Apple's Ventura OS issue with RSB.
Karel Gardas karel at functional.vision
Sat Nov 12 19:02:59 UTC 2022
Hi,
more info on the issue. So, with Ventura I went up to 95 builds of
6/rtems-sparc from which 29 failed.
I've found out that M1 Parallels supports installing Mac OS X
installation into the VM hence went ahead and installed Monterey to have
both OSes available on the same box. Now, in Monterey VM I did 54 builds
of 6/rtems-sparc and with 0 failures. All built fine.
As the issue is pretty random it's really hard to report anything
meaningful to any community. Hence just heads up to you, if you are on
Mac OS X, expect some issues with Ventura -- till hopefully Apple fixes
those...
Karel
On 11/8/22 10:15, Karel Gardas wrote:
> More info on this issue:
> (1) the issue (internal compiler error) does not happen all the time. In
> fact there are builds which even complete. The ratio failure/ok is 10/30
> so far -- building in a loop 6/rtems-sparc.
> (2) attempt to bootstrap with GCC failed even more miserably. At least
> with GCC 12.x I installed from homebrew. The symptoms are fork sys call
> failing and a lot of processes created during the configure stage of
> various packages in a manner that it's too much. Basically RSB's
> packages' configure scripts are a fork bomb for whatever reason here on
> Ventura when attempting to use homebrew GCC 12.x. See below.
> Due to nature of unpredictability this is not something worth reporting
> to GCC team now IMHO. We need to investigate more.
> Ryan, if I'm not mistaken you have M1 mini for RTEMS builds, is that
> right? If so, do you still have Monterey on it? If so, could you be so
> kind and loop building of RSB's 6/rtems-sparc and allow it run for some
> time to see if by any mistake we have not overlooked the same stability
> issues on Monterey too? Let's say 1-2 days run should be enough to tell
> us more or give us some confidence if all builds pass well.
> What I did to my clean config in order to compile RSB is:
> - install xz (from homebrew is fine), side effect of this is you will
> get Apple's command line developer tools installed too -- which you need.
> - compile python3.10 from source -- you need to enable SSL on it
> otherwise RSB would not be able to download from https.
> - set paths to those two and run RSB
> Nothing more was needed on Monterey in order to RSB compile...
> Thanks!
> Karel
> Fork issues (example):
> checking whether strtoull is declared... no
> checking whether strverscmp is declared... no
> checking whether strnlen is declared... no
> checking whether canonicalize_file_name must be declared... yes
> checking for stdlib.h... (cached) yes
> /Users/karel/src/macosx-fix-sis/rtems/build/arm-rtems6-gdb-11.2-arm64-apple-darwin22.1.0-1/gdb-11.2/libiberty/configure: fork: Resource temporarily unavailable
> checking for unistd.h... (cached) yes
> checking for sys/param.h... (cached) yes
> checking for getpagesize... (cached) yes
> checking for working mmap... no
> checking for working strncmp... no
> configure: updating cache ./config.cache
> configure: creating ./config.status
> ./config.status: fork: Resource temporarily unavailable
> make[1]: *** [configure-libiberty] Error 1
> rm: conftest.dSYM: is a directory
> BSD nm
> checking whether ln -s works... yes
> On 11/6/22 16:09, Joel Sherrill wrote:
>> Is the cross gcc compiled with the native compiler provided by Apple?
>> The alternative would likely be you installing something special.
>> I wonder if using gcc to compile it would work. But there's not a real
>> solution.
>> Seems like an issue which needs reporting to gcc.
>> On Sun, Nov 6, 2022, 5:25 AM Karel Gardas <karel at functional.vision>
>> wrote:
>>        Folks,
>>     upgraded to Ventura from Monterey and this breaks RSB for unknown
>>     reason. The issue looks like segfault/internal compiler error in GCC
>>     while compiling newlib.
>>     6/rtems-sparc:
>>         CC       libc/stdlib/libc_a-strtoll_r.o
>>         CC       libm/complex/libm_a-cpowf.o
>>     ../../../../gnu-mirror-gcc-a5a6598/newlib/libm/complex/cexpf.c: In
>>     function 'cexpf':
>>     ../../../../gnu-mirror-gcc-a5a6598/newlib/libm/complex/cexpf.c:47:9:
>>     internal compiler error: Segmentation fault: 11
>>          47 |         w = r * cosf(y) + r * sinf(y) * I;
>>     libbacktrace could not find executable to open
>>     Please submit a full bug report, with preprocessed source (by using
>>     -freport-bug).
>>     See <https://gcc.gnu.org/bugs/ <https://gcc.gnu.org/bugs/>> for
>>     instructions.
>>     make[6]: *** [libm/complex/libm_a-cexpf.o] Error 1
>>     make[6]: *** Waiting for unfinished jobs....
>>         CC       libc/stdlib/libc_a-strtoull_r.o
>>         CC       libc/stdlib/libc_a-wcstoll.o
>>         CC       libc/stdlib/libc_a-wcstoll_r.o
>>         CC       libc/stdlib/libc_a-wcstoull.o
>>         CC       libc/stdlib/libc_a-wcstoull_r.o
>>         CC       libc/stdlib/libc_a-atoll.o
>>     make[5]: *** [all] Error 2
>>     make[4]: *** [multi-do] Error 1
>>     make[3]: *** [all-multi] Error 2
>>     make[3]: *** Waiting for unfinished jobs....
>>     6/rtems-arm:
>>         CC       libm/common/libm_a-s_isinf.o
>>         CC       libm/common/libm_a-s_isinfd.o
>> ../../../../../../gnu-mirror-gcc-a5a6598/newlib/libm/common/s_expm1.c:
>>     In function 'expm1':
>>         CC       libm/common/libm_a-s_isnan.o
>> ../../../../../../gnu-mirror-gcc-a5a6598/newlib/libm/common/s_expm1.c:225:9:
>>     internal compiler error: in real_from_string, at real.cc:2131
>>         225 |         hfx = 0.5*x;
>>         CC       libm/common/libm_a-s_isnand.o
>>     -freport-bug).
>>     instructions.
>>     make[6]: *** [libm/common/libm_a-s_expm1.o] Error 1
>>         CC       libm/common/libm_a-s_log1p.o
>>     make[2]: *** [all] Error 2
>>     make[1]: *** [all-target-newlib] Error 2
>>     make: *** [all] Error 2
>>     shell cmd failed: /bin/sh -ex
>>     /Users/karel/src/macosx-fix-sis/rtems/build/arm-rtems6-gcc-a5a6598
>>     So just HEADS UP to those using Mac OS X on Apple silicon!
>>     Karel
>>     _______________________________________________
>>     devel mailing list
>>     devel at rtems.org <mailto:devel at rtems.org>
>>     http://lists.rtems.org/mailman/listinfo/devel
>>     <http://lists.rtems.org/mailman/listinfo/devel>
> devel mailing list
> devel at rtems.org
