[PATCH v4 11/11] testsuites/sptests: Add sppps01 test
Gabriel Moyano
gabriel.moyano at dlr.de
Fri May 20 09:30:03 UTC 2022
spec/build/testsuites/sptests/grp.yml | 2 +
spec/build/testsuites/sptests/sppps01.yml | 19 +++
testsuites/sptests/sppps01/init.c | 191 ++++++++++++++++++++++
3 files changed, 212 insertions(+)
create mode 100644 spec/build/testsuites/sptests/sppps01.yml
create mode 100644 testsuites/sptests/sppps01/init.c
diff --git a/spec/build/testsuites/sptests/grp.yml b/spec/build/testsuites/sptests/grp.yml
index a69a4d20f7..3264ba5450 100644
--- a/spec/build/testsuites/sptests/grp.yml
+++ b/spec/build/testsuites/sptests/grp.yml
@@ -349,6 +349,8 @@ links:
uid: sppercpudata01
- role: build-dependency
uid: spporterr01
+- role: build-dependency
+ uid: sppps01
uid: spprintk
diff --git a/spec/build/testsuites/sptests/sppps01.yml b/spec/build/testsuites/sptests/sppps01.yml
new file mode 100644
index 0000000000..55770eceb9
--- /dev/null
+++ b/spec/build/testsuites/sptests/sppps01.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 German Aerospace Center (DLR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/sptests/sppps01/init.c
+stlib: []
+target: testsuites/sptests/sppps01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/sptests/sppps01/init.c b/testsuites/sptests/sppps01/init.c
index 0000000000..850c21f1f2
--- /dev/null
+++ b/testsuites/sptests/sppps01/init.c
@@ -0,0 +1,191 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2022 German Aerospace Center (DLR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <rtems/test.h>
+#include <rtems/test-info.h>
+#include <rtems/timespec.h>
+#include <rtems/rtems/event.h>
+#define _KERNEL
+#include <sys/timepps.h>
+const char rtems_test_name[] = "SPPPS 1";
+#define PPS_EVENT RTEMS_EVENT_0
+#define TASK_WAITING RTEMS_EVENT_1
+#define PPS_EVENT_RECEIVED RTEMS_EVENT_2
+struct test_pps_device {
+ struct pps_state pps;
+ rtems_id task_waiting;
+typedef struct {
+ rtems_id main_task;
+ struct test_pps_device *pps_dev;
+} test_context;
+T_TEST_CASE( WaitPPSEventDefaultHandler )
+ int status;
+ struct test_pps_device pps_dev;
+ struct pps_fetch_args fetch;
+ pps_dev.task_waiting = RTEMS_INVALID_ID;
+ memset( &pps_dev.pps, 0, sizeof( pps_dev.pps ) );
+ pps_dev.pps.ppscap = PPS_CAPTUREBOTH;
+ pps_init_abi( &pps_dev.pps );
+ pps_dev.pps.ppsparam.mode = PPS_CAPTUREASSERT;
+ status = pps_ioctl( PPS_IOC_FETCH, (caddr_t)&fetch, &pps_dev.pps );
+ T_eq_int( status, ETIMEDOUT );
+static void wakeup(struct pps_state *pps)
+ pps_dev = RTEMS_CONTAINER_OF( pps, struct test_pps_device, pps );
+ if (pps_dev->task_waiting != RTEMS_INVALID_ID)
+ rtems_event_send( pps_dev->task_waiting, PPS_EVENT );
+static int wait(struct pps_state *pps, struct timespec timeout)
+ rtems_status_code sc;
+ rtems_event_set out;
+ uint32_t timeoutticks;
+ pps_dev->task_waiting = rtems_task_self();
+ timeoutticks = rtems_timespec_to_ticks(&timeout);
+ sc = rtems_event_receive( PPS_EVENT, RTEMS_DEFAULT_OPTIONS, timeoutticks, &out );
+ return rtems_status_code_to_errno(sc);
+static void pps_task(rtems_task_argument arg)
+ int status;
+ test_context *ctx;
+ ctx = (test_context *) arg;
+ fetch.tsformat = PPS_TSFMT_TSPEC;
+ fetch.timeout.tv_sec = 1;
+ fetch.timeout.tv_nsec = 0;
+ sc = rtems_event_send( ctx->main_task, TASK_WAITING );
+ T_rsc_success( sc );
+ status = pps_ioctl( PPS_IOC_FETCH, (caddr_t)&fetch, &ctx->pps_dev->pps );
+ T_eq_int( status, 0 );
+ sc = rtems_event_send( ctx->main_task, PPS_EVENT_RECEIVED );
+ rtems_task_delete(rtems_task_self());
+T_TEST_CASE( WakeupTaskWithPPSEvent )
+ int status;
+ struct pps_kcbind_args kcbind;
+ test_context ctx;
+ rtems_id pps_task_id;
+ rtems_task_priority pps_task_prio = 1;
+ ctx.pps_dev = &pps_dev;
+ ctx.main_task = rtems_task_self();
+ pps_dev.pps.wait = wait;
+ pps_dev.pps.wakeup = wakeup;
+ kcbind.kernel_consumer = PPS_KC_HARDPPS;
+ kcbind.edge = PPS_CAPTUREASSERT;
+ kcbind.tsformat = PPS_TSFMT_TSPEC;
+ status = pps_ioctl( PPS_IOC_KCBIND, (caddr_t)&kcbind, &pps_dev.pps );
+ /* Save current timecounter in pps_state object */
+ pps_capture( &pps_dev.pps );
+ pps_event( &pps_dev.pps, PPS_CAPTUREASSERT );
+ sc = rtems_task_create(
+ rtems_build_name('P', 'P', 'S', 'E'),
+ pps_task_prio,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &pps_task_id
+ sc = rtems_task_start( pps_task_id, pps_task, (rtems_task_argument) &ctx );
+ sc = rtems_event_receive( TASK_WAITING, RTEMS_DEFAULT_OPTIONS, RTEMS_MILLISECONDS_TO_TICKS(100), &out );
+ /* Capture event and send wake-up */
+ sc = rtems_event_receive( PPS_EVENT_RECEIVED, RTEMS_DEFAULT_OPTIONS, RTEMS_MILLISECONDS_TO_TICKS(100), &out );
+static rtems_task Init( rtems_task_argument argument )
+ rtems_test_run( argument, TEST_STATE );
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
2.25.1
