[PATCH] c-user: Add application config info directives
Tue Oct 4 08:31:20 UTC 2022
On 04/10/2022 09:04, Chris Johns wrote:
> On 30/9/2022 11:34 pm, Sebastian Huber wrote:
>> On 17/09/2022 09:31, Chris Johns wrote:
>>>> +rtems_get_version_string()
>>>> +Gets the RTEMS version string.
>>>> +.. rubric:: CALLING SEQUENCE:
>>>> +.. code-block:: c
>>>> +    const char *rtems_get_version_string( void );
>>>> +.. rubric:: RETURN VALUES:
>>>> +Returns the pointer to the RTEMS version string.
>>> Is the version string subject to change across releases or do as set this string
>>> format?
>>> Is it worth discussing the revision values and what they mean?
>> The version string contains a lot of stuff:
>> const char _RTEMS_version[] =
>>    "rtems-" RTEMS_VERSION " (" CPU_NAME "/" CPU_MODEL_NAME "/"
>>    RTEMS_XSTRING( RTEMS_BSP ) ")";
>> I don't know if we should specify a particular format.
> I agree. We should say it may change and parsing it may break.
Ok, I added this to the notes and checked in the updated patch.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
