[PATCH] bsps/zynqmp: Use direct fdt_* calls
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Nov 17 22:13:10 UTC 2022
This changes the ZynqMP device tree parsing over to direct libfdt calls
to avoid inclusion of malloc() in the base BSP which currently causes
sp01 to fail due to unexpected use of TLS space.
bsps/aarch64/xilinx-zynqmp/console/console.c | 32 ++++++--------------
1 file changed, 10 insertions(+), 22 deletions(-)
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
index d546db8535..992b8a62da 100644
--- a/bsps/aarch64/xilinx-zynqmp/console/console.c
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -37,7 +37,6 @@
#include <rtems/console.h>
#include <rtems/bspIo.h>
#include <rtems/endian.h>
-#include <rtems/rtems-fdt.h>
#include <rtems/sysinit.h>
#include <bsp/aarch64-mmu.h>
@@ -47,6 +46,7 @@
#include <dev/serial/zynq-uart.h>
#include <bspopts.h>
+#include <libfdt.h>
#include <libchip/ns16550.h>
@@ -92,42 +92,36 @@ __attribute__ ((weak)) void zynqmp_configure_management_console(rtems_termios_de
static void zynqmp_management_console_init(void)
/* Find the management console in the device tree */
- rtems_fdt_handle fdt_handle;
+ const void *fdt = bsp_fdt_get();
const uint32_t *prop;
uint32_t outprop[4];
int proplen;
int node;
- rtems_fdt_init_handle(&fdt_handle);
- rtems_fdt_register(bsp_fdt_get(), &fdt_handle);
- const char *alias = rtems_fdt_get_alias(&fdt_handle, "mgmtport");
+ const char *alias = fdt_get_alias(fdt, "mgmtport");
if (alias == NULL) {
- rtems_fdt_release_handle(&fdt_handle);
return;
- node = rtems_fdt_path_offset(&fdt_handle, alias);
+ node = fdt_path_offset(fdt, alias);
- prop = rtems_fdt_getprop(&fdt_handle, node, "clock-frequency", &proplen);
+ prop = fdt_getprop(fdt, node, "clock-frequency", &proplen);
if ( prop == NULL || proplen != 4 ) {
zynqmp_mgmt_uart_context.port = 0;
return;
outprop[0] = rtems_uint32_from_big_endian((const uint8_t *) &prop[0]);
zynqmp_mgmt_uart_context.clock = outprop[0];
- prop = rtems_fdt_getprop(&fdt_handle, node, "current-speed", &proplen);
+ prop = fdt_getprop(fdt, node, "current-speed", &proplen);
return;
zynqmp_mgmt_uart_context.initial_baud = outprop[0];
- prop = rtems_fdt_getprop(&fdt_handle, node, "interrupts", &proplen);
+ prop = fdt_getprop(fdt, node, "interrupts", &proplen);
if ( prop == NULL || proplen != 12 ) {
return;
@@ -137,14 +131,12 @@ static void zynqmp_management_console_init(void)
/* proplen is in bytes, interrupt mapping expects a length in 32-bit cells */
zynqmp_mgmt_uart_context.irq = bsp_fdt_map_intr(outprop, proplen / 4);
if ( zynqmp_mgmt_uart_context.irq == 0 ) {
return;
- prop = rtems_fdt_getprop(&fdt_handle, node, "reg", &proplen);
+ prop = fdt_getprop(fdt, node, "reg", &proplen);
if ( prop == NULL || proplen != 16 ) {
return;
@@ -164,26 +156,22 @@ static void zynqmp_management_console_init(void)
return;
- prop = rtems_fdt_getprop(&fdt_handle, node, "reg-offset", &proplen);
+ prop = fdt_getprop(fdt, node, "reg-offset", &proplen);
return;
zynqmp_mgmt_uart_context.port += outprop[0];
- prop = rtems_fdt_getprop(&fdt_handle, node, "reg-shift", &proplen);
+ prop = fdt_getprop(fdt, node, "reg-shift", &proplen);
return;
mgmt_uart_reg_shift = outprop[0];
ns16550_probe(&zynqmp_mgmt_uart_context.base);
zynqmp_configure_management_console(&zynqmp_mgmt_uart_context.base);
2.30.2
