[PATCH] user: Document Zynq network
Sebastian Huber
Mon May 23 13:13:03 UTC 2022
Content is from rtems-libbsd/libbsd.txt with minor modifications.
user/bsps/arm/xilinx-zynq.rst | 18 +++++++++++++++++-
1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/user/bsps/arm/xilinx-zynq.rst b/user/bsps/arm/xilinx-zynq.rst
index 29f9cb0..0ac4487 100644
--- a/user/bsps/arm/xilinx-zynq.rst
+++ b/user/bsps/arm/xilinx-zynq.rst
@@ -1,6 +1,6 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 2020 Chris Johns (chrisj at rtems.org)
+.. Copyright (C) 2015, 2020 Chris Johns (chrisj at rtems.org)
xilinx-zynq
@@ -49,6 +49,22 @@ tools or a bootloader will be overwritten.
The settings for the console driver can be changed by the user
application through the termios API afterwards.
+Network
+The Cadence network interface driver of LibBSD works on the Xilinx Zynq
+platform. The hardware checksum support works on real hardware but does not
+seem to be supported on Qemu therefore the default state is to disable
+``IFCAP_TXCSUM`` and ``IFCAP_RXCSUM`` and this can be enabled from the shell
+with:
+.. code-block:: none
+ ifconfig cgem0 rxcsum txcsum
+or with an ``ioctl()`` call to the network interface driver with ``SIOCSIFCAP``
+and the mask ``IFCAP_TXCSUM`` and ``IFCAP_RXCSUM`` set.
Debugging with xilinx_zynq_a9_qemu
2.35.3
