[PATCH v3] bsp/aarch64: Add new Raspberry Pi 4B BSP
Joel Sherrill
joel at rtems.org
Tue Oct 4 18:39:47 UTC 2022
Once Alan says it's OK, I will merge this.
Great work! Please make sure code, docs, tester configuration, etc gets
merged.
On Tue, Oct 4, 2022 at 1:18 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> I think all of the issues with this patch have been addressed; this looks
> good to me.
> Great work, Noor!
> Kinsey
> On Tue, Oct 4, 2022 at 11:12 AM Noor Aman <nooraman5718 at gmail.com> wrote:
>> hey all,
>> I've fixed the warning and edited the commit message to be more specific
>> and to be in 80 words char limit.
>> Thanks,
>> Noor
>> On Tue, 4 Oct 2022 at 16:08, Mohd Noor Aman <nooraman5718 at gmail.com>
>> wrote:
>>> This patch adds new Raspberry pi 4B AArch64 BSP to the RTEMS Family.
>>> Currently
>>> only LP64 ABI is supported. ILP32 is not supported. RAM starts from
>>> 0x80000 in
>>> 64Bit kernel mode and MMU from 0x0. All Raspberrypi Pi 4B models and
>>> Raspberry
>>> Pi 400 are supported. All the IRQs are similiar to the older Raspberry
>>> pi 2 ARM
>>> BSP.
>>> Raspberry Pi 4B has 2 types of UARTs. Only PL011 serial is supported
>>> currently.
>>> Mini-UART is not supported. Mini-UART is default UART on the board so it
>>> needs
>>> to be disabled by adding "dtoverlay=disable-bt" to the config.txt. No
>>> support
>>> for additional 4 PL011-UARTs on the board.
>>> The raspberrypi.h includes many of the address required for the future
>>> development of the RPi 4B BSP. This includes peripherals, ARM Timer,
>>> VideoCore
>>> Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
>>> bsps/aarch64/raspberrypi/console/console.c | 69 +++
>>> bsps/aarch64/raspberrypi/include/bsp.h | 76 +++
>>> bsps/aarch64/raspberrypi/include/bsp/irq.h | 109 ++++
>>> .../raspberrypi/include/bsp/raspberrypi.h | 471 ++++++++++++++++++
>>> bsps/aarch64/raspberrypi/include/tm27.h | 46 ++
>>> bsps/aarch64/raspberrypi/start/bspstart.c | 49 ++
>>> .../aarch64/raspberrypi/start/bspstarthooks.c | 53 ++
>>> bsps/aarch64/raspberrypi/start/bspstartmmu.c | 84 ++++
>>> spec/build/bsps/aarch64/raspberrypi/abi.yml | 21 +
>>> .../aarch64/raspberrypi/bspraspberrypi4.yml | 81 +++
>>> .../bsps/aarch64/raspberrypi/linkercmds.yml | 76 +++
>>> 11 files changed, 1135 insertions(+)
>>> create mode 100644 bsps/aarch64/raspberrypi/console/console.c
>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp.h
>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> create mode 100644 bsps/aarch64/raspberrypi/include/tm27.h
>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstart.c
>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> create mode 100644 bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> create mode 100644 spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> create mode 100644
>>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> create mode 100644 spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> diff --git a/bsps/aarch64/raspberrypi/console/console.c
>>> b/bsps/aarch64/raspberrypi/console/console.c
>>> new file mode 100644
>>> index 0000000000..73bb0036ff
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/console/console.c
>>> @@ -0,0 +1,69 @@
>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>> + * @file
>>> + * @ingroup RTEMSBSPsAArch64Raspberrypi4
>>> + * @brief Console Configuration
>>> + * Copyright (C) 2022 Mohd Noor Aman
>>> + * Redistribution and use in source and binary forms, with or without
>>> + * modification, are permitted provided that the following conditions
>>> + * are met:
>>> + * 1. Redistributions of source code must retain the above copyright
>>> + * notice, this list of conditions and the following disclaimer.
>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>> + * notice, this list of conditions and the following disclaimer in
>>> the
>>> + * documentation and/or other materials provided with the
>>> distribution.
>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> "AS IS"
>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> TO, THE
>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>> CONTRIBUTORS BE
>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>> IN
>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> + * POSSIBILITY OF SUCH DAMAGE.
>>> +#include <rtems/bspIo.h>
>>> +#include <bsp.h>
>>> +#include <dev/serial/arm-pl011.h>
>>> +#include <bsp/console-termios.h>
>>> +#include <bspopts.h>
>>> +arm_pl011_context raspberrypi_4_context = {
>>> + .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>> + .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
>>> + .initial_baud = 115200
>>> +const console_device console_device_table[] = {
>>> + .device_file = "/dev/ttyS0",
>>> + .probe = console_device_probe_default,
>>> + .handler = &arm_pl011_fns,
>>> + .context = &raspberrypi_4_context.base
>>> +const size_t console_device_count =
>>> RTEMS_ARRAY_SIZE(console_device_table);
>>> +static void output_char( char c )
>>> + arm_pl011_write_polled(&raspberrypi_4_context.base, c);
>>> +BSP_output_char_function_type BSP_output_char = output_char;
>>> +BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp.h
>>> b/bsps/aarch64/raspberrypi/include/bsp.h
>>> index 0000000000..4fa81edd40
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp.h
>>> @@ -0,0 +1,76 @@
>>> + * @file
>>> + * @brief Core BSP definitions
>>> + * are met:
>>> the
>>> distribution.
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>> + * @addtogroup RTEMSBSPsAArch64
>>> +#ifndef ASM
>>> +#include <bsp/default-initial-extension.h>
>>> +#include <bsp/start.h>
>>> +#include <rtems.h>
>>> +/*Raspberry pi MMU initialization */
>>> +BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif /* __cplusplus */
>>> +#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
>>> +#define BSP_ARM_GIC_DIST_BASE 0xFF841000
>>> +#define BSP_RPI4_PL011_BASE 0xFE201000
>>> +#define BSP_RPI4_PL011_LENGTH 0x200
>>> +#ifdef __cplusplus
>>> +#endif /* ASM */
>>> +#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> index 0000000000..effec1b040
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> @@ -0,0 +1,109 @@
>>> + * @file
>>> + * @ingroup raspberrypi_interrupt
>>> + * @brief Interrupt definitions.
>>> + * Copyright (c) 2013 Alan Cudmore
>>> + * Copyright (c) 2022 Mohd Noor Aman
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.org/license/LICENSE
>>> +#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>> +#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>> +#ifndef ASM
>>> +#include <rtems.h>
>>> +#include <rtems/irq.h>
>>> +#include <rtems/irq-extension.h>
>>> +#include <dev/irq/arm-gic-irq.h>
>>> +#if defined(RTEMS_SMP)
>>> +#include <rtems/score/processormask.h>
>>> +#endif
>>> + * @defgroup raspberrypi_interrupt Interrrupt Support
>>> + * @ingroup RTEMSBSPsARMRaspberryPi
>>> + * @brief Interrupt support.
>>> +#define BCM2835_INTC_TOTAL_IRQ (64 + 8)
>>> +#define BCM2835_IRQ_SET1_MIN 0
>>> +#define BCM2835_IRQ_SET2_MIN 32
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M0 0
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M1 1
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M2 2
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M3 3
>>> +#define BCM2835_IRQ_ID_USB 9
>>> +#define BCM2835_IRQ_ID_AUX 29
>>> +#define BCM2835_IRQ_ID_SPI_SLAVE 43
>>> +#define BCM2835_IRQ_ID_PWA0 45
>>> +#define BCM2835_IRQ_ID_PWA1 46
>>> +#define BCM2835_IRQ_ID_SMI 48
>>> +#define BCM2835_IRQ_ID_GPIO_0 49
>>> +#define BCM2835_IRQ_ID_GPIO_1 50
>>> +#define BCM2835_IRQ_ID_GPIO_2 51
>>> +#define BCM2835_IRQ_ID_GPIO_3 52
>>> +#define BCM2835_IRQ_ID_I2C 53
>>> +#define BCM2835_IRQ_ID_SPI 54
>>> +#define BCM2835_IRQ_ID_PCM 55
>>> +#define BCM2835_IRQ_ID_UART 57
>>> +#define BCM2835_IRQ_ID_SD 62
>>> +#define BCM2835_IRQ_ID_BASIC_BASE_ID 64
>>> +#define BCM2835_IRQ_ID_TIMER_0 64
>>> +#define BCM2835_IRQ_ID_MAILBOX_0 65
>>> +#define BCM2835_IRQ_ID_DOORBELL_0 66
>>> +#define BCM2835_IRQ_ID_DOORBELL_1 67
>>> +#define BCM2835_IRQ_ID_GPU0_HALTED 68
>>> +#define BCM2835_IRQ_ID_GPU1_HALTED 69
>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_1 70
>>> +#define BCM2835_IRQ_ID_ILL_ACCESS_0 71
>>> +#define BSP_TIMER_VIRT_PPI 27
>>> +#define BSP_TIMER_PHYS_NS_PPI 30
>>> +#define BSP_VPL011_SPI 32
>>> +#define BSP_INTERRUPT_VECTOR_COUNT BCM2835_INTC_TOTAL_IRQ
>>> +#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
>>> +#define BSP_IRQ_COUNT (BCM2835_INTC_TOTAL_IRQ)
>>> +static inline rtems_status_code bsp_interrupt_set_affinity(
>>> + rtems_vector_number vector,
>>> + const Processor_mask *affinity
>>> + (void) vector;
>>> + (void) affinity;
>>> + return RTEMS_UNSATISFIED;
>>> +static inline rtems_status_code bsp_interrupt_get_affinity(
>>> + Processor_mask *affinity
>>> + (void) vector;
>>> + _Processor_mask_From_index( affinity, 0 );
>>> +#endif
>>> +#endif /* ASM */
>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_IRQ_H */
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> index 0000000000..f148e8df6c
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> @@ -0,0 +1,471 @@
>>> + * @file
>>> + * @ingroup raspberrypi_4_regs
>>> + * @brief Register definitions.
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>> +#include <stdint.h>
>>> +#include <bsp/utility.h>
>>> + * @defgroup raspberrypi_reg Register Definitions
>>> + * @brief Register Definitions
>>> + * @name Register Macros
>>> +#define BCM2711_REG(x) (*(volatile uint64_t *)(x))
>>> +#define BCM2711_BIT(n) (1 << (n))
>>> + * @name Peripheral Base Register Address
>>> +#define RPI_PERIPHERAL_BASE 0xFE000000
>>> +#define BASE_OFFSET 0xFE000000
>>> +#define RPI_PERIPHERAL_SIZE 0x01800000
>>> + * @name Bus to Physical address translation
>>> + * Macro.
>>> +#define BUS_TO_PHY(x) ((x) - BASE_OFFSET)
>>> + * @name Internal ARM Timer Registers
>>> +#define BCM2711_CLOCK_FREQ 250000000
>>> +#define BCM2711_TIMER_BASE (RPI_PERIPHERAL_BASE + 0xB400)
>>> +#define BCM2711_TIMER_LOD (BCM2711_TIMER_BASE + 0x00)
>>> +#define BCM2711_TIMER_VAL (BCM2711_TIMER_BASE + 0x04)
>>> +#define BCM2711_TIMER_CTL (BCM2711_TIMER_BASE + 0x08)
>>> +#define BCM2711_TIMER_CLI (BCM2711_TIMER_BASE + 0x0C)
>>> +#define BCM2711_TIMER_RIS (BCM2711_TIMER_BASE + 0x10)
>>> +#define BCM2711_TIMER_MIS (BCM2711_TIMER_BASE + 0x14)
>>> +#define BCM2711_TIMER_RLD (BCM2711_TIMER_BASE + 0x18)
>>> +#define BCM2711_TIMER_DIV (BCM2711_TIMER_BASE + 0x1C)
>>> +#define BCM2711_TIMER_CNT (BCM2711_TIMER_BASE + 0x20)
>>> +#define BCM2711_TIMER_PRESCALE 0xF9
>>> + * @name Power Management and Watchdog Registers
>>> +#define BCM2711_PM_PASSWD_MAGIC 0x5a000000
>>> +#define BCM2711_PM_BASE (RPI_PERIPHERAL_BASE + 0x100000)
>>> +#define BCM2711_PM_GNRIC (BCM2711_PM_BASE + 0x00)
>>> +#define BCM2711_PM_GNRIC_POWUP 0x00000001
>>> +#define BCM2711_PM_GNRIC_POWOK 0x00000002
>>> +#define BCM2711_PM_GNRIC_ISPOW 0x00000004
>>> +#define BCM2711_PM_GNRIC_MEMREP 0x00000008
>>> +#define BCM2711_PM_GNRIC_MRDONE 0x00000010
>>> +#define BCM2711_PM_GNRIC_ISFUNC 0x00000020
>>> +#define BCM2711_PM_GNRIC_RSTN 0x00000fc0
>>> +#define BCM2711_PM_GNRIC_ENAB 0x00001000
>>> +#define BCM2711_PM_GNRIC_CFG 0x007f0000
>>> +#define BCM2711_PM_AUDIO (BCM2711_PM_BASE + 0x04)
>>> +#define BCM2711_PM_AUDIO_APSM 0x000fffff
>>> +#define BCM2711_PM_AUDIO_CTRLEN 0x00100000
>>> +#define BCM2711_PM_AUDIO_RSTN 0x00200000
>>> +#define BCM2711_PM_STATUS (BCM2711_PM_BASE + 0x18)
>>> +#define BCM2711_PM_RSTC (BCM2711_PM_BASE + 0x1c)
>>> +#define BCM2711_PM_RSTC_DRCFG 0x00000003
>>> +#define BCM2711_PM_RSTC_WRCFG 0x00000030
>>> +#define BCM2711_PM_RSTC_WRCFG_FULL 0x00000020
>>> +#define BCM2711_PM_RSTC_SRCFG 0x00000300
>>> +#define BCM2711_PM_RSTC_QRCFG 0x00003000
>>> +#define BCM2711_PM_RSTC_FRCFG 0x00030000
>>> +#define BCM2711_PM_RSTC_HRCFG 0x00300000
>>> +#define BCM2711_PM_RSTS (BCM2711_PM_BASE + 0x20)
>>> +#define BCM2711_PM_RSTS_HADDRQ 0x00000001
>>> +#define BCM2711_PM_RSTS_HADDRF 0x00000002
>>> +#define BCM2711_PM_RSTS_HADDRH 0x00000004
>>> +#define BCM2711_PM_RSTS_HADWRQ 0x00000010
>>> +#define BCM2711_PM_RSTS_HADWRF 0x0000002
>>> +#define BCM2711_PM_RSTS_HADWRH 0x00000040
>>> +#define BCM2711_PM_RSTS_HADSRQ 0x00000100
>>> +#define BCM2711_PM_RSTS_HADSRF 0x00000200
>>> +#define BCM2711_PM_RSTS_HADSRH 0x00000400
>>> +#define BCM2711_PM_RSTS_HADPOR 0x00001000
>>> +#define BCM2711_PM_WDOG (BCM2711_PM_BASE + 0x24)
>>> + * @name AUX Registers
>>> +#define BCM2711_AUX_BASE (RPI_PERIPHERAL_BASE + 0x215000)
>>> +#define AUX_ENABLES (BCM2711_AUX_BASE + 0x04)
>>> +#define AUX_MU_IO_REG (BCM2711_AUX_BASE + 0x40)
>>> +#define AUX_MU_IER_REG (BCM2711_AUX_BASE + 0x44)
>>> +#define AUX_MU_IIR_REG (BCM2711_AUX_BASE + 0x48)
>>> +#define AUX_MU_LCR_REG (BCM2711_AUX_BASE + 0x4C)
>>> +#define AUX_MU_MCR_REG (BCM2711_AUX_BASE + 0x50)
>>> +#define AUX_MU_LSR_REG (BCM2711_AUX_BASE + 0x54)
>>> +#define AUX_MU_MSR_REG (BCM2711_AUX_BASE + 0x58)
>>> +#define AUX_MU_SCRATCH (BCM2711_AUX_BASE + 0x5C)
>>> +#define AUX_MU_CNTL_REG (BCM2711_AUX_BASE + 0x60)
>>> +#define AUX_MU_STAT_REG (BCM2711_AUX_BASE + 0x64)
>>> +#define AUX_MU_BAUD_REG (BCM2711_AUX_BASE + 0x68)
>>> + * @name GPU Timer Registers
>>> + * NOTE: The GPU uses Compare registers 0 and 2 for
>>> + * it's own RTOS. 1 and 3 are available for use in
>>> + * RTEMS.
>>> +#define BCM2711_GPU_TIMER_BASE (RPI_PERIPHERAL_BASE + 0x3000)
>>> +#define BCM2711_GPU_TIMER_CS (BCM2711_GPU_TIMER_BASE + 0x00)
>>> +#define BCM2711_GPU_TIMER_CS_M0 0x00000001
>>> +#define BCM2711_GPU_TIMER_CS_M1 0x00000002
>>> +#define BCM2711_GPU_TIMER_CS_M2 0x00000004
>>> +#define BCM2711_GPU_TIMER_CS_M3 0x00000008
>>> +#define BCM2711_GPU_TIMER_CLO (BCM2711_GPU_TIMER_BASE + 0x04)
>>> +#define BCM2711_GPU_TIMER_CHI (BCM2711_GPU_TIMER_BASE + 0x08)
>>> +#define BCM2711_GPU_TIMER_C0 (BCM2711_GPU_TIMER_BASE + 0x0C)
>>> +#define BCM2711_GPU_TIMER_C1 (BCM2711_GPU_TIMER_BASE + 0x10)
>>> +#define BCM2711_GPU_TIMER_C2 (BCM2711_GPU_TIMER_BASE + 0x14)
>>> +#define BCM2711_GPU_TIMER_C3 (BCM2711_GPU_TIMER_BASE + 0x18)
>>> + * @name EMMC Registers
>>> + * NOTE: Since the SD controller follows the SDHCI standard,
>>> + * the rtems-libbsd tree already provides the remaining registers.
>>> +#define BCM2711_EMMC_BASE (RPI_PERIPHERAL_BASE + 0x300000)
>>> +* @name Mailbox Registers
>>> +#define BCM2711_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
>>> +#define BCM2711_MBOX_READ (BCM2711_MBOX_BASE+0x00)
>>> +#define BCM2711_MBOX_PEEK (BCM2711_MBOX_BASE+0x10)
>>> +#define BCM2711_MBOX_SENDER (BCM2711_MBOX_BASE+0x14)
>>> +#define BCM2711_MBOX_STATUS (BCM2711_MBOX_BASE+0x18)
>>> +#define BCM2711_MBOX_WRITE (BCM2711_MBOX_BASE+0x20)
>>> +#define BCM2711_MBOX_CONFIG (BCM2711_MBOX_BASE+0x1C)
>>> +#define BCM2711_MBOX_RESPONSE 0x80000000
>>> +#define BCM2711_MBOX_FULL 0x80000000
>>> +#define BCM2711_MBOX_EMPTY 0x40000000
>>> +* @name Mailbox Channels
>>> +/* Power Manager channel */
>>> +#define BCM2711_MBOX_CHANNEL_PM 0
>>> +/* Framebuffer channel */
>>> +#define BCM2711_MBOX_CHANNEL_FB 1
>>> + /* Virtual UART channel */
>>> +#define BCM2711_MBOX_CHANNEL_VUART 2
>>> + /* VCHIQ channel */
>>> +#define BCM2711_MBOX_CHANNEL_VCHIQ 3
>>> + /* LEDs channel */
>>> +#define BCM2711_MBOX_CHANNEL_LED 4
>>> + /* Button channel */
>>> +#define BCM2711_MBOX_CHANNEL_BUTTON 5
>>> + /* Touch screen channel */
>>> +#define BCM2711_MBOX_CHANNEL_TOUCHS 6
>>> +#define BCM2711_MBOX_CHANNEL_COUNT 7
>>> +/* Property tags (ARM <-> VC) channel */
>>> +#define BCM2711_MBOX_CHANNEL_PROP_AVC 8
>>> + /* Property tags (VC <-> ARM) channel */
>>> +#define BCM2711_MBOX_CHANNEL_PROP_VCA 9
>>> + * @name Raspberry Pi 2 Interrupt Register Defines
>>> +/* Timers interrupt control registers */
>>> +#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE 0xFF800040
>>> +#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE 0xFF800044
>>> +#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE 0xFF800048
>>> +#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE 0xFF80004C
>>> +#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
>>> + (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
>>> + * @name Raspberry Pi 4 ARM_LOCAL registers
>>> +#define BCM2711_LOCAL_REGS_BASE 0x4C0000000
>>> +#define BCM2711_LOCAL_REGS_SIZE 0x100
>>> +#define BCM2711_LOCAL_ARM_CONTROL (BCM2711_LOCAL_REGS_BASE
>>> + 0x00)
>>> +#define BCM2711_LOCAL_CORE_IRQ_CONTROL (BCM2711_LOCAL_REGS_BASE
>>> + 0x0c)
>>> +#define BCM2711_LOCAL_PMU_CONTROL_SET (BCM2711_LOCAL_REGS_BASE
>>> + 0x10)
>>> +#define BCM2711_LOCAL_PMU_CONTROL_CLR (BCM2711_LOCAL_REGS_BASE
>>> + 0x14)
>>> +#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 (BCM2711_LOCAL_REGS_BASE
>>> + 0x24)
>>> +#define BCM2711_LOCAL_AXI_QUIET_TIME (BCM2711_LOCAL_REGS_BASE
>>> + 0x30)
>>> +#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL (BCM2711_LOCAL_REGS_BASE
>>> + 0x34)
>>> +#define BCM2711_LOCAL_LOCAL_TIMER_IRQ (BCM2711_LOCAL_REGS_BASE
>>> + 0x38)
>>> +#define BCM2711_LOCAL_TIMER_CNTRL0 (BCM2711_LOCAL_REGS_BASE
>>> + 0x40)
>>> +#define BCM2711_LOCAL_TIMER_CNTRL1 (BCM2711_LOCAL_REGS_BASE
>>> + 0x44)
>>> +#define BCM2711_LOCAL_TIMER_CNTRL2 (BCM2711_LOCAL_REGS_BASE
>>> + 0x48)
>>> +#define BCM2711_LOCAL_TIMER_CNTRL3 (BCM2711_LOCAL_REGS_BASE
>>> + 0x4c)
>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL0 (BCM2711_LOCAL_REGS_BASE
>>> + 0x50)
>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL1 (BCM2711_LOCAL_REGS_BASE
>>> + 0x54)
>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL2 (BCM2711_LOCAL_REGS_BASE
>>> + 0x58)
>>> +#define BCM2711_LOCAL_MAILBOX_CNTRL3 (BCM2711_LOCAL_REGS_BASE
>>> + 0x5c)
>>> +#define BCM2711_LOCAL_IRQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE
>>> + 0x60)
>>> +#define BCM2711_LOCAL_IRQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE
>>> + 0x64)
>>> +#define BCM2711_LOCAL_IRQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE
>>> + 0x68)
>>> +#define BCM2711_LOCAL_IRQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE
>>> + 0x6c)
>>> +#define BCM2711_LOCAL_FIQ_SOURCE0 (BCM2711_LOCAL_REGS_BASE
>>> + 0x70)
>>> +#define BCM2711_LOCAL_FIQ_SOURCE1 (BCM2711_LOCAL_REGS_BASE
>>> + 0x74)
>>> +#define BCM2711_LOCAL_FIQ_SOURCE2 (BCM2711_LOCAL_REGS_BASE
>>> + 0x78)
>>> +#define BCM2711_LOCAL_FIQ_SOURCE3 (BCM2711_LOCAL_REGS_BASE
>>> + 0x7c)
>>> + * @name Raspberry Pi 4 Mailbox registers
>>> +#define BCM2711_MAILBOX_00_WRITE_SET_BASE 0x4C000080
>>> +#define BCM2711_MAILBOX_01_WRITE_SET_BASE 0x4C000084
>>> +#define BCM2711_MAILBOX_02_WRITE_SET_BASE 0x4C000088
>>> +#define BCM2711_MAILBOX_03_WRITE_SET_BASE 0x4C00008C
>>> +#define BCM2711_MAILBOX_04_WRITE_SET_BASE 0x4C000090
>>> +#define BCM2711_MAILBOX_05_WRITE_SET_BASE 0x4C000094
>>> +#define BCM2711_MAILBOX_06_WRITE_SET_BASE 0x4C000098
>>> +#define BCM2711_MAILBOX_07_WRITE_SET_BASE 0x4C00009C
>>> +#define BCM2711_MAILBOX_08_WRITE_SET_BASE 0x4C0000A0
>>> +#define BCM2711_MAILBOX_09_WRITE_SET_BASE 0x4C0000A4
>>> +#define BCM2711_MAILBOX_10_WRITE_SET_BASE 0x4C0000A8
>>> +#define BCM2711_MAILBOX_11_WRITE_SET_BASE 0x4C0000AC
>>> +#define BCM2711_MAILBOX_12_WRITE_SET_BASE 0x4C0000B0
>>> +#define BCM2711_MAILBOX_13_WRITE_SET_BASE 0x4C0000B4
>>> +#define BCM2711_MAILBOX_14_WRITE_SET_BASE 0x4C0000B8
>>> +#define BCM2711_MAILBOX_15_WRITE_SET_BASE 0x4C0000BC
>>> +#define BCM2711_MAILBOX_00_READ_CLEAR_BASE 0x4C0000C0
>>> +#define BCM2711_MAILBOX_01_READ_CLEAR_BASE 0x4C0000C4
>>> +#define BCM2711_MAILBOX_02_READ_CLEAR_BASE 0x4C0000C8
>>> +#define BCM2711_MAILBOX_03_READ_CLEAR_BASE 0x4C0000CC
>>> +#define BCM2711_MAILBOX_04_READ_CLEAR_BASE 0x4C0000D0
>>> +#define BCM2711_MAILBOX_05_READ_CLEAR_BASE 0x4C0000D4
>>> +#define BCM2711_MAILBOX_06_READ_CLEAR_BASE 0x4C0000D8
>>> +#define BCM2711_MAILBOX_07_READ_CLEAR_BASE 0x4C0000DC
>>> +#define BCM2711_MAILBOX_08_READ_CLEAR_BASE 0x4C0000E0
>>> +#define BCM2711_MAILBOX_09_READ_CLEAR_BASE 0x4C0000E4
>>> +#define BCM2711_MAILBOX_10_READ_CLEAR_BASE 0x4C0000E8
>>> +#define BCM2711_MAILBOX_11_READ_CLEAR_BASE 0x4C0000EC
>>> +#define BCM2711_MAILBOX_12_READ_CLEAR_BASE 0x4C0000F0
>>> +#define BCM2711_MAILBOX_13_READ_CLEAR_BASE 0x4C0000F4
>>> +#define BCM2711_MAILBOX_14_READ_CLEAR_BASE 0x4C0000F8
>>> +#define BCM2711_MAILBOX_15_READ_CLEAR_BASE 0x4C0000FC
>>> + * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>> +#define BCM2711_ARMC_REGS_BASE (RPI_PERIPHERAL_BASE +
>>> 0xB200)
>>> +#define BCM2711_ARMC_REGS_SIZE 0x200
>>> +#define BCM2711_ARMC_IRQ0_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x00)
>>> +#define BCM2711_ARMC_IRQ0_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x04)
>>> +#define BCM2711_ARMC_IRQ0_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x08)
>>> +#define BCM2711_ARMC_IRQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x10)
>>> +#define BCM2711_ARMC_IRQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x14)
>>> +#define BCM2711_ARMC_IRQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x18)
>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x20)
>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x24)
>>> +#define BCM2711_ARMC_IRQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x28)
>>> +#define BCM2711_ARMC_IRQ_STATUS0 (BCM2711_ARMC_REGS_BASE
>>> + 0x30)
>>> +#define BCM2711_ARMC_IRQ_STATUS1 (BCM2711_ARMC_REGS_BASE
>>> + 0x34)
>>> +#define BCM2711_ARMC_IRQ_STATUS2 (BCM2711_ARMC_REGS_BASE
>>> + 0x38)
>>> +#define BCM2711_ARMC_IRQ1_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x40)
>>> +#define BCM2711_ARMC_IRQ1_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x44)
>>> +#define BCM2711_ARMC_IRQ1_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x48)
>>> +#define BCM2711_ARMC_IRQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x50)
>>> +#define BCM2711_ARMC_IRQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x54)
>>> +#define BCM2711_ARMC_IRQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x58)
>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x60)
>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x64)
>>> +#define BCM2711_ARMC_IRQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x68)
>>> +#define BCM2711_ARMC_IRQ2_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x80)
>>> +#define BCM2711_ARMC_IRQ2_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x84)
>>> +#define BCM2711_ARMC_IRQ2_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x88)
>>> +#define BCM2711_ARMC_IRQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x90)
>>> +#define BCM2711_ARMC_IRQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x94)
>>> +#define BCM2711_ARMC_IRQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x98)
>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0xA0)
>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0xA4)
>>> +#define BCM2711_ARMC_IRQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0xA8)
>>> +#define BCM2711_ARMC_IRQ3_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0xC0)
>>> +#define BCM2711_ARMC_IRQ3_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0xC4)
>>> +#define BCM2711_ARMC_IRQ3_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0xC8)
>>> +#define BCM2711_ARMC_IRQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0xD0)
>>> +#define BCM2711_ARMC_IRQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0xD4)
>>> +#define BCM2711_ARMC_IRQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0xD8)
>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0xE0)
>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0xE4)
>>> +#define BCM2711_ARMC_IRQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0xE8)
>>> +#define BCM2711_ARMC_FIQ0_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x100)
>>> +#define BCM2711_ARMC_FIQ0_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x104)
>>> +#define BCM2711_ARMC_FIQ0_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x108)
>>> +#define BCM2711_ARMC_FIQ0_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x110)
>>> +#define BCM2711_ARMC_FIQ0_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x114)
>>> +#define BCM2711_ARMC_FIQ0_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x118)
>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x120)
>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x124)
>>> +#define BCM2711_ARMC_FIQ0_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x128)
>>> +#define BCM2711_ARMC_FIQ1_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x140)
>>> +#define BCM2711_ARMC_FIQ1_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x144)
>>> +#define BCM2711_ARMC_FIQ1_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x148)
>>> +#define BCM2711_ARMC_FIQ1_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x150)
>>> +#define BCM2711_ARMC_FIQ1_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x154)
>>> +#define BCM2711_ARMC_FIQ1_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x158)
>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x160)
>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x164)
>>> +#define BCM2711_ARMC_FIQ1_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x168)
>>> +#define BCM2711_ARMC_FIQ2_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x180)
>>> +#define BCM2711_ARMC_FIQ2_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x184)
>>> +#define BCM2711_ARMC_FIQ2_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x188)
>>> +#define BCM2711_ARMC_FIQ2_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x190)
>>> +#define BCM2711_ARMC_FIQ2_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x194)
>>> +#define BCM2711_ARMC_FIQ2_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x198)
>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x1A0)
>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x1A4)
>>> +#define BCM2711_ARMC_FIQ2_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x1A8)
>>> +#define BCM2711_ARMC_FIQ3_PENDING0 (BCM2711_ARMC_REGS_BASE
>>> + 0x1C0)
>>> +#define BCM2711_ARMC_FIQ3_PENDING1 (BCM2711_ARMC_REGS_BASE
>>> + 0x1C4)
>>> +#define BCM2711_ARMC_FIQ3_PENDING2 (BCM2711_ARMC_REGS_BASE
>>> + 0x1C8)
>>> +#define BCM2711_ARMC_FIQ3_SET_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x1D0)
>>> +#define BCM2711_ARMC_FIQ3_SET_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x1D4)
>>> +#define BCM2711_ARMC_FIQ3_SET_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x1D8)
>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_0 (BCM2711_ARMC_REGS_BASE
>>> + 0x1E0)
>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_1 (BCM2711_ARMC_REGS_BASE
>>> + 0x1E4)
>>> +#define BCM2711_ARMC_FIQ3_CLR_EN_2 (BCM2711_ARMC_REGS_BASE
>>> + 0x1E8)
>>> +#define BCM2711_ARMC_SWIRQ_SET (BCM2711_ARMC_REGS_BASE
>>> + 0x1F0)
>>> +#define BCM2711_ARMC_SWIRQ_CLEAR (BCM2711_ARMC_REGS_BASE
>>> + 0x1F4)
>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>> diff --git a/bsps/aarch64/raspberrypi/include/tm27.h
>>> b/bsps/aarch64/raspberrypi/include/tm27.h
>>> index 0000000000..653f88ed01
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/tm27.h
>>> @@ -0,0 +1,46 @@
>>> + * @file
>>> + * @brief BSP tm27 header
>>> + * are met:
>>> the
>>> distribution.
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +#ifndef _RTEMS_TMTEST27
>>> +#error "This is an RTEMS internal file you must not include directly."
>>> +#endif
>>> +#ifndef __tm27_h
>>> +#define __tm27_h
>>> +#include <dev/irq/arm-gic-tm27.h>
>>> +#endif /* __tm27_h */
>>> \ No newline at end of file
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c
>>> b/bsps/aarch64/raspberrypi/start/bspstart.c
>>> index 0000000000..56f52a2231
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstart.c
>>> @@ -0,0 +1,49 @@
>>> + * @file
>>> + * @brief BSP Startup
>>> + * are met:
>>> the
>>> distribution.
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +#include <bsp.h>
>>> +#include <bsp/bootcard.h>
>>> +#include <bsp/irq-generic.h>
>>> +#include <bsp/linker-symbols.h>
>>> +void bsp_start( void )
>>> + bsp_interrupt_initialize();
>>> + rtems_cache_coherent_add_area(
>>> + bsp_section_nocacheheap_begin,
>>> + (uintptr_t) bsp_section_nocacheheap_size
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> index 0000000000..fe0fe77c09
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> @@ -0,0 +1,53 @@
>>> + * @file
>>> + * @brief BSP Startup Hooks
>>> + * are met:
>>> the
>>> distribution.
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +#include <bsp.h>
>>> +#include <rtems/score/cpu.h>
>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>> + /* Do nothing */
>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>> + AArch64_start_set_vector_base();
>>> + bsp_start_copy_sections();
>>> + raspberrypi_4_setup_mmu_and_cache();
>>> + bsp_start_clear_bss();
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> index 0000000000..ab12020a2a
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> @@ -0,0 +1,84 @@
>>> + * @file
>>> + * @brief This source file contains the default MMU tables and setup.
>>> + * are met:
>>> the
>>> distribution.
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> IN
>>> OTHERWISE)
>>> OF THE
>>> +#include <bsp.h>
>>> +#include <bsp/aarch64-mmu.h>
>>> +#include <bsp/raspberrypi.h>
>>> +#include <libcpu/mmu-vmsav8-64.h>
>>> +BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>>> +raspberrypi_4_mmu_config_table[] = {
>>> + AARCH64_MMU_DEFAULT_SECTIONS,
>>> + { /* RPI peripheral address */
>>> + .begin = (unsigned)RPI_PERIPHERAL_BASE,
>>> + .end = (unsigned)RPI_PERIPHERAL_BASE +
>>> (unsigned)RPI_PERIPHERAL_SIZE,
>>> + .flags = AARCH64_MMU_DEVICE
>>> + { /* RPI ARM local registers */
>>> + .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
>>> + .end = (unsigned)BCM2711_LOCAL_REGS_BASE +
>>> (unsigned)BCM2711_LOCAL_REGS_SIZE,
>>> + { /* RPI GIC Interface address */
>>> + .begin = 0xFF800000U,
>>> + .end = 0xFFA00000U,
>>> + * Make weak and let the user override.
>>> +raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
>>> + aarch64_mmu_setup();
>>> + aarch64_mmu_setup_translation_table(
>>> + &raspberrypi_4_mmu_config_table[ 0 ],
>>> + RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
>>> + aarch64_mmu_enable();
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> index 0000000000..5e3e0a4975
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> @@ -0,0 +1,21 @@
>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> +actions:
>>> +- get-string: null
>>> +- split: null
>>> +- env-append: null
>>> +build-type: option
>>> +copyrights:
>>> +- Copyright (C) 2022 Mohd Noor Aman
>>> +default:
>>> +- -mcpu=cortex-a72
>>> +- -march=armv8-a
>>> +default-by-variant: []
>>> +includes: []
>>> +description: |
>>> + ABI flags
>>> +links: []
>>> +enabled-by: true
>>> +name: ABI_FLAGS
>>> +type: build
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> index 0000000000..d2ff76d351
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> @@ -0,0 +1,81 @@
>>> +arch: aarch64
>>> +bsp: raspberrypi4b
>>> +build-type: bsp
>>> +cflags: []
>>> +copyrights:
>>> +cppflags: []
>>> +enabled-by: true
>>> +family: raspberrypi
>>> +includes: []
>>> +install:
>>> +- destination: ${BSP_INCLUDEDIR}
>>> + source:
>>> + - bsps/aarch64/raspberrypi/include/bsp.h
>>> + - bsps/aarch64/raspberrypi/include/tm27.h
>>> +- destination: ${BSP_INCLUDEDIR}/bsp
>>> + source:
>>> + - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> + - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> +source:
>>> +- bsps/aarch64/raspberrypi/console/console.c
>>> +- bsps/aarch64/raspberrypi/start/bspstart.c
>>> +- bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> +- bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> +- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>> +- bsps/aarch64/shared/cache/cache.c
>>> +- bsps/aarch64/shared/mmu/vmsav8-64.c
>>> +- bsps/shared/dev/clock/arm-generic-timer.c
>>> +- bsps/shared/dev/irq/arm-gicv2.c
>>> +- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>> +- bsps/shared/dev/serial/console-termios-init.c
>>> +- bsps/shared/dev/serial/console-termios.c
>>> +- bsps/shared/dev/serial/arm-pl011.c
>>> +- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>> +- bsps/shared/dev/btimer/btimer-cpucounter.c
>>> +- bsps/shared/irq/irq-default-handler.c
>>> +- bsps/shared/irq/irq-handler-install.c
>>> +- bsps/shared/irq/irq-generic.c
>>> +- bsps/shared/irq/irq-lock.c
>>> +- bsps/shared/start/bspfatal-default.c
>>> +- bsps/shared/start/bspreset-arm-psci.c
>>> +- bsps/shared/start/gettargethash-default.c
>>> +- bsps/shared/start/sbrk.c
>>> +- bsps/shared/start/wkspaceinitone.c
>>> +- bsps/shared/start/mallocinitmulti.c
>>> +- bsps/shared/start/bspgetworkarea-default.c
>>> +links:
>>> +- role: build-dependency
>>> + uid: ../grp
>>> + uid: ../start
>>> + uid: ../optmmupages
>>> + uid: ../optgtusevirt
>>> + uid: ../optgtuseps
>>> + uid: abi
>>> + uid: ../../optcachedata
>>> + uid: ../../optcacheinst
>>> + uid: ../../opto2
>>> + uid: ../../bspopts
>>> + uid: linkercmds
>>> + uid: ../../obj
>>> + uid: ../../objirq
>>> +type: build
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> index 0000000000..8598b89cba
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> @@ -0,0 +1,76 @@
>>> +build-type: config-file
>>> +content: |
>>> + /* SPDX-License-Identifier: BSD-2-Clause */
>>> + * are met:
>>> copyright
>>> the
>>> distribution.
>>> CONTRIBUTORS "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> OF
>>> BUSINESS
>>> WHETHER IN
>>> OTHERWISE)
>>> ADVISED OF THE
>>> + MEMORY {
>>> + RAM_MMU : ORIGIN = 0x0, LENGTH = (0x1000 *
>>> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>>> + RAM : ORIGIN = 0x80000, LENGTH = 1024M
>>> + REGION_ALIAS ("REGION_START", RAM);
>>> + REGION_ALIAS ("REGION_VECTOR", RAM);
>>> + REGION_ALIAS ("REGION_TEXT", RAM);
>>> + REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>>> + REGION_ALIAS ("REGION_RODATA", RAM);
>>> + REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>>> + REGION_ALIAS ("REGION_DATA", RAM);
>>> + REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>>> + REGION_ALIAS ("REGION_FAST_TEXT", RAM);
>>> + REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>>> + REGION_ALIAS ("REGION_FAST_DATA", RAM);
>>> + REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>> + REGION_ALIAS ("REGION_BSS", RAM);
>>> + REGION_ALIAS ("REGION_WORK", RAM);
>>> + REGION_ALIAS ("REGION_STACK", RAM);
>>> + REGION_ALIAS ("REGION_NOCACHE", RAM);
>>> + REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
>>> + bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>> bsp_stack_abt_size : 1024;
>>> + bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
>>> bsp_section_rwbarrier_align : 1M;
>>> + bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>> bsp_stack_exception_size : 1024;
>>> + bsp_vector_table_in_start_section = 1;
>>> + bsp_translation_table_base = ORIGIN (RAM_MMU);
>>> + bsp_translation_table_end = ORIGIN (RAM_MMU) + LENGTH (RAM_MMU);
>>> + OUTPUT_FORMAT ("elf64-littleaarch64")
>>> + OUTPUT_ARCH (aarch64)
>>> + INCLUDE linkcmds.base
>>> +copyrights:
>>> +enabled-by: true
>>> +install-path: ${BSP_LIBDIR}
>>> +links: []
>>> +target: linkcmds
>>> +type: build
>>> 2.37.3
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221004/b2280a3d/attachment-0001.htm>
