[libbsd 12/22] libbsd.txt: Move features
Mon May 23 14:33:35 UTC 2022
Add more features and commands.
 README.rst | 72 ++++++++++++++++++++++++++++++++++++++++++++++++++++++
 libbsd.txt | 55 -----------------------------------------
 2 files changed, 72 insertions(+), 55 deletions(-)
diff --git a/README.rst b/README.rst
index cfdb46b3..facea82e 100644
--- a/README.rst
+++ b/README.rst
@@ -324,6 +324,78 @@ freebsd-9.3
     Is the branch for the RTEMS 4.11 release series.  This branch is
     unmaintained.  It is recommended to update to RTEMS 5 or 6.
+Features
+The following features are available in LibBSD.  Some features need device
+driver support for a particular target platform.
+* `BPF(4) <http://www.freebsd.org/cgi/man.cgi?query=bpf&sektion=4>`_: Berkeley Packet Filter
+* `DHCPCD(8) <http://roy.marples.name/projects/dhcpcd/index>`_: DHCP client
+* `dns_sd.h <mDNSResponder/mDNSShared/dns_sd.h>`_: DNS Service Discovery
+* `GETHOSTBYNAME(3) <http://www.freebsd.org/cgi/man.cgi?query=gethostbyname&sektion=3>`_: Get network host entry
+* `IF_BRIDGE(4) <http://www.freebsd.org/cgi/man.cgi?query=if_bridge&sektion=4>`_: Network bridge device
+* `INET(4) <http://www.freebsd.org/cgi/man.cgi?query=inet&sektion=4>`_: Internet protocol family
+* `INET6(4) <http://www.freebsd.org/cgi/man.cgi?query=inet6&sektion=4>`_: Internet protocol version 6 family
+* `IPSEC(4) <http://www.freebsd.org/cgi/man.cgi?query=ipsec&sektion=4>`_: Internet Protocol Security protocol
+* `KQUEUE(2) <http://www.freebsd.org/cgi/man.cgi?query=kqueue&sektion=2>`_: Kernel event notification mechanism
+* `LAGG(4) <http://www.freebsd.org/cgi/man.cgi?query=lagg&sektion=4>`_: Link aggregation and link failover interface
+* `mDNSEmbeddedAPI.h <mDNSResponder/mDNSCore/mDNSEmbeddedAPI.h>`_: Multi-Cast DNS
+* `MMC(4) <http://www.freebsd.org/cgi/man.cgi?query=mmc&sektion=4>`_: MultiMediaCard and SD Card bus driver
+* `NET80211(4) <http://www.freebsd.org/cgi/man.cgi?query=net80211&sektion=4>`_: Standard interface to IEEE 802.11 devices
+* `NVME(4) <http://www.freebsd.org/cgi/man.cgi?query=nvme&sektion=4>`_: NVM Express core driver
+* `PCI(4) <http://www.freebsd.org/cgi/man.cgi?query=pci&sektion=4>`_: Generic PCI/PCIe bus driver
+* `PF(4) <http://www.freebsd.org/cgi/man.cgi?query=pf&sektion=4>`_: Packet filter
+* `POLL(2) <http://www.freebsd.org/cgi/man.cgi?query=poll&sektion=2>`_: Synchronous I/O multiplexing
+* `RESOLVER(3) <http://www.freebsd.org/cgi/man.cgi?query=resolver&sektion=3>`_: Resolver routines
+* `ROUTE(4) <http://www.freebsd.org/cgi/man.cgi?query=route&sektion=4>`_: Kernel packet forwarding database
+* `SELECT(2) <http://www.freebsd.org/cgi/man.cgi?query=select&sektion=2>`_: Synchronous I/O multiplexing
+* `SOCKET(2) <http://www.freebsd.org/cgi/man.cgi?query=socket&sektion=2>`_: Create an endpoint for communication
+* `SSL(7) <http://www.freebsd.org/cgi/man.cgi?query=ssl&sektion=7>`_: OpenSSL SSL/TLS library
+* `SYSCTL(3) <http://www.freebsd.org/cgi/man.cgi?query=sysctl&sektion=3>`_: Get or set system information
+* `TCP(4) <http://www.freebsd.org/cgi/man.cgi?query=tcp&sektion=4>`_: Internet Transmission Control Protocol
+* `UDP(4) <http://www.freebsd.org/cgi/man.cgi?query=udp&sektion=4>`_: Internet User Datagram Protocol
+* `UMASS(4) <http://www.freebsd.org/cgi/man.cgi?query=umass&sektion=4>`_: USB Mass Storage Devices driver
+* `UNIX(4) <http://www.freebsd.org/cgi/man.cgi?query=unix&sektion=4>`_: UNIX-domain protocol family
+* `USB(4) <http://www.freebsd.org/cgi/man.cgi?query=usb&sektion=4>`_: Universal Serial Bus
+* `VLAN(4) <http://www.freebsd.org/cgi/man.cgi?query=vlan&sektion=4>`_: IEEE 802.1Q VLAN network interface
+Commands
+In LibBSD the following ports of FreeBSD command line tools are available.  You
+can invoke the commands in the RTEMS Shell or through function calls, for
+example ``rtems_bsd_command_ifconfig()``.  The functions declarations are
+available through
+`#include <machine/rtems-bsd-commands.h> <rtemsbsd/include/machine/rtems-bsd-commands.h>`_.
+* `ARP(8) <http://www.freebsd.org/cgi/man.cgi?query=arp&sektion=8>`_: Address resolution display and control
+* `HOSTNAME(1) <http://www.freebsd.org/cgi/man.cgi?query=hostname&sektion=1>`_: Set or print name of current host system
+* `IFCONFIG(8) <http://www.freebsd.org/cgi/man.cgi?query=ifconfig&sektion=8>`_: Configure network interface parameters
+* `IFMCSTAT(8) <http://www.freebsd.org/cgi/man.cgi?query=ifmcstat&sektion=8>`_: Dump multicast group management statistics per interface
+* `NETSTAT(1) <http://www.freebsd.org/cgi/man.cgi?query=netstat&sektion=1>`_: Show network status
+* `NVMECONTROL(8) <http://www.freebsd.org/cgi/man.cgi?query=nvmecontrol&sektion=8>`_: NVM Express control utility
+* `OPENSSL(1) <http://www.freebsd.org/cgi/man.cgi?query=openssl&sektion=1>`_: OpenSSL command line tool
+* `PFCTL(8) <http://www.freebsd.org/cgi/man.cgi?query=pfctl&sektion=8>`_: Control the packet filter (PF) device
+* `PING6(8) <http://www.freebsd.org/cgi/man.cgi?query=ping6&sektion=8>`_: Send ICMPv6 ECHO_REQUEST packets to network hosts
+* `PING(8) <http://www.freebsd.org/cgi/man.cgi?query=ping&sektion=8>`_: Send ICMP ECHO_REQUEST packets to network hosts
+* `RACOON(8) <http://www.freebsd.org/cgi/man.cgi?query=racoon&sektion=8>`_: IKE (ISAKMP/Oakley) key management daemon
+* `ROUTE(8) <http://www.freebsd.org/cgi/man.cgi?query=route&sektion=8>`_: Manually manipulate the routing tables
+* `SETKEY(8) <http://www.freebsd.org/cgi/man.cgi?query=setkey&sektion=8>`_: Manually manipulate the IPsec SA/SP database
+* `STTY(1) <http://www.freebsd.org/cgi/man.cgi?query=stty&sektion=1>`_: Set the options for a terminal device interface
+* `SYSCTL(8) <http://www.freebsd.org/cgi/man.cgi?query=sysctl&sektion=8>`_: Get or set kernel state
+* `TCPDUMP(1) <http://www.freebsd.org/cgi/man.cgi?query=tcpdump&sektion=1>`_: Dump traffic on a network
+* `VMSTAT(8) <http://www.freebsd.org/cgi/man.cgi?query=vmstat&sektion=8>`_: Report virtual memory statistics
+* `WPA_SUPPLICANT(8) <http://www.freebsd.org/cgi/man.cgi?query=wpa_supplicant&sektion=8>`_: WPA/802.11i Supplicant for wireless network devices
+Command specific notes are listed below.
+HOSTNAME(1)
+    In addition to the standard options the RTEMS version of the HOSTNAME(1)
+    command supports the -m flag to set/get the multicast hostname of the mDNS
+    resolver instance.  See also ``rtems_mdns_sethostname()`` and
+    ``rtems_mdns_gethostname()``.
 Updating RTEMS Waf Support
diff --git a/libbsd.txt b/libbsd.txt
index 8d5dec2e..384a2f6b 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -7,52 +7,6 @@ RTEMS BSD Library Guide
 == Getting Started
-== Network Stack Features
-http://roy.marples.name/projects/dhcpcd/index[DHCPCD(8)]:: DHCP client
-https://developer.apple.com/library/mac/documentation/Networking/Reference/DNSServiceDiscovery_CRef/Reference/reference.html[dns_sd.h]:: DNS Service Discovery
-http://www.opensource.apple.com/source/mDNSResponder/mDNSResponder-320.10/mDNSCore/mDNSEmbeddedAPI.h[mDNS]:: Multi-Cast DNS
-http://www.freebsd.org/cgi/man.cgi?query=unix&sektion=4[UNIX(4)]:: UNIX-domain protocol family
-http://www.freebsd.org/cgi/man.cgi?query=inet&sektion=4[INET(4)]:: Internet protocol family
-http://www.freebsd.org/cgi/man.cgi?query=inet6&sektion=4[INET6(4)]:: Internet protocol version 6 family
-http://www.freebsd.org/cgi/man.cgi?query=tcp&sektion=4[TCP(4)]:: Internet Transmission Control Protocol
-http://www.freebsd.org/cgi/man.cgi?query=udp&sektion=4[UDP(4)]:: Internet User Datagram Protocol
-http://www.freebsd.org/cgi/man.cgi?query=route&sektion=4[ROUTE(4)]:: Kernel packet forwarding database
-http://www.freebsd.org/cgi/man.cgi?query=bpf&sektion=4[BPF(4)]:: Berkeley Packet Filter
-http://www.freebsd.org/cgi/man.cgi?query=socket&sektion=2[SOCKET(2)]:: Create an endpoint for communication
-http://www.freebsd.org/cgi/man.cgi?query=kqueue&sektion=2[KQUEUE(2)]:: Kernel event notification mechanism
-http://www.freebsd.org/cgi/man.cgi?query=select&sektion=2[SELECT(2)]:: Synchronous I/O multiplexing
-http://www.freebsd.org/cgi/man.cgi?query=poll&sektion=2[POLL(2)]:: Synchronous I/O multiplexing
-http://www.freebsd.org/cgi/man.cgi?query=route&sektion=8[ROUTE(8)]:: Manually manipulate the routing tables
-http://www.freebsd.org/cgi/man.cgi?query=ifconfig&sektion=8[IFCONFIG(8)]:: Configure network interface parameters
-http://www.freebsd.org/cgi/man.cgi?query=netstat&sektion=1[NETSTAT(1)]:: Show network status
-http://www.freebsd.org/cgi/man.cgi?query=ping&sektion=8[PING(8)]:: Send ICMP ECHO_REQUEST packets to network hosts
-http://www.freebsd.org/cgi/man.cgi?query=ping6&sektion=8[PING6(8)]:: Send ICMPv6 ECHO_REQUEST packets to network hosts
-http://www.freebsd.org/cgi/man.cgi?query=sysctl&sektion=3[SYSCTL(3)]:: Get or set system information
-http://www.freebsd.org/cgi/man.cgi?query=resolver&sektion=3[RESOLVER(3)]:: Resolver routines
-http://www.freebsd.org/cgi/man.cgi?query=gethostbyname&sektion=3[GETHOSTBYNAME(3)]:: Get network host entry
 == Network Interface Drivers
 === Link Up/Down Events
@@ -64,15 +18,6 @@ Make sure that the interface flag IFF_UP and the interface driver flag
 IFF_DRV_RUNNING is set in case the link is up, otherwise ether_output() will
 return the error status ENETDOWN.
-== Shell Commands
-=== HOSTNAME(1)
-In addition to the standard options the RTEMS version of the HOSTNAME(1)
-command supports the -m flag to set/get the multicast hostname of the
-mDNS resolver instance.  See also rtems_mdns_sethostname() and
-rtems_mdns_gethostname().
 == Qemu
 Use the following script to set up a virtual network with three tap devices
2.35.3
