[PATCH 6/6] testsuites/smptests: Change license to BSD-2 for files with Gaisler copyright
Tue Nov 15 14:53:23 UTC 2022
Relicensing patches look good. Someone can check in
On Mon, Nov 14, 2022 at 3:03 AM Daniel Cederman <cederman at gaisler.com> wrote:
> This patch changes the license to BSD-2 for all source files where the
> copyright is held by Aeroflex Gaisler, Cobham Gaisler, or Gaisler Research.
> Updates #3053.
>  testsuites/smptests/smpcapture02/init.c | 25 ++++++++++++++++++++++---
>  1 file changed, 22 insertions(+), 3 deletions(-)
> diff --git a/testsuites/smptests/smpcapture02/init.c b/testsuites/smptests/smpcapture02/init.c
> index 4b11e6bbd7..e15945cb91 100644
> --- a/testsuites/smptests/smpcapture02/init.c
> +++ b/testsuites/smptests/smpcapture02/init.c
> @@ -1,10 +1,29 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   *  COPYRIGHT (c) 2015
>   *  Cobham Gaisler
> - *  The license and distribution terms for this file may be
> - *  found in the file LICENSE in this distribution or at
> - *  http://www.rtems.org/license/LICENSE.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> 2.37.2
> devel mailing list
> devel at rtems.org
