[PATCH v3] bsp/aarch64: Add new Raspberry Pi 4B BSP
Mohd Noor Aman nooraman5718 at gmail.com
Tue Oct 4 21:38:48 UTC 2022
This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family. Currently
only LP64 ABI is supported. ILP32 is not supported. RAM starts from 0x80000 in
64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and Raspberry
Pi 400 are supported. All the IRQs are similiar to the older Raspberry pi 2 ARM
BSP.
Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported currently.
Mini-UART is not supported. Mini-UART is default UART on the board so it needs
to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No support
for additional 4 PL011-UARTs on the board.
The raspberrypi.h includes many of the address required for the future
development of the RPi 4B BSP. This includes peripherals, ARM Timer, VideoCore
Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
 bsps/aarch64/raspberrypi/console/console.c    |  69 +++
 bsps/aarch64/raspberrypi/include/bsp.h        |  76 +++
 bsps/aarch64/raspberrypi/include/bsp/irq.h    | 109 ++++
 .../raspberrypi/include/bsp/raspberrypi.h     | 471 ++++++++++++++++++
 bsps/aarch64/raspberrypi/include/tm27.h       |  46 ++
 bsps/aarch64/raspberrypi/start/bspstart.c     |  49 ++
 .../aarch64/raspberrypi/start/bspstarthooks.c |  53 ++
 bsps/aarch64/raspberrypi/start/bspstartmmu.c  |  84 ++++
 spec/build/bsps/aarch64/raspberrypi/abi.yml   |  21 +
 .../aarch64/raspberrypi/bspraspberrypi4.yml   |  81 +++
 .../bsps/aarch64/raspberrypi/linkercmds.yml   |  76 +++
 11 files changed, 1135 insertions(+)
 create mode 100644 bsps/aarch64/raspberrypi/console/console.c
 create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
 create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
 create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
 create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
 create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
 create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
diff --git a/bsps/aarch64/raspberrypi/console/console.c b/bsps/aarch64/raspberrypi/console/console.c
new file mode 100644
index 0000000000..73bb0036ff
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/console/console.c
@@ -0,0 +1,69 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64Raspberrypi4
+ * @brief Console Configuration
+ * Copyright (C) 2022 Mohd Noor Aman
+ * are met:
+#include <rtems/bspIo.h>
+#include <bsp.h>
+#include <dev/serial/arm-pl011.h>
+#include <bsp/console-termios.h>
+#include <bspopts.h>
+arm_pl011_context raspberrypi_4_context = {
+  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
+  .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
+  .initial_baud = 115200
+const console_device console_device_table[] = {
+    .device_file = "/dev/ttyS0",
+    .probe = console_device_probe_default,
+    .handler = &arm_pl011_fns,
+    .context = &raspberrypi_4_context.base
+const size_t console_device_count = RTEMS_ARRAY_SIZE(console_device_table);
+static void output_char( char c )
+  arm_pl011_write_polled(&raspberrypi_4_context.base, c);
+BSP_output_char_function_type BSP_output_char = output_char;
+BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/bsps/aarch64/raspberrypi/include/bsp.h b/bsps/aarch64/raspberrypi/include/bsp.h
index 0000000000..4fa81edd40
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp.h
@@ -0,0 +1,76 @@
+ * @file
+ * @brief Core BSP definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
+#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+/*Raspberry pi MMU initialization */
+BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
+#define BSP_ARM_GIC_DIST_BASE 0xFF841000
+#define BSP_RPI4_PL011_BASE 0xFE201000
+#define BSP_RPI4_PL011_LENGTH 0x200
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h b/bsps/aarch64/raspberrypi/include/bsp/irq.h
index 0000000000..effec1b040
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
@@ -0,0 +1,109 @@
+ * @file
+ * @ingroup raspberrypi_interrupt
+ * @brief Interrupt definitions.
+ * Copyright (c) 2013 Alan Cudmore
+ * Copyright (c) 2022 Mohd Noor Aman
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
+#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
+#ifndef ASM
+#include <rtems.h>
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <dev/irq/arm-gic-irq.h>
+#if defined(RTEMS_SMP)
+#include <rtems/score/processormask.h>
+#endif
+ * @defgroup raspberrypi_interrupt Interrrupt Support
+ * @ingroup RTEMSBSPsARMRaspberryPi
+ * @brief Interrupt support.
+#define BCM2835_INTC_TOTAL_IRQ       (64 + 8)
+#define BCM2835_IRQ_SET1_MIN         0
+#define BCM2835_IRQ_SET2_MIN         32
+#define BCM2835_IRQ_ID_GPU_TIMER_M0  0
+#define BCM2835_IRQ_ID_GPU_TIMER_M1  1
+#define BCM2835_IRQ_ID_GPU_TIMER_M2  2
+#define BCM2835_IRQ_ID_GPU_TIMER_M3  3
+#define BCM2835_IRQ_ID_USB           9
+#define BCM2835_IRQ_ID_AUX           29
+#define BCM2835_IRQ_ID_SPI_SLAVE     43
+#define BCM2835_IRQ_ID_PWA0          45
+#define BCM2835_IRQ_ID_PWA1          46
+#define BCM2835_IRQ_ID_SMI           48
+#define BCM2835_IRQ_ID_GPIO_0        49
+#define BCM2835_IRQ_ID_GPIO_1        50
+#define BCM2835_IRQ_ID_GPIO_2        51
+#define BCM2835_IRQ_ID_GPIO_3        52
+#define BCM2835_IRQ_ID_I2C           53
+#define BCM2835_IRQ_ID_SPI           54
+#define BCM2835_IRQ_ID_PCM           55
+#define BCM2835_IRQ_ID_UART          57
+#define BCM2835_IRQ_ID_SD            62
+#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
+#define BCM2835_IRQ_ID_TIMER_0       64
+#define BCM2835_IRQ_ID_MAILBOX_0     65
+#define BCM2835_IRQ_ID_DOORBELL_0    66
+#define BCM2835_IRQ_ID_DOORBELL_1    67
+#define BCM2835_IRQ_ID_GPU0_HALTED   68
+#define BCM2835_IRQ_ID_GPU1_HALTED   69
+#define BCM2835_IRQ_ID_ILL_ACCESS_1  70
+#define BCM2835_IRQ_ID_ILL_ACCESS_0  71
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define BSP_VPL011_SPI 32
+#define BSP_INTERRUPT_VECTOR_COUNT    BCM2835_INTC_TOTAL_IRQ
+#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
+#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
+static inline rtems_status_code bsp_interrupt_set_affinity(
+  rtems_vector_number   vector,
+  const Processor_mask *affinity
+  (void) vector;
+  (void) affinity;
+  return RTEMS_UNSATISFIED;
+static inline rtems_status_code bsp_interrupt_get_affinity(
+  Processor_mask      *affinity
+  (void) vector;
+  _Processor_mask_From_index( affinity, 0 );
+#endif
+#endif /* ASM */
+#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
index 0000000000..f148e8df6c
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
@@ -0,0 +1,471 @@
+ * @file
+ * @ingroup raspberrypi_4_regs
+ * @brief Register definitions.
+#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
+#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
+#include <stdint.h>
+#include <bsp/utility.h>
+ * @defgroup raspberrypi_reg Register Definitions
+ * @brief Register Definitions
+ * @name Register Macros
+#define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
+#define BCM2711_BIT(n)           (1 << (n))
+ * @name Peripheral Base Register Address
+#define RPI_PERIPHERAL_BASE         0xFE000000
+#define BASE_OFFSET                 0xFE000000
+#define RPI_PERIPHERAL_SIZE         0x01800000
+ * @name Bus to Physical address translation
+ *       Macro.
+#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
+ * @name Internal ARM Timer Registers
+#define BCM2711_CLOCK_FREQ       250000000
+#define BCM2711_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0xB400)
+#define BCM2711_TIMER_LOD        (BCM2711_TIMER_BASE + 0x00)
+#define BCM2711_TIMER_VAL        (BCM2711_TIMER_BASE + 0x04)
+#define BCM2711_TIMER_CTL        (BCM2711_TIMER_BASE + 0x08)
+#define BCM2711_TIMER_CLI        (BCM2711_TIMER_BASE + 0x0C)
+#define BCM2711_TIMER_RIS        (BCM2711_TIMER_BASE + 0x10)
+#define BCM2711_TIMER_MIS        (BCM2711_TIMER_BASE + 0x14)
+#define BCM2711_TIMER_RLD        (BCM2711_TIMER_BASE + 0x18)
+#define BCM2711_TIMER_DIV        (BCM2711_TIMER_BASE + 0x1C)
+#define BCM2711_TIMER_CNT        (BCM2711_TIMER_BASE + 0x20)
+#define BCM2711_TIMER_PRESCALE    0xF9
+ * @name Power Management and Watchdog  Registers
+#define BCM2711_PM_PASSWD_MAGIC  0x5a000000
+#define BCM2711_PM_BASE          (RPI_PERIPHERAL_BASE + 0x100000)
+#define BCM2711_PM_GNRIC         (BCM2711_PM_BASE + 0x00)
+#define BCM2711_PM_GNRIC_POWUP   0x00000001
+#define BCM2711_PM_GNRIC_POWOK   0x00000002
+#define BCM2711_PM_GNRIC_ISPOW   0x00000004
+#define BCM2711_PM_GNRIC_MEMREP  0x00000008
+#define BCM2711_PM_GNRIC_MRDONE  0x00000010
+#define BCM2711_PM_GNRIC_ISFUNC  0x00000020
+#define BCM2711_PM_GNRIC_RSTN    0x00000fc0
+#define BCM2711_PM_GNRIC_ENAB    0x00001000
+#define BCM2711_PM_GNRIC_CFG     0x007f0000
+#define BCM2711_PM_AUDIO         (BCM2711_PM_BASE + 0x04)
+#define BCM2711_PM_AUDIO_APSM    0x000fffff
+#define BCM2711_PM_AUDIO_CTRLEN  0x00100000
+#define BCM2711_PM_AUDIO_RSTN    0x00200000
+#define BCM2711_PM_STATUS        (BCM2711_PM_BASE + 0x18)
+#define BCM2711_PM_RSTC          (BCM2711_PM_BASE + 0x1c)
+#define BCM2711_PM_RSTC_DRCFG    0x00000003
+#define BCM2711_PM_RSTC_WRCFG    0x00000030
+#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
+#define BCM2711_PM_RSTC_SRCFG    0x00000300
+#define BCM2711_PM_RSTC_QRCFG    0x00003000
+#define BCM2711_PM_RSTC_FRCFG    0x00030000
+#define BCM2711_PM_RSTC_HRCFG    0x00300000
+#define BCM2711_PM_RSTS          (BCM2711_PM_BASE + 0x20)
+#define BCM2711_PM_RSTS_HADDRQ   0x00000001
+#define BCM2711_PM_RSTS_HADDRF   0x00000002
+#define BCM2711_PM_RSTS_HADDRH   0x00000004
+#define BCM2711_PM_RSTS_HADWRQ   0x00000010
+#define BCM2711_PM_RSTS_HADWRF   0x0000002
+#define BCM2711_PM_RSTS_HADWRH   0x00000040
+#define BCM2711_PM_RSTS_HADSRQ   0x00000100
+#define BCM2711_PM_RSTS_HADSRF   0x00000200
+#define BCM2711_PM_RSTS_HADSRH   0x00000400
+#define BCM2711_PM_RSTS_HADPOR   0x00001000
+#define BCM2711_PM_WDOG          (BCM2711_PM_BASE + 0x24)
+ * @name AUX Registers
+#define BCM2711_AUX_BASE         (RPI_PERIPHERAL_BASE + 0x215000)
+#define AUX_ENABLES              (BCM2711_AUX_BASE + 0x04)
+#define AUX_MU_IO_REG            (BCM2711_AUX_BASE + 0x40)
+#define AUX_MU_IER_REG           (BCM2711_AUX_BASE + 0x44)
+#define AUX_MU_IIR_REG           (BCM2711_AUX_BASE + 0x48)
+#define AUX_MU_LCR_REG           (BCM2711_AUX_BASE + 0x4C)
+#define AUX_MU_MCR_REG           (BCM2711_AUX_BASE + 0x50)
+#define AUX_MU_LSR_REG           (BCM2711_AUX_BASE + 0x54)
+#define AUX_MU_MSR_REG           (BCM2711_AUX_BASE + 0x58)
+#define AUX_MU_SCRATCH           (BCM2711_AUX_BASE + 0x5C)
+#define AUX_MU_CNTL_REG          (BCM2711_AUX_BASE + 0x60)
+#define AUX_MU_STAT_REG          (BCM2711_AUX_BASE + 0x64)
+#define AUX_MU_BAUD_REG          (BCM2711_AUX_BASE + 0x68)
+ * @name GPU Timer Registers
+ * NOTE: The GPU uses Compare registers 0 and 2 for
+ *       it's own RTOS. 1 and 3 are available for use in
+ *       RTEMS.
+#define BCM2711_GPU_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0x3000)
+#define BCM2711_GPU_TIMER_CS         (BCM2711_GPU_TIMER_BASE + 0x00)
+#define BCM2711_GPU_TIMER_CS_M0      0x00000001
+#define BCM2711_GPU_TIMER_CS_M1      0x00000002
+#define BCM2711_GPU_TIMER_CS_M2      0x00000004
+#define BCM2711_GPU_TIMER_CS_M3      0x00000008
+#define BCM2711_GPU_TIMER_CLO        (BCM2711_GPU_TIMER_BASE + 0x04)
+#define BCM2711_GPU_TIMER_CHI        (BCM2711_GPU_TIMER_BASE + 0x08)
+#define BCM2711_GPU_TIMER_C0         (BCM2711_GPU_TIMER_BASE + 0x0C)
+#define BCM2711_GPU_TIMER_C1         (BCM2711_GPU_TIMER_BASE + 0x10)
+#define BCM2711_GPU_TIMER_C2         (BCM2711_GPU_TIMER_BASE + 0x14)
+#define BCM2711_GPU_TIMER_C3         (BCM2711_GPU_TIMER_BASE + 0x18)
+ * @name EMMC Registers
+ * NOTE: Since the SD controller follows the SDHCI standard,
+ *       the rtems-libbsd tree already provides the remaining registers.
+#define BCM2711_EMMC_BASE           (RPI_PERIPHERAL_BASE + 0x300000)
+* @name Mailbox Registers
+#define BCM2711_MBOX_BASE          (RPI_PERIPHERAL_BASE+0xB880)
+#define BCM2711_MBOX_READ          (BCM2711_MBOX_BASE+0x00)
+#define BCM2711_MBOX_PEEK          (BCM2711_MBOX_BASE+0x10)
+#define BCM2711_MBOX_SENDER        (BCM2711_MBOX_BASE+0x14)
+#define BCM2711_MBOX_STATUS        (BCM2711_MBOX_BASE+0x18)
+#define BCM2711_MBOX_WRITE         (BCM2711_MBOX_BASE+0x20)
+#define BCM2711_MBOX_CONFIG        (BCM2711_MBOX_BASE+0x1C)
+#define BCM2711_MBOX_RESPONSE      0x80000000
+#define BCM2711_MBOX_FULL          0x80000000
+#define BCM2711_MBOX_EMPTY         0x40000000
+* @name Mailbox Channels
+/* Power Manager channel */
+#define BCM2711_MBOX_CHANNEL_PM         0
+/* Framebuffer channel */
+#define BCM2711_MBOX_CHANNEL_FB         1
+ /* Virtual UART channel */
+#define BCM2711_MBOX_CHANNEL_VUART      2
+ /* VCHIQ channel */
+#define BCM2711_MBOX_CHANNEL_VCHIQ      3
+ /* LEDs channel */
+#define BCM2711_MBOX_CHANNEL_LED        4
+ /* Button channel */
+#define BCM2711_MBOX_CHANNEL_BUTTON     5
+ /* Touch screen channel */
+#define BCM2711_MBOX_CHANNEL_TOUCHS     6
+#define BCM2711_MBOX_CHANNEL_COUNT      7
+/* Property tags (ARM <-> VC) channel */
+#define BCM2711_MBOX_CHANNEL_PROP_AVC   8
+ /* Property tags (VC <-> ARM) channel */
+#define BCM2711_MBOX_CHANNEL_PROP_VCA   9
+ * @name Raspberry Pi 2 Interrupt Register Defines
+/* Timers interrupt control registers */
+#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE       0xFF800040
+#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE       0xFF800044
+#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE       0xFF800048
+#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE       0xFF80004C
+#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
+  (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
+ * @name Raspberry Pi 4 ARM_LOCAL registers
+#define BCM2711_LOCAL_REGS_BASE               0x4C0000000
+#define BCM2711_LOCAL_REGS_SIZE               0x100
+#define BCM2711_LOCAL_ARM_CONTROL             (BCM2711_LOCAL_REGS_BASE + 0x00)
+#define BCM2711_LOCAL_CORE_IRQ_CONTROL        (BCM2711_LOCAL_REGS_BASE + 0x0c)
+#define BCM2711_LOCAL_PMU_CONTROL_SET         (BCM2711_LOCAL_REGS_BASE + 0x10)
+#define BCM2711_LOCAL_PMU_CONTROL_CLR         (BCM2711_LOCAL_REGS_BASE + 0x14)
+#define BCM2711_LOCAL_PERI_IRQ_ROUTE0         (BCM2711_LOCAL_REGS_BASE + 0x24)
+#define BCM2711_LOCAL_AXI_QUIET_TIME          (BCM2711_LOCAL_REGS_BASE + 0x30)
+#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL     (BCM2711_LOCAL_REGS_BASE + 0x34)
+#define BCM2711_LOCAL_LOCAL_TIMER_IRQ         (BCM2711_LOCAL_REGS_BASE + 0x38)
+#define BCM2711_LOCAL_TIMER_CNTRL0            (BCM2711_LOCAL_REGS_BASE + 0x40)
+#define BCM2711_LOCAL_TIMER_CNTRL1            (BCM2711_LOCAL_REGS_BASE + 0x44)
+#define BCM2711_LOCAL_TIMER_CNTRL2            (BCM2711_LOCAL_REGS_BASE + 0x48)
+#define BCM2711_LOCAL_TIMER_CNTRL3            (BCM2711_LOCAL_REGS_BASE + 0x4c)
+#define BCM2711_LOCAL_MAILBOX_CNTRL0          (BCM2711_LOCAL_REGS_BASE + 0x50)
+#define BCM2711_LOCAL_MAILBOX_CNTRL1          (BCM2711_LOCAL_REGS_BASE + 0x54)
+#define BCM2711_LOCAL_MAILBOX_CNTRL2          (BCM2711_LOCAL_REGS_BASE + 0x58)
+#define BCM2711_LOCAL_MAILBOX_CNTRL3          (BCM2711_LOCAL_REGS_BASE + 0x5c)
+#define BCM2711_LOCAL_IRQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE + 0x60)
+#define BCM2711_LOCAL_IRQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE + 0x64)
+#define BCM2711_LOCAL_IRQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE + 0x68)
+#define BCM2711_LOCAL_IRQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE + 0x6c)
+#define BCM2711_LOCAL_FIQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE + 0x70)
+#define BCM2711_LOCAL_FIQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE + 0x74)
+#define BCM2711_LOCAL_FIQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE + 0x78)
+#define BCM2711_LOCAL_FIQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE + 0x7c)
+ * @name Raspberry Pi 4 Mailbox registers
+#define BCM2711_MAILBOX_00_WRITE_SET_BASE               0x4C000080
+#define BCM2711_MAILBOX_01_WRITE_SET_BASE               0x4C000084
+#define BCM2711_MAILBOX_02_WRITE_SET_BASE               0x4C000088
+#define BCM2711_MAILBOX_03_WRITE_SET_BASE               0x4C00008C
+#define BCM2711_MAILBOX_04_WRITE_SET_BASE               0x4C000090
+#define BCM2711_MAILBOX_05_WRITE_SET_BASE               0x4C000094
+#define BCM2711_MAILBOX_06_WRITE_SET_BASE               0x4C000098
+#define BCM2711_MAILBOX_07_WRITE_SET_BASE               0x4C00009C
+#define BCM2711_MAILBOX_08_WRITE_SET_BASE               0x4C0000A0
+#define BCM2711_MAILBOX_09_WRITE_SET_BASE               0x4C0000A4
+#define BCM2711_MAILBOX_10_WRITE_SET_BASE               0x4C0000A8
+#define BCM2711_MAILBOX_11_WRITE_SET_BASE               0x4C0000AC
+#define BCM2711_MAILBOX_12_WRITE_SET_BASE               0x4C0000B0
+#define BCM2711_MAILBOX_13_WRITE_SET_BASE               0x4C0000B4
+#define BCM2711_MAILBOX_14_WRITE_SET_BASE               0x4C0000B8
+#define BCM2711_MAILBOX_15_WRITE_SET_BASE               0x4C0000BC
+#define BCM2711_MAILBOX_00_READ_CLEAR_BASE              0x4C0000C0
+#define BCM2711_MAILBOX_01_READ_CLEAR_BASE              0x4C0000C4
+#define BCM2711_MAILBOX_02_READ_CLEAR_BASE              0x4C0000C8
+#define BCM2711_MAILBOX_03_READ_CLEAR_BASE              0x4C0000CC
+#define BCM2711_MAILBOX_04_READ_CLEAR_BASE              0x4C0000D0
+#define BCM2711_MAILBOX_05_READ_CLEAR_BASE              0x4C0000D4
+#define BCM2711_MAILBOX_06_READ_CLEAR_BASE              0x4C0000D8
+#define BCM2711_MAILBOX_07_READ_CLEAR_BASE              0x4C0000DC
+#define BCM2711_MAILBOX_08_READ_CLEAR_BASE              0x4C0000E0
+#define BCM2711_MAILBOX_09_READ_CLEAR_BASE              0x4C0000E4
+#define BCM2711_MAILBOX_10_READ_CLEAR_BASE              0x4C0000E8
+#define BCM2711_MAILBOX_11_READ_CLEAR_BASE              0x4C0000EC
+#define BCM2711_MAILBOX_12_READ_CLEAR_BASE              0x4C0000F0
+#define BCM2711_MAILBOX_13_READ_CLEAR_BASE              0x4C0000F4
+#define BCM2711_MAILBOX_14_READ_CLEAR_BASE              0x4C0000F8
+#define BCM2711_MAILBOX_15_READ_CLEAR_BASE              0x4C0000FC
+ * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
+#define BCM2711_ARMC_REGS_BASE                 (RPI_PERIPHERAL_BASE + 0xB200)
+#define BCM2711_ARMC_REGS_SIZE                 0x200
+#define BCM2711_ARMC_IRQ0_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x00)
+#define BCM2711_ARMC_IRQ0_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x04)
+#define BCM2711_ARMC_IRQ0_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x08)
+#define BCM2711_ARMC_IRQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x10)
+#define BCM2711_ARMC_IRQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x14)
+#define BCM2711_ARMC_IRQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x18)
+#define BCM2711_ARMC_IRQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x20)
+#define BCM2711_ARMC_IRQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x24)
+#define BCM2711_ARMC_IRQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x28)
+#define BCM2711_ARMC_IRQ_STATUS0               (BCM2711_ARMC_REGS_BASE + 0x30)
+#define BCM2711_ARMC_IRQ_STATUS1               (BCM2711_ARMC_REGS_BASE + 0x34)
+#define BCM2711_ARMC_IRQ_STATUS2               (BCM2711_ARMC_REGS_BASE + 0x38)
+#define BCM2711_ARMC_IRQ1_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x40)
+#define BCM2711_ARMC_IRQ1_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x44)
+#define BCM2711_ARMC_IRQ1_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x48)
+#define BCM2711_ARMC_IRQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x50)
+#define BCM2711_ARMC_IRQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x54)
+#define BCM2711_ARMC_IRQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x58)
+#define BCM2711_ARMC_IRQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x60)
+#define BCM2711_ARMC_IRQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x64)
+#define BCM2711_ARMC_IRQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x68)
+#define BCM2711_ARMC_IRQ2_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x80)
+#define BCM2711_ARMC_IRQ2_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x84)
+#define BCM2711_ARMC_IRQ2_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x88)
+#define BCM2711_ARMC_IRQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x90)
+#define BCM2711_ARMC_IRQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x94)
+#define BCM2711_ARMC_IRQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x98)
+#define BCM2711_ARMC_IRQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0xA0)
+#define BCM2711_ARMC_IRQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0xA4)
+#define BCM2711_ARMC_IRQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0xA8)
+#define BCM2711_ARMC_IRQ3_PENDING0             (BCM2711_ARMC_REGS_BASE + 0xC0)
+#define BCM2711_ARMC_IRQ3_PENDING1             (BCM2711_ARMC_REGS_BASE + 0xC4)
+#define BCM2711_ARMC_IRQ3_PENDING2             (BCM2711_ARMC_REGS_BASE + 0xC8)
+#define BCM2711_ARMC_IRQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0xD0)
+#define BCM2711_ARMC_IRQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0xD4)
+#define BCM2711_ARMC_IRQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0xD8)
+#define BCM2711_ARMC_IRQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0xE0)
+#define BCM2711_ARMC_IRQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0xE4)
+#define BCM2711_ARMC_IRQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0xE8)
+#define BCM2711_ARMC_FIQ0_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x100)
+#define BCM2711_ARMC_FIQ0_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x104)
+#define BCM2711_ARMC_FIQ0_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x108)
+#define BCM2711_ARMC_FIQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x110)
+#define BCM2711_ARMC_FIQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x114)
+#define BCM2711_ARMC_FIQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x118)
+#define BCM2711_ARMC_FIQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x120)
+#define BCM2711_ARMC_FIQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x124)
+#define BCM2711_ARMC_FIQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x128)
+#define BCM2711_ARMC_FIQ1_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x140)
+#define BCM2711_ARMC_FIQ1_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x144)
+#define BCM2711_ARMC_FIQ1_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x148)
+#define BCM2711_ARMC_FIQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x150)
+#define BCM2711_ARMC_FIQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x154)
+#define BCM2711_ARMC_FIQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x158)
+#define BCM2711_ARMC_FIQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x160)
+#define BCM2711_ARMC_FIQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x164)
+#define BCM2711_ARMC_FIQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x168)
+#define BCM2711_ARMC_FIQ2_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x180)
+#define BCM2711_ARMC_FIQ2_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x184)
+#define BCM2711_ARMC_FIQ2_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x188)
+#define BCM2711_ARMC_FIQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x190)
+#define BCM2711_ARMC_FIQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x194)
+#define BCM2711_ARMC_FIQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x198)
+#define BCM2711_ARMC_FIQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x1A0)
+#define BCM2711_ARMC_FIQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x1A4)
+#define BCM2711_ARMC_FIQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x1A8)
+#define BCM2711_ARMC_FIQ3_PENDING0             (BCM2711_ARMC_REGS_BASE + 0x1C0)
+#define BCM2711_ARMC_FIQ3_PENDING1             (BCM2711_ARMC_REGS_BASE + 0x1C4)
+#define BCM2711_ARMC_FIQ3_PENDING2             (BCM2711_ARMC_REGS_BASE + 0x1C8)
+#define BCM2711_ARMC_FIQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE + 0x1D0)
+#define BCM2711_ARMC_FIQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE + 0x1D4)
+#define BCM2711_ARMC_FIQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE + 0x1D8)
+#define BCM2711_ARMC_FIQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE + 0x1E0)
+#define BCM2711_ARMC_FIQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE + 0x1E4)
+#define BCM2711_ARMC_FIQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE + 0x1E8)
+#define BCM2711_ARMC_SWIRQ_SET                 (BCM2711_ARMC_REGS_BASE + 0x1F0)
+#define BCM2711_ARMC_SWIRQ_CLEAR               (BCM2711_ARMC_REGS_BASE + 0x1F4)
+#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
diff --git a/bsps/aarch64/raspberrypi/include/tm27.h b/bsps/aarch64/raspberrypi/include/tm27.h
index 0000000000..653f88ed01
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/tm27.h
@@ -0,0 +1,46 @@
+ * @file
+ * @brief BSP tm27 header
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <dev/irq/arm-gic-tm27.h>
+#endif /* __tm27_h */
\ No newline at end of file
diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c b/bsps/aarch64/raspberrypi/start/bspstart.c
index 0000000000..56f52a2231
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstart.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief BSP Startup
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+  bsp_interrupt_initialize();
+  rtems_cache_coherent_add_area(
+    bsp_section_nocacheheap_begin,
+    (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
index 0000000000..fe0fe77c09
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
@@ -0,0 +1,53 @@
+ * @file
+ * @brief BSP Startup Hooks
+ * are met:
+#include <bsp.h>
+#include <rtems/score/cpu.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+  /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+  AArch64_start_set_vector_base();
+  bsp_start_copy_sections();
+  raspberrypi_4_setup_mmu_and_cache();
+  bsp_start_clear_bss();
diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
index 0000000000..ab12020a2a
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
@@ -0,0 +1,84 @@
+ * @file
+ * @brief This source file contains the default MMU tables and setup.
+ * are met:
+#include <bsp.h>
+#include <bsp/aarch64-mmu.h>
+#include <bsp/raspberrypi.h>
+#include <libcpu/mmu-vmsav8-64.h>
+BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
+raspberrypi_4_mmu_config_table[] = {
+  AARCH64_MMU_DEFAULT_SECTIONS,
+  { /* RPI peripheral address */
+    .begin = (unsigned)RPI_PERIPHERAL_BASE,
+    .end = (unsigned)RPI_PERIPHERAL_BASE + (unsigned)RPI_PERIPHERAL_SIZE,
+    .flags = AARCH64_MMU_DEVICE
+  { /* RPI ARM local registers */
+    .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
+    .end = (unsigned)BCM2711_LOCAL_REGS_BASE + (unsigned)BCM2711_LOCAL_REGS_SIZE,
+  { /* RPI GIC Interface address */
+    .begin = 0xFF800000U,
+    .end = 0xFFA00000U,
+ * Make weak and let the user override.
+raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
+  aarch64_mmu_setup();
+  aarch64_mmu_setup_translation_table(
+    &raspberrypi_4_mmu_config_table[ 0 ],
+    RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
+  aarch64_mmu_enable();
diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml b/spec/build/bsps/aarch64/raspberrypi/abi.yml
index 0000000000..5e3e0a4975
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2022 Mohd Noor Aman
+default:
+- -mcpu=cortex-a72
+- -march=armv8-a
+default-by-variant: []
+includes: []
+description: |
+  ABI flags
+links: []
+enabled-by: true
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
index 0000000000..d2ff76d351
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
@@ -0,0 +1,81 @@
+arch: aarch64
+bsp: raspberrypi4b
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: raspberrypi
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - bsps/aarch64/raspberrypi/include/bsp.h
+  - bsps/aarch64/raspberrypi/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/aarch64/raspberrypi/include/bsp/irq.h
+  - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
+source:
+- bsps/aarch64/raspberrypi/console/console.c
+- bsps/aarch64/raspberrypi/start/bspstart.c
+- bsps/aarch64/raspberrypi/start/bspstarthooks.c
+- bsps/aarch64/raspberrypi/start/bspstartmmu.c
+- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/shared/mmu/vmsav8-64.c
+- bsps/shared/dev/clock/arm-generic-timer.c
+- bsps/shared/dev/irq/arm-gicv2.c
+- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/dev/serial/arm-pl011.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/irq/irq-handler-install.c
+- bsps/shared/irq/irq-generic.c
+- bsps/shared/irq/irq-lock.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspreset-arm-psci.c
+- bsps/shared/start/gettargethash-default.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/start/wkspaceinitone.c
+- bsps/shared/start/mallocinitmulti.c
+- bsps/shared/start/bspgetworkarea-default.c
+links:
+- role: build-dependency
+  uid: ../grp
+  uid: ../start
+  uid: ../optmmupages
+  uid: ../optgtusevirt
+  uid: ../optgtuseps
+  uid: abi
+  uid: ../../optcachedata
+  uid: ../../optcacheinst
+  uid: ../../opto2
+  uid: ../../bspopts
+  uid: linkercmds
+  uid: ../../obj
+  uid: ../../objirq
+type: build
diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
index 0000000000..8598b89cba
--- /dev/null
+++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
@@ -0,0 +1,76 @@
+build-type: config-file
+content: |
+  /* SPDX-License-Identifier: BSD-2-Clause */
+   * are met:
+  MEMORY {
+  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 * ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
+  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
+  REGION_ALIAS ("REGION_START",          RAM);
+  REGION_ALIAS ("REGION_VECTOR",         RAM);
+  REGION_ALIAS ("REGION_TEXT",           RAM);
+  REGION_ALIAS ("REGION_TEXT_LOAD",      RAM);
+  REGION_ALIAS ("REGION_RODATA",         RAM);
+  REGION_ALIAS ("REGION_RODATA_LOAD",    RAM);
+  REGION_ALIAS ("REGION_DATA",           RAM);
+  REGION_ALIAS ("REGION_DATA_LOAD",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT",      RAM);
+  REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+  REGION_ALIAS ("REGION_FAST_DATA",      RAM);
+  REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+  REGION_ALIAS ("REGION_BSS",            RAM);
+  REGION_ALIAS ("REGION_WORK",           RAM);
+  REGION_ALIAS ("REGION_STACK",          RAM);
+  REGION_ALIAS ("REGION_NOCACHE",        RAM);
+  REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
+  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size : 1024;
+  bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+  bsp_vector_table_in_start_section = 1;
+  bsp_translation_table_base = ORIGIN (RAM_MMU);
+  bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
+  OUTPUT_FORMAT ("elf64-littleaarch64")
+  OUTPUT_ARCH (aarch64)
+  INCLUDE linkcmds.base
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
2.37.3
