[PATCH] cpukit/fdt: Fix typos and clarify params
Chris Johns
chrisj at rtems.org
Thu Nov 10 21:00:17 UTC 2022
OK.
Thanks
On 10/11/22 4:01 am, Kinsey Moore wrote:
> cpukit/include/rtems/rtems-fdt.h | 24 +++++++++++++++---------
> 1 file changed, 15 insertions(+), 9 deletions(-)
> diff --git a/cpukit/include/rtems/rtems-fdt.h b/cpukit/include/rtems/rtems-fdt.h
> index 3919593582..18e04352aa 100644
> --- a/cpukit/include/rtems/rtems-fdt.h
> +++ b/cpukit/include/rtems/rtems-fdt.h
> @@ -256,7 +256,7 @@ int rtems_fdt_register (const void* blob, rtems_fdt_handle* handle);
> * Unload a device tree blob or DTB file and release any memory allocated when
> - * loading. The blob is removed from the list of registered.
> + * loading. The blob is removed from the list if registered.
> * @param blob_desc A valid blob descriptor.
> * @return int If less than 0 it is an error code else 0 is return on success.
> @@ -296,7 +296,7 @@ int rtems_fdt_get_mem_rsv (rtems_fdt_handle* handle,
> * larger string, such as a full path.
> - * @param arentoffset Structure block offset of a node
> + * @param parentoffset Structure block offset of a node
> * @param name Name of the subnode to locate.
> * @param namelen Number of characters of name to consider.
> * @return int If less than 0 it is an error code else the node offset is
> @@ -345,7 +345,9 @@ int rtems_fdt_path_offset (rtems_fdt_handle* handle, const char* path);
> * @param handle The FDT handle to the current blob.
> * @param nodeoffset Structure block offset of the starting node.
> - * @param length Pointer to an integer variable (will be overwritten) or NULL.
> + * @param length Pointer to an integer variable or NULL. If non-NULL, this will
> + * be overwritten with either the length in bytes or the error
> + * code.
> * @return const char* The node's name on success or NULL on error. The length
> * if non-NULL will hold the error code.
> @@ -378,7 +380,9 @@ int rtems_fdt_next_prop_offset(rtems_fdt_handle* handle, int propoffset);
> * @param propoffset Property offset
> * @param name If not NULL set the pointer to the name string.
> + * code.
> * @return const void* The node's value data.
> const void* rtems_fdt_getprop_by_offset(rtems_fdt_handle* handle,
> @@ -395,8 +399,9 @@ const void* rtems_fdt_getprop_by_offset(rtems_fdt_handle* handle,
> * @param nodeoffset Offset of the node whose property to find
> * @param name The name of the property to find
> * @param namelen The number of characters of name to consider
> - * @param length A pointer to an integer variable (will be overwritten) or
> - * NULL.
> + * code.
> * @return const void* The node's property on success or NULL on error. The
> * length if non-NULL will hold the error code.
> @@ -416,8 +421,9 @@ const void *rtems_fdt_getprop_namelen (rtems_fdt_handle* handle,
> * @param nodeoffset The offset of the node whose property to find.
> * @param name The name of the property to find.
> - * NULL.
> + * code.
> @@ -427,7 +433,7 @@ const void *rtems_fdt_getprop (rtems_fdt_handle* handle,
> int* length);
> - * Retrieve the phandle of a given of the device tree node at structure block
> + * Retrieve the phandle of the device tree node at structure block
> * offset nodeoffset.
