Issues building QEMU on Ubuntu
Ryan Long ryan.long at oarcorp.com
Tue May 24 14:47:07 UTC 2022
When building QEMU it goes through the entire build and it looks like it
passes, but it is failing. The only error that Joel and I saw in the
output was this
Found ninja-1.10.1 at /usr/bin/ninja
LD_LIBRARY_PATH=/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/lib
make -j 8 all
/usr/bin/ninja  build.ninja && touch build.ninja.stamp
ninja: no work to do.
/usr/bin/python3 -B
/home/tester/rtems-cron-6/rtems-source-builder/bare/build/qemu-5.2.0-rc1-x86_64-linux-gnu-1/qemu-5.2.0-rc1/meson/meson.py
introspect --targets --tests --benchmarks | /usr/bin/python3 -B
scripts/mtest2make.py > Makefile.mtest
   BUILD   multiboot.img
   BUILD   linuxboot.img
   BUILD   linuxboot_dma.img
   BUILD   kvmvapic.img
ld: Error: unable to disambiguate: -no-pie (did you mean --no-pie ?)
Unless someone has any objections, I'm going to try the 5.2.0 release,
and if that doesn't work, I'm going to try bumping it to 6.2.0.
Thanks,
Ryan
