Libexpat missing when using Python from python.org
Tue Oct 4 01:11:21 UTC 2022
On 4/10/2022 2:32 am, Ryan Long wrote:
> Hello,
> Following Chris's advice, I installed Python 3.10.6 from Python's website. It
> gets me past the header check for gdb,
Great.
> but then it reports
> checking whether to use expat... yes
> checking for libexpat... no
> configure: error: expat is missing or unusable
> make[1]: *** [configure-gdb] Error 1
> make: *** [all] Error 2
> What's the best way to get Libexpat on macOS?
> I was able to successfully build it with the python installed from Homebrew
> after disabling the building of gsed.
It should build for the Xcode (MacOS) python so I something is wrong in the GDB
common build script.
gsed has to be built if sed is not the GNU version
