[PATCH 4/6] bsps/riscv: Change license to BSD-2 for files with Gaisler copyright
Mon Nov 14 16:04:48 UTC 2022
I have no idea what the correct answer is but is this the time to make all
the references to Gaisler the same? You guys have been bought a few times
with names changes :)
Other than that, these all look good to me.
--joel
On Mon, Nov 14, 2022, 4:03 AM Daniel Cederman <cederman at gaisler.com> wrote:
> This patch changes the license to BSD-2 for all source files where the
> copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
> Some files also includes copyright right statements from OAR and/or
> embedded Brains in addition to Gaisler.
> Updates #3053.
>  bsps/riscv/griscv/clock/clockdrv.c         | 25 +++++++++++++++++++---
>  bsps/riscv/griscv/console/console.c        | 25 +++++++++++++++++++---
>  bsps/riscv/griscv/console/printk_support.c | 25 +++++++++++++++++++---
>  bsps/riscv/griscv/include/amba.h           | 25 +++++++++++++++++++---
>  bsps/riscv/noel/include/bsp.h              |  2 ++
>  5 files changed, 90 insertions(+), 12 deletions(-)
> diff --git a/bsps/riscv/griscv/clock/clockdrv.c
> b/bsps/riscv/griscv/clock/clockdrv.c
> index a5b7b15760..a8e157c71c 100644
> --- a/bsps/riscv/griscv/clock/clockdrv.c
> +++ b/bsps/riscv/griscv/clock/clockdrv.c
> @@ -1,3 +1,5 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   *  Clock Tick Device Driver
> @@ -15,9 +17,26 @@
>   *  Copyright (c) 2014, 2018 embedded brains GmbH
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
>  #include <bsp.h>
> diff --git a/bsps/riscv/griscv/console/console.c
> b/bsps/riscv/griscv/console/console.c
> index c0e19cddfe..af4c19d4cb 100644
> --- a/bsps/riscv/griscv/console/console.c
> +++ b/bsps/riscv/griscv/console/console.c
> @@ -1,3 +1,5 @@
>   *  This file contains the TTY driver for the GRLIB APBUART
> @@ -10,9 +12,26 @@
>   *  COPYRIGHT (c) 2004.
>   *  Gaisler Research.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
>  /* Define CONSOLE_USE_INTERRUPTS to enable APBUART interrupt handling
> instead
> diff --git a/bsps/riscv/griscv/console/printk_support.c
> b/bsps/riscv/griscv/console/printk_support.c
> index f232203520..3a3450551f 100644
> --- a/bsps/riscv/griscv/console/printk_support.c
> +++ b/bsps/riscv/griscv/console/printk_support.c
> @@ -1,3 +1,5 @@
>   *  This file contains the TTY driver for the GRLIb APBUART
> @@ -10,9 +12,26 @@
>   *  COPYRIGHT (c) 2011.
>   *  Aeroflex Gaisler.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
>  #include <bsp.h>
> diff --git a/bsps/riscv/griscv/include/amba.h
> b/bsps/riscv/griscv/include/amba.h
> index 292660d5c1..cff3a53d9e 100644
> --- a/bsps/riscv/griscv/include/amba.h
> +++ b/bsps/riscv/griscv/include/amba.h
> @@ -1,3 +1,5 @@
>   * @file
> @@ -12,9 +14,26 @@
>   *  Gaisler Research
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
>  #ifndef __AMBA_H__
> diff --git a/bsps/riscv/noel/include/bsp.h b/bsps/riscv/noel/include/bsp.h
> index 1b6686a01a..8cad281b6a 100644
> --- a/bsps/riscv/noel/include/bsp.h
> +++ b/bsps/riscv/noel/include/bsp.h
> @@ -1,3 +1,5 @@
>   * @file
> 2.37.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221114/7dfd4397/attachment.htm>
