[PATCH] Fix copyright notice of kernel space headers
Sebastian Huber
Wed May 18 06:57:34 UTC 2022
Use the copyright notice of the associated header file from FreeBSD if the
kernel space header file contains a substantial amount of imported code.
Add include guard checks to all header files.
cpukit/include/machine/_kernel_cpuset.h | 11 +++++--
cpukit/include/machine/_kernel_mman.h | 40 ++++++++++++-------------
cpukit/include/machine/_kernel_param.h | 9 ++++--
cpukit/include/machine/_kernel_time.h | 18 ++++++++---
cpukit/include/machine/_kernel_types.h | 38 +++++++++++++----------
cpukit/include/machine/_timecounter.h | 34 +++++++++++++--------
6 files changed, 93 insertions(+), 57 deletions(-)
diff --git a/cpukit/include/machine/_kernel_cpuset.h b/cpukit/include/machine/_kernel_cpuset.h
index 22a245e037..790314fb30 100644
--- a/cpukit/include/machine/_kernel_cpuset.h
+++ b/cpukit/include/machine/_kernel_cpuset.h
@@ -1,13 +1,14 @@
/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
+ * @file
- * @brief
+ * @brief This header file provides CPU set definitions for the kernel space
+ * (_KERNEL is defined before including <sys/cpuset.h>).
- * Copyright (C) 1989-1998 On-Line Applications Research Corporation (OAR).
+ * Copyright (C) 2016 embedded brains GmbH (http://www.embedded-brains.de)
* modification, are permitted provided that the following conditions
@@ -30,3 +31,7 @@
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
+#if !defined(_SYS_CPUSET_H_) || !defined(_KERNEL)
+#error "must be included via <sys/cpuset.h> in kernel space"
+#endif
diff --git a/cpukit/include/machine/_kernel_mman.h b/cpukit/include/machine/_kernel_mman.h
index 17560c138c..df0a280a86 100644
--- a/cpukit/include/machine/_kernel_mman.h
+++ b/cpukit/include/machine/_kernel_mman.h
@@ -1,8 +1,14 @@
- * SPDX-License-Identifier: BSD-3-Clause
+ * @file
- * Copyright (c) 1982, 1986, 1993
- * The Regents of the University of California. All rights reserved.
+ * @brief This header file provides memory map definitions for the kernel space
+ * (_KERNEL is defined before including <sys/mman.h>).
@@ -12,24 +18,18 @@
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
- * 3. Neither the name of the University nor the names of its contributors
- * may be used to endorse or promote products derived from this software
- * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * @(#)mman.h 8.2 (Berkeley) 1/9/95
- * $FreeBSD: head/sys/sys/mman.h 326023 2017-11-20 19:43:44Z pfg $
#if !defined(_SYS_MMAN_H_) || !defined(_KERNEL)
diff --git a/cpukit/include/machine/_kernel_param.h b/cpukit/include/machine/_kernel_param.h
index dcdd49d467..0c021d6ab1 100644
--- a/cpukit/include/machine/_kernel_param.h
+++ b/cpukit/include/machine/_kernel_param.h
@@ -3,11 +3,12 @@
* @file
- * @brief
+ * @brief This header file provides parameter definitions for the kernel space
+ * (_KERNEL is defined before including <sys/param.h>).
- * Copyright (C) 2017 embedded brains Gmbh (http://www.embedded-brains.de)
+ * Copyright (C) 2017 embedded brains GmbH (http://www.embedded-brains.de)
@@ -36,6 +37,10 @@
#include <sys/time.h>
#include <sys/priority.h>
+#if !defined(_SYS_PARAM_H_) || !defined(_KERNEL)
+#error "must be included via <sys/param.h> in kernel space"
+#endif
#ifndef FALSE
#define FALSE 0
#endif
diff --git a/cpukit/include/machine/_kernel_time.h b/cpukit/include/machine/_kernel_time.h
index f0b6bdfc47..1776447b9a 100644
--- a/cpukit/include/machine/_kernel_time.h
+++ b/cpukit/include/machine/_kernel_time.h
@@ -1,6 +1,10 @@
- * Copyright (c) 2016 embedded brains GmbH
- * All rights reserved.
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1982, 1986, 1993
+ * The Regents of the University of California. All rights reserved.
@@ -10,11 +14,14 @@
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
@@ -22,6 +29,9 @@
* SUCH DAMAGE.
+ * @(#)time.h 8.5 (Berkeley) 5/4/95
+ * $FreeBSD$
#if !defined(_SYS_TIME_H_) || !defined(_KERNEL)
diff --git a/cpukit/include/machine/_kernel_types.h b/cpukit/include/machine/_kernel_types.h
index a02f328aa2..11d463c0dd 100644
--- a/cpukit/include/machine/_kernel_types.h
+++ b/cpukit/include/machine/_kernel_types.h
@@ -1,6 +1,14 @@
+ * @file
+ * @brief This header file provides type definitions for the kernel space
+ * (_KERNEL is defined before including <sys/type.h>).
@@ -11,26 +19,26 @@
- * SUCH DAMAGE.
#if !defined(_SYS_TYPES_H) || !defined(_KERNEL)
-#error "must be included via <sys/types.h> in kernel space"
+#error "must be included via <sys/type.h> in kernel space"
#endif
#include <stdbool.h>
typedef int boolean_t;
typedef struct device *device_t;
-typedef char vm_memattr_t; /* memory attribute codes */
+typedef char vm_memattr_t;
typedef struct vm_page *vm_page_t;
diff --git a/cpukit/include/machine/_timecounter.h b/cpukit/include/machine/_timecounter.h
index fb974f13c1..cc849dd0a3 100644
--- a/cpukit/include/machine/_timecounter.h
+++ b/cpukit/include/machine/_timecounter.h
@@ -1,6 +1,14 @@
+ * @file
+ * @brief This header file provides timecounter definitions for the kernel space
+ * (_KERNEL is defined before including <sys/time.h>) and RTEMS.
@@ -11,17 +19,17 @@
- * SUCH DAMAGE.
#ifndef _SYS_TIME_H_
2.35.3
