Fwd: Identify 3rd party source in spec?
Gedare Bloom
gedare at rtems.org
Wed Nov 2 23:30:49 UTC 2022
It was pointed out in Discord that the "third_party_list" command is
unusual with respect to other waf commands, which are given as oneword
formats (other than bsp_list and bsp_defaults). I think it makes sense
to go with such a oneword format for consistent commands. So I will
instead start prototyping this as
./waf thirdparties
instead of
./waf third_party_list
Relatedly: I might look into changing
./waf bsp_list
to
./waf bsps
and
./waf bsp_defaults
to
./waf bspdefaults
the hard part will be chasing down the documentation.
On Wed, Nov 2, 2022 at 9:50 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Nov 2, 2022 at 9:10 AM Gedare Bloom <gedare at rtems.org> wrote:
> > On Wed, Nov 2, 2022 at 1:10 AM Christian MAUDERER
> > <christian.mauderer at embedded-brains.de> wrote:
> > > Hello Chris,
> > > Am 01.11.22 um 22:08 schrieb Chris Johns:
> > > > On 2/11/2022 3:25 am, oss at c-mauderer.de wrote:> Is it a good idea to make it a
> > > > mandatory attribute? It makes the yaml files
> > > >> bigger. It will only mean that we have to look for copy and paste bugs instead
> > > >> of missing attributes if someone adds a new third party library.
> > > > Can you avoid having to add the item to all? I am no spec build system expert
> > > > (having invested time) and seem to remember needing to hit a lot of files when
> > > > adding something ...
> > > > https://git.rtems.org/rtems/commit/?id=6f2aa8ad36e3aaffc9fa2cb8c744b04da7339ee2
> > > > Chris
> > > The documentation mentions at least some optional attributes in the
> > > specification files. For example "format" in a build option item or the
> > > "do-configure" in a build script item:
> > > https://docs.rtems.org/branches/master/eng/req/items.html#build-option-item-type
> > > https://docs.rtems.org/branches/master/eng/req/items.html#build-script-item-type
> > > But I think the wscript has to take into account that the value might
> > > not exist. I'm not sure whether it does that for the existing "optional"
> > > attributes. For example my first guess would be that the "do-configure"
> > > could throw a KeyError:
> > > https://git.rtems.org/rtems/tree/wscript#n1127
> > > def do_configure(self, conf, cic):
> > > script = self.data["do-configure"]
> > > if script:
> > > exec(script)
> > > Usually I would have expected the following code instead:
> > > try:
> > > except KeyError:
> > > script = None
> > > if script:
> > > exec(script)
> > Thanks for this recommendation and the discussion/example. Indeed, the
> > plumbing right now in the wscript is not very robust to optional
> > attributes. For this particular third-party attribute I will take a
> > stab at making it optional.
> This works pretty well. See attached. I'll continue with the optional
> attribute route for now.
> > I think the additional metadata we would like to track regarding
> > third-party sources can be added incrementally or even separately. I
> > would like to first solve the problem of how to separate third-party
> > from project-owned sources. Once that is done, then we can discuss
> > more ways to improve or use this capability.
> > > So I can't clearly answer your question. I would have to try it. But
> > > regardless whether there are currently such options or not: They
> > > shouldn't be hard to implement. I just hope that this doesn't break some
> > > use case. I'll try to remember to ask Sebastian about it next week.
> > Thanks, I will appreciate that feedback and any tricky things to watch out for.
> > > Best regards
> > > Christian
> > > embedded brains GmbH
> > > Herr Christian MAUDERER
> > > Dornierstr. 4
> > > 82178 Puchheim
> > > Germany
> > > email: christian.mauderer at embedded-brains.de
> > > phone: +49-89-18 94 741 - 18
> > > mobile: +49-176-152 206 08
> > > Registergericht: Amtsgericht München
> > > Registernummer: HRB 157899
> > > Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> > > Unsere Datenschutzerklärung finden Sie hier:
> > > https://embedded-brains.de/datenschutzerklaerung/
