[PATCH] ISL, MPC, MPFR: fix configuration issues on ARM64/Darwin host
Karel Gardas
karel at functional.vision
Tue May 17 09:48:47 UTC 2022
On 5/17/22 11:42, Chris Johns wrote:
> On 17/5/22 4:14 am, Joel Sherrill wrote:
>> On Mon, May 16, 2022, 12:33 PM Karel Gardas <karel at functional.vision> wrote:
>>> On 5/13/22 15:57, Joel Sherrill wrote:
>>>> We do not put patches in RTEMS repos. File an rtems ticket, attach them,
>>>> and reference them from there.
>>>> If they are needed upstream, please submit them to the appropriate
>>> projects.
>>> Joel,
>>> based on the discussion I've created https://devel.rtems.org/ticket/4657
>>> -- hopefully this will be enough to accept interim solution and fix M1
>>> compilation issues.
>>> I'll follow the possible replies, links on their archives and link them
>>> as go into the ticket for your reference.
>> Perfect! Just use the raw attachment url for them.
> Thanks for sorting this out.
Sure! You are welcome! But I guess now, ball is on your side. How will
you proceed? IMHO the most easy is to apply original patch (together
with elftool chain patch) and leave it there for just RTEMS 6 line.
Karel
