[PATCH] zynqmp: Add support for the CFC-400X
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Nov 1 18:38:40 UTC 2022
This adds a BSP variant for the ZynqMP BSP family to support the
Innoflight CFC-400X platform.
bsps/aarch64/xilinx-zynqmp/console/console.c | 72 +++++++++++++++++++
bsps/aarch64/xilinx-zynqmp/include/bsp.h | 11 +++
.../aarch64/xilinx-zynqmp/start/bspstartmmu.c | 7 ++
.../aarch64/xilinx-zynqmp/bspcfc400xlp64.yml | 21 ++++++
.../bsps/aarch64/xilinx-zynqmp/optloadoff.yml | 1 +
.../aarch64/xilinx-zynqmp/optmgmtbase.yml | 20 ++++++
.../bsps/aarch64/xilinx-zynqmp/optramori.yml | 1 +
spec/build/cpukit/optsmp.yml | 1 +
8 files changed, 134 insertions(+)
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optmgmtbase.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
index d1948f1a0c..2fe71787dd 100644
--- a/bsps/aarch64/xilinx-zynqmp/console/console.c
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -43,6 +43,69 @@
#include <bspopts.h>
+#ifdef BSP_XILINX_ZYNQMP_MGMT_UART_BASE
+#include <libchip/ns16550.h>
+/* These values come from the super_if_axi_uart16550_0 DTS entry */
+/* From the Linux DTS, reg-offset */
+#define MGMT_PORT_OFFSET 0x1000
+/* From the Linux DTS, 89 + 32 (Shared Peripheral Interrupt offset) */
+#define MGMT_PORT_IRQ 121
+/* This provides a clock divider of 14 */
+#define MGMT_PORT_CLK 25804800
+static uint8_t get_register(uintptr_t addr, uint8_t i)
+ volatile uint8_t *reg = (uint8_t *) addr;
+ i <<= 2;
+ return reg [i];
+static void set_register(uintptr_t addr, uint8_t i, uint8_t val)
+ i <<= 2;
+ reg [i] = val;
+static ns16550_context zynqmp_mgmt_uart_context_0 = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("Management UART 0"),
+ .get_reg = get_register,
+ .set_reg = set_register,
+ .port = BSP_XILINX_ZYNQMP_MGMT_UART_BASE + MGMT_PORT_OFFSET,
+ .irq = MGMT_PORT_IRQ,
+ .clock = MGMT_PORT_CLK,
+ .initial_baud = 115200,
+__attribute__ ((weak)) void zynqmp_configure_management_console(void)
+ /* This SLIP-encoded watchdog command sets timeouts to 0xFFFFFFFF seconds. */
+ const char mgmt_watchdog_cmd[] =
+ "\xc0\xda\x00\x00\xff\xff\xff\xff\xff\x00\xff\xff\xff\xffM#\xc0";
+ /* Send the system watchdog configuration command */
+ for (int i = 0; i < sizeof(mgmt_watchdog_cmd); i++) {
+ ns16550_polled_putchar(&zynqmp_mgmt_uart_context_0.base, mgmt_watchdog_cmd[i]);
+static void zynqmp_management_console_init(void)
+ ns16550_probe(&zynqmp_mgmt_uart_context_0.base);
+ zynqmp_configure_management_console();
+RTEMS_SYSINIT_ITEM(
+ zynqmp_management_console_init,
+ RTEMS_SYSINIT_BSP_START,
+ RTEMS_SYSINIT_ORDER_FIRST
+#endif
static zynq_uart_context zynqmp_uart_instances[2] = {
.base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
@@ -81,6 +144,15 @@ rtems_status_code console_initialize(
+ rtems_termios_device_install(
+ "/dev/ttyMGMT0",
+ &ns16550_handler_polled,
+ NULL,
+ &zynqmp_mgmt_uart_context_0.base
+#endif
return RTEMS_SUCCESSFUL;
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index d937a313f2..c823d963c5 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -83,6 +83,17 @@ uint32_t zynqmp_clock_i2c0(void);
uint32_t zynqmp_clock_i2c1(void);
+ * @brief Zynq UltraScale+ MPSoC specific set up of a management console.
+ * The ZynqMP SoC's programmable logic can provide a serial interface for system
+ * management which may need special initialization. Provide in the application
+ * to override the defaults in the BSP.
+__attribute__ ((weak)) void zynqmp_configure_management_console(void);
+#endif
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
index 33ca1eafab..30b926a7c0 100644
--- a/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c
@@ -50,6 +50,13 @@ zynqmp_mmu_config_table[] = {
.begin = 0xfd000000U,
.end = 0xffc00000U,
.flags = AARCH64_MMU_DEVICE
+/* This covers the range of addresses where the UART could be */
+ .begin = 0x80000000U,
+ .end = 0x90000000U,
+ .flags = AARCH64_MMU_DEVICE
+#endif
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
new file mode 100644
index 0000000000..05e53c3539
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspcfc400xlp64.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+arch: aarch64
+bsp: xilinx_zynqmp_lp64_cfc400x
+build-type: bsp
+cflags: []
+copyrights:
+- Copyright (C) 2022 On-Line Applications Research (OAR)
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp_zu3eg
+ uid: linkcmds_lp64
+ uid: optmgmtbase
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
index 0bdc2d61df..976a4aeb0e 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
@@ -11,6 +11,7 @@ default: 32768
default-by-variant:
- value: 0x0
variants:
+ - aarch64/xilinx_zynqmp_lp64_cfc400x
- aarch64/xilinx_zynqmp_lp64_zu3eg
- aarch64/xilinx_zynqmp_ilp32_zu3eg
description: |
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optmgmtbase.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optmgmtbase.yml
index 0000000000..8bb59e199b
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optmgmtbase.yml
@@ -0,0 +1,20 @@
+actions:
+- get-integer: null
+- assert-uint64: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+# The super_if_axi_uart16550_0 management UART exists in the FPGA fabric and may
+# exist at different addresses such as 0x80090000.
+default: 0x800a0000
+default-by-variant: []
+description: |
+ Base address of ZynqMP management UART
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_ZYNQMP_MGMT_UART_BASE
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
index c17febe288..427f14c7c8 100644
--- a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
@@ -11,6 +11,7 @@ default: 0x40018000
default-by-variant:
- value: 0x10000000
variants:
description: |
diff --git a/spec/build/cpukit/optsmp.yml b/spec/build/cpukit/optsmp.yml
index b218364194..db404efe21 100644
--- a/spec/build/cpukit/optsmp.yml
+++ b/spec/build/cpukit/optsmp.yml
@@ -13,6 +13,7 @@ description: |
enabled-by:
- aarch64/xilinx_zynqmp_ilp32_qemu
+- aarch64/xilinx_zynqmp_lp64_cfc400x
- aarch64/xilinx_zynqmp_lp64_qemu
- arm/altcycv_devkit
2.30.2
