[libbsd 19/22] libbsd.txt: Move IPsec description
Mon May 23 14:33:42 UTC 2022
 README.rst | 145 +++++++++++++++++++++++++++++++++++++++++++++++++++++
 libbsd.txt | 128 ----------------------------------------------
 2 files changed, 145 insertions(+), 128 deletions(-)
diff --git a/README.rst b/README.rst
index 48adcb20..ff977470 100644
--- a/README.rst
+++ b/README.rst
@@ -513,6 +513,151 @@ Known Restrictions
 * The control interface of ``wpa_supplicant`` most likely doesn't work. The wpa_cli
   application is not ported.
+IPSec
+The IPSec support is optional in LibBSD. It is disabled in the default build
+set. Please make sure to use a build set with ``netipsec = on``.
+Configuration
+To use IPSec the following configuration is necessary:
+.. code-block:: none
+    SYSINIT_MODULE_REFERENCE(if_gif);
+    SYSINIT_MODULE_REFERENCE(cryptodev);
+    RTEMS_BSD_RC_CONF_SYSINT(rc_conf_ipsec)
+    RTEMS_BSD_DEFINE_NEXUS_DEVICE(cryptosoft, 0, 0, NULL);
+Alternatively, you can use the ``RTEMS_BSD_CONFIG_IPSEC`` which also includes the
+rc.conf support for ipsec. It's still necessary to include a crypto device in
+your config (``cryptosoft`` in the above sample).
+The necessary initialization steps for a IPSec connection are similar to the
+steps on a FreeBSD-System. The example assumes the following setup:
+- RTEMS external IP: 192.168.10.1/24
+- RTEMS internal IP: 10.10.1.1/24
+- remote external IP: 192.168.10.10/24
+- remote internal IP: 172.24.0.1/24
+- shared key: "mysecretkey"
+With this the following steps are necessary:
+* Create a gif0 device:
+  .. code-block:: none
+      ifconfig gif0 create
+* Configure the gif0 device:
+      ifconfig gif0 10.10.1.1 172.24.0.1
+      ifconfig gif0 tunnel 192.168.10.1 192.168.10.10
+* Add a route to the remote net via the remote IP:
+      route add 172.24.0.0/24 172.24.0.1
+* Create a correct rule set in ``/etc/setkey.conf``:
+      flush;
+      spdflush;
+      spdadd  10.10.1.0/24 172.24.0.0/24 any -P out ipsec esp/tunnel/192.168.10.1-192.168.10.10/use;
+      spdadd 172.24.0.0/24  10.10.1.0/24 any -P in  ipsec esp/tunnel/192.168.10.10-192.168.10.1/use;
+* Call ``setkey``:
+      setkey -f /etc/setkey.conf
+* Create a correct configuration in ``/etc/racoon.conf``:
+      path    pre_shared_key "/etc/racoon_psk.txt";
+      log     info;
+      padding # options are not to be changed
+              maximum_length                  20;
+              randomize                       off;
+              strict_check                    off;
+              exclusive_tail                  off;
+      listen  # address [port] that racoon will listen on
+              isakmp                          192.168.10.1[500];
+      remote 192.168.10.10 [500]
+              exchange_mode                   main;
+              my_identifier                   address 192.168.10.1;
+              peers_identifier                address 192.168.10.10;
+              proposal_check                  obey;
+              proposal {
+                      encryption_algorithm    3des;
+                      hash_algorithm          md5;
+                      authentication_method   pre_shared_key;
+                      lifetime                time 3600 sec;
+                      dh_group                2;
+      sainfo (address 10.10.1.0/24 any address 172.24.0.0/24 any)
+              pfs_group                       2;
+              lifetime                        time 28800 sec;
+              authentication_algorithm        hmac_md5;
+              compression_algorithm           deflate;
+* Create a correct configuration in ``/etc/racoon_psk.txt``:
+     192.168.10.10   mysecretkey
+* Start a ike-daemon (racoon):
+      racoon -F -f /etc/racoon.conf
+All commands can be called via the respective API functions. For racoon there is
+a ``rtems_bsd_racoon_daemon()`` function that forks of racoon as a task.
+Alternatively, IPSec can also be configured via rc.conf entries:
+      cloned_interfaces="gif0"
+      ifconfig_gif0="10.10.1.1 172.24.0.1 tunnel 192.168.10.1 192.168.10.10"
+      ike_enable="YES"
+      ike_program="racoon"
+      ike_flags="-F -f /etc/racoon.conf"
+      ike_priority="250"
+      ipsec_enable="YES"
+      ipsec_file="/etc/setkey.conf"
+ATTENTION: It is possible that the first packets slip through the tunnel without
+encryption (true for FreeBSD as well as RTEMS). You might want to set up a
+firewall rule to prevent that.
 Updating RTEMS Waf Support
diff --git a/libbsd.txt b/libbsd.txt
index 41061838..cd6c8dae 100644
--- a/libbsd.txt
+++ b/libbsd.txt
@@ -321,134 +321,6 @@ structure that were not being used were conditionally compiled out. The
 capability of supporting children did not appear to be needed and was
 not implemented in the rtems version of these routines.
-== IPSec ==
-The IPSec support is optional in libbsd. It is disabled in the default build
-set. Please make sure to use a build set with +netipsec = on+.
-To use IPSec the following configuration is necessary:
-SYSINIT_MODULE_REFERENCE(if_gif);
-SYSINIT_MODULE_REFERENCE(cryptodev);
-RTEMS_BSD_RC_CONF_SYSINT(rc_conf_ipsec)
-RTEMS_BSD_DEFINE_NEXUS_DEVICE(cryptosoft, 0, 0, NULL);
-Alternatively you can use the `RTEMS_BSD_CONFIG_IPSEC` which also includes the
-rc.conf support for ipsec. It's still necessary to include a crypto device in
-your config (`cryptosoft` in the above sample).
-The necessary initialization steps for a IPSec connection are similar to the
-steps on a FreeBSD-System. The example assumes the following setup:
-- RTEMS external IP: 192.168.10.1/24
-- RTEMS internal IP: 10.10.1.1/24
-- remote external IP: 192.168.10.10/24
-- remote internal IP: 172.24.0.1/24
-- shared key: "mysecretkey"
-With this the following steps are necessary:
-- Create a gif0 device:
-SHLL [/] #  ifconfig gif0 create
-- Configure the gif0 device:
-SHLL [/] # ifconfig gif0 10.10.1.1 172.24.0.1
-SHLL [/] # ifconfig gif0 tunnel 192.168.10.1 192.168.10.10
-- Add a route to the remote net via the remote IP:
-SHLL [/] # route add 172.24.0.0/24 172.24.0.1
-- Call `setkey` with a correct rule set:
-SHLL [/] # cat /etc/setkey.conf
-flush;
-spdflush;
-spdadd  10.10.1.0/24 172.24.0.0/24 any -P out ipsec esp/tunnel/192.168.10.1-192.168.10.10/use;
-spdadd 172.24.0.0/24  10.10.1.0/24 any -P in  ipsec esp/tunnel/192.168.10.10-192.168.10.1/use;
-SHLL [/] # setkey -f /etc/setkey.conf
-- Start a ike-daemon (racoon) with a correct configuration.
-SHLL [/] # cat /etc/racoon.conf
-path	pre_shared_key "/etc/racoon_psk.txt";
-log	info;
-padding # options are not to be changed
-	maximum_length			20;
-	randomize			off;
-	strict_check			off;
-	exclusive_tail			off;
-listen  # address [port] that racoon will listen on
-	isakmp				192.168.10.1[500];
-remote 192.168.10.10 [500]
-	exchange_mode			main;
-	my_identifier			address 192.168.10.1;
-	peers_identifier		address 192.168.10.10;
-	proposal_check			obey;
-	proposal {
-		encryption_algorithm	3des;
-		hash_algorithm		md5;
-		authentication_method	pre_shared_key;
-		lifetime		time 3600 sec;
-		dh_group		2;
-sainfo (address 10.10.1.0/24 any address 172.24.0.0/24 any)
-	pfs_group			2;
-	lifetime			time 28800 sec;
-	authentication_algorithm	hmac_md5;
-	compression_algorithm		deflate;
-SHLL [/] # cat /etc/racoon_psk.txt
-192.168.10.10	mysecretkey
-SHLL [/] # racoon -F -f /etc/racoon.conf
-All commands can be called via the respective API functions. For racoon there is
-a `rtems_bsd_racoon_daemon()` function that forks of racoon as a task.
-Alternatively IPSec can also be configured via rc.conf entries:
-cloned_interfaces="gif0"
-ifconfig_gif0="10.10.1.1 172.24.0.1 tunnel 192.168.10.1 192.168.10.10"
-ike_enable="YES"
-ike_program="racoon"
-ike_flags="-F -f /etc/racoon.conf"
-ike_priority="250"
-ipsec_enable="YES"
-ipsec_file="/etc/setkey.conf"
-ATTENTION: It is possible that the first packets slip through the tunnel without
-encryption (true for FreeBSD as well as RTEMS). You might want to set up a
-firewall rule to prevent that.
 == Problems to report to FreeBSD ==
 The MMAP_NOT_AVAILABLE define is inverted on its usage.  When it is
2.35.3
