[libbsd 06/22] libbsd.txt: Move introduction content
Mon May 23 14:33:29 UTC 2022
 CONTRIBUTING.rst | 22 ++++++++++++++++++++++
 libbsd.txt       | 29 -----------------------------
 2 files changed, 22 insertions(+), 29 deletions(-)
diff --git a/CONTRIBUTING.rst b/CONTRIBUTING.rst
index 0ea66946..1bcdca31 100644
--- a/CONTRIBUTING.rst
+++ b/CONTRIBUTING.rst
@@ -9,6 +9,28 @@ goal of the LibBSD is to stay in synchronization with FreeBSD.  This is only
 feasible if certain rules are in place.  Otherwise, managing more than a
 thousand imported source files will become too labour intensive eventually.
+The LibBSD makes FreeBSD subsystems like TCP/IP, USB, SD/MMC, PCIe, and some
+more usable for RTEMS.  It tries to follow the FreeBSD development as close as
+possible and therefore is updated to the latest FreeBSD HEAD revision of the
+associated FreeBSD branch from time to time.  To find out which version of
+FreeBSD is currently used as the base version for LibBSD please take a look at
+the ``freebsd-org`` submodule.
+This guide captures information on the process of merging code from FreeBSD,
+RTEMS specific support files, general guidelines on what modifications to the
+FreeBSD source are permitted, and some other topics.  For building the library,
+see the `README <README.rst>`_.
+Goals of the LibBSD activity are
+* provide functionality from FreeBSD to RTEMS,
+* ease updating to future FreeBSD versions,
+* ease tracking changes in FreeBSD code,
+* minimize manual changes in FreeBSD code.
+We will work to push our changes upstream to the FreeBSD Project and minimize
+changes required at each update point.
 What is in the Git Repository
diff --git a/libbsd.txt b/libbsd.txt
index 3d665500..2cb7fb07 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -5,35 +5,6 @@ RTEMS BSD Library Guide
 :numbered:
 :website: http://www.rtems.org/
-The libbsd makes FreeBSD subsystems like TCP/IP, USB, SD and some more usable
-for RTEMS. It tries to follow the FreeBSD development as close as possible and
-therefore is updated to the latest FreeBSD HEAD revision from time to time.
-To find out which version of FreeBSD is currently used as the base version for
-libbsd please take a look at the
-https://git.rtems.org/rtems-libbsd/log/freebsd-org[freebsd-org] submodule.
-This is a guide which captures information on the
-process of merging code from FreeBSD, building this library,
-RTEMS specific support files, and general guidelines on what
-modifications to the FreeBSD source are permitted.
-Goals of this effort are
-* update TCP/IP and provide USB in RTEMS,
-* ease updating to future FreeBSD versions,
-* ease tracking changes in FreeBSD code,
-* minimize manual changes in FreeBSD code, and
-* define stable kernel/device driver API which is implemented
-by both RTEMS and FreeBSD. This is the foundation of the port.
-We will work to push our changes upstream to the FreeBSD Project
-and minimize changes required at each update point.
-This is a work in progress and is very likely to be incomplete.
-Please help by adding to it.
 == Getting Started
 === Tool Chain ===
2.35.3
