[PATCH rtems] Remove remnants of rtems_io_lookup_name
Wed Nov 9 14:00:39 UTC 2022
Updates #3420.
 cpukit/include/adainclude/rtems-io.adb | 21 ---------------------
 testsuites/sptests/sp21/sp21.scn       |  3 ---
 2 files changed, 24 deletions(-)
diff --git a/cpukit/include/adainclude/rtems-io.adb b/cpukit/include/adainclude/rtems-io.adb
index 41a315c..addc2e2 100644
--- a/cpukit/include/adainclude/rtems-io.adb
+++ b/cpukit/include/adainclude/rtems-io.adb
@@ -67,27 +67,6 @@ package body RTEMS.IO is
    end Register_Name;
-   procedure Lookup_Name
-     (Name        : in String;
-      Device_Info : out RTEMS.Driver_Name_t;
-      Result      : out RTEMS.Status_Codes)
-   is
-      function Lookup_Name_Base
-        (Name        : Interfaces.C.char_array;
-         Device_Info : access RTEMS.Driver_Name_t)
-         return        RTEMS.Status_Codes;
-      pragma Import (C, Lookup_Name_Base, "rtems_io_lookup_name");
-      Device_Info_Base : aliased RTEMS.Driver_Name_t;
-   begin
-      Result      :=
-         Lookup_Name_Base
-           (Interfaces.C.To_C (Name),
-            Device_Info_Base'Unchecked_Access);
-      Device_Info := Device_Info_Base;
-   end Lookup_Name;
    procedure Open
      (Major    : in RTEMS.Device_Major_Number;
       Minor    : in RTEMS.Device_Minor_Number;
diff --git a/testsuites/sptests/sp21/sp21.scn b/testsuites/sptests/sp21/sp21.scn
index 6c099df..87c798d 100644
--- a/testsuites/sptests/sp21/sp21.scn
+++ b/testsuites/sptests/sp21/sp21.scn
@@ -25,8 +25,5 @@ rtems_io_register_driver - RTEMS_SUCCESSFUL - overwrite NULL
 rtems_io_register_driver - RTEMS_TOO_MANY - no slots
 rtems_io_register_driver - RTEMS_RESOURCE_IN_USE - major in use
 rtems_io_unregister_driver - RTEMS_SUCCESSFUL
-rtems_io_lookup_name( "", &info ) - RTEMS_UNSATISFIED
-rtems_io_lookup_name( "/dev", &info ) - RTEMS_UNSATISFIED
-rtems_io_lookup_name( "/dev/null", &info ) - RTEMS_SUCCESSFUL
 -----  TESTING THE ZERO DRIVER CHECKS  -----
 *** END OF TEST 21 ***
1.8.3.1
