[rtems-docs commit] Update build system related sections for RTEMS 6
Sebastian Huber
Fri Nov 11 07:39:14 UTC 2022
On 10/11/2022 01:30, Chris Johns wrote:
> The first is the maintenance of embedded the version numbers in the
> documentation. If we can avoid doing that the work per release or dot
> release is less.
We could use a simple search and replace for this. Searching for
'rtems[0-9]' shows a couple of spots which need a more through rework.
We even have stuff with rtems4.10.
> The second is the changing of `kernel` to `src`. The use of `kernel` was
> specific because it removes any ambiguity when a new user attempts to
> build a package like libbsd in the same tree. Source can mean it is the
> place where all source is placed. I think `kernel` should be used and
> returned.
I usually place all Git repositories in a "src" directory.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
