[PATCH] user/bsps/arm: improve stm32h7 BSP description
Karel Gardas
karel at functional.vision
Fri May 27 18:00:44 UTC 2022
ping.
I've submited this before my commit access and not sure either if the
doc hacking although purely BSP specific counts as
"A BSP-specific patch may be checked in three work days after sending it
to devel at rtems.org in case nobody explicitly rejected the patch."
from MAINTAINERS... So pinging...
Thanks,
Karel
On 5/18/22 21:02, Karel Gardas wrote:
> This patch adds kind of HOWTO to the stm32h7 BSP description. The howto
> discusses various tools from STM tool-chain and how to use them in order
> to configure board for RTEMS and to upload RTEMS application binary
> to the board. The patch also adds more supported boards to the table.
> Sponsored-By: Precidata
> user/bsps/arm/stm32h7.rst | 544 ++++++++++++++++++++++++++++++++++++--
> 1 file changed, 528 insertions(+), 16 deletions(-)
> diff --git a/user/bsps/arm/stm32h7.rst b/user/bsps/arm/stm32h7.rst
> index b508595..ec7440f 100644
> --- a/user/bsps/arm/stm32h7.rst
> +++ b/user/bsps/arm/stm32h7.rst
> @@ -2,16 +2,36 @@
> .. Copyright (C) 2020 embedded brains GmbH
> +.. Copyright (C) 2022 Karel Gardas <karel at functional.vision>
> stm32h7
> This BSP supports the
> `STM32H7 Series <https://www.st.com/en/microcontrollers-microprocessors/stm32h7-series.html>`_.
> -The BSP is known to run on these boards:
> +The BSP is known to run on these boards on specified core with using specified BSP variant.
> +.. table::
> + | Board name | Core name | BSP variant name |
> + |`STM32H743I-EVAL 2 <https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_| M7 | arm/stm32h7 |
> + |`STM32H743ZI-Nucleo <https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_ | M7 | arm/nucleo-h743zi |
> + |`STM32H7B3I-DK <https://www.st.com/en/evaluation-tools/stm32h7b3i-dk.html>`_ | M7 | arm/stm32h7b3i-dk |
> + |`STM32H757I-EVAL <https://www.st.com/en/evaluation-tools/stm32h757i-eval.html>`_ | M7 | arm/stm32h757i-eval |
> + | | M4 | arm/stm32h757i-eval-m4 |
> + |`STM32H747I-DISCO <https://www.st.com/en/evaluation-tools/stm32h747i-disco.html>`_| M7 | arm/stm32h747i-disco |
> + | | M4 | arm/stm32h747i-disco-m4|
> -* `STM32H743I-EVAL 2 <https://www.st.com/en/evaluation-tools/stm32h743i-eval.html>`_
> -* `STM32H743ZI-Nucleo <https://www.st.com/en/evaluation-tools/nucleo-h743zi.html>`_
> Clock Driver
> @@ -23,20 +43,28 @@ boards, so it is recommended to check the default values of the BSP.
> Console Driver
> -The console driver supports the on-chip UART and USART modules.
> -Different board variations use different GPIO pins and blocks for the default
> -communication UART and it is recommended to check whether the default
> -configuration provided is valid in the BSP.
> +The console driver supports the on-chip UART and USART modules. Even
> +the MCU supports about 10 U(S)ARTs, only those supported by the chosen
> +board are enabled by default configuration. The board needs to support
> +some kind of connector-based connection to the U(S)ART in order for the
> +feature to be considered supported here.
> +.. Leaving previous notes here as a comment. They may still be useful
> +.. and incorporated into the later version of the document.
> +.. Different board variations use different GPIO pins and blocks for the default
> +.. communication UART and it is recommended to check whether the default
> +.. configuration provided is valid in the BSP.
> -To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
> -users can supply ``STM32H743ZI_NUCLEO = True`` to ``config.ini`` when
> -building the BSP.
> +.. To specify that the BSP should be built for the STM32H743ZI-Nucleo board,
> +.. users can supply ``STM32H743ZI_NUCLEO = True`` to ``config.ini`` when
> +.. building the BSP.
> -Alternatively, users can supply the configuration structs defined in ``hal.h``
> -in the application for other boards. For the console driver, the
> -``stm32h7_usartX_config`` structs are used to configure the GPIO pins and other
> -parameters. The default implementations can be found in
> -``bsps/arm/stm32ht/console`` in the RTEMS sources.
> +.. Alternatively, users can supply the configuration structs defined in ``hal.h``
> +.. in the application for other boards. For the console driver, the
> +.. ``stm32h7_usartX_config`` structs are used to configure the GPIO pins and other
> +.. parameters. The default implementations can be found in
> +.. ``bsps/arm/stm32ht/console`` in the RTEMS sources.
> Network Interface Driver
> @@ -70,6 +98,490 @@ Known limitations:
> for UHS cards are not available. All cards fall back to High Speed transfers.
> * The driver uses the IDMA only. MDMA is currently not implemented. For SDMMC1
> that means that the memory buffers can only come from AXI SRAM, QSPI memory,
> - Flash or the FMC (SDRAM, ...). The internal SRAM1, SRAM2, SRAM3 and SRAM4 is
> + Flash or the FMC (SDRAM, ...). The internal SRAM1, SRAM2, SRAM3 and SRAM4 are
> not supported. SDMMC2 should not have that limitation. See ST AN5200 "Getting
> started with STM32H7 Series SDMMC host controller" for more details.
> +How to run RTEMS on the board
> +Following few paragraphs save a purpose of simple HOWTO or a quick
> +starting guide for the users not versed in STM32 toolchain and their
> +boards workflow.
> +Board hardware setup
> +Connect board with the host computer using micro-USB cable connected
> +to micro-USB connector on the board marked with 'ST-LINK V3E' in case of evaluation
> +and discovery boards or with 'USB PWR' in case of Nucleo board.
> +STM32CubeIDE installation
> +Download and install STM32CubeIDE from
> +https://www.st.com/en/development-tools/stm32cubeide.html. Install the
> +software into the user directory. On Linux install with 'sudo' command
> +to install as a root since as part of the installation USB permissions
> +rules for ST-Link GDB server are also installed. The reason for
> +installing into the user directory is that the IDE is based on
> +Eclipse, which provides
> +its own update method and this will not work well in case of read-only
> +access to the installation directory. In case of any troubles consult
> +installation manual provided by ST here https://www.st.com/resource/en/user_manual/um2563-stm32cubeide-installation-guide-stmicroelectronics.pdf.
> +Although we will not used full fledged IDE here, the package provides ST-Link GDB Server which will be used for uploading RTEMS binaries to the board
> +memory.
> +STM32CubeProgrammer installation
> +Download and install STM32CubeProgrammer from
> +https://www.st.com/en/development-tools/stm32cubeprog.html. We will
> +use this software for board setup required for RTEMS and later when
> +something goes wrong to delete content of the MCU flash memory. The
> +software is also internally used by the ST-Link GDB Server from
> +STM32CubeIDE so it is crucial to have it installed.
> +Board ST-Link firmware upgrade
> +Download ST-Link board firmware upgrade package from
> +https://www.st.com/en/development-tools/stsw-link007.html. The
> +software is distributed in a form of Java jar file for Linux and Mac
> +OSX and in a form of Windows binary for MS Windows. Unpack it
> +somewhere and run it with
> +.. code-block:: shell
> + $ unzip en.stsw-link007-v3-9-3_v3.9.3.zip
> + $ cd stsw-link007/AllPlatforms
> + $ java -jar STLinkUpgrade.jar
> +Click on *Open in update mode* button and then if *Version* and *Update
> +to Firmware* version information are different in shown version number/code, click on *Upgrade*
> +button and wait till upgrade finishes.
> +.. note: On Linux you will need to have libusb library installed in
> + order to make upgrade process working. On Ubuntu 20.04 LTS you can do
> + that with following command.
> + $ sudo apt install libusb-1.0-0
> +Dual core board setup for RTEMS
> +Current RTEMS BSP supports
> +running MCU in a single-core mode only on either M7 core or M4
> +core. That means that to not leave other core interfering with the
> +system we either need to upload short infinite loop code to it or we
> +may switch off the core completely. The second option is what is
> +described here. The board by default switches on and starts both
> +cores. Based on chosen BSP variant you may like to switch off other
> +core with using STMCubeProgrammer tool.
> +Go to the directory where you have installed STMCubeProgrammer
> +software and run it with
> + $ cd bin
> + $ ./STM32CubeProgrammer
> +.. important:: It is absolutely necessary you will do that from inside the bin
> + directory where STM32CubeProgrammer binary resides. If you don't, then
> + programmer UI will crash on attempt to connect to the board. Probable
> + reason is a bug in the programmer which is not able to correctly locate
> + its C dynamic library responsible for connecting to the ST-Link board
> + interface. Version 2.9.0 of the programmer is described here. Other
> + versions may behave a bit differently.
> +When you start the programmer application, the UI window of the programmer will
> +appear.
> +Click on green *Connect* button in the right upper corner of
> +the UI. This will connect programmer to the board.
> +Then click on *OB*
> +icon in the left upper corner. Actually this is hidden menu item which you
> +can un-hide by clicking on menu icon (three horizontal stripes) in the
> +upper left corner.
> +When you click on *OB* or *Option bytes* in un-hidden state, then
> +click on *User Configuration* in the options list and when the user
> +configuration list opens
> +unselect preselected *BCM4* item inside it to switch off M4 core or
> +unselect preselected *BCM7* item to switch off M7 core from
> +starting up. The action needs to be saved by clicking on *Apply* button
> +below the option table.
> +.. warning:: Be careful! Wrong setup in STM32H7 configuration may result in
> + *bricked* board.
> +Do not forget to disconnect the programmer application from the board by clicking on green *Disconnect* button
> +in the upper right corner and then close the programmer UI.
> +.. important:: If you keep programmer connected then you will not be able
> + to connect ST-Link GDB server to the board and upload RTEMS binary to
> + it.
> +STM32CubeIDE ST-Link GDB Server setup
> +In order to use STM provided ST-Link GDB server externally, that is
> +not from inside the IDE, we need to configure it. Please go to the
> +directory where you have installed STM32CubeIDE software. Look for
> +file containing *ST-LINK* string inside its name. Following shell
> +command sequence shows example about how to find it.
> + $ cd $HOME/sfw/stm32cubeide_1.8.0
> + $ find . -name 'ST-LINK*'
> + ./plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.200.202202231230/tools/bin/ST-LINK_gdbserver.sh
> + ./plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.100.202109301221/tools/bin/ST-LINK_gdbserver.sh
> +Notice that in this particular installation case we already have two
> +versions of GDB server installed. This is due to fact that version
> +1.8.0 of the IDE was later upgraded to 1.9.0 version. Anyway, we will choose
> +to use the latest one, or if there is only one, then the only one
> +installed. Please go to its *bin* directory. E.g.
> + $ cd plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.200.202202231230/tools/bin
> +Now, you will need to edit provided *config.txt* file inside the
> +directory. Use your favorite editor. Open the file and scrolls
> +down to its end. You will see following comment:
> +.. code-block:: none
> + # -cp <path> : Path to STM32CubeProgrammer
> + # Modify to correct path
> + # for STM32_Programmer_CLI executable
> + -cp
> +and here you will need to place path where your STM32CubeProgrammer is
> +installed directly behind the *-cp* parameter. E.g.
> + -cp /home/karel/sfw/stm32cubeide_1.8.0/plugins/com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.linux64_2.0.200.202202231230/tools/bin
> +Once you are done with it, you can save the file and close the
> +editor. Let's verify that GDB server is configured and running well by starting
> +it inside the shell. Please go inside the directory where
> +ST-LINK_gdbserver.sh is located and run it by:
> + $ ./ST-LINK_gdbserver.sh
> +If everything is all right and if you have board still connected to
> +the host computer then you should see output like following:
> + STMicroelectronics ST-LINK GDB server. Version 6.1.0
> + Copyright (c) 2022, STMicroelectronics. All rights reserved.
> + Starting server with the following options:
> + Persistent Mode : Enabled
> + LogFile Name : debug.log
> + Logging Level : 31
> + Listen Port Number : 61234
> + Status Refresh Delay : 15s
> + Verbose Mode : Disabled
> + SWD Debug : Enabled
> + COM frequency = 24000 kHz
> + Target connection mode: Default
> + Reading ROM table for AP 0 @0xe00fefd0
> + Hardware watchpoint supported by the target
> + ST-LINK Firmware version : V3J9M3
> + Device ID: 0x450
> + PC: 0x8028fa4
> + ST-LINK device status: HALT_MODE
> + ST-LINK detects target voltage = 3.28 V
> + ST-LINK device initialization OK
> + Stm32Device, pollAndNotify running...
> + SwvSrv state change: 0 -> 1
> + Waiting for connection on port 61235...
> + Waiting for debugger connection...
> + Waiting for connection on port 61234...
> +In output above you can see ST-Link GDB server waiting for debugger
> +connection. If this is the case in your case, then you can finish GDB server by hitting
> +*Ctrl-C* key combination.
> +RTEMS BSP samples build and run
> +We will use STM32H747I-DISCO board as an example hereafter. If you use
> +different board please adjust configuration steps in BSP configuration
> +accordingly. You should use BSP variant name specified for your
> +particular board in the table above.
> +Generate default configuration for the board:
> + $ ./waf bsp_defaults --rtems-bsps=arm/stm32h747i-disco > stm32h747i-disco.ini
> + Regenerate build specification cache (needs a couple of seconds)...
> +To run basic hello world or ticker samples you do not need to modify
> +default BSP configuration here as the compilation of basic RTEMS demo samples is
> +enabled by default. Let's continue with configuration of
> +the RTEMS source by running following command. Please change the RTEMS
> +tools installation prefix to suite your installation.
> + $ ./waf configure --rtems-bsps=arm/stm32h747i-disco --rtems-config=./stm32h747i-disco.ini --rtems-tools=$HOME/workspace/rtems-tools
> + Setting top to : /home/rtems/workspace/rtems
> + Setting out to : /home/rtems/workspace/rtems/build
> + Configure board support package (BSP) : arm/stm32h747i-disco
> + Checking for program 'arm-rtems6-gcc' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-gcc
> + Checking for program 'arm-rtems6-g++' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-g++
> + Checking for program 'arm-rtems6-ar' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-ar
> + Checking for program 'arm-rtems6-ld' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-ld
> + Checking for program 'ar' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-ar
> + Checking for program 'g++, c++' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-g++
> + Checking for program 'gas, gcc' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-gcc
> + Checking for program 'gcc, cc' : /home/rtems/workspace/rtems-tools/bin/arm-rtems6-gcc
> + Checking for asm flags '-MMD' : yes
> + Checking for c flags '-MMD' : yes
> + Checking for cxx flags '-MMD' : yes
> + 'configure' finished successfully (0.454s)
> +Build the BSP including samples using *build* command:
> + $ ./waf build
> +the command outputs a lot of information about files being compiled
> +and ends with output like:
> + Waf: Leaving directory `/home/rtems/workspace/rtems/build/arm/stm32h747i-disco'
> + 'build_arm/stm32h747i-disco' finished successfully (12.086s)
> +As your RTEMS BSP including samples is compiled, we will proceed with
> +running the hello world sample on the board now.
> +Open 3 shell windows for the test on the host computer. Also make sure
> +board is connected to the computer and is running. It does not matter
> +if manufacturer's demo is running there or if you navigated to some
> +demo part and left it there. ST-Link GDB server always takes over the
> +board when connected to it.
> +Start GDB server in the first window by switching to GDB server
> +directory and running the shell script. This is from testing machine
> +installation, the path to GDB server will probably look different in your
> +installation case.
> + $ cd sfw/stm32cubeide_1.8.0/plugins/com.st.stm32cube.ide.mcu.externaltools.stlink-gdb-server.linux64_2.0.200.202202231230/tools/bin
> + Device ID: 0x450
> + PC: 0x8028fa4
> +In second shell window you will need to run your terminal program and
> +connect to the board virtual serial port. Following steps describes
> +how to do that on the Ubuntu 20.04. The recommended way here is to use minicom. Let's install it
> +first by:
> + $ sudo apt install minicom
> +And run it with root privileges to be able to reach USB serial port
> +provided by board:
> + $ sudo minicom -s
> +The minicom is invoked with configuration menu open. Go into the
> +*Serial port setup* and hit *a* key to select *Serial Device*
> +setup. Change */dev/modem* from there into */dev/ttyACM0* and hit
> +*Enter* key. Hit *f* key to change hardware flow control from *Yes* to
> +*No*. When you are done with it, you can hit *Enter* key to finish
> +this part of configuration and then scrolls in menu to *Exit* and hit
> +*Enter* key on it. The minicom will switch to terminal mode with just
> +provided configuration.
> +In the third shell window navigate into the BSP build directory and start
> +RTEMS GDB with the hello.exe sample.
> + $ arm-rtems6-gdb build/arm/stm32h747i-disco/testsuites/samples/hello.exe
> + GNU gdb (GDB) 10.1.90.20210409-git
> + Copyright (C) 2021 Free Software Foundation, Inc.
> + License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> + This is free software: you are free to change and redistribute it.
> + There is NO WARRANTY, to the extent permitted by law.
> + Type "show copying" and "show warranty" for details.
> + This GDB was configured as "--host=x86_64-linux-gnu --target=arm-rtems6".
> + Type "show configuration" for configuration details.
> + For bug reporting instructions, please see:
> + <https://www.gnu.org/software/gdb/bugs/>.
> + Find the GDB manual and other documentation resources online at:
> + <http://www.gnu.org/software/gdb/documentation/>.
> + For help, type "help".
> + Type "apropos word" to search for commands related to "word"...
> + Reading symbols from build/arm/stm32h747i-disco/testsuites/samples/hello.exe...
> + (gdb)
> +Now, you need to connect GDB with the ST's GDB server by:
> + (gdb) target extended-remote :61234
> + Remote debugging using :61234
> + 0x08028fa4 in ?? ()
> + (gdb)
> +and finally you will need to load hello.exe binary into the board
> +memory by:
> + (gdb) load
> + Loading section .start, size 0x458 lma 0x24000000
> + Loading section .text, size 0xfca8 lma 0x24000480
> + Loading section .init, size 0xc lma 0x24010128
> + Loading section .fini, size 0xfecc lma 0x24010134
> + Loading section .rodata, size 0x1aab lma 0x24020000
> + Loading section .ARM.exidx, size 0x8 lma 0x24021aac
> + Loading section .eh_frame, size 0x4 lma 0x24021ab4
> + Loading section .init_array, size 0x4 lma 0x24021ab8
> + Loading section .fini_array, size 0x4 lma 0x24021abc
> + Loading section .rtemsroset, size 0x540 lma 0x24021ac0
> + Loading section .data, size 0x6a4 lma 0x24022000
> + Start address 0x24000400, load size 140923
> + Transfer rate: 684 KB/sec, 2562 bytes/write.
> + (gdb)
> +If everything went fine, then you can run the RTEMS binary by using
> +*cont* GDB command.
> +.. note:: Memory address values in the load output in the gdb shows
> + that we have loaded our application into the AXI
> + SRAM. Memory addresses will be different when loading into
> + different part of MCU memory.
> + (gdb) cont
> + Continuing.
> +Note that this command should never finish. To see the actual output
> +from RTEMS switch to
> +the second shell window with minicom (or other terminal emulation
> +program) running and you should see hello output
> +there:
> + *** BEGIN OF TEST HELLO WORLD ***
> + *** TEST VERSION: 6.0.0.50ce036cfbd9807a54af47eb60eadb6a33a9e82d
> + *** TEST STATE: EXPECTED_PASS
> + *** TEST BUILD:
> + *** TEST TOOLS: 10.3.1 20220224 (RTEMS 6, RSB 49e3dac17765fa82ce2f754da839638ee352f95c, Newlib 64b2081)
> + Hello World
> + *** END OF TEST HELLO WORLD ***
> + [ RTEMS shutdown ]
> + RTEMS version: 6.0.0.50ce036cfbd9807a54af47eb60eadb6a33a9e82d
> + RTEMS tools: 10.3.1 20220224 (RTEMS 6, RSB 49e3dac17765fa82ce2f754da839638ee352f95c, Newlib 64b2081)
> + executing thread ID: 0x08a010001
> +Since default RTEMS BSP configuration resets the board after run
> +immediately you can also see output from the immediately started ST
> +demo:
> + STM32H747I-DISCO_MB1248: Out Of the Box Demonstration V1.0.1 (Build Aug 22 2019 at 11:56:22)
> + STM32H747I-DISCO_MB1248: ST Menu Launcher V1.1.0
> + CPU running at 400MHz, Peripherals at 100MHz/100Mz
> +which is not a problem here at all. Later we can reconfigure BSP to
> +not reset board to prevent demo output here.
> +How to load binary file into the QSPI NOR
> +Connect the board to your host computer using micro-USB
> +cable. Start STM32CubeProgrammer and connect it to the board by
> +clicking on *Connect* button which is located in the right upper
> +corner of the programmer application UI. For accessing QSPI connected
> +memory you will need to configure programmer's external loader which
> +needs to match your target board. Click on *EL* icon (or *External
> +loaders*) in the left sidebar menu. Either go thorough the list of
> +external loaders or just search for your board by typing board
> +name (or part of the name) into the search bar located on top of the table view. When
> +you find your board, select it by selecting rectangle in the *Select*
> +table column. That's what is needed to make programmer ready to
> +program your board memory.
> +For uploading file to the board, you need to continue with clicking on
> +*Erase & programming* menu item in the left sidebar menu. It's second item
> +from the top. Now, let's select
> +your file to upload by clicking on *Browse* button and selecting the
> +file name from your host computer filesystem. The most important thing here is
> +to specify start address of flashing process. You need to do that by
> +typing start address into the *Start address* field.
> +.. note:: Usually external memory connected to QSPI has 0x90000000 starting
> + address.
> +When all is set you can click on *Start Programming* button.
> +.. important:: Cube programmer is very picky about files it shows in the file list. The only recognized suffixes are: elf, bin, hex and
> + similar. Also do not try to fool programmer by renaming let's say text
> + file to bin file. It'll detect file type as ascii text and will not
> + show it in the list of files to flash. So bin file type is really for
> + media types like avi, jpeg, mpeg or for binary dumps from elf
> + files. If you need to save text file, convert it to hex file first.
