[PATCH rtems-libbsd 2/2] if_ffec: Allow PHY that is connected to other FFEC
Christian Mauderer christian.mauderer at embedded-brains.de
Mon May 23 12:21:48 UTC 2022
The i.MX6UL (and some others from the i.MX family) have shared MDIO
lines for multiple FFECs. This patch allows to use the MDIO interface
from another Ethernet controller.
Note that you have to make sure that the FFECs are initialized in the
right order. Normally that can be done via FDT.
 freebsd/sys/dev/ffec/if_ffec.c | 120 +++++++++++++++++++++++++++++++++
 1 file changed, 120 insertions(+)
diff --git a/freebsd/sys/dev/ffec/if_ffec.c b/freebsd/sys/dev/ffec/if_ffec.c
index 4c1e147b..316e077c 100644
--- a/freebsd/sys/dev/ffec/if_ffec.c
+++ b/freebsd/sys/dev/ffec/if_ffec.c
@@ -209,6 +209,11 @@ struct ffec_softc {
 	int		rx_ic_count;	/* RW, valid values 0..255 */
 	int		tx_ic_time;
 	int		tx_ic_count;
+#ifdef __rtems__
+	device_t		mdio_device;
+	struct mtx		mdio_mtx;
+#endif /* __rtems__ */
 static struct resource_spec irq_res_spec[MAX_IRQ_COUNT + 1] = {
@@ -376,6 +381,13 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
 	int val;
 	sc = device_get_softc(dev);
+#ifdef __rtems__
+	if (sc->mdio_device) {
+		return (MIIBUS_READREG(sc->mdio_device, phy, reg));
+	mtx_lock(&sc->mdio_mtx);
 	WR4(sc, FEC_IER_REG, FEC_IER_MII);
@@ -386,11 +398,17 @@ ffec_miibus_readreg(device_t dev, int phy, int reg)
 	if (!ffec_miibus_iowait(sc)) {
 		device_printf(dev, "timeout waiting for mii read\n");
+#ifdef __rtems__
+		mtx_unlock(&sc->mdio_mtx);
 		return (-1); /* All-ones is a symptom of bad mdio. */
 	val = RD4(sc, FEC_MMFR_REG) & FEC_MMFR_DATA_MASK;
+#ifdef __rtems__
 	return (val);
@@ -400,6 +418,13 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
 	struct ffec_softc *sc;
+#ifdef __rtems__
+		return (MIIBUS_WRITEREG(sc->mdio_device, phy, reg, val));
@@ -411,9 +436,15 @@ ffec_miibus_writereg(device_t dev, int phy, int reg, int val)
 		device_printf(dev, "timeout waiting for mii write\n");
+#ifdef __rtems__
 		return (-1);
+#ifdef __rtems__
 	return (0);
@@ -1577,6 +1608,9 @@ ffec_detach(device_t dev)
 	if (sc->mem_res != NULL)
 		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->mem_res);
+#ifdef __rtems__
+	mtx_destroy(&sc->mtx);
 	FFEC_LOCK_DESTROY(sc);
 	return (0);
@@ -1726,6 +1760,80 @@ ffec_set_txic(struct ffec_softc *sc)
 	ffec_set_ic(sc, FEC_TXIC0_REG, sc->tx_ic_count, sc->tx_ic_time);
+#ifdef __rtems__
+int
+ffec_get_phy_information(
+	struct ffec_softc *sc,
+	phandle_t node,
+	device_t dev,
+	int *phy_addr
+	phandle_t phy_node;
+	phandle_t parent_node;
+	pcell_t phy_handle, phy_reg;
+	device_t other;
+	phandle_t xref;
+	/* Search for the phy-handle and get the address */
+	if (OF_getencprop(node, "phy-handle", (void *)&phy_handle,
+	    sizeof(phy_handle)) <= 0)
+		return (ENXIO);
+	phy_node = OF_node_from_xref(phy_handle);
+	if (OF_getencprop(phy_node, "reg", (void *)&phy_reg,
+	    sizeof(phy_reg)) <= 0)
+		return (ENXIO);
+	*phy_addr = phy_reg;
+	/* Detect whether PHY handle is connected to this or another FFEC. */
+	parent_node = phy_node;
+	while (parent_node != 0) {
+		if (parent_node == node) {
+			/* PHY is directly connected. That's easy. */
+			sc->mdio_device = NULL;
+			return 0;
+		 * Check whether the node is also an Ethernet controller. Do
+		 * that by just assuming that every Ethernet controller has a
+		 * PHY attached to it.
+		if (OF_getencprop(parent_node, "phy-handle",
+		    (void *)&phy_handle, sizeof(phy_handle)) > 0) {
+			 * Try to find the device of the other Ethernet
+			 * controller and use that for MDIO communication.
+			 * Note: This is not really a nice workaround but it
+			 * works.
+			xref = OF_xref_from_node(parent_node);
+			if (xref == 0) {
+				device_printf(dev,
+				    "Couldn't get device that handles PHY\n");
+				return (ENXIO);
+			other = OF_device_from_xref(xref);
+			if (other == 0) {
+				return (ENXIO);
+			sc->mdio_device = other;
+			return 0;
+		parent_node = OF_parent(parent_node);
+	return (ENXIO);
 static int
 ffec_attach(device_t dev)
@@ -1743,6 +1851,10 @@ ffec_attach(device_t dev)
 	sc->dev = dev;
 	FFEC_LOCK_INIT(sc);
+#ifdef __rtems__
+	mtx_init(&sc->mtx, device_get_nameunit(sc->dev),
+	    MTX_NETWORK_LOCK, MTX_DEF);
 	 * There are differences in the implementation and features of the FEC
@@ -2047,9 +2159,17 @@ ffec_attach(device_t dev)
 	ffec_miigasket_setup(sc);
 	/* Attach the mii driver. */
+#ifdef __rtems__
+	OF_device_register_xref(OF_xref_from_node(ofw_node), dev);
+	if (ffec_get_phy_information(sc, ofw_node, dev, &phynum) != 0) {
+		phynum = MII_PHY_ANY;
+	(void) dummy;
+#else /* __rtems__ */
 	if (fdt_get_phyaddr(ofw_node, dev, &phynum, &dummy) != 0) {
 	error = mii_attach(dev, &sc->miibus, ifp, ffec_media_change,
 	    ffec_media_status, BMSR_DEFCAPMASK, phynum, MII_OFFSET_ANY,
 	    (sc->fecflags & FECTYPE_MVF) ? MIIF_FORCEANEG : 0);
2.35.3
