Use of rtems_fdt_* and sp01
Fri Nov 18 06:44:20 UTC 2022
On 18/11/2022 06:32, Kinsey Moore wrote:
> On Thu, Nov 17, 2022 at 4:49 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 18/11/2022 2:39 am, Kinsey Moore wrote:
>      > I recently added FDT support to the AArch64 ZynqMP BSPs to
>     support an optional
>      > management console and managing ethernet parameters for LibBSD.
>     Use of the
>      > rtems_fdt_* functions implies use of malloc which adds 4 bytes in
>     the TLS space.
>      > The sp01 test uses rtems_task_construct and specifies a maximum
>     TLS size of 0
>      > bytes which causes a failure which the non-zero TLS size is
>     checked against the
>      > maximum TLS size of 0.
>     Does this mean there exists a requirement a BSPs cannot internally
>     use the heap?
> That appears to be the case, at least practically. It works fine, but it
> causes a test failure...
You can use the heap during system initialization. However, you should
avoid dependencies on errno, so instead of using malloc()/calloc() use
rtems_malloc()/rtems_calloc(). Independent of this, if the BSP
initialization can easily avoid the heap, then it should not use the heap.
>     Maybe the test needs to be adjusted?
> That's part of why I sent this to the list. I was unsure whether it was
> allowed or whether the test had bad assumptions baked into it.
The tests check specific aspects of the thread-local storage support and
this works only if the BSP does not depend on TLS objects such as errno.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
