[PATCH rtems-docs] c-user/*: Add trailing parentheses on methods in index which were missing it
Chris Johns
chrisj at rtems.org
Wed Nov 30 21:10:26 UTC 2022
Looks good and thanks
On 1/12/2022 3:00 am, Joel Sherrill wrote:
> Closes #4766.
> c-user/chains.rst | 46 +++++++++++++++++------------------
> c-user/clock/removed-directives.rst | 2 +-
> c-user/constant_bandwidth_server.rst | 24 +++++++++---------
> c-user/cpu_usage_statistics.rst | 4 +--
> c-user/directive_status_codes.rst | 2 +-
> c-user/key_concepts.rst | 12 ++++-----
> c-user/task/deprecated-directives.rst | 2 +-
> c-user/task/operations.rst | 10 ++++----
> c-user/task/removed-directives.rst | 10 ++++----
> c-user/timespec_helpers.rst | 28 ++++++++++-----------
> c-user/user-extensions/background.rst | 2 +-
> 11 files changed, 71 insertions(+), 71 deletions(-)
> diff --git a/c-user/chains.rst b/c-user/chains.rst
> index 0dce1d9..f518ef4 100644
> --- a/c-user/chains.rst
> +++ b/c-user/chains.rst
> @@ -220,7 +220,7 @@ The section details the Chains directives.
> .. _rtems_chain_initialize:
> .. index:: chain initialize
> -.. index:: rtems_chain_initialize
> +.. index:: rtems_chain_initialize()
> Initialize Chain With Nodes
> @@ -258,7 +258,7 @@ NOTES:
> .. _rtems_chain_initialize_empty:
> .. index:: chain initialize empty
> -.. index:: rtems_chain_initialize_empty
> +.. index:: rtems_chain_initialize_empty()
> Initialize Empty
> @@ -287,7 +287,7 @@ NOTES:
> .. _rtems_chain_is_null_node:
> .. index:: chain is node null
> -.. index:: rtems_chain_is_null_node
> +.. index:: rtems_chain_is_null_node()
> Is Null Node ?
> @@ -313,7 +313,7 @@ DESCRIPTION:
> .. _rtems_chain_head:
> .. index:: chain get head
> -.. index:: rtems_chain_head
> +.. index:: rtems_chain_head()
> Head
> @@ -338,7 +338,7 @@ DESCRIPTION:
> .. _rtems_chain_tail:
> .. index:: chain get tail
> -.. index:: rtems_chain_tail
> +.. index:: rtems_chain_tail()
> Tail
> @@ -363,7 +363,7 @@ DESCRIPTION:
> .. _rtems_chain_are_nodes_equal:
> .. index:: chare are nodes equal
> -.. index:: rtems_chain_are_nodes_equal
> +.. index:: rtems_chain_are_nodes_equal()
> Are Two Nodes Equal ?
> @@ -391,7 +391,7 @@ DESCRIPTION:
> .. _rtems_chain_is_empty:
> .. index:: chain is chain empty
> -.. index:: rtems_chain_is_empty
> +.. index:: rtems_chain_is_empty()
> Is the Chain Empty
> @@ -418,7 +418,7 @@ DESCRIPTION:
> .. _rtems_chain_is_first:
> .. index:: chain is node the first
> -.. index:: rtems_chain_is_first
> +.. index:: rtems_chain_is_first()
> Is this the First Node on the Chain ?
> @@ -445,7 +445,7 @@ DESCRIPTION:
> .. _rtems_chain_is_last:
> .. index:: chain is node the last
> -.. index:: rtems_chain_is_last
> +.. index:: rtems_chain_is_last()
> Is this the Last Node on the Chain ?
> @@ -472,7 +472,7 @@ DESCRIPTION:
> .. _rtems_chain_has_only_one_node:
> .. index:: chain only one node
> -.. index:: rtems_chain_has_only_one_node
> +.. index:: rtems_chain_has_only_one_node()
> Does this Chain have only One Node ?
> @@ -499,7 +499,7 @@ DESCRIPTION:
> .. _rtems_chain_node_count_unprotected:
> -.. index:: rtems_chain_node_count_unprotected
> +.. index:: rtems_chain_node_count_unprotected()
> Returns the node count of the chain (unprotected)
> @@ -524,7 +524,7 @@ DESCRIPTION:
> .. _rtems_chain_is_head:
> .. index:: chain is node the head
> -.. index:: rtems_chain_is_head
> +.. index:: rtems_chain_is_head()
> Is this Node the Chain Head ?
> @@ -552,7 +552,7 @@ DESCRIPTION:
> .. _rtems_chain_is_tail:
> .. index:: chain is node the tail
> -.. index:: rtems_chain_is_tail
> +.. index:: rtems_chain_is_tail()
> Is this Node the Chain Tail ?
> @@ -580,7 +580,7 @@ DESCRIPTION:
> .. _rtems_chain_extract:
> .. index:: chain extract a node
> -.. index:: rtems_chain_extract
> +.. index:: rtems_chain_extract()
> Extract a Node
> @@ -611,7 +611,7 @@ NOTES:
> .. _rtems_chain_extract_unprotected:
> .. index:: chain extract a node unprotected
> -.. index:: rtems_chain_extract_unprotected
> +.. index:: rtems_chain_extract_unprotected()
> Extract a Node (unprotected)
> @@ -639,7 +639,7 @@ NOTES:
> .. _rtems_chain_get:
> .. index:: chain get first node
> -.. index:: rtems_chain_get
> +.. index:: rtems_chain_get()
> Get the First Node
> @@ -672,7 +672,7 @@ NOTES:
> .. _rtems_chain_get_unprotected:
> -.. index:: rtems_chain_get_unprotected
> +.. index:: rtems_chain_get_unprotected()
> Get the First Node (unprotected)
> @@ -701,7 +701,7 @@ NOTES:
> .. _rtems_chain_insert:
> .. index:: chain insert a node
> -.. index:: rtems_chain_insert
> +.. index:: rtems_chain_insert()
> Insert a Node
> @@ -734,7 +734,7 @@ NOTES:
> .. _rtems_chain_insert_unprotected:
> .. index:: chain insert a node unprotected
> -.. index:: rtems_chain_insert_unprotected
> +.. index:: rtems_chain_insert_unprotected()
> Insert a Node (unprotected)
> @@ -764,7 +764,7 @@ NOTES:
> .. _rtems_chain_append:
> .. index:: chain append a node
> -.. index:: rtems_chain_append
> +.. index:: rtems_chain_append()
> Append a Node
> @@ -796,7 +796,7 @@ NOTES:
> .. _rtems_chain_append_unprotected:
> .. index:: chain append a node unprotected
> -.. index:: rtems_chain_append_unprotected
> +.. index:: rtems_chain_append_unprotected()
> Append a Node (unprotected)
> @@ -825,7 +825,7 @@ NOTES:
> .. _rtems_chain_prepend:
> .. index:: prepend node
> -.. index:: rtems_chain_prepend
> +.. index:: rtems_chain_prepend()
> Prepend a Node
> @@ -857,7 +857,7 @@ NOTES:
> .. _rtems_chain_prepend_unprotected:
> .. index:: prepend node unprotected
> -.. index:: rtems_chain_prepend_unprotected
> +.. index:: rtems_chain_prepend_unprotected()
> Prepend a Node (unprotected)
> diff --git a/c-user/clock/removed-directives.rst b/c-user/clock/removed-directives.rst
> index d7fd775..66be74e 100644
> --- a/c-user/clock/removed-directives.rst
> +++ b/c-user/clock/removed-directives.rst
> @@ -14,7 +14,7 @@ Removed Directives
> CLOCK_GET - Get date and time information
> .. index:: obtain the time of day
> -.. index:: rtems_clock_get
> +.. index:: rtems_clock_get()
> .. warning::
> diff --git a/c-user/constant_bandwidth_server.rst b/c-user/constant_bandwidth_server.rst
> index eddc89a..d610ad9 100644
> --- a/c-user/constant_bandwidth_server.rst
> +++ b/c-user/constant_bandwidth_server.rst
> @@ -233,7 +233,7 @@ sequence, related constants, usage, and status codes.
> \clearpage
> .. index:: initialize the CBS library
> -.. index:: rtems_cbs_initialize
> +.. index:: rtems_cbs_initialize()
> .. _rtems_cbs_initialize:
> CBS_INITIALIZE - Initialize the CBS library
> @@ -271,7 +271,7 @@ NOTES:
> \clearpage
> .. index:: cleanup the CBS library
> -.. index:: rtems_cbs_cleanup
> +.. index:: rtems_cbs_cleanup()
> .. _rtems_cbs_cleanup:
> @@ -302,7 +302,7 @@ NOTES:
> \clearpage
> .. index:: create a new bandwidth server
> -.. index:: rtems_cbs_create_server
> +.. index:: rtems_cbs_create_server()
> .. _rtems_cbs_create_server:
> @@ -351,7 +351,7 @@ NOTES:
> \clearpage
> .. index:: attach a thread to server
> -.. index:: rtems_cbs_attach_thread
> +.. index:: rtems_cbs_attach_thread()
> .. _rtems_cbs_attach_thread:
> @@ -394,7 +394,7 @@ NOTES:
> \clearpage
> .. index:: detach a thread from server
> -.. index:: rtems_cbs_detach_thread
> +.. index:: rtems_cbs_detach_thread()
> .. _rtems_cbs_detach_thread:
> @@ -432,7 +432,7 @@ NOTES:
> \clearpage
> .. index:: destroy a bandwidth server
> -.. index:: rtems_cbs_destroy_server
> +.. index:: rtems_cbs_destroy_server()
> .. _rtems_cbs_destroy_server:
> @@ -470,7 +470,7 @@ NOTES:
> \clearpage
> .. index:: get an ID of a server
> -.. index:: rtems_cbs_get_server_id
> +.. index:: rtems_cbs_get_server_id()
> .. _rtems_cbs_get_server_id:
> @@ -502,7 +502,7 @@ DESCRIPTION:
> \clearpage
> .. index:: get scheduling parameters of a server
> -.. index:: rtems_cbs_get_parameters
> +.. index:: rtems_cbs_get_parameters()
> .. _rtems_cbs_get_parameters:
> @@ -540,7 +540,7 @@ NOTES:
> \clearpage
> .. index:: set scheduling parameters
> -.. index:: rtems_cbs_set_parameters
> +.. index:: rtems_cbs_set_parameters()
> .. _rtems_cbs_set_parameters:
> @@ -580,7 +580,7 @@ NOTES:
> \clearpage
> .. index:: get elapsed execution time
> -.. index:: rtems_cbs_get_execution_time
> +.. index:: rtems_cbs_get_execution_time()
> .. _rtems_cbs_get_execution_time:
> @@ -619,7 +619,7 @@ NOTES:
> \clearpage
> .. index:: get remaining execution time
> -.. index:: rtems_cbs_get_remaining_budget
> +.. index:: rtems_cbs_get_remaining_budget()
> .. _rtems_cbs_get_remaining_budget:
> @@ -658,7 +658,7 @@ NOTES:
> \clearpage
> .. index:: get scheduler approved execution time
> -.. index:: rtems_cbs_get_approved_budget
> +.. index:: rtems_cbs_get_approved_budget()
> .. _rtems_cbs_get_approved_budget:
> diff --git a/c-user/cpu_usage_statistics.rst b/c-user/cpu_usage_statistics.rst
> index 46d130c..4f98b75 100644
> --- a/c-user/cpu_usage_statistics.rst
> +++ b/c-user/cpu_usage_statistics.rst
> @@ -108,7 +108,7 @@ calling sequence, related constants, usage, and status codes.
> \clearpage
> -.. index:: rtems_cpu_usage_report
> +.. index:: rtems_cpu_usage_report()
> .. _rtems_cpu_usage_report:
> @@ -134,7 +134,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_cpu_usage_reset
> +.. index:: rtems_cpu_usage_reset()
> .. _rtems_cpu_usage_reset:
> diff --git a/c-user/directive_status_codes.rst b/c-user/directive_status_codes.rst
> index 1331076..d93f850 100644
> --- a/c-user/directive_status_codes.rst
> +++ b/c-user/directive_status_codes.rst
> @@ -87,7 +87,7 @@ The directives are:
> \clearpage
> -.. index:: rtems_status_text
> +.. index:: rtems_status_text()
> .. _rtems_status_text:
> diff --git a/c-user/key_concepts.rst b/c-user/key_concepts.rst
> index 3628954..e3f4811 100644
> --- a/c-user/key_concepts.rst
> +++ b/c-user/key_concepts.rst
> @@ -45,7 +45,7 @@ An object name is an unsigned thirty-two bit entity associated with the object
> by the user. The data type ``rtems_name`` is used to store object
> names.
> -.. index:: rtems_build_name
> +.. index:: rtems_build_name()
> Although not required by RTEMS, object names are often composed of four ASCII
> characters which help identify that object. For example, a task which causes a
> @@ -64,7 +64,7 @@ would be difficult to assign meaningful ASCII names to each task. A more
> convenient approach would be to name them the binary values one through
> one-hundred, respectively.
> -.. index:: rtems_object_get_name
> +.. index:: rtems_object_get_name()
> RTEMS provides a helper routine, ``rtems_object_get_name``, which can be used
> to obtain the name of any RTEMS object using just its ID. This routine
> @@ -150,10 +150,10 @@ prototyped as follows:
> .. index:: get class from object ID
> .. index:: get node from object ID
> .. index:: get index from object ID
> -.. index:: rtems_object_id_get_api
> -.. index:: rtems_object_id_get_class
> -.. index:: rtems_object_id_get_node
> -.. index:: rtems_object_id_get_index
> +.. index:: rtems_object_id_get_api()
> +.. index:: rtems_object_id_get_class()
> +.. index:: rtems_object_id_get_node()
> +.. index:: rtems_object_id_get_index()
> .. code-block:: c
> diff --git a/c-user/task/deprecated-directives.rst b/c-user/task/deprecated-directives.rst
> index 107c5e0..949d499 100644
> --- a/c-user/task/deprecated-directives.rst
> +++ b/c-user/task/deprecated-directives.rst
> @@ -9,7 +9,7 @@ Deprecated Directives
> \clearpage
> -.. index:: rtems_iterate_over_all_threads
> +.. index:: rtems_iterate_over_all_threads()
> .. _rtems_iterate_over_all_threads:
> diff --git a/c-user/task/operations.rst b/c-user/task/operations.rst
> index 58174d6..524258e 100644
> --- a/c-user/task/operations.rst
> +++ b/c-user/task/operations.rst
> @@ -160,8 +160,8 @@ It is important to note that the ``cpuset`` is not validated until the
> ``rtems_task_set_affinity`` call is made. At that point, it is validated
> against the current system configuration.
> -.. index:: rtems_task_get_note
> -.. index:: rtems_task_set_note
> +.. index:: rtems_task_get_note()
> +.. index:: rtems_task_set_note()
> Transition Advice for Removed Notepads
> @@ -177,9 +177,9 @@ over the key (e.g. notepad index) selection. For most applications, POSIX Keys
> should be used. These are available in all RTEMS build configurations. It is
> also possible that thread-local storage (TLS) is an option for some use cases.
> -.. index:: rtems_task_variable_add
> -.. index:: rtems_task_variable_get
> -.. index:: rtems_task_variable_delete
> +.. index:: rtems_task_variable_add()
> +.. index:: rtems_task_variable_get()
> +.. index:: rtems_task_variable_delete()
> Transition Advice for Removed Task Variables
> diff --git a/c-user/task/removed-directives.rst b/c-user/task/removed-directives.rst
> index 8c8aae9..677e810 100644
> --- a/c-user/task/removed-directives.rst
> +++ b/c-user/task/removed-directives.rst
> @@ -10,7 +10,7 @@ Removed Directives
> \clearpage
> .. index:: get task notepad entry
> .. _rtems_task_get_note:
> @@ -64,7 +64,7 @@ NOTES:
> \clearpage
> .. index:: set task notepad entry
> .. _rtems_task_set_note:
> @@ -119,7 +119,7 @@ NOTES:
> .. index:: per-task variable
> .. index:: task private variable
> .. index:: task private data
> .. _rtems_task_variable_add:
> @@ -182,7 +182,7 @@ NOTES:
> .. index:: get per-task variable
> .. index:: obtain per-task variable
> .. _rtems_task_variable_get:
> @@ -241,7 +241,7 @@ NOTES:
> .. _rtems_task_variable_delete:
> diff --git a/c-user/timespec_helpers.rst b/c-user/timespec_helpers.rst
> index f2ef5cd..bc39630 100644
> --- a/c-user/timespec_helpers.rst
> +++ b/c-user/timespec_helpers.rst
> @@ -125,7 +125,7 @@ sequence, related constants, usage, and status codes.
> \clearpage
> .. index:: set struct timespec instance
> -.. index:: rtems_timespec_set
> +.. index:: rtems_timespec_set()
> .. _rtems_timespec_set:
> @@ -156,7 +156,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_zero
> +.. index:: rtems_timespec_zero()
> .. _rtems_timespec_zero:
> @@ -184,7 +184,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_is_valid
> +.. index:: rtems_timespec_is_valid()
> .. _rtems_timespec_is_valid:
> @@ -214,7 +214,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_add_to
> +.. index:: rtems_timespec_add_to()
> .. _rtems_timespec_add_to:
> @@ -244,7 +244,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_subtract
> +.. index:: rtems_timespec_subtract()
> .. _rtems_timespec_subtract:
> @@ -279,7 +279,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_divide
> +.. index:: rtems_timespec_divide()
> .. _rtems_timespec_divide:
> @@ -320,7 +320,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_divide_by_integer
> +.. index:: rtems_timespec_divide_by_integer()
> .. _rtems_timespec_divide_by_integer:
> @@ -352,7 +352,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_less_than
> +.. index:: rtems_timespec_less_than()
> .. _rtems_timespec_less_than:
> @@ -383,7 +383,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_greater_than
> +.. index:: rtems_timespec_greater_than()
> .. _rtems_timespec_greater_than:
> @@ -412,7 +412,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_equal_to
> +.. index:: rtems_timespec_equal_to()
> .. _rtems_timespec_equal_to:
> @@ -441,7 +441,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_get_seconds
> +.. index:: rtems_timespec_get_seconds()
> .. _rtems_timespec_get_seconds:
> \clearpage
> -.. index:: rtems_timespec_get_nanoseconds
> +.. index:: rtems_timespec_get_nanoseconds()
> .. _rtems_timespec_get_nanoseconds:
> @@ -499,7 +499,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_to_ticks
> +.. index:: rtems_timespec_to_ticks()
> .. _rtems_timespec_to_ticks:
> @@ -527,7 +527,7 @@ NOTES:
> \clearpage
> -.. index:: rtems_timespec_from_ticks
> +.. index:: rtems_timespec_from_ticks()
> .. _rtems_timespec_from_ticks:
> diff --git a/c-user/user-extensions/background.rst b/c-user/user-extensions/background.rst
> index 5aa747b..c1430a9 100644
> --- a/c-user/user-extensions/background.rst
> +++ b/c-user/user-extensions/background.rst
> @@ -143,7 +143,7 @@ installed after the Standard C Library will operate correctly even if they
> utilize the C Library because the C Library's thread delete extension is
> invoked after that of the other thread delete extensions.
> -.. index:: rtems_task_create_extension
> +.. index:: rtems_task_create_extension()
> Thread Create Extension
