[PATCH v2 05/13] config: Changeable size for IDLE stack allocator
Sebastian Huber
Thu Oct 6 08:23:24 UTC 2022
Allow the IDLE stack allocator to change the stack size. This can be
used by applications with a very dynamic thread-local storage size to
adjust the thread storage area of the IDLE tasks dynamically.
Update #4524.
cpukit/doxygen/appl-config.h | 2 +-
cpukit/include/rtems/score/stack.h | 17 ++++++++++++-----
cpukit/score/src/stackallocatorforidle.c | 19 +++++++++----------
cpukit/score/src/threadcreateidle.c | 4 ++--
testsuites/sptests/spstkalloc03/init.c | 4 ++--
testsuites/sptests/spstkalloc04/init.c | 4 ++--
testsuites/validation/ts-config.h | 2 +-
testsuites/validation/ts-default.h | 4 ++--
8 files changed, 31 insertions(+), 25 deletions(-)
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
index 1df7f335e6..d53947c71a 100644
--- a/cpukit/doxygen/appl-config.h
+++ b/cpukit/doxygen/appl-config.h
@@ -4836,7 +4836,7 @@
* @par Value Constraints
* The value of this configuration option shall be defined to a valid function
- * pointer of the type ``void *( *allocate )( uint32_t, size_t )``.
+ * pointer of the type ``void *( *allocate )( uint32_t, size_t * )``.
* @par Notes
* This configuration option is independent of the other thread stack allocator
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index 360e4d61f6..7577ca0474 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -105,15 +105,22 @@ typedef void ( *Stack_Allocator_free )( void *addr );
* The allocate for idle handler is optional even when the user thread stack
* allocator and deallocator are configured.
- * @param cpu Index of the CPU for the IDLE thread using this stack
- * @param stack_size The size of the stack area to allocate in bytes.
+ * @param cpu is the index of the CPU for the IDLE thread using this stack.
- * @retval NULL Not enough memory.
- * @retval other Pointer to begin of stack area.
+ * @param stack_size[in, out] is pointer to a size_t object. On function
+ * entry, the object contains the proposed size of the stack area to allocate
+ * in bytes. The proposed size does not take the actual thread-local storage
+ * size of the application into account. The stack allocator can modify the
+ * size to ensure that there is enough space available in the stack area for
+ * the thread-local storage.
+ * @retval NULL There was not enough memory available to allocate a stack area.
+ * @return Returns the pointer to begin of the allocated stack area.
typedef void *( *Stack_Allocator_allocate_for_idle )(
uint32_t cpu,
- size_t stack_size
+ size_t *stack_size
diff --git a/cpukit/score/src/stackallocatorforidle.c b/cpukit/score/src/stackallocatorforidle.c
index 76b6ace1f4..c97dde030f 100644
--- a/cpukit/score/src/stackallocatorforidle.c
+++ b/cpukit/score/src/stackallocatorforidle.c
@@ -34,27 +34,26 @@
- * @brief Default stack allocator allocate for idle handler.
- * The allocate for idle handler is optional even when the user thread stack
- * allocator and deallocator are configured.
+ * @brief Default stack allocator allocate for IDLE threads.
* The default allocator for IDLE thread stacks gets the memory from a
* statically allocated area provided via confdefs.h.
- * @param cpu_index Index of the CPU for the IDLE thread using this stack
+ * @param stack_size[in] is pointer to a size_t object. On function
+ * entry, the object contains the size of the stack area to allocate in
+ * bytes.
- * @retval NULL Not enough memory (never returned).
static void *_Stack_Allocator_allocate_for_idle_default(
uint32_t cpu_index,
- size_t stack_size
#if defined(RTEMS_SMP)
- return &_Thread_Idle_stacks[ cpu_index * stack_size ];
+ return &_Thread_Idle_stacks[ cpu_index * ( *stack_size ) ];
#else
_Assert( cpu_index == 0 );
return &_Thread_Idle_stacks[ 0 ];
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index b5e0cfdc9b..3e3c7cfc83 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -73,9 +73,9 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
* The IDLE thread stacks may be statically allocated or there may be a
* custom allocator provided just as with user threads.
- config.stack_area = (*_Stack_Allocator_allocate_for_idle)(
+ config.stack_area = ( *_Stack_Allocator_allocate_for_idle )(
_Per_CPU_Get_index( cpu ),
- config.stack_size
+ &config.stack_size
diff --git a/testsuites/sptests/spstkalloc03/init.c b/testsuites/sptests/spstkalloc03/init.c
index 6d6817bccb..5ee7de26ec 100644
--- a/testsuites/sptests/spstkalloc03/init.c
+++ b/testsuites/sptests/spstkalloc03/init.c
@@ -87,12 +87,12 @@ static void thread_stacks_free(void *addr)
static void *thread_stacks_allocate_for_idle(
uint32_t cpu,
- size_t stack_size
rtems_test_assert(thread_stacks_count == 0);
thread_stacks_count++;
- return allocate_helper(stack_size);
+ return allocate_helper(*stack_size);
diff --git a/testsuites/sptests/spstkalloc04/init.c b/testsuites/sptests/spstkalloc04/init.c
index c5d2614f64..9678f6e00c 100644
--- a/testsuites/sptests/spstkalloc04/init.c
+++ b/testsuites/sptests/spstkalloc04/init.c
@@ -69,12 +69,12 @@ static void *allocate_helper(size_t size)
uint32_t cpu,
- size_t stack_size
diff --git a/testsuites/validation/ts-config.h b/testsuites/validation/ts-config.h
index 7685fee278..fbd62ac6b5 100644
--- a/testsuites/validation/ts-config.h
+++ b/testsuites/validation/ts-config.h
@@ -109,7 +109,7 @@ void *test_task_stack_allocate( size_t size );
void test_task_stack_deallocate( void *stack );
-void *test_idle_task_stack_allocate( uint32_t cpu_index, size_t size );
+void *test_idle_task_stack_allocate( uint32_t cpu_index, size_t *size );
extern rtems_task_argument test_runner_argument;
diff --git a/testsuites/validation/ts-default.h b/testsuites/validation/ts-default.h
index 435fccdc51..6e77496b90 100644
--- a/testsuites/validation/ts-default.h
+++ b/testsuites/validation/ts-default.h
@@ -322,9 +322,9 @@ static char test_idle_stacks[ CONFIGURE_MAXIMUM_PROCESSORS ][
RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
RTEMS_SECTION( ".rtemsstack.idle" );
- if ( size > sizeof( test_idle_stacks[ 0 ] ) ) {
+ if ( *size > sizeof( test_idle_stacks[ 0 ] ) ) {
rtems_fatal( RTEMS_FATAL_SOURCE_APPLICATION, 0xABAD1DEA );
2.35.3
