[PATCH] MAINTAINERS: Add myself to Write After Approval
Karel Gardas
karel at functional.vision
Thu May 26 22:24:18 UTC 2022
Oh, that would be then this warning I got:
To reduce spam only list members may post to this list. If you think
that your messages are being rejected in error please contact
vc-owner at rtems.org.
Karel
On 5/26/22 23:51, Chris Johns wrote:
> I did not see a message in the vc list?
> Chris
> On 27/5/2022 5:14 am, Karel Gardas wrote:
>> On 5/26/22 20:49, Joel Sherrill wrote:
>>> This looks good to me.
>> Thanks!
>>> Try and commit it so we can see if everything works. :)
>> push looks fine except error on buildbot. Is that expected?
>> $ git push
>> Enumerating objects: 5, done.
>> Counting objects: 100% (5/5), done.
>> Delta compression using up to 12 threads
>> Compressing objects: 100% (3/3), done.
>> Writing objects: 100% (3/3), 415 bytes | 415.00 KiB/s, done.
>> Total 3 (delta 2), reused 0 (delta 0)
>> remote: 0: init
>> remote: 1: mail vc at rtems.org
>> remote: Warning: Permanently added 'devel.int.rtems.org' (ECDSA) to the list of
>> known hosts.
>> remote: 4: IRC
>> remote: 5: Buildbot
>> remote: git_buildbot: ERROR: Could not connect to buildbot.int.rtems.org:9899:
>> Connection was refused by other side: 61: Connection refused.
>> To ssh://dispatch.rtems.org/data/git/rtems.git
>> 495f8363de..f91f30f69a master -> master
>> rtems at silence:~/git/rtems/ssh-rtems$
>> Karel
>>> --joel
>>> On Thu, May 26, 2022 at 1:42 PM Karel Gardas <karel at functional.vision> wrote:
>>> Add myself also to Localized Write Permission for x86_64.
>>> MAINTAINERS | 3 ++-
>>> 1 file changed, 2 insertions(+), 1 deletion(-)
>>> diff --git a/MAINTAINERS b/MAINTAINERS
>>> index 446bec7d19..2c997cb58d 100644
>>> --- a/MAINTAINERS
>>> +++ b/MAINTAINERS
>>> @@ -55,6 +55,7 @@ Christian Mauderer
>>> christian.mauderer at embedded-brains.de
>>> <mailto:christian.mauderer at embedded-brains.de>
>>> Hesham Almatary heshamelmatary at gmail.com
>>> <mailto:heshamelmatary at gmail.com>
>>> Vijay Kumar Banerjee vijay at rtems.org <mailto:vijay at rtems.org>
>>> Jan Sommer jan at rtems.org <mailto:jan at rtems.org>
>>> +Karel Gardas karel at functional.vision
>>> @@ -62,7 +63,7 @@ sparc Daniel Hellstrom
>>> (daniel at gaisler.com <mailto:daniel at gaisler.com>)
>>> beagle Ben Gras (beng at rtems.org
>>> <mailto:beng at rtems.org>)
>>> tms570 Pavel Pisa (pisa at cmp.felk.cvut.cz
>>> <mailto:pisa at cmp.felk.cvut.cz>)
>>> raspberrypi Pavel Pisa (pisa at cmp.felk.cvut.cz
>>> -x86_64 TBD
>>> +x86_64 Karel Gardas (karel at functional.vision)
>>> beagle Vijay Kumar Banerjee (vijay at rtems.org
>>> <mailto:vijay at rtems.org>)
>>> Emeritus Maintainers
>>> -- 2.25.1
>>> devel mailing list
>>> devel at rtems.org <mailto:devel at rtems.org>
>>> http://lists.rtems.org/mailman/listinfo/devel
>>> <http://lists.rtems.org/mailman/listinfo/devel>
>> devel mailing list
>> devel at rtems.org
