[PATCH 2/2] tester/bsps: add stm32h7-stlink family configuration
Chris Johns
chrisj at rtems.org
Sun May 29 22:52:33 UTC 2022
On 30/5/2022 7:35 am, Karel Gardas wrote:
> Sponsored-By: Precidata
> tester/rtems/testing/bsps/stm32h7-stlink.ini | 43 ++++++++++++++++++++
> 1 file changed, 43 insertions(+)
> create mode 100644 tester/rtems/testing/bsps/stm32h7-stlink.ini
> diff --git a/tester/rtems/testing/bsps/stm32h7-stlink.ini b/tester/rtems/testing/bsps/stm32h7-stlink.ini
> new file mode 100644
> index 0000000..042ec7c
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/stm32h7-stlink.ini
> @@ -0,0 +1,43 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2015 On-Line Applications Research Corporation (OAR).
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The stm32h7 BSP family
> +[stm32h7-stlink]
> +bsp = stm32h7-stlink
> +arch = arm
> +tester = %{_rtscripts}/gdb.cfg
> +jobs = 1
> +gdb_script = bsp_gdb_script
> +requires: bsp_tty_dev, bsp_gdb_script, target_pretest_command, target_posttest_command
Should this be `requires =`?
> +bsp_gdb_script = target extended-remote :61234
> + load
> + cont
