[libbsd 22/22] libbsd.txt: Move issues and TODO
Sebastian Huber
Mon May 23 14:33:45 UTC 2022
CONTRIBUTING.rst | 124 ++++++++++++++++++++++++++++++++++++++++
libbsd.txt | 144 -----------------------------------------------
2 files changed, 124 insertions(+), 144 deletions(-)
delete mode 100644 libbsd.txt
diff --git a/CONTRIBUTING.rst b/CONTRIBUTING.rst
index c7c35df9..8cf42dff 100644
--- a/CONTRIBUTING.rst
+++ b/CONTRIBUTING.rst
@@ -599,3 +599,127 @@ System Control Hints
If you get undefined references to ``_bsd_sysctl_*`` symbols, then you have to
locate and add the associated system control node, see
`SYSCTL(9) <http://www.freebsd.org/cgi/man.cgi?query=SYSCTL_DECL&sektion=9>`_.
+Issues and TODO
+* PCI support on x86 uses a quick and dirty hack, see pci_reserve_map().
+* Priority queues are broken with clustered scheduling.
+* Per-CPU data should be enabled once the new stack is ready for SMP.
+* Per-CPU NETISR(9) should be enabled onece the new stack is ready for SMP.
+* Multiple routing tables are not supported. Every FIB value is set to zero
+ (= BSD_DEFAULT_FIB).
+* Process identifiers are not supported. Every PID value is set to zero
+ (= BSD_DEFAULT_PID).
+* User credentials are not supported. The following functions allow the
+ operation for everyone
+ * prison_equal_ip4(),
+ * chgsbsize(),
+ * cr_cansee(),
+ * cr_canseesocket() and
+ * cr_canseeinpcb().
+* A basic USB functionality test that is known to work on Qemu is desirable.
+* Adapt generic IRQ PIC interface code to Simple Vectored Interrupt Model
+ so that those architectures can use new TCP/IP and USB code.
+* freebsd-userspace/rtems/include/sys/syslog.h is a copy from the old
+ RTEMS TCP/IP stack. For some reason, the __printflike markers do not
+ compile in this environment. We may want to use the FreeBSD syslog.h
+ and get this addressed.
+* in_cksum implementations for architectures not supported by FreeBSD.
+ This will require figuring out where to put implementations that do
+ not originate from FreeBSD and are populated via the script.
+* MAC support functions are not thread-safe ("freebsd/lib/libc/posix1e/mac.c").
+* IFCONFIG(8): IEEE80211 support is disabled. This module depends on a XML
+ parser and mmap().
+* get_cyclecount(): The implementation is a security problem.
+* What to do with the priority parameter present in the FreeBSD synchronization
+ primitives and the thread creation functions?
+* TASKQUEUE(9): Support spin mutexes.
+* ZONE(9): Review allocator lock usage in rtems-bsd-chunk.c.
+* KQUEUE(2): Choose proper lock for global kqueue list.
+* TIMEOUT(9): Maybe use special task instead of timer server to call
+ callout_tick().
+* sysctl_handle_opaque(): Implement reliable snapshots.
+* PING6(8): What to do with SIGALARM?
+* <sys/param.h>: Update Newlib to use a MSIZE of 256.
+* BPF(4): Add support for zero-copy buffers.
+* UNIX(4): Fix race conditions in the area of socket object and file node
+ destruction. Add support for file descriptor transmission via control
+ messages.
+* PRINTF(9): Add support for log(), the %D format specifier is missing in the
+ normal printf() family.
+* Why is the interrupt server used? The BSD interrupt handlers can block on
+ synchronization primitives like mutexes. This is in contrast to RTEMS
+ interrupt service routines. The BSPs using the generic interrupt support
+ must implement the ``bsp_interrupt_vector_enable()`` and
+ ``bsp_interrupt_vector_disable()`` routines. They normally enable/disable a
+ particular interrupt source at the interrupt controller. This can be used to
+ implement the interrupt server. The interrupt server is a task that wakes-up
+ in case an associated interrupt happens. The interrupt source is disabled in
+ a generic interrupt handler that wakes-up the interrupt server task. Once
+ the postponed interrupt processing is performed in the interrupt server the
+ interrupt source is enabled again.
+* Convert all BSP linkcmds to use a linkcmds.base so the sections are
+ easier to insert.
+* NIC Device Drivers
+* Only common PCI NIC drivers have been included in the initial set. These
+ do not include any system on chip or ISA drivers.
+* PCI configuration probe does not appear to happen to determine if a
+ NIC is in I/O or memory space. We have worked around this by using a
+ static hint to tell the fxp driver the correct mode. But this needs to
+ be addressed.
+* The ISA drivers require more BSD infrastructure to be addressed. This was
+ outside the scope of the initial porting effort.
+* devfs (Device file system): There is a minimal implementation based on IMFS.
+ The mount point is fixed to "/dev". Note that the devfs is only used by the
+ cdev subsystem. cdev has been adapted so that the full path (including the
+ leading "/dev") is given to devfs. This saves some copy operations.
+ devfs_create() first creates the full path and then creates an IMFS generic
+ node for the device.
+ TBD: remove empty paths on devfs_destroy().
+* altq_subr.c - Arbitrary choices were made in this file that RTEMS would not
+ support tsc frequency change. Additionally, the clock frequency for
+ machclk_freq is always measured for RTEMS.
+* conf.h - In order to add make_dev and destroy_dev, variables in the cdev
+ structure that were not being used were conditionally compiled out. The
+ capability of supporting children did not appear to be needed and was not
+ implemented in the rtems version of these routines.
+* Problem to report to FreeBSD: The MMAP_NOT_AVAILABLE define is inverted on
+ its usage. When it is defined the mmap method is called. Additionally, it is
+ not used thoroughly. It is not used in the unmap portion of the source. The
+ file rec_open.c uses the define MMAP_NOT_AVAILABLE to wrap the call to mmap
+ and file rec_close.c uses the munmap method.
diff --git a/libbsd.txt b/libbsd.txt
deleted file mode 100644
index 706faeb6..00000000
--- a/libbsd.txt
+++ /dev/null
@@ -1,144 +0,0 @@
-RTEMS BSD Library Guide
-:toc:
-:icons:
-:numbered:
-:website: http://www.rtems.org/
-== Getting Started
-== Issues and TODO
-* PCI support on x86 uses a quick and dirty hack, see pci_reserve_map().
-* Priority queues are broken with clustered scheduling.
-* Per-CPU data should be enabled once the new stack is ready for SMP.
-* Per-CPU NETISR(9) should be enabled onece the new stack is ready for SMP.
-* Multiple routing tables are not supported. Every FIB value is set to zero
- (= BSD_DEFAULT_FIB).
-* Process identifiers are not supported. Every PID value is set to zero
- (= BSD_DEFAULT_PID).
-* User credentials are not supported. The following functions allow the
- operation for everyone
- - prison_equal_ip4(),
- - chgsbsize(),
- - cr_cansee(),
- - cr_canseesocket() and
- - cr_canseeinpcb().
-* A basic USB functionality test that is known to work on Qemu is desirable.
-* Adapt generic IRQ PIC interface code to Simple Vectored Interrupt Model
- so that those architectures can use new TCP/IP and USB code.
-* freebsd-userspace/rtems/include/sys/syslog.h is a copy from the old
- RTEMS TCP/IP stack. For some reason, the __printflike markers do not
- compile in this environment. We may want to use the FreeBSD syslog.h
- and get this addressed.
-* in_cksum implementations for architectures not supported by FreeBSD.
- This will require figuring out where to put implementations that do
- not originate from FreeBSD and are populated via the script.
-* MAC support functions are not thread-safe ("freebsd/lib/libc/posix1e/mac.c").
-* IFCONFIG(8): IEEE80211 support is disabled. This module depends on a XML
- parser and mmap().
-* get_cyclecount(): The implementation is a security problem.
-* What to do with the priority parameter present in the FreeBSD synchronization
- primitives and the thread creation functions?
-* TASKQUEUE(9): Support spin mutexes.
-* ZONE(9): Review allocator lock usage in rtems-bsd-chunk.c.
-* KQUEUE(2): Choose proper lock for global kqueue list.
-* TIMEOUT(9): Maybe use special task instead of timer server to call
- callout_tick().
-* sysctl_handle_opaque(): Implement reliable snapshots.
-* PING6(8): What to do with SIGALARM?
-* <sys/param.h>: Update Newlib to use a MSIZE of 256.
-* BPF(4): Add support for zero-copy buffers.
-* UNIX(4): Fix race conditions in the area of socket object and file node
- destruction. Add support for file descriptor transmission via control
- messages.
-* PRINTF(9): Add support for log(), the %D format specifier is missing in the
- normal printf() family.
-* Why is the interrupt server used? The BSD interrupt handlers can block on
-synchronization primitives like mutexes. This is in contrast to RTEMS
-interrupt service routines. The BSPs using the generic interrupt support must
-implement the `bsp_interrupt_vector_enable()` and
-`bsp_interrupt_vector_disable()` routines. They normally enable/disable a
-particular interrupt source at the interrupt controller. This can be used to
-implement the interrupt server. The interrupt server is a task that wakes-up
-in case an associated interrupt happens. The interrupt source is disabled in
-a generic interrupt handler that wakes-up the interrupt server task. Once the
-postponed interrupt processing is performed in the interrupt server the
-interrupt source is enabled again.
-* Convert all BSP linkcmds to use a linkcmds.base so the sections are
-easier to insert.
-* NIC Device Drivers
-- Only common PCI NIC drivers have been included in the initial set. These
-do not include any system on chip or ISA drivers.
-- PCI configuration probe does not appear to happen to determine if a
-NIC is in I/O or memory space. We have worked around this by using a
-static hint to tell the fxp driver the correct mode. But this needs to
-be addressed.
-- The ISA drivers require more BSD infrastructure to be addressed. This was
-outside the scope of the initial porting effort.
-The FreeBSD device model is quite elaborated (with follow-ups):
-http://www.freebsd.org/cgi/man.cgi?query=driver
-The devices form a tree with the Nexus device at a high-level. This Nexus
-device is architecture specific in FreeBSD. In RTEMS we have our own Nexus
-device, see `rtemsbsd/bsp/bsp-bsd-nexus-devices.c`.
-=== devfs (Device file system) ===
-There is a minimal implementation based on IMFS. The mount point is fixed to
-"/dev". Note that the devfs is only used by the cdev subsystem. cdev has been
-adapted so that the full path (including the leading "/dev") is given to devfs.
-This saves some copy operations.
-devfs_create() first creates the full path and then creates an IMFS generic node
-for the device.
-TBD: remove empty paths on devfs_destroy().
-== Notes by File ==
-altq_subr.c - Arbitrary choices were made in this file that RTEMS would
-not support tsc frequency change. Additionally, the clock frequency
-for machclk_freq is always measured for RTEMS.
-conf.h - In order to add make_dev and destroy_dev, variables in the cdev
-structure that were not being used were conditionally compiled out. The
-capability of supporting children did not appear to be needed and was
-not implemented in the rtems version of these routines.
-== Problems to report to FreeBSD ==
-The MMAP_NOT_AVAILABLE define is inverted on its usage. When it is
-defined the mmap method is called. Additionally, it is not used
-thoroughly. It is not used in the unmap portion of the source.
-The file rec_open.c uses the define MMAP_NOT_AVAILABLE to wrap
-the call to mmap and file rec_close.c uses the munmap method.
2.35.3
