Add Formal Verification chapter v2
Gedare Bloom
gedare at rtems.org
Wed Nov 16 16:44:38 UTC 2022
Hi Andrew,
I guess I was overly optimistic last night. The note on the front
matter should be resolved before we push the full documentation. I
guess it's a bit of chicken-and-egg but the documentation should be
pushed concurrent with the software that it documents. So, when there
is a `formal` folder in `rtems-central` then it makes sense to push
this documentation. I think the documentation is valuable, but I'm not
sure how relevant it is without the associated tooling?
We probably need to rearrange this section slightly to accommodate the
possibility (extant) of other formal verification approaches. I think
I'd like to see Sections "9.2 Formal Tools Setup" and 9.4 through the
end of the section become nested beneath "9.3 Modelling RTEMS with
Promela". Add a new section 9.2 to introduce the different approaches
that have/are/might be used to formally verify RTEMS. This will allow
alternatives to be documented and acknowledged by the RTEMS Project.
There's a bunch of terminology that is introduced in this chapter
without additions to the glossary/index. I think we need some
definitions added there to complement the new material. At the very
least I would like to see definitions added for the keywords that are
defined especially in the introduction:
* semantics, formal model, artifact, refinement, LTL
Once those are defined, the terms should be linked to the glossary.
You can see how this is done for example in Section 5.3.4 Traceability
between Software Requirements, Architecture and Design. Glossary
definitions can/should link to each other as relevant.
"To avoid using (long) absolute pathnames to the tools directory" ...
--> maybe it makes sense for you to provide these as part of the env?
Is this stuff using venv or something else?
incomplete section header? "need to explain how to configure testbuilder"
RTMES typo in that section
In section "9.2.2 Running Test Generation" please add some notion of
what is the expected output that one would be checking in the step
"use a simulator to run ts-model-0.exe directly."
There is overuse of double quotations throughout. Sometimes double
quotes are being used to introduce terminology, avoid that. Sometimes
double quotes appear in section headings, avoid that. Prefer to use
double quotes only for quoting (e.g., from references or tool output).
Most cases of the double quotes use in this document should be
eliminated.
In section "9.4 Promela to C Refinement" what is the name of the YAML
file? Is there more than one, or is it unique.
Some of the text that provides examples of how to do some of this
might be suited to a new How-To subsection such as in the end of the
"BSP Build System" section.
In Section "9.6 Test Generation Maintenance" please refer to Section
"Software Development Management" instead of hard-coding the patch
submission process.
Section 9.7 "RTEMS Formal Model Guide" seems like it includes both
some aspects of a How-To but also a lot of details that might be
better as a separate document specific to the Promela/Verification
detailed implementation. The point of the RTEMS Software Engineering
manual is to provide developers with the guidelines of how to work
with RTEMS. This section is very detailed about the implementation of
specific models and feels unbalanced with the rest of the new section.
For example, this section is about 3/5 of the entire "Formal
Verification" section.
Gedare
On Wed, Nov 16, 2022 at 3:57 AM Andrew.Butterfield at scss.tcd.ie
<Andrew.Butterfield at scss.tcd.ie> wrote:
> Dear Gedare,
> thanks for doing this - all feedback welcome!
> Best regards,
> Andrew
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
> -----Original Message-----
> From: Gedare Bloom <gedare at rtems.org>
> Date: Wednesday 16 November 2022 at 02:00
> To: Chris Johns <chrisj at rtems.org>
> Cc: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "rtems-devel at rtems.org" <rtems-devel at rtems.org>
> Subject: Re: Add Formal Verification chapter v2
> I plan to look at this tomorrow and will plan to push it as-is. I will
> push any modifications I think should be made, or send notes back
> here, after I look through it very carefully.
> On Wed, Nov 9, 2022 at 5:39 PM Chris Johns <chrisj at rtems.org> wrote:
> > On 9/11/2022 9:48 pm, Andrew.Butterfield at scss.tcd.ie wrote:
> > > ping
> > > (my fault really, i've let this sit!)
> > Thank you for raising this and I am sorry we have not been as proactive
> > as we should be.
> > > But I have been busy, interacting with a group doing a follow-up IV&V project with the qualification data package we produced.
> > > A conseuience of this is that I am helping them to add two extra manager models developed by students, for Barriers and Message Queues.
> > > This would add two more entries to the model guide, and raises the question of the best place to document the models.
> > > Is the RTEMS Software Engineering manual the best location for those? If not, where should they live?
> > > Another side effect fo all this is that there is now a definitive version of the formal models and test generation in a public repo:
> > > https://github.com/andrewbutterfield/RTEMS-SMP-Formal
> > Excellent.
> > I have no expertise in this area and I am more than happy to defer to
> > you and your team in this area.
> > I have no objections to this working being merge as is. I see it as
> > green field work and yours is the first here. I am sure updates or
> > changes can be made over time by you or others as the work is absorbed
> > and reviewed.
> > Thank you for all the efforts you and those with you have made. I
> > personally think it is fantastic to have this work happen and being made
> > public in this way so thank you from me.
> > Chris
> > devel mailing list
> > devel at rtems.org
