AW: [PATCH] score: Fix pps_fetch()
Gabriel.Moyano at dlr.de
Fri May 27 09:19:39 UTC 2022
Hi Sebastian,
It is ok. Thx for adding this, I must have removed this "if" accidentally.
> Return early only if there was a timeout, otherwise return the PPS info.
> Update #2349.
> cpukit/score/src/kern_tc.c | 3 ++-
> 1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c index c09900f096..2e3709a9ad 100644
> --- a/cpukit/score/src/kern_tc.c
> +++ b/cpukit/score/src/kern_tc.c
> @@ -1980,7 +1980,8 @@ pps_fetch(struct pps_fetch_args *fapi, struct pps_state *pps) #else /* __rtems__ */
> _Assert(pps->wait != NULL);
> err = (*pps->wait)(pps, fapi->timeout);
> - return (err);
> + if (err != 0)
> + return (err);
> #endif /* __rtems__ */
> 2.35.3
