[PATCH 1/7] bsps/arm: add CMSIS Cortex-M4 Core Peripheral Access Layer Header File
Karel Gardas karel at functional.vision
Sun May 29 23:36:02 UTC 2022
 bsps/arm/include/core_cm4.h | 1937 +++++++++++++++++++++++++++++++++++
 1 file changed, 1937 insertions(+)
 create mode 100644 bsps/arm/include/core_cm4.h
diff --git a/bsps/arm/include/core_cm4.h b/bsps/arm/include/core_cm4.h
new file mode 100644
index 0000000000..dc840ebf22
--- /dev/null
+++ b/bsps/arm/include/core_cm4.h
@@ -0,0 +1,1937 @@
+ * @file     core_cm4.h
+ * @brief    CMSIS Cortex-M4 Core Peripheral Access Layer Header File
+ * @version  V4.30
+ * @date     20. October 2015
+/* Copyright (c) 2009 - 2015 ARM LIMITED
+   All rights reserved.
+   Redistribution and use in source and binary forms, with or without
+   modification, are permitted provided that the following conditions are met:
+   - Redistributions of source code must retain the above copyright
+     notice, this list of conditions and the following disclaimer.
+   - Redistributions in binary form must reproduce the above copyright
+     notice, this list of conditions and the following disclaimer in the
+     documentation and/or other materials provided with the distribution.
+   - Neither the name of ARM nor the names of its contributors may be used
+     to endorse or promote products derived from this software without
+     specific prior written permission.
+   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+   AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+   IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+   ARE DISCLAIMED. IN NO EVENT SHALL COPYRIGHT HOLDERS AND CONTRIBUTORS BE
+   LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+   CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+   SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+   INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+   CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+   ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+   POSSIBILITY OF SUCH DAMAGE.
+#if   defined ( __ICCARM__ )
+ #pragma system_include         /* treat file as system include file for MISRA check */
+#elif defined(__ARMCC_VERSION) && (__ARMCC_VERSION >= 6010050)
+  #pragma clang system_header   /* treat file as system include file */
+#endif
+#ifndef __CORE_CM4_H_GENERIC
+#define __CORE_CM4_H_GENERIC
+#include <stdint.h>
+#ifdef __cplusplus
+ extern "C" {
+#endif
+  \page CMSIS_MISRA_Exceptions  MISRA-C:2004 Compliance Exceptions
+  CMSIS violates the following MISRA-C:2004 rules:
+   \li Required Rule 8.5, object/function definition in header file.<br>
+     Function definitions in header files are used to allow 'inlining'.
+   \li Required Rule 18.4, declaration of union type or object of union type: '{...}'.<br>
+     Unions are used for effective representation of core registers.
+   \li Advisory Rule 19.7, Function-like macro defined.<br>
+     Function-like macros are used to allow more efficient code.
+ *                 CMSIS definitions
+  \ingroup Cortex_M4
+/*  CMSIS CM4 definitions */
+#define __CM4_CMSIS_VERSION_MAIN  (0x04U)                                      /*!< [31:16] CMSIS HAL main version */
+#define __CM4_CMSIS_VERSION_SUB   (0x1EU)                                      /*!< [15:0]  CMSIS HAL sub version */
+#define __CM4_CMSIS_VERSION       ((__CM4_CMSIS_VERSION_MAIN << 16U) | \
+                                    __CM4_CMSIS_VERSION_SUB           )        /*!< CMSIS HAL version number */
+#define __CORTEX_M                (0x04U)                                      /*!< Cortex-M Core */
+#if   defined ( __CC_ARM )
+  #define __ASM            __asm                                      /*!< asm keyword for ARM Compiler */
+  #define __INLINE         __inline                                   /*!< inline keyword for ARM Compiler */
+  #define __STATIC_INLINE  static __inline
+#elif defined ( __GNUC__ )
+  #define __ASM            __asm                                      /*!< asm keyword for GNU Compiler */
+  #define __INLINE         inline                                     /*!< inline keyword for GNU Compiler */
+  #define __STATIC_INLINE  static inline
+#elif defined ( __ICCARM__ )
+  #define __ASM            __asm                                      /*!< asm keyword for IAR Compiler */
+  #define __INLINE         inline                                     /*!< inline keyword for IAR Compiler. Only available in High optimization mode! */
+#elif defined ( __TMS470__ )
+  #define __ASM            __asm                                      /*!< asm keyword for TI CCS Compiler */
+#elif defined ( __TASKING__ )
+  #define __ASM            __asm                                      /*!< asm keyword for TASKING Compiler */
+  #define __INLINE         inline                                     /*!< inline keyword for TASKING Compiler */
+#elif defined ( __CSMC__ )
+  #define __packed
+  #define __ASM            _asm                                      /*!< asm keyword for COSMIC Compiler */
+  #define __INLINE         inline                                    /*!< inline keyword for COSMIC Compiler. Use -pc99 on compile line */
+#else
+  #error Unknown compiler
+#endif
+/** __FPU_USED indicates whether an FPU is used or not.
+    For this, __FPU_PRESENT has to be checked prior to making use of FPU specific registers and functions.
+  #if defined __TARGET_FPU_VFP
+    #if (__FPU_PRESENT == 1U)
+      #define __FPU_USED       1U
+    #else
+      #error "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
+      #define __FPU_USED       0U
+    #endif
+  #else
+  #endif
+  #if defined __ARM_PCS_VFP
+    #if (__FPU_PRESENT == 1)
+    #else
+      #warning "Compiler generates FPU instructions for a device without an FPU (check __FPU_PRESENT)"
+    #endif
+  #else
+  #endif
+  #if defined (__VFP_FP__) && !defined(__SOFTFP__)
+    #else
+    #endif
+  #else
+  #endif
+  #if defined __ARMVFP__
+    #else
+    #endif
+  #else
+  #endif
+  #if defined __TI_VFP_SUPPORT__
+    #else
+    #endif
+  #else
+  #endif
+  #if defined __FPU_VFP__
+    #else
+    #endif
+  #else
+  #endif
+  #if ( __CSMC__ & 0x400U)
+    #else
+    #endif
+  #else
+  #endif
+#endif
+#include "core_cmInstr.h"                /* Core Instruction Access */
+#include "core_cmFunc.h"                 /* Core Function Access */
+#include "core_cmSimd.h"                 /* Compiler specific SIMD Intrinsics */
+#ifdef __cplusplus
+#endif
+#endif /* __CORE_CM4_H_GENERIC */
+#ifndef __CMSIS_GENERIC
+#ifndef __CORE_CM4_H_DEPENDANT
+#define __CORE_CM4_H_DEPENDANT
+#ifdef __cplusplus
+ extern "C" {
+#endif
+/* check device defines and use defaults */
+#if defined __CHECK_DEVICE_DEFINES
+  #ifndef __CM4_REV
+    #define __CM4_REV               0x0000U
+    #warning "__CM4_REV not defined in device header file; using default!"
+  #endif
+  #ifndef __FPU_PRESENT
+    #define __FPU_PRESENT             0U
+    #warning "__FPU_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __MPU_PRESENT
+    #define __MPU_PRESENT             0U
+    #warning "__MPU_PRESENT not defined in device header file; using default!"
+  #endif
+  #ifndef __NVIC_PRIO_BITS
+    #define __NVIC_PRIO_BITS          4U
+    #warning "__NVIC_PRIO_BITS not defined in device header file; using default!"
+  #endif
+  #ifndef __Vendor_SysTickConfig
+    #define __Vendor_SysTickConfig    0U
+    #warning "__Vendor_SysTickConfig not defined in device header file; using default!"
+  #endif
+#endif
+/* IO definitions (access restrictions to peripheral registers) */
+    \defgroup CMSIS_glob_defs CMSIS Global Defines
+    <strong>IO Type Qualifiers</strong> are used
+    \li to specify the access to peripheral variables.
+    \li for automatic generation of peripheral register debug information.
+#ifdef __cplusplus
+  #define   __I     volatile             /*!< Defines 'read only' permissions */
+#else
+  #define   __I     volatile const       /*!< Defines 'read only' permissions */
+#endif
+#define     __O     volatile             /*!< Defines 'write only' permissions */
+#define     __IO    volatile             /*!< Defines 'read / write' permissions */
+/* following defines should be used for structure members */
+#define     __IM     volatile const      /*! Defines 'read only' structure member permissions */
+#define     __OM     volatile            /*! Defines 'write only' structure member permissions */
+#define     __IOM    volatile            /*! Defines 'read / write' structure member permissions */
+/*@} end of group Cortex_M4 */
+ *                 Register Abstraction
+  Core Register contain:
+  - Core Register
+  - Core NVIC Register
+  - Core SCB Register
+  - Core SysTick Register
+  - Core Debug Register
+  - Core MPU Register
+  - Core FPU Register
+  \defgroup CMSIS_core_register Defines and Type Definitions
+  \brief Type definitions and defines for Cortex-M processor based devices.
+  \ingroup    CMSIS_core_register
+  \defgroup   CMSIS_CORE  Status and Control Registers
+  \brief      Core Register type definitions.
+  \brief  Union type to access the Application Program Status Register (APSR).
+typedef union
+  struct
+    uint32_t _reserved0:16;              /*!< bit:  0..15  Reserved */
+    uint32_t GE:4;                       /*!< bit: 16..19  Greater than or Equal flags */
+    uint32_t _reserved1:7;               /*!< bit: 20..26  Reserved */
+    uint32_t Q:1;                        /*!< bit:     27  Saturation condition flag */
+    uint32_t V:1;                        /*!< bit:     28  Overflow condition code flag */
+    uint32_t C:1;                        /*!< bit:     29  Carry condition code flag */
+    uint32_t Z:1;                        /*!< bit:     30  Zero condition code flag */
+    uint32_t N:1;                        /*!< bit:     31  Negative condition code flag */
+  } b;                                   /*!< Structure used for bit  access */
+  uint32_t w;                            /*!< Type      used for word access */
+} APSR_Type;
+/* APSR Register Definitions */
+#define APSR_N_Pos                         31U                                            /*!< APSR: N Position */
+#define APSR_N_Msk                         (1UL << APSR_N_Pos)                            /*!< APSR: N Mask */
+#define APSR_Z_Pos                         30U                                            /*!< APSR: Z Position */
+#define APSR_Z_Msk                         (1UL << APSR_Z_Pos)                            /*!< APSR: Z Mask */
+#define APSR_C_Pos                         29U                                            /*!< APSR: C Position */
+#define APSR_C_Msk                         (1UL << APSR_C_Pos)                            /*!< APSR: C Mask */
+#define APSR_V_Pos                         28U                                            /*!< APSR: V Position */
+#define APSR_V_Msk                         (1UL << APSR_V_Pos)                            /*!< APSR: V Mask */
+#define APSR_Q_Pos                         27U                                            /*!< APSR: Q Position */
+#define APSR_Q_Msk                         (1UL << APSR_Q_Pos)                            /*!< APSR: Q Mask */
+#define APSR_GE_Pos                        16U                                            /*!< APSR: GE Position */
+#define APSR_GE_Msk                        (0xFUL << APSR_GE_Pos)                         /*!< APSR: GE Mask */
+  \brief  Union type to access the Interrupt Program Status Register (IPSR).
+typedef union
+  struct
+    uint32_t ISR:9;                      /*!< bit:  0.. 8  Exception number */
+    uint32_t _reserved0:23;              /*!< bit:  9..31  Reserved */
+} IPSR_Type;
+/* IPSR Register Definitions */
+#define IPSR_ISR_Pos                        0U                                            /*!< IPSR: ISR Position */
+#define IPSR_ISR_Msk                       (0x1FFUL /*<< IPSR_ISR_Pos*/)                  /*!< IPSR: ISR Mask */
+  \brief  Union type to access the Special-Purpose Program Status Registers (xPSR).
+typedef union
+  struct
+    uint32_t _reserved0:7;               /*!< bit:  9..15  Reserved */
+    uint32_t _reserved1:4;               /*!< bit: 20..23  Reserved */
+    uint32_t T:1;                        /*!< bit:     24  Thumb bit        (read 0) */
+    uint32_t IT:2;                       /*!< bit: 25..26  saved IT state   (read 0) */
+} xPSR_Type;
+/* xPSR Register Definitions */
+#define xPSR_N_Pos                         31U                                            /*!< xPSR: N Position */
+#define xPSR_N_Msk                         (1UL << xPSR_N_Pos)                            /*!< xPSR: N Mask */
+#define xPSR_Z_Pos                         30U                                            /*!< xPSR: Z Position */
+#define xPSR_Z_Msk                         (1UL << xPSR_Z_Pos)                            /*!< xPSR: Z Mask */
+#define xPSR_C_Pos                         29U                                            /*!< xPSR: C Position */
+#define xPSR_C_Msk                         (1UL << xPSR_C_Pos)                            /*!< xPSR: C Mask */
+#define xPSR_V_Pos                         28U                                            /*!< xPSR: V Position */
+#define xPSR_V_Msk                         (1UL << xPSR_V_Pos)                            /*!< xPSR: V Mask */
+#define xPSR_Q_Pos                         27U                                            /*!< xPSR: Q Position */
+#define xPSR_Q_Msk                         (1UL << xPSR_Q_Pos)                            /*!< xPSR: Q Mask */
+#define xPSR_IT_Pos                        25U                                            /*!< xPSR: IT Position */
+#define xPSR_IT_Msk                        (3UL << xPSR_IT_Pos)                           /*!< xPSR: IT Mask */
+#define xPSR_T_Pos                         24U                                            /*!< xPSR: T Position */
+#define xPSR_T_Msk                         (1UL << xPSR_T_Pos)                            /*!< xPSR: T Mask */
+#define xPSR_GE_Pos                        16U                                            /*!< xPSR: GE Position */
+#define xPSR_GE_Msk                        (0xFUL << xPSR_GE_Pos)                         /*!< xPSR: GE Mask */
+#define xPSR_ISR_Pos                        0U                                            /*!< xPSR: ISR Position */
+#define xPSR_ISR_Msk                       (0x1FFUL /*<< xPSR_ISR_Pos*/)                  /*!< xPSR: ISR Mask */
+  \brief  Union type to access the Control Registers (CONTROL).
+typedef union
+  struct
+    uint32_t nPRIV:1;                    /*!< bit:      0  Execution privilege in Thread mode */
+    uint32_t SPSEL:1;                    /*!< bit:      1  Stack to be used */
+    uint32_t FPCA:1;                     /*!< bit:      2  FP extension active flag */
+    uint32_t _reserved0:29;              /*!< bit:  3..31  Reserved */
+} CONTROL_Type;
+/* CONTROL Register Definitions */
+#define CONTROL_FPCA_Pos                    2U                                            /*!< CONTROL: FPCA Position */
+#define CONTROL_FPCA_Msk                   (1UL << CONTROL_FPCA_Pos)                      /*!< CONTROL: FPCA Mask */
+#define CONTROL_SPSEL_Pos                   1U                                            /*!< CONTROL: SPSEL Position */
+#define CONTROL_SPSEL_Msk                  (1UL << CONTROL_SPSEL_Pos)                     /*!< CONTROL: SPSEL Mask */
+#define CONTROL_nPRIV_Pos                   0U                                            /*!< CONTROL: nPRIV Position */
+#define CONTROL_nPRIV_Msk                  (1UL /*<< CONTROL_nPRIV_Pos*/)                 /*!< CONTROL: nPRIV Mask */
+/*@} end of group CMSIS_CORE */
+  \defgroup   CMSIS_NVIC  Nested Vectored Interrupt Controller (NVIC)
+  \brief      Type definitions for the NVIC Registers
+  \brief  Structure type to access the Nested Vectored Interrupt Controller (NVIC).
+typedef struct
+  __IOM uint32_t ISER[8U];               /*!< Offset: 0x000 (R/W)  Interrupt Set Enable Register */
+        uint32_t RESERVED0[24U];
+  __IOM uint32_t ICER[8U];               /*!< Offset: 0x080 (R/W)  Interrupt Clear Enable Register */
+        uint32_t RSERVED1[24U];
+  __IOM uint32_t ISPR[8U];               /*!< Offset: 0x100 (R/W)  Interrupt Set Pending Register */
+        uint32_t RESERVED2[24U];
+  __IOM uint32_t ICPR[8U];               /*!< Offset: 0x180 (R/W)  Interrupt Clear Pending Register */
+        uint32_t RESERVED3[24U];
+  __IOM uint32_t IABR[8U];               /*!< Offset: 0x200 (R/W)  Interrupt Active bit Register */
+        uint32_t RESERVED4[56U];
+  __IOM uint8_t  IP[240U];               /*!< Offset: 0x300 (R/W)  Interrupt Priority Register (8Bit wide) */
+        uint32_t RESERVED5[644U];
+  __OM  uint32_t STIR;                   /*!< Offset: 0xE00 ( /W)  Software Trigger Interrupt Register */
+}  NVIC_Type;
+/* Software Triggered Interrupt Register Definitions */
+#define NVIC_STIR_INTID_Pos                 0U                                         /*!< STIR: INTLINESNUM Position */
+#define NVIC_STIR_INTID_Msk                (0x1FFUL /*<< NVIC_STIR_INTID_Pos*/)        /*!< STIR: INTLINESNUM Mask */
+/*@} end of group CMSIS_NVIC */
+  \defgroup CMSIS_SCB     System Control Block (SCB)
+  \brief    Type definitions for the System Control Block Registers
+  \brief  Structure type to access the System Control Block (SCB).
+typedef struct
+  __IM  uint32_t CPUID;                  /*!< Offset: 0x000 (R/ )  CPUID Base Register */
+  __IOM uint32_t ICSR;                   /*!< Offset: 0x004 (R/W)  Interrupt Control and State Register */
+  __IOM uint32_t VTOR;                   /*!< Offset: 0x008 (R/W)  Vector Table Offset Register */
+  __IOM uint32_t AIRCR;                  /*!< Offset: 0x00C (R/W)  Application Interrupt and Reset Control Register */
+  __IOM uint32_t SCR;                    /*!< Offset: 0x010 (R/W)  System Control Register */
+  __IOM uint32_t CCR;                    /*!< Offset: 0x014 (R/W)  Configuration Control Register */
+  __IOM uint8_t  SHP[12U];               /*!< Offset: 0x018 (R/W)  System Handlers Priority Registers (4-7, 8-11, 12-15) */
+  __IOM uint32_t SHCSR;                  /*!< Offset: 0x024 (R/W)  System Handler Control and State Register */
+  __IOM uint32_t CFSR;                   /*!< Offset: 0x028 (R/W)  Configurable Fault Status Register */
+  __IOM uint32_t HFSR;                   /*!< Offset: 0x02C (R/W)  HardFault Status Register */
+  __IOM uint32_t DFSR;                   /*!< Offset: 0x030 (R/W)  Debug Fault Status Register */
+  __IOM uint32_t MMFAR;                  /*!< Offset: 0x034 (R/W)  MemManage Fault Address Register */
+  __IOM uint32_t BFAR;                   /*!< Offset: 0x038 (R/W)  BusFault Address Register */
+  __IOM uint32_t AFSR;                   /*!< Offset: 0x03C (R/W)  Auxiliary Fault Status Register */
+  __IM  uint32_t PFR[2U];                /*!< Offset: 0x040 (R/ )  Processor Feature Register */
+  __IM  uint32_t DFR;                    /*!< Offset: 0x048 (R/ )  Debug Feature Register */
+  __IM  uint32_t ADR;                    /*!< Offset: 0x04C (R/ )  Auxiliary Feature Register */
+  __IM  uint32_t MMFR[4U];               /*!< Offset: 0x050 (R/ )  Memory Model Feature Register */
+  __IM  uint32_t ISAR[5U];               /*!< Offset: 0x060 (R/ )  Instruction Set Attributes Register */
+        uint32_t RESERVED0[5U];
+  __IOM uint32_t CPACR;                  /*!< Offset: 0x088 (R/W)  Coprocessor Access Control Register */
+} SCB_Type;
+/* SCB CPUID Register Definitions */
+#define SCB_CPUID_IMPLEMENTER_Pos          24U                                            /*!< SCB CPUID: IMPLEMENTER Position */
+#define SCB_CPUID_IMPLEMENTER_Msk          (0xFFUL << SCB_CPUID_IMPLEMENTER_Pos)          /*!< SCB CPUID: IMPLEMENTER Mask */
+#define SCB_CPUID_VARIANT_Pos              20U                                            /*!< SCB CPUID: VARIANT Position */
+#define SCB_CPUID_VARIANT_Msk              (0xFUL << SCB_CPUID_VARIANT_Pos)               /*!< SCB CPUID: VARIANT Mask */
+#define SCB_CPUID_ARCHITECTURE_Pos         16U                                            /*!< SCB CPUID: ARCHITECTURE Position */
+#define SCB_CPUID_ARCHITECTURE_Msk         (0xFUL << SCB_CPUID_ARCHITECTURE_Pos)          /*!< SCB CPUID: ARCHITECTURE Mask */
+#define SCB_CPUID_PARTNO_Pos                4U                                            /*!< SCB CPUID: PARTNO Position */
+#define SCB_CPUID_PARTNO_Msk               (0xFFFUL << SCB_CPUID_PARTNO_Pos)              /*!< SCB CPUID: PARTNO Mask */
+#define SCB_CPUID_REVISION_Pos              0U                                            /*!< SCB CPUID: REVISION Position */
+#define SCB_CPUID_REVISION_Msk             (0xFUL /*<< SCB_CPUID_REVISION_Pos*/)          /*!< SCB CPUID: REVISION Mask */
+/* SCB Interrupt Control State Register Definitions */
+#define SCB_ICSR_NMIPENDSET_Pos            31U                                            /*!< SCB ICSR: NMIPENDSET Position */
+#define SCB_ICSR_NMIPENDSET_Msk            (1UL << SCB_ICSR_NMIPENDSET_Pos)               /*!< SCB ICSR: NMIPENDSET Mask */
+#define SCB_ICSR_PENDSVSET_Pos             28U                                            /*!< SCB ICSR: PENDSVSET Position */
+#define SCB_ICSR_PENDSVSET_Msk             (1UL << SCB_ICSR_PENDSVSET_Pos)                /*!< SCB ICSR: PENDSVSET Mask */
+#define SCB_ICSR_PENDSVCLR_Pos             27U                                            /*!< SCB ICSR: PENDSVCLR Position */
+#define SCB_ICSR_PENDSVCLR_Msk             (1UL << SCB_ICSR_PENDSVCLR_Pos)                /*!< SCB ICSR: PENDSVCLR Mask */
+#define SCB_ICSR_PENDSTSET_Pos             26U                                            /*!< SCB ICSR: PENDSTSET Position */
+#define SCB_ICSR_PENDSTSET_Msk             (1UL << SCB_ICSR_PENDSTSET_Pos)                /*!< SCB ICSR: PENDSTSET Mask */
+#define SCB_ICSR_PENDSTCLR_Pos             25U                                            /*!< SCB ICSR: PENDSTCLR Position */
+#define SCB_ICSR_PENDSTCLR_Msk             (1UL << SCB_ICSR_PENDSTCLR_Pos)                /*!< SCB ICSR: PENDSTCLR Mask */
+#define SCB_ICSR_ISRPREEMPT_Pos            23U                                            /*!< SCB ICSR: ISRPREEMPT Position */
+#define SCB_ICSR_ISRPREEMPT_Msk            (1UL << SCB_ICSR_ISRPREEMPT_Pos)               /*!< SCB ICSR: ISRPREEMPT Mask */
+#define SCB_ICSR_ISRPENDING_Pos            22U                                            /*!< SCB ICSR: ISRPENDING Position */
+#define SCB_ICSR_ISRPENDING_Msk            (1UL << SCB_ICSR_ISRPENDING_Pos)               /*!< SCB ICSR: ISRPENDING Mask */
+#define SCB_ICSR_VECTPENDING_Pos           12U                                            /*!< SCB ICSR: VECTPENDING Position */
+#define SCB_ICSR_VECTPENDING_Msk           (0x1FFUL << SCB_ICSR_VECTPENDING_Pos)          /*!< SCB ICSR: VECTPENDING Mask */
+#define SCB_ICSR_RETTOBASE_Pos             11U                                            /*!< SCB ICSR: RETTOBASE Position */
+#define SCB_ICSR_RETTOBASE_Msk             (1UL << SCB_ICSR_RETTOBASE_Pos)                /*!< SCB ICSR: RETTOBASE Mask */
+#define SCB_ICSR_VECTACTIVE_Pos             0U                                            /*!< SCB ICSR: VECTACTIVE Position */
+#define SCB_ICSR_VECTACTIVE_Msk            (0x1FFUL /*<< SCB_ICSR_VECTACTIVE_Pos*/)       /*!< SCB ICSR: VECTACTIVE Mask */
+/* SCB Vector Table Offset Register Definitions */
+#define SCB_VTOR_TBLOFF_Pos                 7U                                            /*!< SCB VTOR: TBLOFF Position */
+#define SCB_VTOR_TBLOFF_Msk                (0x1FFFFFFUL << SCB_VTOR_TBLOFF_Pos)           /*!< SCB VTOR: TBLOFF Mask */
+/* SCB Application Interrupt and Reset Control Register Definitions */
+#define SCB_AIRCR_VECTKEY_Pos              16U                                            /*!< SCB AIRCR: VECTKEY Position */
+#define SCB_AIRCR_VECTKEY_Msk              (0xFFFFUL << SCB_AIRCR_VECTKEY_Pos)            /*!< SCB AIRCR: VECTKEY Mask */
+#define SCB_AIRCR_VECTKEYSTAT_Pos          16U                                            /*!< SCB AIRCR: VECTKEYSTAT Position */
+#define SCB_AIRCR_VECTKEYSTAT_Msk          (0xFFFFUL << SCB_AIRCR_VECTKEYSTAT_Pos)        /*!< SCB AIRCR: VECTKEYSTAT Mask */
+#define SCB_AIRCR_ENDIANESS_Pos            15U                                            /*!< SCB AIRCR: ENDIANESS Position */
+#define SCB_AIRCR_ENDIANESS_Msk            (1UL << SCB_AIRCR_ENDIANESS_Pos)               /*!< SCB AIRCR: ENDIANESS Mask */
+#define SCB_AIRCR_PRIGROUP_Pos              8U                                            /*!< SCB AIRCR: PRIGROUP Position */
+#define SCB_AIRCR_PRIGROUP_Msk             (7UL << SCB_AIRCR_PRIGROUP_Pos)                /*!< SCB AIRCR: PRIGROUP Mask */
+#define SCB_AIRCR_SYSRESETREQ_Pos           2U                                            /*!< SCB AIRCR: SYSRESETREQ Position */
+#define SCB_AIRCR_SYSRESETREQ_Msk          (1UL << SCB_AIRCR_SYSRESETREQ_Pos)             /*!< SCB AIRCR: SYSRESETREQ Mask */
+#define SCB_AIRCR_VECTCLRACTIVE_Pos         1U                                            /*!< SCB AIRCR: VECTCLRACTIVE Position */
+#define SCB_AIRCR_VECTCLRACTIVE_Msk        (1UL << SCB_AIRCR_VECTCLRACTIVE_Pos)           /*!< SCB AIRCR: VECTCLRACTIVE Mask */
+#define SCB_AIRCR_VECTRESET_Pos             0U                                            /*!< SCB AIRCR: VECTRESET Position */
+#define SCB_AIRCR_VECTRESET_Msk            (1UL /*<< SCB_AIRCR_VECTRESET_Pos*/)           /*!< SCB AIRCR: VECTRESET Mask */
+/* SCB System Control Register Definitions */
+#define SCB_SCR_SEVONPEND_Pos               4U                                            /*!< SCB SCR: SEVONPEND Position */
+#define SCB_SCR_SEVONPEND_Msk              (1UL << SCB_SCR_SEVONPEND_Pos)                 /*!< SCB SCR: SEVONPEND Mask */
+#define SCB_SCR_SLEEPDEEP_Pos               2U                                            /*!< SCB SCR: SLEEPDEEP Position */
+#define SCB_SCR_SLEEPDEEP_Msk              (1UL << SCB_SCR_SLEEPDEEP_Pos)                 /*!< SCB SCR: SLEEPDEEP Mask */
+#define SCB_SCR_SLEEPONEXIT_Pos             1U                                            /*!< SCB SCR: SLEEPONEXIT Position */
+#define SCB_SCR_SLEEPONEXIT_Msk            (1UL << SCB_SCR_SLEEPONEXIT_Pos)               /*!< SCB SCR: SLEEPONEXIT Mask */
+/* SCB Configuration Control Register Definitions */
+#define SCB_CCR_STKALIGN_Pos                9U                                            /*!< SCB CCR: STKALIGN Position */
+#define SCB_CCR_STKALIGN_Msk               (1UL << SCB_CCR_STKALIGN_Pos)                  /*!< SCB CCR: STKALIGN Mask */
+#define SCB_CCR_BFHFNMIGN_Pos               8U                                            /*!< SCB CCR: BFHFNMIGN Position */
+#define SCB_CCR_BFHFNMIGN_Msk              (1UL << SCB_CCR_BFHFNMIGN_Pos)                 /*!< SCB CCR: BFHFNMIGN Mask */
+#define SCB_CCR_DIV_0_TRP_Pos               4U                                            /*!< SCB CCR: DIV_0_TRP Position */
+#define SCB_CCR_DIV_0_TRP_Msk              (1UL << SCB_CCR_DIV_0_TRP_Pos)                 /*!< SCB CCR: DIV_0_TRP Mask */
+#define SCB_CCR_UNALIGN_TRP_Pos             3U                                            /*!< SCB CCR: UNALIGN_TRP Position */
+#define SCB_CCR_UNALIGN_TRP_Msk            (1UL << SCB_CCR_UNALIGN_TRP_Pos)               /*!< SCB CCR: UNALIGN_TRP Mask */
+#define SCB_CCR_USERSETMPEND_Pos            1U                                            /*!< SCB CCR: USERSETMPEND Position */
+#define SCB_CCR_USERSETMPEND_Msk           (1UL << SCB_CCR_USERSETMPEND_Pos)              /*!< SCB CCR: USERSETMPEND Mask */
+#define SCB_CCR_NONBASETHRDENA_Pos          0U                                            /*!< SCB CCR: NONBASETHRDENA Position */
+#define SCB_CCR_NONBASETHRDENA_Msk         (1UL /*<< SCB_CCR_NONBASETHRDENA_Pos*/)        /*!< SCB CCR: NONBASETHRDENA Mask */
+/* SCB System Handler Control and State Register Definitions */
+#define SCB_SHCSR_USGFAULTENA_Pos          18U                                            /*!< SCB SHCSR: USGFAULTENA Position */
+#define SCB_SHCSR_USGFAULTENA_Msk          (1UL << SCB_SHCSR_USGFAULTENA_Pos)             /*!< SCB SHCSR: USGFAULTENA Mask */
+#define SCB_SHCSR_BUSFAULTENA_Pos          17U                                            /*!< SCB SHCSR: BUSFAULTENA Position */
+#define SCB_SHCSR_BUSFAULTENA_Msk          (1UL << SCB_SHCSR_BUSFAULTENA_Pos)             /*!< SCB SHCSR: BUSFAULTENA Mask */
+#define SCB_SHCSR_MEMFAULTENA_Pos          16U                                            /*!< SCB SHCSR: MEMFAULTENA Position */
+#define SCB_SHCSR_MEMFAULTENA_Msk          (1UL << SCB_SHCSR_MEMFAULTENA_Pos)             /*!< SCB SHCSR: MEMFAULTENA Mask */
+#define SCB_SHCSR_SVCALLPENDED_Pos         15U                                            /*!< SCB SHCSR: SVCALLPENDED Position */
+#define SCB_SHCSR_SVCALLPENDED_Msk         (1UL << SCB_SHCSR_SVCALLPENDED_Pos)            /*!< SCB SHCSR: SVCALLPENDED Mask */
+#define SCB_SHCSR_BUSFAULTPENDED_Pos       14U                                            /*!< SCB SHCSR: BUSFAULTPENDED Position */
+#define SCB_SHCSR_BUSFAULTPENDED_Msk       (1UL << SCB_SHCSR_BUSFAULTPENDED_Pos)          /*!< SCB SHCSR: BUSFAULTPENDED Mask */
+#define SCB_SHCSR_MEMFAULTPENDED_Pos       13U                                            /*!< SCB SHCSR: MEMFAULTPENDED Position */
+#define SCB_SHCSR_MEMFAULTPENDED_Msk       (1UL << SCB_SHCSR_MEMFAULTPENDED_Pos)          /*!< SCB SHCSR: MEMFAULTPENDED Mask */
+#define SCB_SHCSR_USGFAULTPENDED_Pos       12U                                            /*!< SCB SHCSR: USGFAULTPENDED Position */
+#define SCB_SHCSR_USGFAULTPENDED_Msk       (1UL << SCB_SHCSR_USGFAULTPENDED_Pos)          /*!< SCB SHCSR: USGFAULTPENDED Mask */
+#define SCB_SHCSR_SYSTICKACT_Pos           11U                                            /*!< SCB SHCSR: SYSTICKACT Position */
+#define SCB_SHCSR_SYSTICKACT_Msk           (1UL << SCB_SHCSR_SYSTICKACT_Pos)              /*!< SCB SHCSR: SYSTICKACT Mask */
+#define SCB_SHCSR_PENDSVACT_Pos            10U                                            /*!< SCB SHCSR: PENDSVACT Position */
+#define SCB_SHCSR_PENDSVACT_Msk            (1UL << SCB_SHCSR_PENDSVACT_Pos)               /*!< SCB SHCSR: PENDSVACT Mask */
+#define SCB_SHCSR_MONITORACT_Pos            8U                                            /*!< SCB SHCSR: MONITORACT Position */
+#define SCB_SHCSR_MONITORACT_Msk           (1UL << SCB_SHCSR_MONITORACT_Pos)              /*!< SCB SHCSR: MONITORACT Mask */
+#define SCB_SHCSR_SVCALLACT_Pos             7U                                            /*!< SCB SHCSR: SVCALLACT Position */
+#define SCB_SHCSR_SVCALLACT_Msk            (1UL << SCB_SHCSR_SVCALLACT_Pos)               /*!< SCB SHCSR: SVCALLACT Mask */
+#define SCB_SHCSR_USGFAULTACT_Pos           3U                                            /*!< SCB SHCSR: USGFAULTACT Position */
+#define SCB_SHCSR_USGFAULTACT_Msk          (1UL << SCB_SHCSR_USGFAULTACT_Pos)             /*!< SCB SHCSR: USGFAULTACT Mask */
+#define SCB_SHCSR_BUSFAULTACT_Pos           1U                                            /*!< SCB SHCSR: BUSFAULTACT Position */
+#define SCB_SHCSR_BUSFAULTACT_Msk          (1UL << SCB_SHCSR_BUSFAULTACT_Pos)             /*!< SCB SHCSR: BUSFAULTACT Mask */
+#define SCB_SHCSR_MEMFAULTACT_Pos           0U                                            /*!< SCB SHCSR: MEMFAULTACT Position */
+#define SCB_SHCSR_MEMFAULTACT_Msk          (1UL /*<< SCB_SHCSR_MEMFAULTACT_Pos*/)         /*!< SCB SHCSR: MEMFAULTACT Mask */
+/* SCB Configurable Fault Status Register Definitions */
+#define SCB_CFSR_USGFAULTSR_Pos            16U                                            /*!< SCB CFSR: Usage Fault Status Register Position */
+#define SCB_CFSR_USGFAULTSR_Msk            (0xFFFFUL << SCB_CFSR_USGFAULTSR_Pos)          /*!< SCB CFSR: Usage Fault Status Register Mask */
+#define SCB_CFSR_BUSFAULTSR_Pos             8U                                            /*!< SCB CFSR: Bus Fault Status Register Position */
+#define SCB_CFSR_BUSFAULTSR_Msk            (0xFFUL << SCB_CFSR_BUSFAULTSR_Pos)            /*!< SCB CFSR: Bus Fault Status Register Mask */
+#define SCB_CFSR_MEMFAULTSR_Pos             0U                                            /*!< SCB CFSR: Memory Manage Fault Status Register Position */
+#define SCB_CFSR_MEMFAULTSR_Msk            (0xFFUL /*<< SCB_CFSR_MEMFAULTSR_Pos*/)        /*!< SCB CFSR: Memory Manage Fault Status Register Mask */
+/* SCB Hard Fault Status Register Definitions */
+#define SCB_HFSR_DEBUGEVT_Pos              31U                                            /*!< SCB HFSR: DEBUGEVT Position */
+#define SCB_HFSR_DEBUGEVT_Msk              (1UL << SCB_HFSR_DEBUGEVT_Pos)                 /*!< SCB HFSR: DEBUGEVT Mask */
+#define SCB_HFSR_FORCED_Pos                30U                                            /*!< SCB HFSR: FORCED Position */
+#define SCB_HFSR_FORCED_Msk                (1UL << SCB_HFSR_FORCED_Pos)                   /*!< SCB HFSR: FORCED Mask */
+#define SCB_HFSR_VECTTBL_Pos                1U                                            /*!< SCB HFSR: VECTTBL Position */
+#define SCB_HFSR_VECTTBL_Msk               (1UL << SCB_HFSR_VECTTBL_Pos)                  /*!< SCB HFSR: VECTTBL Mask */
+/* SCB Debug Fault Status Register Definitions */
+#define SCB_DFSR_EXTERNAL_Pos               4U                                            /*!< SCB DFSR: EXTERNAL Position */
+#define SCB_DFSR_EXTERNAL_Msk              (1UL << SCB_DFSR_EXTERNAL_Pos)                 /*!< SCB DFSR: EXTERNAL Mask */
+#define SCB_DFSR_VCATCH_Pos                 3U                                            /*!< SCB DFSR: VCATCH Position */
+#define SCB_DFSR_VCATCH_Msk                (1UL << SCB_DFSR_VCATCH_Pos)                   /*!< SCB DFSR: VCATCH Mask */
+#define SCB_DFSR_DWTTRAP_Pos                2U                                            /*!< SCB DFSR: DWTTRAP Position */
+#define SCB_DFSR_DWTTRAP_Msk               (1UL << SCB_DFSR_DWTTRAP_Pos)                  /*!< SCB DFSR: DWTTRAP Mask */
+#define SCB_DFSR_BKPT_Pos                   1U                                            /*!< SCB DFSR: BKPT Position */
+#define SCB_DFSR_BKPT_Msk                  (1UL << SCB_DFSR_BKPT_Pos)                     /*!< SCB DFSR: BKPT Mask */
+#define SCB_DFSR_HALTED_Pos                 0U                                            /*!< SCB DFSR: HALTED Position */
+#define SCB_DFSR_HALTED_Msk                (1UL /*<< SCB_DFSR_HALTED_Pos*/)               /*!< SCB DFSR: HALTED Mask */
+/*@} end of group CMSIS_SCB */
+  \defgroup CMSIS_SCnSCB System Controls not in SCB (SCnSCB)
+  \brief    Type definitions for the System Control and ID Register not in the SCB
+  \brief  Structure type to access the System Control and ID Register not in the SCB.
+typedef struct
+        uint32_t RESERVED0[1U];
+  __IM  uint32_t ICTR;                   /*!< Offset: 0x004 (R/ )  Interrupt Controller Type Register */
+  __IOM uint32_t ACTLR;                  /*!< Offset: 0x008 (R/W)  Auxiliary Control Register */
+} SCnSCB_Type;
+/* Interrupt Controller Type Register Definitions */
+#define SCnSCB_ICTR_INTLINESNUM_Pos         0U                                         /*!< ICTR: INTLINESNUM Position */
+#define SCnSCB_ICTR_INTLINESNUM_Msk        (0xFUL /*<< SCnSCB_ICTR_INTLINESNUM_Pos*/)  /*!< ICTR: INTLINESNUM Mask */
+/* Auxiliary Control Register Definitions */
+#define SCnSCB_ACTLR_DISOOFP_Pos            9U                                         /*!< ACTLR: DISOOFP Position */
+#define SCnSCB_ACTLR_DISOOFP_Msk           (1UL << SCnSCB_ACTLR_DISOOFP_Pos)           /*!< ACTLR: DISOOFP Mask */
+#define SCnSCB_ACTLR_DISFPCA_Pos            8U                                         /*!< ACTLR: DISFPCA Position */
+#define SCnSCB_ACTLR_DISFPCA_Msk           (1UL << SCnSCB_ACTLR_DISFPCA_Pos)           /*!< ACTLR: DISFPCA Mask */
+#define SCnSCB_ACTLR_DISFOLD_Pos            2U                                         /*!< ACTLR: DISFOLD Position */
+#define SCnSCB_ACTLR_DISFOLD_Msk           (1UL << SCnSCB_ACTLR_DISFOLD_Pos)           /*!< ACTLR: DISFOLD Mask */
+#define SCnSCB_ACTLR_DISDEFWBUF_Pos         1U                                         /*!< ACTLR: DISDEFWBUF Position */
+#define SCnSCB_ACTLR_DISDEFWBUF_Msk        (1UL << SCnSCB_ACTLR_DISDEFWBUF_Pos)        /*!< ACTLR: DISDEFWBUF Mask */
+#define SCnSCB_ACTLR_DISMCYCINT_Pos         0U                                         /*!< ACTLR: DISMCYCINT Position */
+#define SCnSCB_ACTLR_DISMCYCINT_Msk        (1UL /*<< SCnSCB_ACTLR_DISMCYCINT_Pos*/)    /*!< ACTLR: DISMCYCINT Mask */
+/*@} end of group CMSIS_SCnotSCB */
+  \defgroup CMSIS_SysTick     System Tick Timer (SysTick)
+  \brief    Type definitions for the System Timer Registers.
+  \brief  Structure type to access the System Timer (SysTick).
+typedef struct
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  SysTick Control and Status Register */
+  __IOM uint32_t LOAD;                   /*!< Offset: 0x004 (R/W)  SysTick Reload Value Register */
+  __IOM uint32_t VAL;                    /*!< Offset: 0x008 (R/W)  SysTick Current Value Register */
+  __IM  uint32_t CALIB;                  /*!< Offset: 0x00C (R/ )  SysTick Calibration Register */
+} SysTick_Type;
+/* SysTick Control / Status Register Definitions */
+#define SysTick_CTRL_COUNTFLAG_Pos         16U                                            /*!< SysTick CTRL: COUNTFLAG Position */
+#define SysTick_CTRL_COUNTFLAG_Msk         (1UL << SysTick_CTRL_COUNTFLAG_Pos)            /*!< SysTick CTRL: COUNTFLAG Mask */
+#define SysTick_CTRL_CLKSOURCE_Pos          2U                                            /*!< SysTick CTRL: CLKSOURCE Position */
+#define SysTick_CTRL_CLKSOURCE_Msk         (1UL << SysTick_CTRL_CLKSOURCE_Pos)            /*!< SysTick CTRL: CLKSOURCE Mask */
+#define SysTick_CTRL_TICKINT_Pos            1U                                            /*!< SysTick CTRL: TICKINT Position */
+#define SysTick_CTRL_TICKINT_Msk           (1UL << SysTick_CTRL_TICKINT_Pos)              /*!< SysTick CTRL: TICKINT Mask */
+#define SysTick_CTRL_ENABLE_Pos             0U                                            /*!< SysTick CTRL: ENABLE Position */
+#define SysTick_CTRL_ENABLE_Msk            (1UL /*<< SysTick_CTRL_ENABLE_Pos*/)           /*!< SysTick CTRL: ENABLE Mask */
+/* SysTick Reload Register Definitions */
+#define SysTick_LOAD_RELOAD_Pos             0U                                            /*!< SysTick LOAD: RELOAD Position */
+#define SysTick_LOAD_RELOAD_Msk            (0xFFFFFFUL /*<< SysTick_LOAD_RELOAD_Pos*/)    /*!< SysTick LOAD: RELOAD Mask */
+/* SysTick Current Register Definitions */
+#define SysTick_VAL_CURRENT_Pos             0U                                            /*!< SysTick VAL: CURRENT Position */
+#define SysTick_VAL_CURRENT_Msk            (0xFFFFFFUL /*<< SysTick_VAL_CURRENT_Pos*/)    /*!< SysTick VAL: CURRENT Mask */
+/* SysTick Calibration Register Definitions */
+#define SysTick_CALIB_NOREF_Pos            31U                                            /*!< SysTick CALIB: NOREF Position */
+#define SysTick_CALIB_NOREF_Msk            (1UL << SysTick_CALIB_NOREF_Pos)               /*!< SysTick CALIB: NOREF Mask */
+#define SysTick_CALIB_SKEW_Pos             30U                                            /*!< SysTick CALIB: SKEW Position */
+#define SysTick_CALIB_SKEW_Msk             (1UL << SysTick_CALIB_SKEW_Pos)                /*!< SysTick CALIB: SKEW Mask */
+#define SysTick_CALIB_TENMS_Pos             0U                                            /*!< SysTick CALIB: TENMS Position */
+#define SysTick_CALIB_TENMS_Msk            (0xFFFFFFUL /*<< SysTick_CALIB_TENMS_Pos*/)    /*!< SysTick CALIB: TENMS Mask */
+/*@} end of group CMSIS_SysTick */
+  \defgroup CMSIS_ITM     Instrumentation Trace Macrocell (ITM)
+  \brief    Type definitions for the Instrumentation Trace Macrocell (ITM)
+  \brief  Structure type to access the Instrumentation Trace Macrocell Register (ITM).
+typedef struct
+  __OM  union
+    __OM  uint8_t    u8;                 /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 8-bit */
+    __OM  uint16_t   u16;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 16-bit */
+    __OM  uint32_t   u32;                /*!< Offset: 0x000 ( /W)  ITM Stimulus Port 32-bit */
+  }  PORT [32U];                         /*!< Offset: 0x000 ( /W)  ITM Stimulus Port Registers */
+        uint32_t RESERVED0[864U];
+  __IOM uint32_t TER;                    /*!< Offset: 0xE00 (R/W)  ITM Trace Enable Register */
+        uint32_t RESERVED1[15U];
+  __IOM uint32_t TPR;                    /*!< Offset: 0xE40 (R/W)  ITM Trace Privilege Register */
+        uint32_t RESERVED2[15U];
+  __IOM uint32_t TCR;                    /*!< Offset: 0xE80 (R/W)  ITM Trace Control Register */
+        uint32_t RESERVED3[29U];
+  __OM  uint32_t IWR;                    /*!< Offset: 0xEF8 ( /W)  ITM Integration Write Register */
+  __IM  uint32_t IRR;                    /*!< Offset: 0xEFC (R/ )  ITM Integration Read Register */
+  __IOM uint32_t IMCR;                   /*!< Offset: 0xF00 (R/W)  ITM Integration Mode Control Register */
+        uint32_t RESERVED4[43U];
+  __OM  uint32_t LAR;                    /*!< Offset: 0xFB0 ( /W)  ITM Lock Access Register */
+  __IM  uint32_t LSR;                    /*!< Offset: 0xFB4 (R/ )  ITM Lock Status Register */
+        uint32_t RESERVED5[6U];
+  __IM  uint32_t PID4;                   /*!< Offset: 0xFD0 (R/ )  ITM Peripheral Identification Register #4 */
+  __IM  uint32_t PID5;                   /*!< Offset: 0xFD4 (R/ )  ITM Peripheral Identification Register #5 */
+  __IM  uint32_t PID6;                   /*!< Offset: 0xFD8 (R/ )  ITM Peripheral Identification Register #6 */
+  __IM  uint32_t PID7;                   /*!< Offset: 0xFDC (R/ )  ITM Peripheral Identification Register #7 */
+  __IM  uint32_t PID0;                   /*!< Offset: 0xFE0 (R/ )  ITM Peripheral Identification Register #0 */
+  __IM  uint32_t PID1;                   /*!< Offset: 0xFE4 (R/ )  ITM Peripheral Identification Register #1 */
+  __IM  uint32_t PID2;                   /*!< Offset: 0xFE8 (R/ )  ITM Peripheral Identification Register #2 */
+  __IM  uint32_t PID3;                   /*!< Offset: 0xFEC (R/ )  ITM Peripheral Identification Register #3 */
+  __IM  uint32_t CID0;                   /*!< Offset: 0xFF0 (R/ )  ITM Component  Identification Register #0 */
+  __IM  uint32_t CID1;                   /*!< Offset: 0xFF4 (R/ )  ITM Component  Identification Register #1 */
+  __IM  uint32_t CID2;                   /*!< Offset: 0xFF8 (R/ )  ITM Component  Identification Register #2 */
+  __IM  uint32_t CID3;                   /*!< Offset: 0xFFC (R/ )  ITM Component  Identification Register #3 */
+} ITM_Type;
+/* ITM Trace Privilege Register Definitions */
+#define ITM_TPR_PRIVMASK_Pos                0U                                            /*!< ITM TPR: PRIVMASK Position */
+#define ITM_TPR_PRIVMASK_Msk               (0xFUL /*<< ITM_TPR_PRIVMASK_Pos*/)            /*!< ITM TPR: PRIVMASK Mask */
+/* ITM Trace Control Register Definitions */
+#define ITM_TCR_BUSY_Pos                   23U                                            /*!< ITM TCR: BUSY Position */
+#define ITM_TCR_BUSY_Msk                   (1UL << ITM_TCR_BUSY_Pos)                      /*!< ITM TCR: BUSY Mask */
+#define ITM_TCR_TraceBusID_Pos             16U                                            /*!< ITM TCR: ATBID Position */
+#define ITM_TCR_TraceBusID_Msk             (0x7FUL << ITM_TCR_TraceBusID_Pos)             /*!< ITM TCR: ATBID Mask */
+#define ITM_TCR_GTSFREQ_Pos                10U                                            /*!< ITM TCR: Global timestamp frequency Position */
+#define ITM_TCR_GTSFREQ_Msk                (3UL << ITM_TCR_GTSFREQ_Pos)                   /*!< ITM TCR: Global timestamp frequency Mask */
+#define ITM_TCR_TSPrescale_Pos              8U                                            /*!< ITM TCR: TSPrescale Position */
+#define ITM_TCR_TSPrescale_Msk             (3UL << ITM_TCR_TSPrescale_Pos)                /*!< ITM TCR: TSPrescale Mask */
+#define ITM_TCR_SWOENA_Pos                  4U                                            /*!< ITM TCR: SWOENA Position */
+#define ITM_TCR_SWOENA_Msk                 (1UL << ITM_TCR_SWOENA_Pos)                    /*!< ITM TCR: SWOENA Mask */
+#define ITM_TCR_DWTENA_Pos                  3U                                            /*!< ITM TCR: DWTENA Position */
+#define ITM_TCR_DWTENA_Msk                 (1UL << ITM_TCR_DWTENA_Pos)                    /*!< ITM TCR: DWTENA Mask */
+#define ITM_TCR_SYNCENA_Pos                 2U                                            /*!< ITM TCR: SYNCENA Position */
+#define ITM_TCR_SYNCENA_Msk                (1UL << ITM_TCR_SYNCENA_Pos)                   /*!< ITM TCR: SYNCENA Mask */
+#define ITM_TCR_TSENA_Pos                   1U                                            /*!< ITM TCR: TSENA Position */
+#define ITM_TCR_TSENA_Msk                  (1UL << ITM_TCR_TSENA_Pos)                     /*!< ITM TCR: TSENA Mask */
+#define ITM_TCR_ITMENA_Pos                  0U                                            /*!< ITM TCR: ITM Enable bit Position */
+#define ITM_TCR_ITMENA_Msk                 (1UL /*<< ITM_TCR_ITMENA_Pos*/)                /*!< ITM TCR: ITM Enable bit Mask */
+/* ITM Integration Write Register Definitions */
+#define ITM_IWR_ATVALIDM_Pos                0U                                            /*!< ITM IWR: ATVALIDM Position */
+#define ITM_IWR_ATVALIDM_Msk               (1UL /*<< ITM_IWR_ATVALIDM_Pos*/)              /*!< ITM IWR: ATVALIDM Mask */
+/* ITM Integration Read Register Definitions */
+#define ITM_IRR_ATREADYM_Pos                0U                                            /*!< ITM IRR: ATREADYM Position */
+#define ITM_IRR_ATREADYM_Msk               (1UL /*<< ITM_IRR_ATREADYM_Pos*/)              /*!< ITM IRR: ATREADYM Mask */
+/* ITM Integration Mode Control Register Definitions */
+#define ITM_IMCR_INTEGRATION_Pos            0U                                            /*!< ITM IMCR: INTEGRATION Position */
+#define ITM_IMCR_INTEGRATION_Msk           (1UL /*<< ITM_IMCR_INTEGRATION_Pos*/)          /*!< ITM IMCR: INTEGRATION Mask */
+/* ITM Lock Status Register Definitions */
+#define ITM_LSR_ByteAcc_Pos                 2U                                            /*!< ITM LSR: ByteAcc Position */
+#define ITM_LSR_ByteAcc_Msk                (1UL << ITM_LSR_ByteAcc_Pos)                   /*!< ITM LSR: ByteAcc Mask */
+#define ITM_LSR_Access_Pos                  1U                                            /*!< ITM LSR: Access Position */
+#define ITM_LSR_Access_Msk                 (1UL << ITM_LSR_Access_Pos)                    /*!< ITM LSR: Access Mask */
+#define ITM_LSR_Present_Pos                 0U                                            /*!< ITM LSR: Present Position */
+#define ITM_LSR_Present_Msk                (1UL /*<< ITM_LSR_Present_Pos*/)               /*!< ITM LSR: Present Mask */
+/*@}*/ /* end of group CMSIS_ITM */
+  \defgroup CMSIS_DWT     Data Watchpoint and Trace (DWT)
+  \brief    Type definitions for the Data Watchpoint and Trace (DWT)
+  \brief  Structure type to access the Data Watchpoint and Trace Register (DWT).
+typedef struct
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x000 (R/W)  Control Register */
+  __IOM uint32_t CYCCNT;                 /*!< Offset: 0x004 (R/W)  Cycle Count Register */
+  __IOM uint32_t CPICNT;                 /*!< Offset: 0x008 (R/W)  CPI Count Register */
+  __IOM uint32_t EXCCNT;                 /*!< Offset: 0x00C (R/W)  Exception Overhead Count Register */
+  __IOM uint32_t SLEEPCNT;               /*!< Offset: 0x010 (R/W)  Sleep Count Register */
+  __IOM uint32_t LSUCNT;                 /*!< Offset: 0x014 (R/W)  LSU Count Register */
+  __IOM uint32_t FOLDCNT;                /*!< Offset: 0x018 (R/W)  Folded-instruction Count Register */
+  __IM  uint32_t PCSR;                   /*!< Offset: 0x01C (R/ )  Program Counter Sample Register */
+  __IOM uint32_t COMP0;                  /*!< Offset: 0x020 (R/W)  Comparator Register 0 */
+  __IOM uint32_t MASK0;                  /*!< Offset: 0x024 (R/W)  Mask Register 0 */
+  __IOM uint32_t FUNCTION0;              /*!< Offset: 0x028 (R/W)  Function Register 0 */
+  __IOM uint32_t COMP1;                  /*!< Offset: 0x030 (R/W)  Comparator Register 1 */
+  __IOM uint32_t MASK1;                  /*!< Offset: 0x034 (R/W)  Mask Register 1 */
+  __IOM uint32_t FUNCTION1;              /*!< Offset: 0x038 (R/W)  Function Register 1 */
+        uint32_t RESERVED1[1U];
+  __IOM uint32_t COMP2;                  /*!< Offset: 0x040 (R/W)  Comparator Register 2 */
+  __IOM uint32_t MASK2;                  /*!< Offset: 0x044 (R/W)  Mask Register 2 */
+  __IOM uint32_t FUNCTION2;              /*!< Offset: 0x048 (R/W)  Function Register 2 */
+        uint32_t RESERVED2[1U];
+  __IOM uint32_t COMP3;                  /*!< Offset: 0x050 (R/W)  Comparator Register 3 */
+  __IOM uint32_t MASK3;                  /*!< Offset: 0x054 (R/W)  Mask Register 3 */
+  __IOM uint32_t FUNCTION3;              /*!< Offset: 0x058 (R/W)  Function Register 3 */
+} DWT_Type;
+/* DWT Control Register Definitions */
+#define DWT_CTRL_NUMCOMP_Pos               28U                                         /*!< DWT CTRL: NUMCOMP Position */
+#define DWT_CTRL_NUMCOMP_Msk               (0xFUL << DWT_CTRL_NUMCOMP_Pos)             /*!< DWT CTRL: NUMCOMP Mask */
+#define DWT_CTRL_NOTRCPKT_Pos              27U                                         /*!< DWT CTRL: NOTRCPKT Position */
+#define DWT_CTRL_NOTRCPKT_Msk              (0x1UL << DWT_CTRL_NOTRCPKT_Pos)            /*!< DWT CTRL: NOTRCPKT Mask */
+#define DWT_CTRL_NOEXTTRIG_Pos             26U                                         /*!< DWT CTRL: NOEXTTRIG Position */
+#define DWT_CTRL_NOEXTTRIG_Msk             (0x1UL << DWT_CTRL_NOEXTTRIG_Pos)           /*!< DWT CTRL: NOEXTTRIG Mask */
+#define DWT_CTRL_NOCYCCNT_Pos              25U                                         /*!< DWT CTRL: NOCYCCNT Position */
+#define DWT_CTRL_NOCYCCNT_Msk              (0x1UL << DWT_CTRL_NOCYCCNT_Pos)            /*!< DWT CTRL: NOCYCCNT Mask */
+#define DWT_CTRL_NOPRFCNT_Pos              24U                                         /*!< DWT CTRL: NOPRFCNT Position */
+#define DWT_CTRL_NOPRFCNT_Msk              (0x1UL << DWT_CTRL_NOPRFCNT_Pos)            /*!< DWT CTRL: NOPRFCNT Mask */
+#define DWT_CTRL_CYCEVTENA_Pos             22U                                         /*!< DWT CTRL: CYCEVTENA Position */
+#define DWT_CTRL_CYCEVTENA_Msk             (0x1UL << DWT_CTRL_CYCEVTENA_Pos)           /*!< DWT CTRL: CYCEVTENA Mask */
+#define DWT_CTRL_FOLDEVTENA_Pos            21U                                         /*!< DWT CTRL: FOLDEVTENA Position */
+#define DWT_CTRL_FOLDEVTENA_Msk            (0x1UL << DWT_CTRL_FOLDEVTENA_Pos)          /*!< DWT CTRL: FOLDEVTENA Mask */
+#define DWT_CTRL_LSUEVTENA_Pos             20U                                         /*!< DWT CTRL: LSUEVTENA Position */
+#define DWT_CTRL_LSUEVTENA_Msk             (0x1UL << DWT_CTRL_LSUEVTENA_Pos)           /*!< DWT CTRL: LSUEVTENA Mask */
+#define DWT_CTRL_SLEEPEVTENA_Pos           19U                                         /*!< DWT CTRL: SLEEPEVTENA Position */
+#define DWT_CTRL_SLEEPEVTENA_Msk           (0x1UL << DWT_CTRL_SLEEPEVTENA_Pos)         /*!< DWT CTRL: SLEEPEVTENA Mask */
+#define DWT_CTRL_EXCEVTENA_Pos             18U                                         /*!< DWT CTRL: EXCEVTENA Position */
+#define DWT_CTRL_EXCEVTENA_Msk             (0x1UL << DWT_CTRL_EXCEVTENA_Pos)           /*!< DWT CTRL: EXCEVTENA Mask */
+#define DWT_CTRL_CPIEVTENA_Pos             17U                                         /*!< DWT CTRL: CPIEVTENA Position */
+#define DWT_CTRL_CPIEVTENA_Msk             (0x1UL << DWT_CTRL_CPIEVTENA_Pos)           /*!< DWT CTRL: CPIEVTENA Mask */
+#define DWT_CTRL_EXCTRCENA_Pos             16U                                         /*!< DWT CTRL: EXCTRCENA Position */
+#define DWT_CTRL_EXCTRCENA_Msk             (0x1UL << DWT_CTRL_EXCTRCENA_Pos)           /*!< DWT CTRL: EXCTRCENA Mask */
+#define DWT_CTRL_PCSAMPLENA_Pos            12U                                         /*!< DWT CTRL: PCSAMPLENA Position */
+#define DWT_CTRL_PCSAMPLENA_Msk            (0x1UL << DWT_CTRL_PCSAMPLENA_Pos)          /*!< DWT CTRL: PCSAMPLENA Mask */
+#define DWT_CTRL_SYNCTAP_Pos               10U                                         /*!< DWT CTRL: SYNCTAP Position */
+#define DWT_CTRL_SYNCTAP_Msk               (0x3UL << DWT_CTRL_SYNCTAP_Pos)             /*!< DWT CTRL: SYNCTAP Mask */
+#define DWT_CTRL_CYCTAP_Pos                 9U                                         /*!< DWT CTRL: CYCTAP Position */
+#define DWT_CTRL_CYCTAP_Msk                (0x1UL << DWT_CTRL_CYCTAP_Pos)              /*!< DWT CTRL: CYCTAP Mask */
+#define DWT_CTRL_POSTINIT_Pos               5U                                         /*!< DWT CTRL: POSTINIT Position */
+#define DWT_CTRL_POSTINIT_Msk              (0xFUL << DWT_CTRL_POSTINIT_Pos)            /*!< DWT CTRL: POSTINIT Mask */
+#define DWT_CTRL_POSTPRESET_Pos             1U                                         /*!< DWT CTRL: POSTPRESET Position */
+#define DWT_CTRL_POSTPRESET_Msk            (0xFUL << DWT_CTRL_POSTPRESET_Pos)          /*!< DWT CTRL: POSTPRESET Mask */
+#define DWT_CTRL_CYCCNTENA_Pos              0U                                         /*!< DWT CTRL: CYCCNTENA Position */
+#define DWT_CTRL_CYCCNTENA_Msk             (0x1UL /*<< DWT_CTRL_CYCCNTENA_Pos*/)       /*!< DWT CTRL: CYCCNTENA Mask */
+/* DWT CPI Count Register Definitions */
+#define DWT_CPICNT_CPICNT_Pos               0U                                         /*!< DWT CPICNT: CPICNT Position */
+#define DWT_CPICNT_CPICNT_Msk              (0xFFUL /*<< DWT_CPICNT_CPICNT_Pos*/)       /*!< DWT CPICNT: CPICNT Mask */
+/* DWT Exception Overhead Count Register Definitions */
+#define DWT_EXCCNT_EXCCNT_Pos               0U                                         /*!< DWT EXCCNT: EXCCNT Position */
+#define DWT_EXCCNT_EXCCNT_Msk              (0xFFUL /*<< DWT_EXCCNT_EXCCNT_Pos*/)       /*!< DWT EXCCNT: EXCCNT Mask */
+/* DWT Sleep Count Register Definitions */
+#define DWT_SLEEPCNT_SLEEPCNT_Pos           0U                                         /*!< DWT SLEEPCNT: SLEEPCNT Position */
+#define DWT_SLEEPCNT_SLEEPCNT_Msk          (0xFFUL /*<< DWT_SLEEPCNT_SLEEPCNT_Pos*/)   /*!< DWT SLEEPCNT: SLEEPCNT Mask */
+/* DWT LSU Count Register Definitions */
+#define DWT_LSUCNT_LSUCNT_Pos               0U                                         /*!< DWT LSUCNT: LSUCNT Position */
+#define DWT_LSUCNT_LSUCNT_Msk              (0xFFUL /*<< DWT_LSUCNT_LSUCNT_Pos*/)       /*!< DWT LSUCNT: LSUCNT Mask */
+/* DWT Folded-instruction Count Register Definitions */
+#define DWT_FOLDCNT_FOLDCNT_Pos             0U                                         /*!< DWT FOLDCNT: FOLDCNT Position */
+#define DWT_FOLDCNT_FOLDCNT_Msk            (0xFFUL /*<< DWT_FOLDCNT_FOLDCNT_Pos*/)     /*!< DWT FOLDCNT: FOLDCNT Mask */
+/* DWT Comparator Mask Register Definitions */
+#define DWT_MASK_MASK_Pos                   0U                                         /*!< DWT MASK: MASK Position */
+#define DWT_MASK_MASK_Msk                  (0x1FUL /*<< DWT_MASK_MASK_Pos*/)           /*!< DWT MASK: MASK Mask */
+/* DWT Comparator Function Register Definitions */
+#define DWT_FUNCTION_MATCHED_Pos           24U                                         /*!< DWT FUNCTION: MATCHED Position */
+#define DWT_FUNCTION_MATCHED_Msk           (0x1UL << DWT_FUNCTION_MATCHED_Pos)         /*!< DWT FUNCTION: MATCHED Mask */
+#define DWT_FUNCTION_DATAVADDR1_Pos        16U                                         /*!< DWT FUNCTION: DATAVADDR1 Position */
+#define DWT_FUNCTION_DATAVADDR1_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR1_Pos)      /*!< DWT FUNCTION: DATAVADDR1 Mask */
+#define DWT_FUNCTION_DATAVADDR0_Pos        12U                                         /*!< DWT FUNCTION: DATAVADDR0 Position */
+#define DWT_FUNCTION_DATAVADDR0_Msk        (0xFUL << DWT_FUNCTION_DATAVADDR0_Pos)      /*!< DWT FUNCTION: DATAVADDR0 Mask */
+#define DWT_FUNCTION_DATAVSIZE_Pos         10U                                         /*!< DWT FUNCTION: DATAVSIZE Position */
+#define DWT_FUNCTION_DATAVSIZE_Msk         (0x3UL << DWT_FUNCTION_DATAVSIZE_Pos)       /*!< DWT FUNCTION: DATAVSIZE Mask */
+#define DWT_FUNCTION_LNK1ENA_Pos            9U                                         /*!< DWT FUNCTION: LNK1ENA Position */
+#define DWT_FUNCTION_LNK1ENA_Msk           (0x1UL << DWT_FUNCTION_LNK1ENA_Pos)         /*!< DWT FUNCTION: LNK1ENA Mask */
+#define DWT_FUNCTION_DATAVMATCH_Pos         8U                                         /*!< DWT FUNCTION: DATAVMATCH Position */
+#define DWT_FUNCTION_DATAVMATCH_Msk        (0x1UL << DWT_FUNCTION_DATAVMATCH_Pos)      /*!< DWT FUNCTION: DATAVMATCH Mask */
+#define DWT_FUNCTION_CYCMATCH_Pos           7U                                         /*!< DWT FUNCTION: CYCMATCH Position */
+#define DWT_FUNCTION_CYCMATCH_Msk          (0x1UL << DWT_FUNCTION_CYCMATCH_Pos)        /*!< DWT FUNCTION: CYCMATCH Mask */
+#define DWT_FUNCTION_EMITRANGE_Pos          5U                                         /*!< DWT FUNCTION: EMITRANGE Position */
+#define DWT_FUNCTION_EMITRANGE_Msk         (0x1UL << DWT_FUNCTION_EMITRANGE_Pos)       /*!< DWT FUNCTION: EMITRANGE Mask */
+#define DWT_FUNCTION_FUNCTION_Pos           0U                                         /*!< DWT FUNCTION: FUNCTION Position */
+#define DWT_FUNCTION_FUNCTION_Msk          (0xFUL /*<< DWT_FUNCTION_FUNCTION_Pos*/)    /*!< DWT FUNCTION: FUNCTION Mask */
+/*@}*/ /* end of group CMSIS_DWT */
+  \defgroup CMSIS_TPI     Trace Port Interface (TPI)
+  \brief    Type definitions for the Trace Port Interface (TPI)
+  \brief  Structure type to access the Trace Port Interface Register (TPI).
+typedef struct
+  __IOM uint32_t SSPSR;                  /*!< Offset: 0x000 (R/ )  Supported Parallel Port Size Register */
+  __IOM uint32_t CSPSR;                  /*!< Offset: 0x004 (R/W)  Current Parallel Port Size Register */
+        uint32_t RESERVED0[2U];
+  __IOM uint32_t ACPR;                   /*!< Offset: 0x010 (R/W)  Asynchronous Clock Prescaler Register */
+        uint32_t RESERVED1[55U];
+  __IOM uint32_t SPPR;                   /*!< Offset: 0x0F0 (R/W)  Selected Pin Protocol Register */
+        uint32_t RESERVED2[131U];
+  __IM  uint32_t FFSR;                   /*!< Offset: 0x300 (R/ )  Formatter and Flush Status Register */
+  __IOM uint32_t FFCR;                   /*!< Offset: 0x304 (R/W)  Formatter and Flush Control Register */
+  __IM  uint32_t FSCR;                   /*!< Offset: 0x308 (R/ )  Formatter Synchronization Counter Register */
+        uint32_t RESERVED3[759U];
+  __IM  uint32_t TRIGGER;                /*!< Offset: 0xEE8 (R/ )  TRIGGER */
+  __IM  uint32_t FIFO0;                  /*!< Offset: 0xEEC (R/ )  Integration ETM Data */
+  __IM  uint32_t ITATBCTR2;              /*!< Offset: 0xEF0 (R/ )  ITATBCTR2 */
+        uint32_t RESERVED4[1U];
+  __IM  uint32_t ITATBCTR0;              /*!< Offset: 0xEF8 (R/ )  ITATBCTR0 */
+  __IM  uint32_t FIFO1;                  /*!< Offset: 0xEFC (R/ )  Integration ITM Data */
+  __IOM uint32_t ITCTRL;                 /*!< Offset: 0xF00 (R/W)  Integration Mode Control */
+        uint32_t RESERVED5[39U];
+  __IOM uint32_t CLAIMSET;               /*!< Offset: 0xFA0 (R/W)  Claim tag set */
+  __IOM uint32_t CLAIMCLR;               /*!< Offset: 0xFA4 (R/W)  Claim tag clear */
+        uint32_t RESERVED7[8U];
+  __IM  uint32_t DEVID;                  /*!< Offset: 0xFC8 (R/ )  TPIU_DEVID */
+  __IM  uint32_t DEVTYPE;                /*!< Offset: 0xFCC (R/ )  TPIU_DEVTYPE */
+} TPI_Type;
+/* TPI Asynchronous Clock Prescaler Register Definitions */
+#define TPI_ACPR_PRESCALER_Pos              0U                                         /*!< TPI ACPR: PRESCALER Position */
+#define TPI_ACPR_PRESCALER_Msk             (0x1FFFUL /*<< TPI_ACPR_PRESCALER_Pos*/)    /*!< TPI ACPR: PRESCALER Mask */
+/* TPI Selected Pin Protocol Register Definitions */
+#define TPI_SPPR_TXMODE_Pos                 0U                                         /*!< TPI SPPR: TXMODE Position */
+#define TPI_SPPR_TXMODE_Msk                (0x3UL /*<< TPI_SPPR_TXMODE_Pos*/)          /*!< TPI SPPR: TXMODE Mask */
+/* TPI Formatter and Flush Status Register Definitions */
+#define TPI_FFSR_FtNonStop_Pos              3U                                         /*!< TPI FFSR: FtNonStop Position */
+#define TPI_FFSR_FtNonStop_Msk             (0x1UL << TPI_FFSR_FtNonStop_Pos)           /*!< TPI FFSR: FtNonStop Mask */
+#define TPI_FFSR_TCPresent_Pos              2U                                         /*!< TPI FFSR: TCPresent Position */
+#define TPI_FFSR_TCPresent_Msk             (0x1UL << TPI_FFSR_TCPresent_Pos)           /*!< TPI FFSR: TCPresent Mask */
+#define TPI_FFSR_FtStopped_Pos              1U                                         /*!< TPI FFSR: FtStopped Position */
+#define TPI_FFSR_FtStopped_Msk             (0x1UL << TPI_FFSR_FtStopped_Pos)           /*!< TPI FFSR: FtStopped Mask */
+#define TPI_FFSR_FlInProg_Pos               0U                                         /*!< TPI FFSR: FlInProg Position */
+#define TPI_FFSR_FlInProg_Msk              (0x1UL /*<< TPI_FFSR_FlInProg_Pos*/)        /*!< TPI FFSR: FlInProg Mask */
+/* TPI Formatter and Flush Control Register Definitions */
+#define TPI_FFCR_TrigIn_Pos                 8U                                         /*!< TPI FFCR: TrigIn Position */
+#define TPI_FFCR_TrigIn_Msk                (0x1UL << TPI_FFCR_TrigIn_Pos)              /*!< TPI FFCR: TrigIn Mask */
+#define TPI_FFCR_EnFCont_Pos                1U                                         /*!< TPI FFCR: EnFCont Position */
+#define TPI_FFCR_EnFCont_Msk               (0x1UL << TPI_FFCR_EnFCont_Pos)             /*!< TPI FFCR: EnFCont Mask */
+/* TPI TRIGGER Register Definitions */
+#define TPI_TRIGGER_TRIGGER_Pos             0U                                         /*!< TPI TRIGGER: TRIGGER Position */
+#define TPI_TRIGGER_TRIGGER_Msk            (0x1UL /*<< TPI_TRIGGER_TRIGGER_Pos*/)      /*!< TPI TRIGGER: TRIGGER Mask */
+/* TPI Integration ETM Data Register Definitions (FIFO0) */
+#define TPI_FIFO0_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO0: ITM_ATVALID Position */
+#define TPI_FIFO0_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ITM_ATVALID_Pos)        /*!< TPI FIFO0: ITM_ATVALID Mask */
+#define TPI_FIFO0_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO0: ITM_bytecount Position */
+#define TPI_FIFO0_ITM_bytecount_Msk        (0x3UL << TPI_FIFO0_ITM_bytecount_Pos)      /*!< TPI FIFO0: ITM_bytecount Mask */
+#define TPI_FIFO0_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO0: ETM_ATVALID Position */
+#define TPI_FIFO0_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO0_ETM_ATVALID_Pos)        /*!< TPI FIFO0: ETM_ATVALID Mask */
+#define TPI_FIFO0_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO0: ETM_bytecount Position */
+#define TPI_FIFO0_ETM_bytecount_Msk        (0x3UL << TPI_FIFO0_ETM_bytecount_Pos)      /*!< TPI FIFO0: ETM_bytecount Mask */
+#define TPI_FIFO0_ETM2_Pos                 16U                                         /*!< TPI FIFO0: ETM2 Position */
+#define TPI_FIFO0_ETM2_Msk                 (0xFFUL << TPI_FIFO0_ETM2_Pos)              /*!< TPI FIFO0: ETM2 Mask */
+#define TPI_FIFO0_ETM1_Pos                  8U                                         /*!< TPI FIFO0: ETM1 Position */
+#define TPI_FIFO0_ETM1_Msk                 (0xFFUL << TPI_FIFO0_ETM1_Pos)              /*!< TPI FIFO0: ETM1 Mask */
+#define TPI_FIFO0_ETM0_Pos                  0U                                         /*!< TPI FIFO0: ETM0 Position */
+#define TPI_FIFO0_ETM0_Msk                 (0xFFUL /*<< TPI_FIFO0_ETM0_Pos*/)          /*!< TPI FIFO0: ETM0 Mask */
+/* TPI ITATBCTR2 Register Definitions */
+#define TPI_ITATBCTR2_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR2: ATREADY Position */
+#define TPI_ITATBCTR2_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR2_ATREADY_Pos*/)    /*!< TPI ITATBCTR2: ATREADY Mask */
+/* TPI Integration ITM Data Register Definitions (FIFO1) */
+#define TPI_FIFO1_ITM_ATVALID_Pos          29U                                         /*!< TPI FIFO1: ITM_ATVALID Position */
+#define TPI_FIFO1_ITM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ITM_ATVALID_Pos)        /*!< TPI FIFO1: ITM_ATVALID Mask */
+#define TPI_FIFO1_ITM_bytecount_Pos        27U                                         /*!< TPI FIFO1: ITM_bytecount Position */
+#define TPI_FIFO1_ITM_bytecount_Msk        (0x3UL << TPI_FIFO1_ITM_bytecount_Pos)      /*!< TPI FIFO1: ITM_bytecount Mask */
+#define TPI_FIFO1_ETM_ATVALID_Pos          26U                                         /*!< TPI FIFO1: ETM_ATVALID Position */
+#define TPI_FIFO1_ETM_ATVALID_Msk          (0x3UL << TPI_FIFO1_ETM_ATVALID_Pos)        /*!< TPI FIFO1: ETM_ATVALID Mask */
+#define TPI_FIFO1_ETM_bytecount_Pos        24U                                         /*!< TPI FIFO1: ETM_bytecount Position */
+#define TPI_FIFO1_ETM_bytecount_Msk        (0x3UL << TPI_FIFO1_ETM_bytecount_Pos)      /*!< TPI FIFO1: ETM_bytecount Mask */
+#define TPI_FIFO1_ITM2_Pos                 16U                                         /*!< TPI FIFO1: ITM2 Position */
+#define TPI_FIFO1_ITM2_Msk                 (0xFFUL << TPI_FIFO1_ITM2_Pos)              /*!< TPI FIFO1: ITM2 Mask */
+#define TPI_FIFO1_ITM1_Pos                  8U                                         /*!< TPI FIFO1: ITM1 Position */
+#define TPI_FIFO1_ITM1_Msk                 (0xFFUL << TPI_FIFO1_ITM1_Pos)              /*!< TPI FIFO1: ITM1 Mask */
+#define TPI_FIFO1_ITM0_Pos                  0U                                         /*!< TPI FIFO1: ITM0 Position */
+#define TPI_FIFO1_ITM0_Msk                 (0xFFUL /*<< TPI_FIFO1_ITM0_Pos*/)          /*!< TPI FIFO1: ITM0 Mask */
+/* TPI ITATBCTR0 Register Definitions */
+#define TPI_ITATBCTR0_ATREADY_Pos           0U                                         /*!< TPI ITATBCTR0: ATREADY Position */
+#define TPI_ITATBCTR0_ATREADY_Msk          (0x1UL /*<< TPI_ITATBCTR0_ATREADY_Pos*/)    /*!< TPI ITATBCTR0: ATREADY Mask */
+/* TPI Integration Mode Control Register Definitions */
+#define TPI_ITCTRL_Mode_Pos                 0U                                         /*!< TPI ITCTRL: Mode Position */
+#define TPI_ITCTRL_Mode_Msk                (0x1UL /*<< TPI_ITCTRL_Mode_Pos*/)          /*!< TPI ITCTRL: Mode Mask */
+/* TPI DEVID Register Definitions */
+#define TPI_DEVID_NRZVALID_Pos             11U                                         /*!< TPI DEVID: NRZVALID Position */
+#define TPI_DEVID_NRZVALID_Msk             (0x1UL << TPI_DEVID_NRZVALID_Pos)           /*!< TPI DEVID: NRZVALID Mask */
+#define TPI_DEVID_MANCVALID_Pos            10U                                         /*!< TPI DEVID: MANCVALID Position */
+#define TPI_DEVID_MANCVALID_Msk            (0x1UL << TPI_DEVID_MANCVALID_Pos)          /*!< TPI DEVID: MANCVALID Mask */
+#define TPI_DEVID_PTINVALID_Pos             9U                                         /*!< TPI DEVID: PTINVALID Position */
+#define TPI_DEVID_PTINVALID_Msk            (0x1UL << TPI_DEVID_PTINVALID_Pos)          /*!< TPI DEVID: PTINVALID Mask */
+#define TPI_DEVID_MinBufSz_Pos              6U                                         /*!< TPI DEVID: MinBufSz Position */
+#define TPI_DEVID_MinBufSz_Msk             (0x7UL << TPI_DEVID_MinBufSz_Pos)           /*!< TPI DEVID: MinBufSz Mask */
+#define TPI_DEVID_AsynClkIn_Pos             5U                                         /*!< TPI DEVID: AsynClkIn Position */
+#define TPI_DEVID_AsynClkIn_Msk            (0x1UL << TPI_DEVID_AsynClkIn_Pos)          /*!< TPI DEVID: AsynClkIn Mask */
+#define TPI_DEVID_NrTraceInput_Pos          0U                                         /*!< TPI DEVID: NrTraceInput Position */
+#define TPI_DEVID_NrTraceInput_Msk         (0x1FUL /*<< TPI_DEVID_NrTraceInput_Pos*/)  /*!< TPI DEVID: NrTraceInput Mask */
+/* TPI DEVTYPE Register Definitions */
+#define TPI_DEVTYPE_MajorType_Pos           4U                                         /*!< TPI DEVTYPE: MajorType Position */
+#define TPI_DEVTYPE_MajorType_Msk          (0xFUL << TPI_DEVTYPE_MajorType_Pos)        /*!< TPI DEVTYPE: MajorType Mask */
+#define TPI_DEVTYPE_SubType_Pos             0U                                         /*!< TPI DEVTYPE: SubType Position */
+#define TPI_DEVTYPE_SubType_Msk            (0xFUL /*<< TPI_DEVTYPE_SubType_Pos*/)      /*!< TPI DEVTYPE: SubType Mask */
+/*@}*/ /* end of group CMSIS_TPI */
+#if (__MPU_PRESENT == 1U)
+  \defgroup CMSIS_MPU     Memory Protection Unit (MPU)
+  \brief    Type definitions for the Memory Protection Unit (MPU)
+  \brief  Structure type to access the Memory Protection Unit (MPU).
+typedef struct
+  __IM  uint32_t TYPE;                   /*!< Offset: 0x000 (R/ )  MPU Type Register */
+  __IOM uint32_t CTRL;                   /*!< Offset: 0x004 (R/W)  MPU Control Register */
+  __IOM uint32_t RNR;                    /*!< Offset: 0x008 (R/W)  MPU Region RNRber Register */
+  __IOM uint32_t RBAR;                   /*!< Offset: 0x00C (R/W)  MPU Region Base Address Register */
+  __IOM uint32_t RASR;                   /*!< Offset: 0x010 (R/W)  MPU Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A1;                /*!< Offset: 0x014 (R/W)  MPU Alias 1 Region Base Address Register */
+  __IOM uint32_t RASR_A1;                /*!< Offset: 0x018 (R/W)  MPU Alias 1 Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A2;                /*!< Offset: 0x01C (R/W)  MPU Alias 2 Region Base Address Register */
+  __IOM uint32_t RASR_A2;                /*!< Offset: 0x020 (R/W)  MPU Alias 2 Region Attribute and Size Register */
+  __IOM uint32_t RBAR_A3;                /*!< Offset: 0x024 (R/W)  MPU Alias 3 Region Base Address Register */
+  __IOM uint32_t RASR_A3;                /*!< Offset: 0x028 (R/W)  MPU Alias 3 Region Attribute and Size Register */
+} MPU_Type;
+/* MPU Type Register Definitions */
+#define MPU_TYPE_IREGION_Pos               16U                                            /*!< MPU TYPE: IREGION Position */
+#define MPU_TYPE_IREGION_Msk               (0xFFUL << MPU_TYPE_IREGION_Pos)               /*!< MPU TYPE: IREGION Mask */
+#define MPU_TYPE_DREGION_Pos                8U                                            /*!< MPU TYPE: DREGION Position */
+#define MPU_TYPE_DREGION_Msk               (0xFFUL << MPU_TYPE_DREGION_Pos)               /*!< MPU TYPE: DREGION Mask */
+#define MPU_TYPE_SEPARATE_Pos               0U                                            /*!< MPU TYPE: SEPARATE Position */
+#define MPU_TYPE_SEPARATE_Msk              (1UL /*<< MPU_TYPE_SEPARATE_Pos*/)             /*!< MPU TYPE: SEPARATE Mask */
+/* MPU Control Register Definitions */
+#define MPU_CTRL_PRIVDEFENA_Pos             2U                                            /*!< MPU CTRL: PRIVDEFENA Position */
+#define MPU_CTRL_PRIVDEFENA_Msk            (1UL << MPU_CTRL_PRIVDEFENA_Pos)               /*!< MPU CTRL: PRIVDEFENA Mask */
+#define MPU_CTRL_HFNMIENA_Pos               1U                                            /*!< MPU CTRL: HFNMIENA Position */
+#define MPU_CTRL_HFNMIENA_Msk              (1UL << MPU_CTRL_HFNMIENA_Pos)                 /*!< MPU CTRL: HFNMIENA Mask */
+#define MPU_CTRL_ENABLE_Pos                 0U                                            /*!< MPU CTRL: ENABLE Position */
+#define MPU_CTRL_ENABLE_Msk                (1UL /*<< MPU_CTRL_ENABLE_Pos*/)               /*!< MPU CTRL: ENABLE Mask */
+/* MPU Region Number Register Definitions */
+#define MPU_RNR_REGION_Pos                  0U                                            /*!< MPU RNR: REGION Position */
+#define MPU_RNR_REGION_Msk                 (0xFFUL /*<< MPU_RNR_REGION_Pos*/)             /*!< MPU RNR: REGION Mask */
+/* MPU Region Base Address Register Definitions */
+#define MPU_RBAR_ADDR_Pos                   5U                                            /*!< MPU RBAR: ADDR Position */
+#define MPU_RBAR_ADDR_Msk                  (0x7FFFFFFUL << MPU_RBAR_ADDR_Pos)             /*!< MPU RBAR: ADDR Mask */
+#define MPU_RBAR_VALID_Pos                  4U                                            /*!< MPU RBAR: VALID Position */
+#define MPU_RBAR_VALID_Msk                 (1UL << MPU_RBAR_VALID_Pos)                    /*!< MPU RBAR: VALID Mask */
+#define MPU_RBAR_REGION_Pos                 0U                                            /*!< MPU RBAR: REGION Position */
+#define MPU_RBAR_REGION_Msk                (0xFUL /*<< MPU_RBAR_REGION_Pos*/)             /*!< MPU RBAR: REGION Mask */
+/* MPU Region Attribute and Size Register Definitions */
+#define MPU_RASR_ATTRS_Pos                 16U                                            /*!< MPU RASR: MPU Region Attribute field Position */
+#define MPU_RASR_ATTRS_Msk                 (0xFFFFUL << MPU_RASR_ATTRS_Pos)               /*!< MPU RASR: MPU Region Attribute field Mask */
+#define MPU_RASR_XN_Pos                    28U                                            /*!< MPU RASR: ATTRS.XN Position */
+#define MPU_RASR_XN_Msk                    (1UL << MPU_RASR_XN_Pos)                       /*!< MPU RASR: ATTRS.XN Mask */
+#define MPU_RASR_AP_Pos                    24U                                            /*!< MPU RASR: ATTRS.AP Position */
+#define MPU_RASR_AP_Msk                    (0x7UL << MPU_RASR_AP_Pos)                     /*!< MPU RASR: ATTRS.AP Mask */
+#define MPU_RASR_TEX_Pos                   19U                                            /*!< MPU RASR: ATTRS.TEX Position */
+#define MPU_RASR_TEX_Msk                   (0x7UL << MPU_RASR_TEX_Pos)                    /*!< MPU RASR: ATTRS.TEX Mask */
+#define MPU_RASR_S_Pos                     18U                                            /*!< MPU RASR: ATTRS.S Position */
+#define MPU_RASR_S_Msk                     (1UL << MPU_RASR_S_Pos)                        /*!< MPU RASR: ATTRS.S Mask */
+#define MPU_RASR_C_Pos                     17U                                            /*!< MPU RASR: ATTRS.C Position */
+#define MPU_RASR_C_Msk                     (1UL << MPU_RASR_C_Pos)                        /*!< MPU RASR: ATTRS.C Mask */
+#define MPU_RASR_B_Pos                     16U                                            /*!< MPU RASR: ATTRS.B Position */
+#define MPU_RASR_B_Msk                     (1UL << MPU_RASR_B_Pos)                        /*!< MPU RASR: ATTRS.B Mask */
+#define MPU_RASR_SRD_Pos                    8U                                            /*!< MPU RASR: Sub-Region Disable Position */
+#define MPU_RASR_SRD_Msk                   (0xFFUL << MPU_RASR_SRD_Pos)                   /*!< MPU RASR: Sub-Region Disable Mask */
+#define MPU_RASR_SIZE_Pos                   1U                                            /*!< MPU RASR: Region Size Field Position */
+#define MPU_RASR_SIZE_Msk                  (0x1FUL << MPU_RASR_SIZE_Pos)                  /*!< MPU RASR: Region Size Field Mask */
+#define MPU_RASR_ENABLE_Pos                 0U                                            /*!< MPU RASR: Region enable bit Position */
+#define MPU_RASR_ENABLE_Msk                (1UL /*<< MPU_RASR_ENABLE_Pos*/)               /*!< MPU RASR: Region enable bit Disable Mask */
+/*@} end of group CMSIS_MPU */
+#endif
+#if (__FPU_PRESENT == 1U)
+  \defgroup CMSIS_FPU     Floating Point Unit (FPU)
+  \brief    Type definitions for the Floating Point Unit (FPU)
+  \brief  Structure type to access the Floating Point Unit (FPU).
+typedef struct
+  __IOM uint32_t FPCCR;                  /*!< Offset: 0x004 (R/W)  Floating-Point Context Control Register */
+  __IOM uint32_t FPCAR;                  /*!< Offset: 0x008 (R/W)  Floating-Point Context Address Register */
+  __IOM uint32_t FPDSCR;                 /*!< Offset: 0x00C (R/W)  Floating-Point Default Status Control Register */
+  __IM  uint32_t MVFR0;                  /*!< Offset: 0x010 (R/ )  Media and FP Feature Register 0 */
+  __IM  uint32_t MVFR1;                  /*!< Offset: 0x014 (R/ )  Media and FP Feature Register 1 */
+} FPU_Type;
+/* Floating-Point Context Control Register Definitions */
+#define FPU_FPCCR_ASPEN_Pos                31U                                            /*!< FPCCR: ASPEN bit Position */
+#define FPU_FPCCR_ASPEN_Msk                (1UL << FPU_FPCCR_ASPEN_Pos)                   /*!< FPCCR: ASPEN bit Mask */
+#define FPU_FPCCR_LSPEN_Pos                30U                                            /*!< FPCCR: LSPEN Position */
+#define FPU_FPCCR_LSPEN_Msk                (1UL << FPU_FPCCR_LSPEN_Pos)                   /*!< FPCCR: LSPEN bit Mask */
+#define FPU_FPCCR_MONRDY_Pos                8U                                            /*!< FPCCR: MONRDY Position */
+#define FPU_FPCCR_MONRDY_Msk               (1UL << FPU_FPCCR_MONRDY_Pos)                  /*!< FPCCR: MONRDY bit Mask */
+#define FPU_FPCCR_BFRDY_Pos                 6U                                            /*!< FPCCR: BFRDY Position */
+#define FPU_FPCCR_BFRDY_Msk                (1UL << FPU_FPCCR_BFRDY_Pos)                   /*!< FPCCR: BFRDY bit Mask */
+#define FPU_FPCCR_MMRDY_Pos                 5U                                            /*!< FPCCR: MMRDY Position */
+#define FPU_FPCCR_MMRDY_Msk                (1UL << FPU_FPCCR_MMRDY_Pos)                   /*!< FPCCR: MMRDY bit Mask */
+#define FPU_FPCCR_HFRDY_Pos                 4U                                            /*!< FPCCR: HFRDY Position */
+#define FPU_FPCCR_HFRDY_Msk                (1UL << FPU_FPCCR_HFRDY_Pos)                   /*!< FPCCR: HFRDY bit Mask */
+#define FPU_FPCCR_THREAD_Pos                3U                                            /*!< FPCCR: processor mode bit Position */
+#define FPU_FPCCR_THREAD_Msk               (1UL << FPU_FPCCR_THREAD_Pos)                  /*!< FPCCR: processor mode active bit Mask */
+#define FPU_FPCCR_USER_Pos                  1U                                            /*!< FPCCR: privilege level bit Position */
+#define FPU_FPCCR_USER_Msk                 (1UL << FPU_FPCCR_USER_Pos)                    /*!< FPCCR: privilege level bit Mask */
+#define FPU_FPCCR_LSPACT_Pos                0U                                            /*!< FPCCR: Lazy state preservation active bit Position */
+#define FPU_FPCCR_LSPACT_Msk               (1UL /*<< FPU_FPCCR_LSPACT_Pos*/)              /*!< FPCCR: Lazy state preservation active bit Mask */
+/* Floating-Point Context Address Register Definitions */
+#define FPU_FPCAR_ADDRESS_Pos               3U                                            /*!< FPCAR: ADDRESS bit Position */
+#define FPU_FPCAR_ADDRESS_Msk              (0x1FFFFFFFUL << FPU_FPCAR_ADDRESS_Pos)        /*!< FPCAR: ADDRESS bit Mask */
+/* Floating-Point Default Status Control Register Definitions */
+#define FPU_FPDSCR_AHP_Pos                 26U                                            /*!< FPDSCR: AHP bit Position */
+#define FPU_FPDSCR_AHP_Msk                 (1UL << FPU_FPDSCR_AHP_Pos)                    /*!< FPDSCR: AHP bit Mask */
+#define FPU_FPDSCR_DN_Pos                  25U                                            /*!< FPDSCR: DN bit Position */
+#define FPU_FPDSCR_DN_Msk                  (1UL << FPU_FPDSCR_DN_Pos)                     /*!< FPDSCR: DN bit Mask */
+#define FPU_FPDSCR_FZ_Pos                  24U                                            /*!< FPDSCR: FZ bit Position */
+#define FPU_FPDSCR_FZ_Msk                  (1UL << FPU_FPDSCR_FZ_Pos)                     /*!< FPDSCR: FZ bit Mask */
+#define FPU_FPDSCR_RMode_Pos               22U                                            /*!< FPDSCR: RMode bit Position */
+#define FPU_FPDSCR_RMode_Msk               (3UL << FPU_FPDSCR_RMode_Pos)                  /*!< FPDSCR: RMode bit Mask */
+/* Media and FP Feature Register 0 Definitions */
+#define FPU_MVFR0_FP_rounding_modes_Pos    28U                                            /*!< MVFR0: FP rounding modes bits Position */
+#define FPU_MVFR0_FP_rounding_modes_Msk    (0xFUL << FPU_MVFR0_FP_rounding_modes_Pos)     /*!< MVFR0: FP rounding modes bits Mask */
+#define FPU_MVFR0_Short_vectors_Pos        24U                                            /*!< MVFR0: Short vectors bits Position */
+#define FPU_MVFR0_Short_vectors_Msk        (0xFUL << FPU_MVFR0_Short_vectors_Pos)         /*!< MVFR0: Short vectors bits Mask */
+#define FPU_MVFR0_Square_root_Pos          20U                                            /*!< MVFR0: Square root bits Position */
+#define FPU_MVFR0_Square_root_Msk          (0xFUL << FPU_MVFR0_Square_root_Pos)           /*!< MVFR0: Square root bits Mask */
+#define FPU_MVFR0_Divide_Pos               16U                                            /*!< MVFR0: Divide bits Position */
+#define FPU_MVFR0_Divide_Msk               (0xFUL << FPU_MVFR0_Divide_Pos)                /*!< MVFR0: Divide bits Mask */
+#define FPU_MVFR0_FP_excep_trapping_Pos    12U                                            /*!< MVFR0: FP exception trapping bits Position */
+#define FPU_MVFR0_FP_excep_trapping_Msk    (0xFUL << FPU_MVFR0_FP_excep_trapping_Pos)     /*!< MVFR0: FP exception trapping bits Mask */
+#define FPU_MVFR0_Double_precision_Pos      8U                                            /*!< MVFR0: Double-precision bits Position */
+#define FPU_MVFR0_Double_precision_Msk     (0xFUL << FPU_MVFR0_Double_precision_Pos)      /*!< MVFR0: Double-precision bits Mask */
+#define FPU_MVFR0_Single_precision_Pos      4U                                            /*!< MVFR0: Single-precision bits Position */
+#define FPU_MVFR0_Single_precision_Msk     (0xFUL << FPU_MVFR0_Single_precision_Pos)      /*!< MVFR0: Single-precision bits Mask */
+#define FPU_MVFR0_A_SIMD_registers_Pos      0U                                            /*!< MVFR0: A_SIMD registers bits Position */
+#define FPU_MVFR0_A_SIMD_registers_Msk     (0xFUL /*<< FPU_MVFR0_A_SIMD_registers_Pos*/)  /*!< MVFR0: A_SIMD registers bits Mask */
+/* Media and FP Feature Register 1 Definitions */
+#define FPU_MVFR1_FP_fused_MAC_Pos         28U                                            /*!< MVFR1: FP fused MAC bits Position */
+#define FPU_MVFR1_FP_fused_MAC_Msk         (0xFUL << FPU_MVFR1_FP_fused_MAC_Pos)          /*!< MVFR1: FP fused MAC bits Mask */
+#define FPU_MVFR1_FP_HPFP_Pos              24U                                            /*!< MVFR1: FP HPFP bits Position */
+#define FPU_MVFR1_FP_HPFP_Msk              (0xFUL << FPU_MVFR1_FP_HPFP_Pos)               /*!< MVFR1: FP HPFP bits Mask */
+#define FPU_MVFR1_D_NaN_mode_Pos            4U                                            /*!< MVFR1: D_NaN mode bits Position */
+#define FPU_MVFR1_D_NaN_mode_Msk           (0xFUL << FPU_MVFR1_D_NaN_mode_Pos)            /*!< MVFR1: D_NaN mode bits Mask */
+#define FPU_MVFR1_FtZ_mode_Pos              0U                                            /*!< MVFR1: FtZ mode bits Position */
+#define FPU_MVFR1_FtZ_mode_Msk             (0xFUL /*<< FPU_MVFR1_FtZ_mode_Pos*/)          /*!< MVFR1: FtZ mode bits Mask */
+/*@} end of group CMSIS_FPU */
+#endif
+  \defgroup CMSIS_CoreDebug       Core Debug Registers (CoreDebug)
+  \brief    Type definitions for the Core Debug Registers
+  \brief  Structure type to access the Core Debug Register (CoreDebug).
+typedef struct
+  __IOM uint32_t DHCSR;                  /*!< Offset: 0x000 (R/W)  Debug Halting Control and Status Register */
+  __OM  uint32_t DCRSR;                  /*!< Offset: 0x004 ( /W)  Debug Core Register Selector Register */
+  __IOM uint32_t DCRDR;                  /*!< Offset: 0x008 (R/W)  Debug Core Register Data Register */
+  __IOM uint32_t DEMCR;                  /*!< Offset: 0x00C (R/W)  Debug Exception and Monitor Control Register */
+} CoreDebug_Type;
+/* Debug Halting Control and Status Register Definitions */
+#define CoreDebug_DHCSR_DBGKEY_Pos         16U                                            /*!< CoreDebug DHCSR: DBGKEY Position */
+#define CoreDebug_DHCSR_DBGKEY_Msk         (0xFFFFUL << CoreDebug_DHCSR_DBGKEY_Pos)       /*!< CoreDebug DHCSR: DBGKEY Mask */
+#define CoreDebug_DHCSR_S_RESET_ST_Pos     25U                                            /*!< CoreDebug DHCSR: S_RESET_ST Position */
+#define CoreDebug_DHCSR_S_RESET_ST_Msk     (1UL << CoreDebug_DHCSR_S_RESET_ST_Pos)        /*!< CoreDebug DHCSR: S_RESET_ST Mask */
+#define CoreDebug_DHCSR_S_RETIRE_ST_Pos    24U                                            /*!< CoreDebug DHCSR: S_RETIRE_ST Position */
+#define CoreDebug_DHCSR_S_RETIRE_ST_Msk    (1UL << CoreDebug_DHCSR_S_RETIRE_ST_Pos)       /*!< CoreDebug DHCSR: S_RETIRE_ST Mask */
+#define CoreDebug_DHCSR_S_LOCKUP_Pos       19U                                            /*!< CoreDebug DHCSR: S_LOCKUP Position */
+#define CoreDebug_DHCSR_S_LOCKUP_Msk       (1UL << CoreDebug_DHCSR_S_LOCKUP_Pos)          /*!< CoreDebug DHCSR: S_LOCKUP Mask */
+#define CoreDebug_DHCSR_S_SLEEP_Pos        18U                                            /*!< CoreDebug DHCSR: S_SLEEP Position */
+#define CoreDebug_DHCSR_S_SLEEP_Msk        (1UL << CoreDebug_DHCSR_S_SLEEP_Pos)           /*!< CoreDebug DHCSR: S_SLEEP Mask */
+#define CoreDebug_DHCSR_S_HALT_Pos         17U                                            /*!< CoreDebug DHCSR: S_HALT Position */
+#define CoreDebug_DHCSR_S_HALT_Msk         (1UL << CoreDebug_DHCSR_S_HALT_Pos)            /*!< CoreDebug DHCSR: S_HALT Mask */
+#define CoreDebug_DHCSR_S_REGRDY_Pos       16U                                            /*!< CoreDebug DHCSR: S_REGRDY Position */
+#define CoreDebug_DHCSR_S_REGRDY_Msk       (1UL << CoreDebug_DHCSR_S_REGRDY_Pos)          /*!< CoreDebug DHCSR: S_REGRDY Mask */
+#define CoreDebug_DHCSR_C_SNAPSTALL_Pos     5U                                            /*!< CoreDebug DHCSR: C_SNAPSTALL Position */
+#define CoreDebug_DHCSR_C_SNAPSTALL_Msk    (1UL << CoreDebug_DHCSR_C_SNAPSTALL_Pos)       /*!< CoreDebug DHCSR: C_SNAPSTALL Mask */
+#define CoreDebug_DHCSR_C_MASKINTS_Pos      3U                                            /*!< CoreDebug DHCSR: C_MASKINTS Position */
+#define CoreDebug_DHCSR_C_MASKINTS_Msk     (1UL << CoreDebug_DHCSR_C_MASKINTS_Pos)        /*!< CoreDebug DHCSR: C_MASKINTS Mask */
+#define CoreDebug_DHCSR_C_STEP_Pos          2U                                            /*!< CoreDebug DHCSR: C_STEP Position */
+#define CoreDebug_DHCSR_C_STEP_Msk         (1UL << CoreDebug_DHCSR_C_STEP_Pos)            /*!< CoreDebug DHCSR: C_STEP Mask */
+#define CoreDebug_DHCSR_C_HALT_Pos          1U                                            /*!< CoreDebug DHCSR: C_HALT Position */
+#define CoreDebug_DHCSR_C_HALT_Msk         (1UL << CoreDebug_DHCSR_C_HALT_Pos)            /*!< CoreDebug DHCSR: C_HALT Mask */
+#define CoreDebug_DHCSR_C_DEBUGEN_Pos       0U                                            /*!< CoreDebug DHCSR: C_DEBUGEN Position */
+#define CoreDebug_DHCSR_C_DEBUGEN_Msk      (1UL /*<< CoreDebug_DHCSR_C_DEBUGEN_Pos*/)     /*!< CoreDebug DHCSR: C_DEBUGEN Mask */
+/* Debug Core Register Selector Register Definitions */
+#define CoreDebug_DCRSR_REGWnR_Pos         16U                                            /*!< CoreDebug DCRSR: REGWnR Position */
+#define CoreDebug_DCRSR_REGWnR_Msk         (1UL << CoreDebug_DCRSR_REGWnR_Pos)            /*!< CoreDebug DCRSR: REGWnR Mask */
+#define CoreDebug_DCRSR_REGSEL_Pos          0U                                            /*!< CoreDebug DCRSR: REGSEL Position */
+#define CoreDebug_DCRSR_REGSEL_Msk         (0x1FUL /*<< CoreDebug_DCRSR_REGSEL_Pos*/)     /*!< CoreDebug DCRSR: REGSEL Mask */
+/* Debug Exception and Monitor Control Register Definitions */
+#define CoreDebug_DEMCR_TRCENA_Pos         24U                                            /*!< CoreDebug DEMCR: TRCENA Position */
+#define CoreDebug_DEMCR_TRCENA_Msk         (1UL << CoreDebug_DEMCR_TRCENA_Pos)            /*!< CoreDebug DEMCR: TRCENA Mask */
+#define CoreDebug_DEMCR_MON_REQ_Pos        19U                                            /*!< CoreDebug DEMCR: MON_REQ Position */
+#define CoreDebug_DEMCR_MON_REQ_Msk        (1UL << CoreDebug_DEMCR_MON_REQ_Pos)           /*!< CoreDebug DEMCR: MON_REQ Mask */
+#define CoreDebug_DEMCR_MON_STEP_Pos       18U                                            /*!< CoreDebug DEMCR: MON_STEP Position */
+#define CoreDebug_DEMCR_MON_STEP_Msk       (1UL << CoreDebug_DEMCR_MON_STEP_Pos)          /*!< CoreDebug DEMCR: MON_STEP Mask */
+#define CoreDebug_DEMCR_MON_PEND_Pos       17U                                            /*!< CoreDebug DEMCR: MON_PEND Position */
+#define CoreDebug_DEMCR_MON_PEND_Msk       (1UL << CoreDebug_DEMCR_MON_PEND_Pos)          /*!< CoreDebug DEMCR: MON_PEND Mask */
+#define CoreDebug_DEMCR_MON_EN_Pos         16U                                            /*!< CoreDebug DEMCR: MON_EN Position */
+#define CoreDebug_DEMCR_MON_EN_Msk         (1UL << CoreDebug_DEMCR_MON_EN_Pos)            /*!< CoreDebug DEMCR: MON_EN Mask */
+#define CoreDebug_DEMCR_VC_HARDERR_Pos     10U                                            /*!< CoreDebug DEMCR: VC_HARDERR Position */
+#define CoreDebug_DEMCR_VC_HARDERR_Msk     (1UL << CoreDebug_DEMCR_VC_HARDERR_Pos)        /*!< CoreDebug DEMCR: VC_HARDERR Mask */
+#define CoreDebug_DEMCR_VC_INTERR_Pos       9U                                            /*!< CoreDebug DEMCR: VC_INTERR Position */
+#define CoreDebug_DEMCR_VC_INTERR_Msk      (1UL << CoreDebug_DEMCR_VC_INTERR_Pos)         /*!< CoreDebug DEMCR: VC_INTERR Mask */
+#define CoreDebug_DEMCR_VC_BUSERR_Pos       8U                                            /*!< CoreDebug DEMCR: VC_BUSERR Position */
+#define CoreDebug_DEMCR_VC_BUSERR_Msk      (1UL << CoreDebug_DEMCR_VC_BUSERR_Pos)         /*!< CoreDebug DEMCR: VC_BUSERR Mask */
+#define CoreDebug_DEMCR_VC_STATERR_Pos      7U                                            /*!< CoreDebug DEMCR: VC_STATERR Position */
+#define CoreDebug_DEMCR_VC_STATERR_Msk     (1UL << CoreDebug_DEMCR_VC_STATERR_Pos)        /*!< CoreDebug DEMCR: VC_STATERR Mask */
+#define CoreDebug_DEMCR_VC_CHKERR_Pos       6U                                            /*!< CoreDebug DEMCR: VC_CHKERR Position */
+#define CoreDebug_DEMCR_VC_CHKERR_Msk      (1UL << CoreDebug_DEMCR_VC_CHKERR_Pos)         /*!< CoreDebug DEMCR: VC_CHKERR Mask */
+#define CoreDebug_DEMCR_VC_NOCPERR_Pos      5U                                            /*!< CoreDebug DEMCR: VC_NOCPERR Position */
+#define CoreDebug_DEMCR_VC_NOCPERR_Msk     (1UL << CoreDebug_DEMCR_VC_NOCPERR_Pos)        /*!< CoreDebug DEMCR: VC_NOCPERR Mask */
+#define CoreDebug_DEMCR_VC_MMERR_Pos        4U                                            /*!< CoreDebug DEMCR: VC_MMERR Position */
+#define CoreDebug_DEMCR_VC_MMERR_Msk       (1UL << CoreDebug_DEMCR_VC_MMERR_Pos)          /*!< CoreDebug DEMCR: VC_MMERR Mask */
+#define CoreDebug_DEMCR_VC_CORERESET_Pos    0U                                            /*!< CoreDebug DEMCR: VC_CORERESET Position */
+#define CoreDebug_DEMCR_VC_CORERESET_Msk   (1UL /*<< CoreDebug_DEMCR_VC_CORERESET_Pos*/)  /*!< CoreDebug DEMCR: VC_CORERESET Mask */
+/*@} end of group CMSIS_CoreDebug */
+  \ingroup    CMSIS_core_register
+  \defgroup   CMSIS_core_bitfield     Core register bit field macros
+  \brief      Macros for use with bit field definitions (xxx_Pos, xxx_Msk).
+  \brief   Mask and shift a bit field value for use in a register bit range.
+  \param[in] field  Name of the register bit field.
+  \param[in] value  Value of the bit field.
+  \return           Masked and shifted value.
+#define _VAL2FLD(field, value)    ((value << field ## _Pos) & field ## _Msk)
+  \brief     Mask and shift a register value to extract a bit filed value.
+  \param[in] value  Value of register.
+  \return           Masked and shifted bit field value.
+#define _FLD2VAL(field, value)    ((value & field ## _Msk) >> field ## _Pos)
+/*@} end of group CMSIS_core_bitfield */
+  \defgroup   CMSIS_core_base     Core Definitions
+  \brief      Definitions for base addresses, unions, and structures.
+/* Memory mapping of Cortex-M4 Hardware */
+#define SCS_BASE            (0xE000E000UL)                            /*!< System Control Space Base Address */
+#define ITM_BASE            (0xE0000000UL)                            /*!< ITM Base Address */
+#define DWT_BASE            (0xE0001000UL)                            /*!< DWT Base Address */
+#define TPI_BASE            (0xE0040000UL)                            /*!< TPI Base Address */
+#define CoreDebug_BASE      (0xE000EDF0UL)                            /*!< Core Debug Base Address */
+#define SysTick_BASE        (SCS_BASE +  0x0010UL)                    /*!< SysTick Base Address */
+#define NVIC_BASE           (SCS_BASE +  0x0100UL)                    /*!< NVIC Base Address */
+#define SCB_BASE            (SCS_BASE +  0x0D00UL)                    /*!< System Control Block Base Address */
+#define SCnSCB              ((SCnSCB_Type    *)     SCS_BASE      )   /*!< System control Register not in SCB */
+#define SCB                 ((SCB_Type       *)     SCB_BASE      )   /*!< SCB configuration struct */
+#define SysTick             ((SysTick_Type   *)     SysTick_BASE  )   /*!< SysTick configuration struct */
+#define NVIC                ((NVIC_Type      *)     NVIC_BASE     )   /*!< NVIC configuration struct */
+#define ITM                 ((ITM_Type       *)     ITM_BASE      )   /*!< ITM configuration struct */
+#define DWT                 ((DWT_Type       *)     DWT_BASE      )   /*!< DWT configuration struct */
+#define TPI                 ((TPI_Type       *)     TPI_BASE      )   /*!< TPI configuration struct */
+#define CoreDebug           ((CoreDebug_Type *)     CoreDebug_BASE)   /*!< Core Debug configuration struct */
+  #define MPU_BASE          (SCS_BASE +  0x0D90UL)                    /*!< Memory Protection Unit */
+  #define MPU               ((MPU_Type       *)     MPU_BASE      )   /*!< Memory Protection Unit */
+#endif
+  #define FPU_BASE          (SCS_BASE +  0x0F30UL)                    /*!< Floating Point Unit */
+  #define FPU               ((FPU_Type       *)     FPU_BASE      )   /*!< Floating Point Unit */
+#endif
+ *                Hardware Abstraction Layer
+  Core Function Interface contains:
+  - Core NVIC Functions
+  - Core SysTick Functions
+  - Core Debug Functions
+  - Core Register Access Functions
+  \defgroup CMSIS_Core_FunctionInterface Functions and Instructions Reference
+/* ##########################   NVIC functions  #################################### */
+  \ingroup  CMSIS_Core_FunctionInterface
+  \defgroup CMSIS_Core_NVICFunctions NVIC Functions
+  \brief    Functions that manage interrupts and exceptions via the NVIC.
+  \brief   Set Priority Grouping
+  \details Sets the priority grouping field using the required unlock sequence.
+           The parameter PriorityGroup is assigned to the field SCB->AIRCR [10:8] PRIGROUP field.
+           Only values from 0..7 are used.
+           In case of a conflict between priority grouping and available
+           priority bits (__NVIC_PRIO_BITS), the smallest possible priority group is set.
+  \param [in]      PriorityGroup  Priority grouping field.
+__STATIC_INLINE void NVIC_SetPriorityGrouping(uint32_t PriorityGroup)
+  uint32_t reg_value;
+  uint32_t PriorityGroupTmp = (PriorityGroup & (uint32_t)0x07UL);             /* only values 0..7 are used          */
+  reg_value  =  SCB->AIRCR;                                                   /* read old register configuration    */
+  reg_value &= ~((uint32_t)(SCB_AIRCR_VECTKEY_Msk | SCB_AIRCR_PRIGROUP_Msk)); /* clear bits to change               */
+  reg_value  =  (reg_value                                   |
+                ((uint32_t)0x5FAUL << SCB_AIRCR_VECTKEY_Pos) |
+                (PriorityGroupTmp << 8U)                      );              /* Insert write key and priorty group */
+  SCB->AIRCR =  reg_value;
+  \brief   Get Priority Grouping
+  \details Reads the priority grouping field from the NVIC Interrupt Controller.
+  \return                Priority grouping field (SCB->AIRCR [10:8] PRIGROUP field).
+__STATIC_INLINE uint32_t NVIC_GetPriorityGrouping(void)
+  return ((uint32_t)((SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) >> SCB_AIRCR_PRIGROUP_Pos));
+  \brief   Enable External Interrupt
+  \details Enables a device-specific interrupt in the NVIC interrupt controller.
+  \param [in]      IRQn  External interrupt number. Value cannot be negative.
+__STATIC_INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
+  NVIC->ISER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+  \brief   Disable External Interrupt
+  \details Disables a device-specific interrupt in the NVIC interrupt controller.
+__STATIC_INLINE void NVIC_DisableIRQ(IRQn_Type IRQn)
+  NVIC->ICER[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+  \brief   Get Pending Interrupt
+  \details Reads the pending register in the NVIC and returns the pending bit for the specified interrupt.
+  \param [in]      IRQn  Interrupt number.
+  \return             0  Interrupt status is not pending.
+  \return             1  Interrupt status is pending.
+__STATIC_INLINE uint32_t NVIC_GetPendingIRQ(IRQn_Type IRQn)
+  return((uint32_t)(((NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  \brief   Set Pending Interrupt
+  \details Sets the pending bit of an external interrupt.
+  \param [in]      IRQn  Interrupt number. Value cannot be negative.
+__STATIC_INLINE void NVIC_SetPendingIRQ(IRQn_Type IRQn)
+  NVIC->ISPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+  \brief   Clear Pending Interrupt
+  \details Clears the pending bit of an external interrupt.
+__STATIC_INLINE void NVIC_ClearPendingIRQ(IRQn_Type IRQn)
+  NVIC->ICPR[(((uint32_t)(int32_t)IRQn) >> 5UL)] = (uint32_t)(1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL));
+  \brief   Get Active Interrupt
+  \details Reads the active register in NVIC and returns the active bit.
+  \return             0  Interrupt status is not active.
+  \return             1  Interrupt status is active.
+__STATIC_INLINE uint32_t NVIC_GetActive(IRQn_Type IRQn)
+  return((uint32_t)(((NVIC->IABR[(((uint32_t)(int32_t)IRQn) >> 5UL)] & (1UL << (((uint32_t)(int32_t)IRQn) & 0x1FUL))) != 0UL) ? 1UL : 0UL));
+  \brief   Set Interrupt Priority
+  \details Sets the priority of an interrupt.
+  \note    The priority cannot be set for every core interrupt.
+  \param [in]  priority  Priority to set.
+__STATIC_INLINE void NVIC_SetPriority(IRQn_Type IRQn, uint32_t priority)
+  if ((int32_t)(IRQn) < 0)
+    SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+  else
+    NVIC->IP[((uint32_t)(int32_t)IRQn)]               = (uint8_t)((priority << (8U - __NVIC_PRIO_BITS)) & (uint32_t)0xFFUL);
+  \brief   Get Interrupt Priority
+  \details Reads the priority of an interrupt.
+           The interrupt number can be positive to specify an external (device specific) interrupt,
+           or negative to specify an internal (core) interrupt.
+  \return             Interrupt Priority.
+                      Value is aligned automatically to the implemented priority bits of the microcontroller.
+__STATIC_INLINE uint32_t NVIC_GetPriority(IRQn_Type IRQn)
+    return(((uint32_t)SCB->SHP[(((uint32_t)(int32_t)IRQn) & 0xFUL)-4UL] >> (8U - __NVIC_PRIO_BITS)));
+  else
+    return(((uint32_t)NVIC->IP[((uint32_t)(int32_t)IRQn)]               >> (8U - __NVIC_PRIO_BITS)));
+  \brief   Encode Priority
+  \details Encodes the priority for an interrupt with the given priority group,
+           preemptive priority value, and subpriority value.
+  \param [in]     PriorityGroup  Used priority group.
+  \param [in]   PreemptPriority  Preemptive priority value (starting from 0).
+  \param [in]       SubPriority  Subpriority value (starting from 0).
+  \return                        Encoded priority. Value can be used in the function \ref NVIC_SetPriority().
+__STATIC_INLINE uint32_t NVIC_EncodePriority (uint32_t PriorityGroup, uint32_t PreemptPriority, uint32_t SubPriority)
+  uint32_t PreemptPriorityBits;
+  uint32_t SubPriorityBits;
+  PreemptPriorityBits = ((7UL - PriorityGroupTmp) > (uint32_t)(__NVIC_PRIO_BITS)) ? (uint32_t)(__NVIC_PRIO_BITS) : (uint32_t)(7UL - PriorityGroupTmp);
+  SubPriorityBits     = ((PriorityGroupTmp + (uint32_t)(__NVIC_PRIO_BITS)) < (uint32_t)7UL) ? (uint32_t)0UL : (uint32_t)((PriorityGroupTmp - 7UL) + (uint32_t)(__NVIC_PRIO_BITS));
+  return (
+           ((PreemptPriority & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL)) << SubPriorityBits) |
+           ((SubPriority     & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL)))
+  \brief   Decode Priority
+  \details Decodes an interrupt priority value with a given priority group to
+           preemptive priority value and subpriority value.
+           priority bits (__NVIC_PRIO_BITS) the smallest possible priority group is set.
+  \param [in]         Priority   Priority value, which can be retrieved with the function \ref NVIC_GetPriority().
+  \param [out] pPreemptPriority  Preemptive priority value (starting from 0).
+  \param [out]     pSubPriority  Subpriority value (starting from 0).
+__STATIC_INLINE void NVIC_DecodePriority (uint32_t Priority, uint32_t PriorityGroup, uint32_t* const pPreemptPriority, uint32_t* const pSubPriority)
+  *pPreemptPriority = (Priority >> SubPriorityBits) & (uint32_t)((1UL << (PreemptPriorityBits)) - 1UL);
+  *pSubPriority     = (Priority                   ) & (uint32_t)((1UL << (SubPriorityBits    )) - 1UL);
+  \brief   System Reset
+  \details Initiates a system reset request to reset the MCU.
+__STATIC_INLINE void NVIC_SystemReset(void)
+  __DSB();                                                          /* Ensure all outstanding memory accesses included
+        buffered write are completed before reset */
+  SCB->AIRCR  = (uint32_t)((0x5FAUL << SCB_AIRCR_VECTKEY_Pos)    |
+                           (SCB->AIRCR & SCB_AIRCR_PRIGROUP_Msk) |
+                            SCB_AIRCR_SYSRESETREQ_Msk    );         /* Keep priority group unchanged */
+  __DSB();                                                          /* Ensure completion of memory access */
+  for(;;)                                                           /* wait until reset */
+    __NOP();
+/*@} end of CMSIS_Core_NVICFunctions */
+/* ##################################    SysTick function  ############################################ */
+  \defgroup CMSIS_Core_SysTickFunctions SysTick Functions
+  \brief    Functions that configure the System.
+#if (__Vendor_SysTickConfig == 0U)
+  \brief   System Tick Configuration
+  \details Initializes the System Timer and its interrupt, and starts the System Tick Timer.
+           Counter is in free running mode to generate periodic interrupts.
+  \param [in]  ticks  Number of ticks between two interrupts.
+  \return          0  Function succeeded.
+  \return          1  Function failed.
+  \note    When the variable <b>__Vendor_SysTickConfig</b> is set to 1, then the
+           function <b>SysTick_Config</b> is not included. In this case, the file <b><i>device</i>.h</b>
+           must contain a vendor-specific implementation of this function.
+__STATIC_INLINE uint32_t SysTick_Config(uint32_t ticks)
+  if ((ticks - 1UL) > SysTick_LOAD_RELOAD_Msk)
+    return (1UL);                                                   /* Reload value impossible */
+  SysTick->LOAD  = (uint32_t)(ticks - 1UL);                         /* set reload register */
+  NVIC_SetPriority (SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); /* set Priority for Systick Interrupt */
+  SysTick->VAL   = 0UL;                                             /* Load the SysTick Counter Value */
+  SysTick->CTRL  = SysTick_CTRL_CLKSOURCE_Msk |
+                   SysTick_CTRL_TICKINT_Msk   |
+                   SysTick_CTRL_ENABLE_Msk;                         /* Enable SysTick IRQ and SysTick Timer */
+  return (0UL);                                                     /* Function successful */
+#endif
+/*@} end of CMSIS_Core_SysTickFunctions */
+/* ##################################### Debug In/Output function ########################################### */
+  \defgroup CMSIS_core_DebugFunctions ITM Functions
+  \brief    Functions that access the ITM debug interface.
+extern volatile int32_t ITM_RxBuffer;                    /*!< External variable to receive characters. */
+#define                 ITM_RXBUFFER_EMPTY   0x5AA55AA5U /*!< Value identifying \ref ITM_RxBuffer is ready for next character. */
+  \brief   ITM Send Character
+  \details Transmits a character via the ITM channel 0, and
+           \li Just returns when no debugger is connected that has booked the output.
+           \li Is blocking when a debugger is connected, but the previous character sent has not been transmitted.
+  \param [in]     ch  Character to transmit.
+  \returns            Character to transmit.
+__STATIC_INLINE uint32_t ITM_SendChar (uint32_t ch)
+  if (((ITM->TCR & ITM_TCR_ITMENA_Msk) != 0UL) &&      /* ITM enabled */
+      ((ITM->TER & 1UL               ) != 0UL)   )     /* ITM Port #0 enabled */
+    while (ITM->PORT[0U].u32 == 0UL)
+      __NOP();
+    ITM->PORT[0U].u8 = (uint8_t)ch;
+  return (ch);
+  \brief   ITM Receive Character
+  \details Inputs a character via the external variable \ref ITM_RxBuffer.
+  \return             Received character.
+  \return         -1  No character pending.
+__STATIC_INLINE int32_t ITM_ReceiveChar (void)
+  int32_t ch = -1;                           /* no character available */
+  if (ITM_RxBuffer != ITM_RXBUFFER_EMPTY)
+    ch = ITM_RxBuffer;
+    ITM_RxBuffer = ITM_RXBUFFER_EMPTY;       /* ready for next character */
+  return (ch);
+  \brief   ITM Check Character
+  \details Checks whether a character is pending for reading in the variable \ref ITM_RxBuffer.
+  \return          0  No character available.
+  \return          1  Character available.
+__STATIC_INLINE int32_t ITM_CheckChar (void)
+  if (ITM_RxBuffer == ITM_RXBUFFER_EMPTY)
+    return (0);                              /* no character available */
+  else
+    return (1);                              /*    character available */
+/*@} end of CMSIS_core_DebugFunctions */
+#ifdef __cplusplus
+#endif
+#endif /* __CORE_CM4_H_DEPENDANT */
+#endif /* __CMSIS_GENERIC */
2.25.1
