CPU_INSTRUCTION_CACHE_ALIGNMENT 32
 #define CPU_CACHE_SUPPORT_PROVIDES_RANGE_FUNCTIONS
+#endif
 static inline void _CPU_cache_flush_data_range(
   const void *d_addr,
   size_t n_bytes
   SCB_CleanInvalidateDCache_by_Addr(
     RTEMS_DECONST(uint32_t *, (const uint32_t *) d_addr),
     n_bytes
+#endif
 static inline void _CPU_cache_invalidate_data_range(
@@ -31,10 +35,12 @@ static inline void _CPU_cache_invalidate_data_range(
   size_t n_bytes
   SCB_InvalidateDCache_by_Addr(
     n_bytes
+#endif
 static inline void _CPU_cache_freeze_data(void)
@@ -52,11 +58,13 @@ static inline void _CPU_cache_invalidate_instruction_range(
   size_t n_bytes
   rtems_interrupt_level level;
   rtems_interrupt_disable(level);
   SCB_InvalidateICache();
   rtems_interrupt_enable(level);
+#endif
 static inline void _CPU_cache_freeze_instruction(void)
@@ -71,65 +79,79 @@ static inline void _CPU_cache_unfreeze_instruction(void)
 static inline void _CPU_cache_flush_entire_data(void)
   SCB_CleanDCache();
+#endif
 static inline void _CPU_cache_invalidate_entire_data(void)
   SCB_InvalidateDCache();
+#endif
 static inline void _CPU_cache_enable_data(void)
   SCB_EnableDCache();
+#endif
 static inline void _CPU_cache_disable_data(void)
   SCB_DisableDCache();
+#endif
 static inline void _CPU_cache_invalidate_entire_instruction(void)
+#endif
 static inline void _CPU_cache_enable_instruction(void)
   SCB_EnableICache();
+#endif
 static inline void _CPU_cache_disable_instruction(void)
   SCB_DisableICache();
+#endif
 #include "../../shared/cache/cacheimpl.h"
2.25.1
