[PATCH v2] libmisc/rtems-fdt: Support prop map items up to the size of uintptr_t
chrisj at rtems.org
chrisj at rtems.org
Fri Nov 25 03:32:25 UTC 2022
Updates #4729
cpukit/include/rtems/rtems-fdt.h | 6 ++++++
cpukit/libmisc/rtems-fdt/rtems-fdt.c | 19 +++++++++++++++++--
2 files changed, 23 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/rtems-fdt.h b/cpukit/include/rtems/rtems-fdt.h
index 18e04352aa..e3ebfe3ba4 100644
--- a/cpukit/include/rtems/rtems-fdt.h
+++ b/cpukit/include/rtems/rtems-fdt.h
@@ -694,6 +694,12 @@ const char *rtems_fdt_entry_name(rtems_fdt_handle* handle, int id);
int rtems_fdt_entry_offset(rtems_fdt_handle* handle, int id);
+ * Helper function to convert the void* property result of unknown
+ * length to an unsigned int pointer value.
+uintptr_t rtems_fdt_get_offset_len_uintptr(const void* prop, int offset, int len);
* Helper function to convert the void* property result to a 32bit unsigned int.
diff --git a/cpukit/libmisc/rtems-fdt/rtems-fdt.c b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
index e5bab21664..ec8f270eef 100644
--- a/cpukit/libmisc/rtems-fdt/rtems-fdt.c
+++ b/cpukit/libmisc/rtems-fdt/rtems-fdt.c
@@ -1063,18 +1063,33 @@ rtems_fdt_prop_map(const char* const path,
return length;
- if (length != sizeof (uintptr_t))
+ if (length > sizeof (uintptr_t))
rtems_fdt_release_handle (&fdt);
return -RTEMS_FDT_ERR_BADPATH;
- values[item] = rtems_fdt_get_uintptr(prop);
+ values[item] = rtems_fdt_get_offset_len_uintptr(prop, 0, length);
return 0;
+uintptr_t
+rtems_fdt_get_offset_len_uintptr (const void* prop, int offset, int len)
+ const uint8_t* p = prop;
+ uintptr_t value = 0;
+ int b;
+ if (len <= sizeof(uintptr_t)) {
+ for (b = 0; b < len; ++b) {
+ value = (value << 8) | (uintptr_t) p[offset++];
+ return value;
uint32_t
rtems_fdt_get_offset_uint32 (const void* prop, int offset)
2.19.1
