[PATCH 2/2] user: Add documentation for leon2 and leon3 BSP
Tue Nov 15 14:50:34 UTC 2022
doc patches OK
On Wed, Oct 26, 2022 at 5:35 AM Daniel Cederman <cederman at gaisler.com> wrote:
>  user/bsps/bsps-sparc.rst | 74 ++++++++++++++++++++++++++++++++++++++--
>  1 file changed, 72 insertions(+), 2 deletions(-)
> diff --git a/user/bsps/bsps-sparc.rst b/user/bsps/bsps-sparc.rst
> index d0316a9..a2c2a47 100644
> --- a/user/bsps/bsps-sparc.rst
> +++ b/user/bsps/bsps-sparc.rst
> @@ -20,11 +20,81 @@ TODO.
>  leon2
> -TODO.
> +This BSP supports LEON2 systems, in particular the `Microchip AT697F
> +<https://www.microchip.com/en-us/product/AT697F>`_. The following
> +default build configurations are provided:
> +* leon2 - A generic LEON2 system with memory at 0x4000000.
> +* at697f - For the AT697F. Built with ``-mcpu=leon3 -mfix-ut700``.
> +The BSP contains UART, timer, and interrupt controller drivers.
> +Drivers for PCI are available through the :ref:`driver manager <BSP_sparc_leon3_drv_mgr>`.
>  .. _BSP_sparc_leon3:
>  leon3
> -TODO.
> +This BSP supports the LEON3/4/5 systems from Cobham Gaisler.
> +The following default build configurations are provided:
> +* leon3 - A generic `LEON3/4/5 <https://www.gaisler.com/leon5>`_ system with memory at 0x4000000.
> +* ut700 - For the `UT700 <https://caes.com/product/ut700>`_. Built with ``-mcpu=leon3 -mfix-ut700``.
> +* ut699 - For the `UT699 <https://caes.com/product/ut699>`_. Built with ``-mcpu=leon -mfix-ut699``.
> +* gr712rc - For the `GR712RC <https://www.gaisler.com/gr712rc>`_. Built with ``-mcpu=leon3 -mfix-gr712rc``.
> +* gr740 - For the `GR740  <https://www.gaisler.com/gr740>`_. Memory located at address 0x0.
> +The BSP contains UART, timer, and interrupt controller drivers. Drivers for additional
> +peripherals are available through the driver manager.
> +.. _BSP_sparc_leon3_drv_mgr:
> +Driver Manager
> +The leon3 BSP includes an optional driver manager that handles drivers and
> +devices on the AMBA and PCI Plug & Play buses. The driver manager can either
> +be initialized manually by the user, or started automatically on startup by
> +setting the ``RTEMS_DRVMGR_STARTUP`` option. It can be configured to
> +automatically instantiate a driver for each hardware device found.
> +Drivers for the following devices are provided and handled via the driver manager:
> +* SpaceWire (GRSPW, GRSPW2)
> +* SpaceWire Router (GRSPWROUTER)
> +* SpaceWire Time Distribution Protocol (SPWTDP)
> +* CAN - non-DMA (OCCAN) and DMA (GRCAN, GRCANFD)
> +- GPIO (GRGPIO)
> +- L2 Cache (L2CACHE)
> +- IOMMU (GRIOMMU)
> +- ADC/DAC (GRADCDAC)
> +- Timers (GPTIMER, GRTIMER)
> +- 1553 BC, RT and BM support (GR1553B)
> +- I2C Master (I2CMST)
> +- PCI (GRPCI2, GRPCI, PCIF)
> +- Memory Controller (MCTRL)
> +- Memory Scrubber (MEMSCRUB)
> +- Pulse Width Modulation Generator (GRPWM)
> +- CCSDS/ECSS Telemetry Encoder/Decoder (GRTM/GRTC)
> +- CSDS Time Manager (GRCTM)
> +- Ethernet (GRETH 10/100/1000) (requires network stack)
> +- Performance counters (L4STAT)
> +- Serial Peripheral Interface (AHBSTAT)
> +- AHB Status (AHBSTAT)
> +Build Configuration Options
> +The following options can be used in the BSP section of the ``waf``
> +configuration INI file. The ``waf`` defaults can be used to inspect the values.
> +``CONSOLE_USE_INTERRUPTS``
> +     Use the Termios interrupt mode in the console driver (false by default).
> +``RTEMS_DRVMGR_STARTUP``
> +     Enable the Driver Manager at startup (false by default).
> 2.34.1
> devel mailing list
> devel at rtems.org
