[PATCH] cpukit/rtems-fdt: Avoid use of malloc/errno
    Chris Johns
    chrisj at rtems.org
    Fri Nov 18 20:03:00 UTC 2022
Looks good and thanks
On 19/11/2022 2:47 am, Kinsey Moore wrote:
> Use of malloc implies errno which adds TLS dependencies and prevents use
> of this FDT wrapper library in BSP initialization code. This change
> makes use of rtems_malloc and rtems_calloc which avoid TLS dependencies.
>  cpukit/libmisc/rtems-fdt/rtems-fdt.c | 13 ++++++-------
>  1 file changed, 6 insertions(+), 7 deletions(-)
> diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
> index 1e382ca108..e5bab21664 100644
> --- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
> +++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
> @@ -25,9 +25,7 @@
>   * POSSIBILITY OF SUCH DAMAGE.
> -#include <errno.h>
>  #include <fcntl.h>
> -#include <stdlib.h>
>  #include <stdio.h>
>  #include <sys/stat.h>
>  #include <sys/types.h>
> @@ -35,6 +33,7 @@
>  #include <libfdt.h>
>  #include <zlib.h>
> +#include <rtems/malloc.h>
>  #include <rtems/rtems-fdt.h>
>  #include <rtems/thread.h>
> @@ -175,13 +174,13 @@ rtems_fdt_init_index (rtems_fdt_handle* fdt, rtems_fdt_blob* blob)
>     * Create the index.
> -  entries = calloc(num_entries, sizeof(rtems_fdt_index_entry));
> +  entries = rtems_calloc(num_entries, sizeof(rtems_fdt_index_entry));
>    if (!entries)
>      return -RTEMS_FDT_ERR_NO_MEMORY;
> -  names = calloc(1, total_name_memory);
> +  names = rtems_calloc(1, total_name_memory);
>    if (!names)
>      free(entries);
> @@ -505,7 +504,7 @@ rtems_fdt_load (const char* filename, rtems_fdt_handle* handle)
>      size_t offset;
> -    cdata = malloc(sb.st_size);
> +    cdata = rtems_malloc(sb.st_size);
>      if (!cdata)
>        close (bf);
> @@ -546,7 +545,7 @@ rtems_fdt_load (const char* filename, rtems_fdt_handle* handle)
>    name_len = strlen (filename) + 1;
> -  blob = malloc(sizeof (rtems_fdt_blob) + name_len + bsize);
> +  blob = rtems_malloc(sizeof (rtems_fdt_blob) + name_len + bsize);
>    if (!blob)
>      free(cdata);
> @@ -649,7 +648,7 @@ rtems_fdt_register (const void* dtb, rtems_fdt_handle* handle)
>      return fe;
> -  blob = malloc(sizeof (rtems_fdt_blob));
> +  blob = rtems_malloc(sizeof (rtems_fdt_blob));
>    if (!blob)
