[PATCH] c-user: CAN framework docs
Prashanth S
fishesprashanth at gmail.com
Wed Nov 16 06:14:28 UTC 2022
Hi Gedare,
> What are the images?
There three images:
images/c_user/CAN-framework.jpg ->* Overview of CAN-Framework*
images/c_user/CAN-rx-data-path.jpg -> *Rx Data Path flow*
images/c_user/CAN-tx-data-path.jpg -> *Tx Data Path flow*
> This is not exactly correct. It is actually recessive where | CANH -
> CANL | < t1 for some threshold t1,
> and dominant where | CANH - CANL | > t2. And there is a gap where the
> bus is not defined at t1 < | CANH - CANL| < t2
> This detail is not so important here, but if we're going to describe
> it then we need it to be correct.
> > +A 0 data bit encodes a dominant state, while a 1 data bit encodes a
recessive
> > +state, supporting a wired-AND convention, which gives nodes with lower
ID
> > +numbers priority on the bus.
> I see this text has been copied from Wikipedia. This is not acceptable
> without proper attribution/reference. Please rewrite, remove, or
> reference cited material properly. Please identify if any of the below
> text is also copied from anywhere else.
I will rewrite this text.
> > +This document covers, the CAN framework and its usage by BSP CAN
drivers and
> Remove the comma after covers
> typo: Initialize
> typo: Further
I will update these typo errors.
Regards
Prashanth S
On Tue, 15 Nov 2022 at 20:34, Gedare Bloom <gedare at rtems.org> wrote:
> Hi Prashant,
> On Tue, Nov 15, 2022 at 7:49 AM Prashanth S <fishesprashanth at gmail.com>
> wrote:
> > bsp-howto/can.rst | 201 +++++++++++++++++++++++++++++
> > bsp-howto/index.rst | 1 +
> > images/c_user/CAN-framework.jpg | Bin 0 -> 146625 bytes
> > images/c_user/CAN-rx-data-path.jpg | Bin 0 -> 187438 bytes
> > images/c_user/CAN-tx-data-path.jpg | Bin 0 -> 128765 bytes
> > 5 files changed, 202 insertions(+)
> > create mode 100644 bsp-howto/can.rst
> > create mode 100644 images/c_user/CAN-framework.jpg
> > create mode 100644 images/c_user/CAN-rx-data-path.jpg
> > create mode 100644 images/c_user/CAN-tx-data-path.jpg
> > diff --git a/bsp-howto/can.rst b/bsp-howto/can.rst
> > new file mode 100644
> > index 0000000..36d6a04
> > --- /dev/null
> > +++ b/bsp-howto/can.rst
> > @@ -0,0 +1,201 @@
> > +.. SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. Copyright (C) 2022 Prashanth S <fishesprashanth at gmail.com>
> > +CAN Library
> > +Introduction
> > +The Controller Area Network is a robust multi-master serial
> communication
> > +protocol extensively used in automobiles for reliable data transfer.
> Two or more
> > +nodes are required on the CAN network to communicate. All nodes are
> connected to
> > +each other through a physically conventional two-wire bus. The wires
> are a
> > +twisted pair with a 120 Ω (nominal) characteristic impedance.
> > +This bus uses differential wired-AND signals. Two signals, CAN high
> (CANH) and
> > +CAN low (CANL) are either driven to a "dominant" state with CANH > CANL
> or not
> > +driven and pulled by passive resistors to a "recessive" state with CANH
> ≤ CANL.
> recessive
> ID
> drivers and
> > +applications.
> > +The CAN framework allows the applications to be written in a portable
> manner,
> > +which implies that an application can access the CAN bus without
> knowing the
> > +details of the CAN hardware, the platform specific translations are
> taken care
> > +by the CAN framework (So the application can focus more on the CAN
> protocol
> > +specific implementation).
> > +The CAN framework aims to be compatible with classical CAN and CAN FD.
> > +CAN Framework
> > +The CAN framework is located in the cpukit/dev/can directory.
> > +.. figure:: ../../../images/c_user/CAN-framework.jpg
> > + :width: 100%
> > + :align: center
> > + :alt: CAN Framework
> > +This Fig shows the control flow and data flow of application and BSP
> CAN driver
> > +with the CAN framework.
> > +Once the BSP CAN driver registers with the CAN framework, the interface
> for an
> > +application to access the CAN hardware will be created (``/dev/can{0,
> 1, *}``).
> > +Through this interface, applications can access the CAN hardware with
> the
> > +features provided by the CAN framework (buffer management (Tx and Rx
> buffers),
> > +multi-threaded access to the CAN hardware, synchronization and
> concurrency
> > +handling between threads)
> > +Registering with CAN Framework
> > +Every BSP CAN driver should register itself with the CAN framework to
> use its
> > +services and allow access of CAN hardware to the application.
> > +The registration is done by calling ``can_bus_init`` followed by
> > +``can_bus_register`` with ``can_bus`` data structure as an argument.
> The BSP
> > +CAN driver should populate the ``can_bus`` data structure with
> appropriate data
> > +for a successful registration (``can_bus`` data structure can be
> allocated by
> > +BSP CAN driver and passed to ``can_bus_init`` for initialization or call
> > +``can_bus_alloc_and_init`` directly which allocates and initializes
> ``can_bus``
> > +data structure).
> > +.. code-block:: c
> > + can_bus *can_bus_alloc_and_init(size_t size);
> > + int can_bus_init(can_bus *bus);
> > + rtems_status_code can_bus_register(can_bus *bus, const char
> *bus_path);
> > +Successful registration creates a ``/dev/can{0, 1, *}`` device file for
> the
> > +application to communicate with the corresponding CAN hardware.
> > +.. code-block:: c
> > + struct can_bus *bus = can_bus_alloc_and_init(sizeof(struct
> can_bus));
> > + priv->bus = bus;
> > + snprintf(if_name, IF_NAME_SIZE_MAX, "/dev/can%d", i);
> > + /* BSP specific information */
> > + bus->priv = priv;
> > + /* Intialize can_dev_ops */
> typo: Initialize
> > + dcan_init_ops(priv);
> > + if (can_bus_register(bus, if_name) != 0) {
> > + CAN_ERR("beagle_can_init: bus register failed\n");
> > + free(priv);
> > + return;
> > +This example shows the DCAN BSP driver registration with the CAN
> framework.
> > +Concurrency and buffer synchronization
> > +The CAN framework uses a counting semaphore (one for Tx FIFO and one
> for Rx
> > +FIFO) and a mutex to handle concurrency and buffer synchronization. The
> count
> > +value depends on the number of FIFO
> > +buffers allocated.
> > +In the Tx path, at any time, the semaphore count denotes the number of
> empty Tx
> > +FIFO buffers available.
> > +In the Rx path, at any time, the semaphore count denotes the number of
> valid CAN
> > +messages in the Rx FIFO buffer available.
> > +Tx and Rx data flow
> > +The ``can_msg`` data structure defined in
> ``cpukit/include/dev/can/can-msg.h``
> > +represents a CAN message in application, CAN framework and BSP CAN
> driver.
> > +.. code-block:: c
> > + struct can_msg {
> > + uint32_t id;
> > + uint32_t timestamp;
> > + uint16_t flags;
> > + uint16_t len;
> > + uint8_t data[CAN_MSG_MAX_SIZE];
> > +Applications use the interface ``/dev/can{0, 1, *)`` device file to
> communicate
> > +with the CAN hardware. Once the device file is created by the CAN
> framework,
> > +applications can do file operations (open, close, read, write, ioctl)
> on the
> > +device file. Every file operation on the device file is handled by the
> CAN framework.
> > +Tx data flow
> > +Once a ``write`` is made on ``/dev/can{0, 1, *}`` from the application
> to send a
> > +CAN message, it reaches the ``can_bus_write``. The ``can_bus_write``
> checks for
> > +the availability of empty Tx FIFO buffer (by calling
> ``rtems_semaphore_obtain``).
> > +If an empty buffer is not available, based on the flags to the open
> call it sleeps
> > +or returns).
> > +If an empty Tx FIFO buffer is available, the CAN message is copied to
> the Tx FIFO
> > +buffer and checks whether CAN hardware is ready to accept a CAN message
> to transmit
> > +(by calling the function ``can_dev_ops->dev_tx_ready``). If the device
> is not
> > +ready to accept, the instance returns to the application with number of
> bytes
> > +copied.
> > +If the device is ready, ``can_xmit`` function is called, which picks up
> a buffer
> > +from Tx FIFO to transmit. Then ``can_dev_ops->dev_tx`` is called with
> > +``can_msg`` data structure as an argument (where the CAN hardware
> handles the
> > +``can_msg`` data structure to transmit). Once the CAN message is copied
> to the
> > +device FIFO to transmit, ``can_dev_ops->dev_tx`` returns back to
> ``can_xmit``
> > +invalidates the corresponding Tx FIFO buffer and wakes up an instance
> (by
> > +calling ``rtems_semaphore_release``) that is waiting for an empty CAN
> Tx FIFO
> > +buffer.
> > +The BSP CAN driver then sends the CAN message to the CAN bus. Once the
> CAN
> > +message transmission is complete the BSP CAN driver should call
> ``can_txdone``,
> > +which in turn calls ``can_xmit`` for further CAN message to send.
> > +.. caution::
> > + ``can_xmit`` function runs with interrupts disabled, this means the
> > + should return as soon as possible.
> > +This figure shows the Tx data path.
> > +.. figure:: ../../../images/c_user/CAN-tx-data-path.jpg
> > + :width: 100%
> > + :align: center
> > + :alt: CAN Tx data path
> > +Rx data flow
> > +Once a ``read`` is made on ``/dev/can{0, 1, *}`` from the application,
> the
> > +instance reaches the ``can_bus_read``. The ``can_bus_read`` function
> checks, if
> > +there are any CAN messages available in the Rx FIFO (this can be
> checked by calling
> > +``rtems_semaphore_obtain``). If available, the requested bytes of data
> are
> > +copied to user buffer and the corresponding Rx Fifo buffers are
> invalidated. If no
> > +Rx message is available, the instance goes to sleep or returns based on
> the
> > +flags to the open call.
> > +On the BSP CAN driver, Once a CAN message is received from the CAN bus,
> the
> > +message is given to the CAN Framework by calling ``can_receive``
> function.
> > +This figure shows the Rx data path.
> > +.. figure:: ../../../images/c_user/CAN-rx-data-path.jpg
> > + :width: 100%
> > + :align: center
> > + :alt: CAN Rx data path
> > +.. seealso::
> > + For Reference, `DCAN BSP driver <
> https://github.com/RTEMS/rtems/commit/26d50bdfb601b9ef71ec2b30d2d9467c2437f443>`_
> is implemented which uses CAN framework.
> > +.. admonition:: Note
> > + The existing implementation creates only two FIFO (each one for Tx
> and Rx).
> > + Futher implementation of creating Tx and Rx FIFO for each open call
> should be done.
> typo: Further
> > diff --git a/bsp-howto/index.rst b/bsp-howto/index.rst
> > index d095fc7..4f5af01 100644
> > --- a/bsp-howto/index.rst
> > +++ b/bsp-howto/index.rst
> > @@ -32,6 +32,7 @@ RTEMS BSP and Driver Guide (|version|).
> > getentropy
> > i2c
> > spi
> > + can
> > real_time_clock
> > networking
> > frame_buffer
> > diff --git a/images/c_user/CAN-framework.jpg
> b/images/c_user/CAN-framework.jpg
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221116/4161acb3/attachment-0001.htm>
