[PATCH] gsed.cfg: Add check for gsed
Chris Johns
chrisj at rtems.org
Tue Oct 4 01:13:31 UTC 2022
On 4/10/2022 2:52 am, Ryan Long wrote:
> bare/config/textproc/gsed.cfg | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/bare/config/textproc/gsed.cfg b/bare/config/textproc/gsed.cfg
> index 8287c74..b4aaf4f 100644
> --- a/bare/config/textproc/gsed.cfg
> +++ b/bare/config/textproc/gsed.cfg
> @@ -2,7 +2,7 @@
> # GNU sed has a version option, check for it.
> # If not found build it.
> -%define has_gnu_sed %(sed --version > /dev/null 2>&1; echo $?)
> +%define has_gnu_sed %(sed --version > /dev/null 2>&1 || gsed --version > /dev/null 2>&1; echo $?)
> %if %{has_gnu_sed} != 0
> %include %{_configdir}/textproc/gsed-4.8.cfg
> %endif
What does gcc require sed be as a command? Is it sed or gsed?
Which host has gsed installed?
