[libbsd 10/22] libbsd.txt: Move configuration of network tests
Mon May 23 14:33:33 UTC 2022
 README.rst | 15 +++++++++++++++
 libbsd.txt | 14 --------------
 2 files changed, 15 insertions(+), 14 deletions(-)
diff --git a/README.rst b/README.rst
index 8e584266..9aa424dc 100644
--- a/README.rst
+++ b/README.rst
@@ -249,6 +249,21 @@ a scheduler with thread pinning support is required.  This is the case if you
 use the default scheduler configuration.  EPOCH(9) is a central synchronization
 mechanism of the network stack.
+Configuration for Network Tests
+If you need some other IP configuration for the network tests that use a fixed
+IP config you can copy ``config.inc`` to a location outside to the source tree and
+adapt it. Then use the option ``--net-test-config=NET_CONFIG`` to pass the file to
+Waf's configure command.
+.. code-block:: none
+    NET_CFG_SELF_IP = 10.0.0.2
+    NET_CFG_NETMASK = 255.255.0.0
+    NET_CFG_PEER_IP = 10.0.0.1
+    NET_CFG_GATEWAY_IP = 10.0.0.1
 Qemu and Networking
diff --git a/libbsd.txt b/libbsd.txt
index 631acb80..c20a7083 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -7,20 +7,6 @@ RTEMS BSD Library Guide
 == Getting Started
-===== Example Configuration for Network Tests =====
-If you need some other IP configuration for the network tests that use a fixed
-IP config you can copy `config.inc` to a location outside to the source tree and
-adapt it. Then use the option `--net-test-config=NET_CONFIG` to pass the file to
-waf's configure command.
-NET_CFG_SELF_IP = 10.0.0.2
-NET_CFG_NETMASK = 255.255.0.0
-NET_CFG_PEER_IP = 10.0.0.1
-NET_CFG_GATEWAY_IP = 10.0.0.1
 === BSD Library Initialization ===
 To initialise the BSD Library create a suitable rc.conf file. The FreeBSD man
2.35.3
